[geos-commits] [SCM] GEOS branch master updated. e45655ae1cbad6fedb5e8cdd9a00ec9bef399427
git at osgeo.org
git at osgeo.org
Fri Jun 14 03:20:06 PDT 2019
the project "GEOS".
via e45655ae1cbad6fedb5e8cdd9a00ec9bef399427 (commit)
from d1556af8cddca70ef7872c9b157907cdf07a1f8a (commit)
revisions in full, below.
commit e45655ae1cbad6fedb5e8cdd9a00ec9bef399427
Author: nila <n_larsson at yahoo.com>
Date: Mon Jun 3 18:07:30 2019 +0200
[doxygen] fix errors and links
diff --git a/include/geos/algorithm/BoundaryNodeRule.h b/include/geos/algorithm/BoundaryNodeRule.h
index 3a7b294..85e4827 100644
--- a/include/geos/algorithm/BoundaryNodeRule.h
+++ b/include/geos/algorithm/BoundaryNodeRule.h
@@ -28,15 +28,16 @@ namespace geos {
namespace algorithm { // geos::algorithm
- * An interface for rules which determine whether node points
- * which are in boundaries of {@link Lineal} geometry components
+/** \brief
+ * An interface for rules which determine whether node points which are
+ * in boundaries of [Lineal](@ref geom::Lineal) geometry components
* are in the boundary of the parent geometry collection.
* The SFS specifies a single kind of boundary node rule,
- * the {@link Mod2BoundaryNodeRule} rule.
+ * the `Mod2BoundaryNodeRule` rule.
* However, other kinds of Boundary Node Rules are appropriate
* in specific situations (for instance, linear network topology
- * usually follows the {@link EndPointBoundaryNodeRule}.)
+ * usually follows the `EndPointBoundaryNodeRule`.)
* Some JTS operations allow the BoundaryNodeRule to be specified,
* and respect this rule when computing the results of the operation.
@@ -55,15 +56,15 @@ public:
virtual
~BoundaryNodeRule() {}
- * Tests whether a point that lies in <tt>boundaryCount</tt>
+ /** \brief
+ * Tests whether a point that lies in `boundaryCount`
* geometry component boundaries is considered to form part of
* the boundary of the parent geometry.
* @param boundaryCount the number of component boundaries that
* this point occurs in
- * @return true if points in this number of boundaries lie in
- * the parent boundary
+ * @return `true` if points in this number of boundaries lie in
+ * the parent boundary
virtual bool isInBoundary(int boundaryCount) const = 0;
@@ -71,7 +72,13 @@ public:
* The Mod-2 Boundary Node Rule (which is the rule specified
* in the OGC SFS).
- * @see Mod2BoundaryNodeRule
+ * A BoundaryNodeRule specifies that points are in the boundary of
+ * a lineal geometry iff the point lies on the boundary of an odd number
+ * of components. Under this rule LinearRings and closed LineStrings have
+ * an empty boundary.
+ * This is the rule specified by the OGC SFS, and is the default
+ * rule used in JTS.
//static const BoundaryNodeRule& MOD2_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryRuleMod2();
@@ -79,7 +86,20 @@ public:
/** \brief
* The Endpoint Boundary Node Rule.
- * @see EndPointBoundaryNodeRule
+ * A BoundaryNodeRule which specifies that any points which are endpoints
+ * of lineal components are in the boundary of the parent geometry. This
+ * corresponds to the "intuitive" topological definition of boundary. Under
+ * this rule LinearRings have a non-empty boundary (the common endpoint
+ * of the underlying LineString).
+ * This rule is useful when dealing with linear networks. For example,
+ * it can be used to check whether linear networks are correctly noded.
+ * The usual network topology constraint is that linear segments may
+ * touch only at endpoints. In the case of a segment touching a closed
+ * segment (ring) at one point, the Mod2 rule cannot distinguish between
+ * the permitted case of touching at the node point and the invalid case
+ * of touching at some other interior (non-node) point. The EndPoint rule
+ * does distinguish between these cases, so is more appropriate for use.
//static const BoundaryNodeRule& ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryEndPoint();
@@ -87,7 +107,10 @@ public:
/** \brief
* The MultiValent Endpoint Boundary Node Rule.
- * @see MultiValentEndPointBoundaryNodeRule
+ * A BoundaryNodeRule which determines that only endpoints with valency
+ * greater than 1 are on the boundary. This corresponds to the boundary
+ * of a MultiLineString being all the "attached" endpoints, but not
+ * the "unattached" ones.
//static const BoundaryNodeRule& MULTIVALENT_ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryMultivalentEndPoint();
@@ -95,7 +118,9 @@ public:
/** \brief
* The Monovalent Endpoint Boundary Node Rule.
- * @see MonoValentEndPointBoundaryNodeRule
+ * A BoundaryNodeRule which determines that only endpoints with valency of
+ * exactly 1 are on the boundary. This corresponds to the boundary of
+ * a MultiLineString being all the "unattached" endpoints.
//static const BoundaryNodeRule& MONOVALENT_ENDPOINT_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryMonovalentEndPoint();
@@ -104,7 +129,10 @@ public:
* The Boundary Node Rule specified by the OGC Simple Features
* Specification, which is the same as the Mod-2 rule.
+ * of a MultiLineString being all the "attached" endpoints, but not the
+ * "unattached" ones.
//static const BoundaryNodeRule& OGC_SFS_BOUNDARY_RULE;
static const BoundaryNodeRule& getBoundaryOGCSFS();
diff --git a/include/geos/algorithm/Centroid.h b/include/geos/algorithm/Centroid.h
index e2eae3d..e6d49fc 100644
--- a/include/geos/algorithm/Centroid.h
+++ b/include/geos/algorithm/Centroid.h
@@ -36,44 +36,44 @@ class CoordinateSequence;
namespace geos {
- * Computes the centroid of a {@link Geometry} of any dimension.
- * If the geometry is nomimally of higher dimension, but contains only components
- * having a lower effective dimension (i.e. zero length or area),
+/**\brief
+ * Computes the centroid of a [Geometry](@ref geom::Geometry) of any dimension.
+ * If the geometry is nomimally of higher dimension, but contains only
+ * components having a lower effective dimension (i.e. zero length or area),
* the centroid will be computed appropriately.
- * <h2>Algorithm</h2>
- * <ul>
- * <li><b>Dimension = 2</b> - Based on the usual algorithm for calculating
- * the centroid as a weighted sum of the centroids
- * of a decomposition of the area into (possibly overlapping) triangles.
- * The algorithm has been extended to handle holes and multi-polygons.
- * See <code>http://www.faqs.org/faqs/graphics/algorithms-faq/</code>
- * for further details of the basic approach.
- * <li><b>Dimension = 1</b> - Computes the average of the midpoints
- * of all line segments weighted by the segment length.
- * <li><b>Dimension = 0</b> - Compute the average coordinate over all points.
- * </ul>
- * If the input geometries are empty, a
- * <code>null</code> Coordinate is returned.
+ * ### Algorithm #
+ * - **Dimension = 2** - Based on the usual algorithm for calculating
+ * the centroid as a weighted sum of the centroids
+ * of a decomposition of the area into (possibly overlapping) triangles.
+ * The algorithm has been extended to handle holes and multi-polygons.
+ * See http://www.faqs.org/faqs/graphics/algorithms-faq/
+ * for further details of the basic approach.
+ * - **Dimension = 1** - Computes the average of the midpoints
+ * of all line segments weighted by the segment length.
+ * - **Dimension = 0** - Compute the average coordinate over all points.
+ * If the input geometries are empty, a `null` Coordinate is returned.
class GEOS_DLL Centroid {
public:
+ /** \brief
* Computes the centroid point of a geometry.
* @param geom the geometry to use
* @param cent will be set to the centroid point, if any
- * @return true if a centroid could be computed,
- * false otherwise (empty geom)
+ * @return `true` if a centroid could be computed,
+ * `false` otherwise (empty geom)
static bool getCentroid(const geom::Geometry& geom, geom::Coordinate& cent);
+ /** \brief
* Creates a new instance for computing the centroid of a geometry
Centroid(const geom::Geometry& geom)
@@ -85,13 +85,13 @@ public:
add(geom);
+ /** \brief
* Gets the computed centroid.
bool getCentroid(geom::Coordinate& cent) const;
diff --git a/include/geos/algorithm/HCoordinate.h b/include/geos/algorithm/HCoordinate.h
index f2a0fc3..4a90a73 100644
--- a/include/geos/algorithm/HCoordinate.h
+++ b/include/geos/algorithm/HCoordinate.h
@@ -51,11 +51,11 @@ public:
* Computes the (approximate) intersection point between two line
* segments using homogeneous coordinates.
- * Note that this algorithm is
- * not numerically stable; i.e. it can produce intersection points which
- * lie outside the envelope of the line segments themselves. In order
- * to increase the precision of the calculation input points should be
- * normalized before passing them to this routine.
+ * @note this algorithm is not numerically stable; i.e. it can
+ * produce intersection points which lie outside the envelope of the
+ * line segments themselves. In order to increase the precision of
+ * the calculation input points should be normalized before
+ * passing them to this routine.
static void intersection(const geom::Coordinate& p1,
const geom::Coordinate& p2,
@@ -74,7 +74,7 @@ public:
/** \brief
* Constructs a homogeneous coordinate which is the intersection
* of the lines define by the homogenous coordinates represented
- * by two {@link Coordinate}s.
+ * by two [Coordinates](@ref geom::Coordinate).
* @param p1
* @param p2
diff --git a/include/geos/algorithm/MinimumDiameter.h b/include/geos/algorithm/MinimumDiameter.h
index 7f6bb14..4917f30 100644
--- a/include/geos/algorithm/MinimumDiameter.h
+++ b/include/geos/algorithm/MinimumDiameter.h
@@ -41,24 +41,20 @@ namespace algorithm { // geos::algorithm
/** \brief
* Computes the minimum diameter of a geom::Geometry
- * The minimum diameter is defined to be the
- * width of the smallest band that
- * contains the geometry,
- * where a band is a strip of the plane defined
- * by two parallel lines.
- * This can be thought of as the smallest hole that the geometry can be
- * moved through, with a single rotation.
- * <p>
+ * The minimum diameter is defined to be the width of the smallest band that
+ * contains the geometry, where a band is a strip of the plane defined
+ * by two parallel lines. This can be thought of as the smallest hole
+ * that the geometry can be moved through, with a single rotation.
* The first step in the algorithm is computing the convex hull of the Geometry.
* If the input Geometry is known to be convex, a hint can be supplied to
* avoid this computation.
- * <p>
* This class can also be used to compute a line segment representing
* the minimum diameter, the supporting line segment of the minimum diameter,
* and a minimum rectangle enclosing the input geometry.
- * This rectangle will
- * have width equal to the minimum diameter, and have one side
- * parallel to the supporting segment.
+ * This rectangle will have width equal to the minimum diameter, and have
+ * one side parallel to the supporting segment.
* @see ConvexHull
@@ -100,9 +96,9 @@ public:
~MinimumDiameter();
/** \brief
- * Compute a minimum diameter for a giver {@link Geometry}.
+ * Compute a minimum diameter for a given [Geometry](@ref geom::Geometry).
- * @param geom a Geometry
+ * @param newInputGeom a Geometry
MinimumDiameter(const geom::Geometry* newInputGeom);
@@ -113,51 +109,53 @@ public:
* or a two-point LineString, or a Point).
* @param newInputGeom a Geometry which is convex
- * @param newIsConvex <code>true</code> if the input geometry is convex
+ * @param newIsConvex `true` if the input geometry is convex
MinimumDiameter(const geom::Geometry* newInputGeom,
const bool newIsConvex);
/** \brief
- * Gets the length of the minimum diameter of the input Geometry
+ * Gets the length of the minimum diameter of the input Geometry.
* @return the length of the minimum diameter
double getLength();
/** \brief
- * Gets the {@link geom::Coordinate} forming one end of the minimum diameter
+ * Gets the {@link geom::Coordinate} forming one end of the minimum diameter.
* @return a coordinate forming one end of the minimum diameter
geom::Coordinate* getWidthCoordinate();
/** \brief
- * Gets the segment forming the base of the minimum diameter
+ * Gets the segment forming the base of the minimum diameter.
* @return the segment forming the base of the minimum diameter
geom::LineString* getSupportingSegment();
/** \brief
- * Gets a LineString which is a minimum diameter
+ * Gets a LineString which is a minimum diameter.
* @return a LineString which is a minimum diameter
geom::LineString* getDiameter();
- * Gets the minimum rectangular Polygon which encloses the input geometry. The rectangle has width
- * equal to the minimum diameter, and a longer length. If the convex hill of the input is degenerate
- * (a line or point) a LineString or Point is returned.
- * The minimum rectangle can be used as an extremely generalized representation for the given
- * geometry.
+ /** \brief
+ * Gets the minimum rectangular Polygon which encloses the input geometry.
+ * The rectangle has width equal to the minimum diameter, and a longer
+ * length. If the convex hill of the input is degenerate (a line or point)
+ * a LineString or Point is returned.
+ * The minimum rectangle can be used as an extremely generalized
+ * representation for the given geometry.
* @return the minimum rectangle enclosing the input (or a line or point if degenerate)
geom::Geometry* getMinimumRectangle();
+ /** \brief
* Gets the minimum rectangle enclosing a geometry.
@@ -165,8 +163,8 @@ public:
static geom::Geometry* getMinimumRectangle(geom::Geometry* geom);
- * Gets the length of the minimum diameter enclosing a geometry
+ /** \brief
+ * Gets the length of the minimum diameter enclosing a geometry.
* @return the length of the minimum diameter of the geometry
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index db9d6e7..bad90c7 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -26,20 +26,20 @@
namespace geos {
-* Functions to compute the orientation of basic geometric structures
-* including point triplets (triangles) and rings.
-* Orientation is a fundamental property of planar geometries
-* (and more generally geometry on two-dimensional manifolds).
-* Orientation is notoriously subject to numerical precision errors
-* in the case of collinear or nearly collinear points.
-* JTS uses extended-precision arithmetic to increase
-* the robustness of the computation.
-* @author Martin Davis
+/** \brief
+ * Functions to compute the orientation of basic geometric structures
+ * including point triplets (triangles) and rings.
+ * Orientation is a fundamental property of planar geometries
+ * (and more generally geometry on two-dimensional manifolds).
+ * Orientation is notoriously subject to numerical precision errors
+ * in the case of collinear or nearly collinear points.
+ * JTS uses extended-precision arithmetic to increase
+ * the robustness of the computation.
+ * @author Martin Davis
class GEOS_DLL Orientation {
public:
@@ -53,36 +53,36 @@ public:
STRAIGHT = 0
- * Returns the orientation index of the direction of the point q relative to
- * a directed infinite line specified by p1-p2.
- * The index indicates whether the point lies to the
- * {@link #Orientation::LEFT} or {@link #Orientation::RIGHT}
- * of the line, or lies on it {@link #Orientation::COLLINEAR}.
- * The index also indicates the orientation of the triangle formed
- * by the three points
- * ( {@link #Orientation::COUNTERCLOCKWISE},
- * {@link #Orientation::CLOCKWISE}, or {@link #Orientation::STRAIGHT} )
+ /** \brief
+ * Returns the orientation index of the direction of the point q relative to
+ * a directed infinite line specified by p1-p2.
+ * The index indicates whether the point lies to the
+ * `Orientation::LEFT` or `Orientation::RIGHT`
+ * of the line, or lies on it `Orientation::COLLINEAR`.
+ * The index also indicates the orientation of the triangle formed
+ * by the three points
+ * ( `Orientation::COUNTERCLOCKWISE`,
+ * `Orientation::CLOCKWISE`, or `Orientation::STRAIGHT` )
static int index(const geom::Coordinate& p1, const geom::Coordinate& p2,
const geom::Coordinate& q);
- * Computes whether a ring defined by an array of {@link Coordinate}s is
- * oriented counter-clockwise.
- * - The list of points is assumed to have the first and last points equal.
- * - This will handle coordinate lists which contain repeated points.
- * This algorithm is *only<* guaranteed to work with valid rings. If the
- * ring is invalid (e.g. self-crosses or touches), the computed result may not
- * be correct.
- * @param ring
- * an array of Coordinates forming a ring
- * @return true if the ring is oriented counter-clockwise.
- * @throws IllegalArgumentException
- * if there are too few points to determine orientation (< 4)
+ /** \brief
+ * Computes whether a ring defined by an array of
+ * [Coordinates](@ref geom::Coordinate) is oriented counter-clockwise.
+ * - The list of points is assumed to have the first and last points equal.
+ * - This will handle coordinate lists which contain repeated points.
+ * This algorithm is *only* guaranteed to work with valid rings. If the
+ * ring is invalid (e.g. self-crosses or touches), the computed result may not
+ * be correct.
+ * @param ring an array of Coordinates forming a ring
+ * @return `true` if the ring is oriented counter-clockwise.
+ * @throws IllegalArgumentException
+ * if there are too few points to determine orientation (< 4)
static bool isCCW(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/PointLocation.h b/include/geos/algorithm/PointLocation.h
index 0732d29..fd548da 100644
--- a/include/geos/algorithm/PointLocation.h
+++ b/include/geos/algorithm/PointLocation.h
@@ -26,7 +26,7 @@
namespace geos {
+/** \brief
* Functions for locating points within basic geometric
* structures such as lines and rings.
@@ -36,62 +36,59 @@ namespace algorithm { // geos::algorithm
class GEOS_DLL PointLocation {
public:
- * Tests whether a point lies on the line defined by a list of
- * coordinates.
- * @param p the point to test
- * @param line the line coordinates
- * @return true if the point is a vertex of the line or lies in the interior
- * of a line segment in the line
+ /** \brief
+ * Tests whether a point lies on the line defined by a list of
+ * coordinates.
+ * @param p the point to test
+ * @param line the line coordinates
+ * @return `true` if the point is a vertex of the line or lies in the interior
+ * of a line segment in the line
//static bool isOnLine(const Coordinate &p, const std::vector<Coordinate> &line);
- * {@link CoordinateSequence}.
+ /** \brief
+ * [CoordinateSequence](@ref geom::CoordinateSequence).
+ * @return true if the point is a vertex of the line or lies in the interior
static bool isOnLine(const geom::Coordinate& p, const geom::CoordinateSequence* line);
- * Tests whether a point lies inside or on a ring. The ring may be oriented in
- * either direction. A point lying exactly on the ring boundary is considered
- * to be inside the ring.
- * This method does *not* first check the point against the envelope of
- * the ring.
- * @param p
- * point to check for ring inclusion
- * @param ring
- * an array of coordinates representing the ring (which must have
- * first point identical to last point)
- * @return true if p is inside ring
- * @see locatePointInRing
+ /** \brief
+ * Tests whether a point lies inside or on a ring.
+ * The ring may be oriented in either direction. A point lying exactly
+ * on the ring boundary is considered to be inside the ring.
+ * This method does **not** first check the point against the envelope of
+ * the ring.
+ * @param p point to check for ring inclusion
+ * @param ring an array of coordinates representing the ring (which must have
+ * first point identical to last point)
+ * @return `true` if p is inside ring
+ * @see RayCrossingCounter::locatePointInRing()
static bool isInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
static bool isInRing(const geom::Coordinate& p, const geom::CoordinateSequence* ring);
- * Determines whether a point lies in the interior, on the boundary, or in the
- * exterior of a ring. The ring may be oriented in either direction.
- * the ring.
- * @param p
- * @param ring
- * @return the {@link Location} of p relative to the ring
+ /** \brief
+ * Determines whether a point lies in the interior, on the boundary, or in the
+ * exterior of a ring. The ring may be oriented in either direction.
+ * the ring.
+ * @return the [Location](@ref geom::Location) of p relative to the ring
static int locateInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
static int locateInRing(const geom::Coordinate& p, const geom::CoordinateSequence& ring);
diff --git a/include/geos/algorithm/RayCrossingCounter.h b/include/geos/algorithm/RayCrossingCounter.h
index fbbebcc..d0aef85 100644
--- a/include/geos/algorithm/RayCrossingCounter.h
+++ b/include/geos/algorithm/RayCrossingCounter.h
@@ -37,28 +37,29 @@ namespace geos {
/** \brief
- * Counts the number of segments crossed by a horizontal ray extending to the right
- * from a given point, in an incremental fashion.
+ * Counts the number of segments crossed by a horizontal ray extending to the
+ * right from a given point, in an incremental fashion.
- * This can be used to determine whether a point lies in a {@link Polygonal} geometry.
- * The class determines the situation where the point lies exactly on a segment.
- * When being used for Point-In-Polygon determination, this case allows short-circuiting
+ * This can be used to determine whether a point lies in a
+ * [Polygonal](@ref geom::Polygonal) geometry. The class determines
+ * the situation where the point lies exactly on a segment. When being
+ * used for Point-In-Polygon determination, this case allows short-circuiting
* the evaluation.
* This class handles polygonal geometries with any number of shells and holes.
* The orientation of the shell and hole rings is unimportant.
* In order to compute a correct location for a given polygonal geometry,
- * it is essential that <b>all</b> segments are counted which
- * <ul>
- * <li>touch the ray
- * <li>lie in in any ring which may contain the point
- * </ul>
- * The only exception is when the point-on-segment situation is detected, in which
- * case no further processing is required.
+ * it is essential that **all** segments are counted which
+ * - touch the ray
+ * - lie in in any ring which may contain the point
+ * The only exception is when the point-on-segment situation is detected, in
+ * which case no further processing is required.
* The implication of the above rule is that segments
- * which can be a priori determined to <i>not</i> touch the ray
+ * which can be a priori determined to *not* touch the ray
* (i.e. by a test of their bounding box or Y-extent)
- * do not need to be counted. This allows for optimization by indexing.
+ * do not need to be counted. This allows for optimization by indexing.
@@ -77,8 +78,9 @@ private:
RayCrossingCounter& operator=(const RayCrossingCounter& rhs) = delete;
public:
- * Determines the {@link Location} of a point in a ring.
+ /** \brief
+ * Determines the [Location](@ref geom::Location) of a point in a ring.
* This method is an exemplar of how to use this class.
@@ -98,7 +100,7 @@ public:
isPointOnSegment(false)
+ /** \brief
* Counts a segment
* @param p1 an endpoint of the segment
@@ -107,14 +109,14 @@ public:
void countSegment(const geom::Coordinate& p1,
const geom::Coordinate& p2);
+ /** \brief
* Reports whether the point lies exactly on one of the supplied segments.
* This method may be called at any time as segments are processed.
- * If the result of this method is <tt>true</tt>,
- * no further segments need be supplied, since the result
- * will never change again.
+ * If the result of this method is `true`, no further segments need
+ * be supplied, since the result will never change again.
- * @return true if the point lies exactly on a segment
+ * @return `true` if the point lies exactly on a segment
bool
isOnSegment()
@@ -122,27 +124,26 @@ public:
return isPointOnSegment;
- * Gets the {@link Location} of the point relative to
- * the ring, polygon
- * or multipolygon from which the processed segments were provided.
- * <p>
+ /** \brief
+ * Gets the [Location](@ref geom::Location) of the point relative to
+ * the ring, polygon or multipolygon from which the processed
+ * segments were provided.
* This method only determines the correct location
- * if <b>all</b> relevant segments must have been processed.
+ * if **all** relevant segments must have been processed.
* @return the Location of the point
int getLocation();
- * Tests whether the point lies in or on
- * <p>
- * This method only determines the correct location
+ /** \brief
+ * Tests whether the point lies in or on the ring, polygon or
+ * multipolygon from which the processed segments were provided.
+ * This method only determines the correct location if **all** relevant
+ * segments must have been processed.
- * @return true if the point lies in or on the supplied polygon
+ * @return `true` if the point lies in or on the supplied polygon
bool isPointInPolygon();
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
index bc2ddf0..95d7de5 100644
--- a/include/geos/algorithm/RayCrossingCounterDD.h
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -37,30 +37,31 @@ class CoordinateSequence;
namespace geos {
+/** \brief
+ * the right from a given point, in an incremental fashion.
+ * the situation where the point lies exactly on a segment. When being used
+ * for Point-In-Polygon determination, this case allows short-circuiting
* the evaluation.
- * <p>
- * <ul>
- * </ul>
- * The implication of the above rule is that segments
- * (i.e. by a test of their bounding box or Y-extent)
+ * - touch the ray
+ * in which case no further processing is required.
+ * The implication of the above rule is that segments which can be a
+ * priori determined to *not* touch the ray (i.e. by a test of their
+ * bounding box or Y-extent) do not need to be counted. This allows
+ * for optimization by indexing.
class GEOS_DLL RayCrossingCounterDD {
private:
const geom::Coordinate& point;
@@ -75,8 +76,8 @@ private:
RayCrossingCounterDD& operator=(const RayCrossingCounterDD& rhs) = delete;
public:
+ /** \brief
@@ -91,8 +92,8 @@ public:
/** \brief
- * Returns the index of the direction of the point <code>q</code>
- * relative to a vector specified by <code>p1-p2</code>.
+ * Returns the index of the direction of the point `q`
+ * relative to a vector specified by `p1-p2`.
* @param p1 the origin point of the vector
* @param p2 the final point of the vector
@@ -112,8 +113,8 @@ public:
- * Counts a segment
+ /** \brief
+ * Counts a segment.
* @param p2 another endpoint of the segment
@@ -121,14 +122,14 @@ public:
+ /** \brief
+ * If the result of this method is `true`, no further segments need be
+ * supplied, since the result will never change again.
bool
isOnSegment()
@@ -136,25 +137,23 @@ public:
- * <p>
+ /** \brief
+ * Gets the [Location](@ref geom::Location) of the point relative to the ring,
+ * polygon or multipolygon from which the processed segments were provided.
int getLocation();
- * <p>
+ /** \brief
+ * Tests whether the point lies in or on the ring, polygon or multipolygon
+ * from which the processed segments were provided.
diff --git a/include/geos/algorithm/locate/PointOnGeometryLocator.h b/include/geos/algorithm/locate/PointOnGeometryLocator.h
index c06fd8a..39e0b7f 100644
--- a/include/geos/algorithm/locate/PointOnGeometryLocator.h
+++ b/include/geos/algorithm/locate/PointOnGeometryLocator.h
@@ -27,8 +27,8 @@ namespace algorithm { // geos::algorithm
namespace locate { // geos::algorithm::locate
/** \brief
- * An interface for classes which determine the {@link Location} of
- * points in {@link Polygon} or {@link MultiPolygon} geometries.
+ * An interface for classes which determine the [Location](@ref geom::Location) of
+ * points in [Polygon](@ref geom::Polygon) or [MultiPolygon](@ref geom::MultiPolygon) geometries.
@@ -41,7 +41,7 @@ public:
- * Determines the {@link Location} of a point in an areal {@link Geometry}.
+ * Determines the [Location](@ref geom::Location) of a point in an areal [Geometry](@ref geom::Geometry).
* @return the location of the point in the geometry
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 5a52a06..22d7c8f 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -32,23 +32,17 @@ namespace algorithm { // geos::algorithm
/** \brief
- * Computes the location of points
- * relative to a {@link Polygonal} {@link Geometry},
- * using a simple <tt>O(n)</tt> algorithm.
+ * Computes the location of points relative to a [Polygonal](@ref geom::Polygonal)
+ * [Geometry](@ref geom::Geometry), using a simple `O(n)` algorithm.
- * The algorithm used reports
- * if a point lies in the interior, exterior,
+ * The algorithm used reports if a point lies in the interior, exterior,
* or exactly on the boundary of the Geometry.
- * Instance methods are provided to implement
- * the interface {@link PointInAreaLocator}.
- * However, they provide no performance
- * advantage over the class methods.
+ * Instance methods are provided to implement the interface `PointInAreaLocator`.
+ * However, they provide no performance advantage over the class methods.
- * This algorithm is suitable for use in cases where
- * only a few points will be tested.
- * If many points will be tested,
- * {@link IndexedPointInAreaLocator} may provide better performance.
+ * This algorithm is suitable for use in cases where only a few points will be tested.
+ * If many points will be tested, IndexedPointInAreaLocator may provide better performance.
class SimplePointInAreaLocator : public PointOnGeometryLocator {
@@ -57,39 +51,41 @@ public:
static int locate(const geom::Coordinate& p,
const geom::Geometry* geom);
- * Determines the {@link Location} of a point in a {@link Polygon}.
- * The return value is one of:
- * - {@link Location.INTERIOR} if the point is in the geometry interior
- * - {@link Location.BOUNDARY} if the point lies exactly on the boundary
- * - {@link Location.EXTERIOR} if the point is outside the geometry
- * Computes {@link Location::BOUNDARY} if the point lies exactly
- * on the polygon boundary.
- * @param poly the geometry to test
- * @return the Location of the point in the polygon
+ /** \brief
+ * Determines the Location of a point in a [Polygon](@ref geom::Polygon).
+ * The return value is one of:
+ * - [Location::INTERIOR](@ref geom::Location::INTERIOR) if the point is in the geometry interior
+ * - [Location::BOUNDARY](@ref geom::Location::BOUNDARY) if the point lies exactly on the boundary
+ * - [Location::EXTERIOR](@ref geom::Location::EXTERIOR) if the point is outside the geometry
+ * Computes `Location::BOUNDARY` if the point lies exactly
+ * on the polygon boundary.
+ * @param poly the geometry to test
+ * @return the Location of the point in the polygon
static int locatePointInPolygon(const geom::Coordinate& p,
const geom::Polygon* poly);
- * Determines whether a point is contained in a {@link Geometry},
- * or lies on its boundary.
- * This is a convenience method for
- * Location.EXTERIOR != locate(p, geom)
- * @param geom the geometry to test
- * @return true if the point lies in or on the geometry
+ /** \brief
+ * Determines whether a point is contained in a [Geometry](@ref geom::Geometry),
+ * or lies on its boundary.
+ * This is a convenience method for
+ * Location.EXTERIOR != locate(p, geom)
+ * @param geom the geometry to test
+ * @return true if the point lies in or on the geometry
static bool isContained(const geom::Coordinate& p,
SimplePointInAreaLocator(const geom::Geometry* p_g)
- : g(p_g)
+ : g(p_g)
int
diff --git a/include/geos/algorithm/ttmath/ttmathtypes.h b/include/geos/algorithm/ttmath/ttmathtypes.h
index a6e4903..5c4e0b7 100644
--- a/include/geos/algorithm/ttmath/ttmathtypes.h
+++ b/include/geos/algorithm/ttmath/ttmathtypes.h
@@ -46,7 +46,7 @@
As our library is written in header files (templates) we cannot use
constants like 'const int' etc. because we should have some source files
*.cpp to define this variables. Only what we can have are constants
- defined by #define preprocessor macros.
+ defined by \#define preprocessor macros.
All macros are preceded by TTMATH_ prefix
diff --git a/include/geos/geom.h b/include/geos/geom.h
index 6b96d08..9a555b4 100644
--- a/include/geos/geom.h
+++ b/include/geos/geom.h
@@ -37,7 +37,7 @@
/** \page c_iface C wrapper interface
- * \section Overview
+ * \section overview_c Overview
* This is the preferred access method for GEOS.
@@ -53,7 +53,7 @@
/** \page cpp_iface C++ interface
+ * \section overview_cpp Overview
* Main class is geos::geom::Geometry, from which all geometry types
* derive.
diff --git a/include/geos/geom/CoordinateArraySequence.h b/include/geos/geom/CoordinateArraySequence.h
index fce0bc3..a1cdaf6 100644
--- a/include/geos/geom/CoordinateArraySequence.h
+++ b/include/geos/geom/CoordinateArraySequence.h
@@ -104,7 +104,7 @@ public:
* @param allowRepeated if set to false, repeated coordinates are
* collapsed
- * NOTE: this is a CoordinateList interface in JTS
+ * @note this is a CoordinateList interface in JTS
void add(std::size_t i, const Coordinate& coord, bool allowRepeated);
diff --git a/include/geos/geom/CoordinateFilter.h b/include/geos/geom/CoordinateFilter.h
index 9ea063b..10f5a5d 100644
--- a/include/geos/geom/CoordinateFilter.h
+++ b/include/geos/geom/CoordinateFilter.h
@@ -25,9 +25,9 @@ namespace geom { // geos::geom
class Coordinate;
- * <code>Geometry</code> classes support the concept of applying a
- * coordinate filter to every coordinate in the <code>Geometry</code>.
+/** \brief
+ * Geometry classes support the concept of applying a
+ * coordinate filter to every coordinate in the Geometry.
* A coordinate filter can either record information about each coordinate or
* change the coordinate in some way. Coordinate filters implement the
@@ -45,10 +45,10 @@ public:
virtual
~CoordinateFilter() {}
- * Performs an operation on <code>coord</code>.
+ /** \brief
+ * Performs an operation on `coord`.
- * @param coord a <code>Coordinate</code> to which the filter is applied.
+ * **param** `coord` a Coordinate to which the filter is applied.
virtual void
filter_rw(Coordinate* /*coord*/) const
@@ -56,10 +56,10 @@ public:
assert(0);
- * Performs an operation with <code>coord</code>.
+ /** \brief
+ * Performs an operation with `coord`.
virtual void
filter_ro(const Coordinate* /*coord*/)
diff --git a/include/geos/geom/CoordinateSequenceFilter.h b/include/geos/geom/CoordinateSequenceFilter.h
index 0741328..0574d1e 100644
--- a/include/geos/geom/CoordinateSequenceFilter.h
+++ b/include/geos/geom/CoordinateSequenceFilter.h
@@ -34,24 +34,23 @@ class CoordinateSequence;
namespace geos {
- * Interface for classes which provide operations that
- * can be applied to the coordinates in a {@link CoordinateSequence}.
- * A CoordinateSequence filter can either record information about each
- * coordinate or change the coordinate in some way.
- * CoordinateSequence filters can be
- * used to implement such things as coordinate transformations, centroid and
- * envelope computation, and many other functions.
- * For maximum efficiency, the execution of filters can be short-circuited.
- * {@link Geometry} classes support the concept of applying a
- * <code>CoordinateSequenceFilter</code> to each
- * {@link CoordinateSequence}s they contain.
- * <p>
- * <code>CoordinateSequenceFilter</code> is
- * an example of the Gang-of-Four Visitor pattern.
+/** \brief
+ * Interface for classes which provide operations that can be applied to
+ * the coordinates in a CoordinateSequence.
- * @see Geometry::apply_ro(CoordinateSequenceFilter)
- * @see Geometry::apply_rw(CoordinateSequenceFilter)
+ * A CoordinateSequence filter can either record information about each
+ * coordinate or change the coordinate in some way.
+ * CoordinateSequence filters can be used to implement such things as
+ * coordinate transformations, centroid and envelope computation, and many
+ * other functions.
+ * For maximum efficiency, the execution of filters can be short-circuited.
+ * Geometry classes support the concept of applying a CoordinateSequenceFilter
+ * to each CoordinateSequences they contain.
+ * CoordinateSequenceFilter is an example of the Gang-of-Four Visitor pattern.
+ * @see Geometry::apply_ro(CoordinateSequenceFilter& filter) const
+ * @see Geometry::apply_rw(CoordinateSequenceFilter& filter)
@@ -62,12 +61,11 @@ public:
virtual
~CoordinateSequenceFilter() {}
- * Performs an operation on a coordinate in a {@link CoordinateSequence}.
+ /** \brief
+ * Performs an operation on a coordinate in a CoordinateSequence.
- * @param seq the <code>CoordinateSequence</code> to which the filter
- * is applied
- * @param i the index of the coordinate to apply the filter to
+ * **param** `seq` the CoordinateSequence to which the filter is applied
+ * **param** `i` the index of the coordinate to apply the filter to
virtual void
filter_rw(CoordinateSequence& /*seq*/, std::size_t /*i*/)
@@ -75,12 +73,11 @@ public:
assert(0);
+ /** \brief
- * is applied
virtual void
filter_ro(const CoordinateSequence& /*seq*/, std::size_t /*i*/)
@@ -88,26 +85,28 @@ public:
assert(0);
+ /** \brief
* Reports whether the application of this filter can be terminated.
- * Once this method returns <tt>false</tt>, it should
- * continue to return <tt>false</tt> on every subsequent call.
- * @return true if the application of this filter can be terminated.
+ * Once this method returns `false`, it should continue to return
+ * `false` on every subsequent call.
+ * @return `true` if the application of this filter can be terminated.
virtual bool isDone() const = 0;
- * Reports whether the execution of this filter
- * has modified the coordinates of the geometry.
- * If so, {@link Geometry#geometryChanged} will be executed
- * after this filter has finished being executed.
+ /** \brief
+ * Reports whether the execution of this filter has modified
+ * the coordinates of the geometry.
+ * If so, Geometry::geometryChanged() will be executed after this
+ * filter has finished being executed.
- * Most filters can simply return a constant value reflecting
- * whether they are able to change the coordinates.
+ * Most filters can simply return a constant value reflecting whether
+ * they are able to change the coordinates.
- * @return true if this filter has changed the coordinates of the geometry
+ * @return `true` if this filter has changed the coordinates of the geometry
virtual bool isGeometryChanged() const = 0;
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 27c4d1b..8a09d05 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -49,11 +49,10 @@ class Coordinate;
* e.g. the minimum and maximum x and y values of the Coordinates.
* Note that Envelopes support infinite or half-infinite regions, by using
- * the values of <code>Double_POSITIVE_INFINITY</code> and
- * <code>Double_NEGATIVE_INFINITY</code>.
+ * the values of `Double_POSITIVE_INFINITY` and `Double_NEGATIVE_INFINITY`.
- * When Envelope objects are created or initialized,
- * the supplies extent values are automatically sorted into the correct order.
+ * When Envelope objects are created or initialized, the supplies extent
+ * values are automatically sorted into the correct order.
class GEOS_DLL Envelope {
@@ -65,13 +64,12 @@ public:
typedef std::unique_ptr<Envelope> Ptr;
/** \brief
- * Creates a null <code>Envelope</code>.
+ * Creates a null Envelope.
Envelope(void);
/** \brief
- * Creates an <code>Envelope</code> for a region defined by
- * maximum and minimum values.
+ * Creates an Envelope for a region defined by maximum and minimum values.
* @param x1 the first x-value
* @param x2 the second x-value
@@ -81,8 +79,7 @@ public:
Envelope(double x1, double x2, double y1, double y2);
/** \brief
- * two Coordinates.
+ * Creates an Envelope for a region defined by two Coordinates.
* @param p1 the first Coordinate
* @param p2 the second Coordinate
@@ -103,57 +100,56 @@ public:
Envelope& operator=(const Envelope& e);
/** \brief
- * Create an <code>Envelope</code> from an Envelope
- * string representation produced by Envelope.toString()
+ * Create an Envelope from an Envelope string representation produced
+ * by Envelope::toString()
Envelope(const std::string& str);
~Envelope(void);
/** \brief
- * Test the point q to see whether it intersects the
- * Envelope defined by p1-p2
+ * Test the point `q` to see whether it intersects the Envelope
+ * defined by `p1-p2`.
* @param p1 one extremal point of the envelope
* @param p2 another extremal point of the envelope
* @param q the point to test for intersection
- * @return <code>true</code> if q intersects the envelope p1-p2
+ * @return `true` if q intersects the envelope p1-p2
static bool intersects(const Coordinate& p1, const Coordinate& p2,
const Coordinate& q);
/** \brief
- * Test the envelope defined by p1-p2 for intersection
- * with the envelope defined by q1-q2
+ * Test the envelope defined by `p1-p2` for intersection
+ * with the envelope defined by `q1-q2`.
* @param p1 one extremal point of the envelope P
* @param p2 another extremal point of the envelope P
* @param q1 one extremal point of the envelope Q
* @param q2 another extremal point of the envelope Q
- * @return <code>true</code> if Q intersects P
+ * @return `true` if Q intersects P
const Coordinate& q1, const Coordinate& q2);
- * Check if the extent defined by two extremal points
- * intersects the extent of this <code>Envelope</code>.
- * @param a a point
- * @param b another point
- * @return <code>true</code> if the extents intersect
+ /** \brief
+ * Check if the extent defined by two extremal points intersects
+ * the extent of this Envelope.
+ * @param a a point
+ * @param b another point
+ * @return `true` if the extents intersect
bool intersects(const Coordinate& a, const Coordinate& b) const;
/** \brief
- * Initialize to a null <code>Envelope</code>.
+ * Initialize to a null Envelope.
void init(void);
/** \brief
- * Initialize an <code>Envelope</code> for a region defined by
+ * Initialize an Envelope for a region defined by maximum and minimum values.
@@ -163,8 +159,7 @@ public:
void init(double x1, double x2, double y1, double y2);
/** \brief
- * Initialize an <code>Envelope</code> to a region defined
- * by two Coordinates.
+ * Initialize an Envelope to a region defined by two Coordinates.
@@ -172,8 +167,7 @@ public:
void init(const Coordinate& p1, const Coordinate& p2);
/** \brief
- * by a single Coordinate.
+ * Initialize an Envelope to a region defined by a single Coordinate.
* @param p the Coordinate
@@ -183,36 +177,34 @@ public:
//void init(Envelope env);
/** \brief
- * Makes this <code>Envelope</code> a "null" envelope,
- * that is, the envelope of the empty geometry.
+ * Makes this `Envelope` a "null" envelope, that is, the envelope
+ * of the empty geometry.
void setToNull(void);
/** \brief
- * Returns <code>true</code> if this <code>Envelope</code>
- * is a "null" envelope.
+ * Returns `true` if this Envelope is a "null" envelope.
- * @return <code>true</code> if this <code>Envelope</code>
- * is uninitialized or is the envelope of the
- * empty geometry.
+ * @return `true` if this Envelope is uninitialized or is the
+ * envelope of the empty geometry.
bool isNull(void) const;
/** \brief
* Returns the difference between the maximum and minimum x values.
- * @return max x - min x, or 0 if this is a null Envelope
+ * @return `max x - min x`, or 0 if this is a null Envelope
double getWidth(void) const;
/** \brief
* Returns the difference between the maximum and minimum y values.
- * @return max y - min y, or 0 if this is a null Envelope
+ * @return `max y - min y`, or 0 if this is a null Envelope
double getHeight(void) const;
+ /** \brief
* Gets the area of this envelope.
* @return the area of the envelope
@@ -224,42 +216,41 @@ public:
return getWidth() * getHeight();
- * Returns the Envelope maximum y-value. min y > max y
- * indicates that this is a null Envelope.
+ /** \brief
+ * Returns the Envelope maximum y-value. `min y > max y` indicates
+ * that this is a null Envelope.
double getMaxY() const;
- * Returns the Envelope maximum x-value. min x > max x
+ /** \brief
+ * Returns the Envelope maximum x-value. `min x > max x` indicates
double getMaxX() const;
- * Returns the Envelope minimum y-value. min y > max y
+ /** \brief
+ * Returns the Envelope minimum y-value. `min y > max y` indicates
double getMinY() const;
- * Returns the Envelope minimum x-value. min x > max x
+ /** \brief
+ * Returns the Envelope minimum x-value. `min x > max x` indicates
double getMinX() const;
+ /** \brief
* Computes the coordinate of the centre of this envelope
- * (as long as it is non-null)
+ * (as long as it is non-null).
* @param centre The coordinate to write results into
- * @return NULL is the center could not be found
- * (null envelope).
+ * @return `false` if the center could not be found (null envelope).
bool centre(Coordinate& centre) const;
- * Computes the intersection of two {@link Envelopes}
+ /** \brief
+ * Computes the intersection of two [Envelopes](@ref Envelope).
* @param env the envelope to intersect with
* @param result the envelope representing the intersection of
@@ -281,15 +272,14 @@ public:
* Expands this envelope by a given distance in all directions.
* Both positive and negative distances are supported.
- * @param deltaX the distance to expand the envelope along
- * the X axis
- * @param deltaY the distance to expand the envelope along
- * the Y axis
+ * @param deltaX the distance to expand the envelope along the X axis
+ * @param deltaY the distance to expand the envelope along the Y axis
void expandBy(double deltaX, double deltaY);
/** \brief
* @param p_distance the distance to expand the envelope
@@ -302,16 +292,17 @@ public:
/** \brief
- * Enlarges the boundary of the Envelope so that it contains
- * p. Does nothing if p is already on or within the boundaries.
+ * Enlarges the boundary of the Envelope so that it contains p. Does
+ * nothing if p is already on or within the boundaries.
- * @param p the Coordinate to include
+ * @param p the Coordinate to include
void expandToInclude(const Coordinate& p);
/** \brief
- * (x,y). Does nothing if (x,y) is already on or within the boundaries.
+ * Enlarges the boundary of the Envelope so that it contains (x,y).
+ * Does nothing if (x,y) is already on or within the boundaries.
* @param x the value to lower the minimum x
* to or to raise the maximum x to
@@ -321,24 +312,23 @@ public:
void expandToInclude(double x, double y);
/** \brief
- * <code>other</code>. Does nothing if other is wholly on or
- * within the boundaries.
+ * Enlarges the boundary of the Envelope so that it contains `other`.
+ * Does nothing if other is wholly on or within the boundaries.
- * @param other the <code>Envelope</code> to merge with
+ * @param other the Envelope to merge with
void expandToInclude(const Envelope* other);
/** \brief
- * Tests if the <code>Envelope other</code> lies wholely
- * inside this <code>Envelope</code> (inclusive of the boundary).
+ * Tests if the Envelope `other` lies wholly inside this Envelope
+ * (inclusive of the boundary).
- * Note that this is <b>not</b> the same definition as the SFS
- * <tt>contains</tt>, which would exclude the envelope boundary.
+ * Note that this is **not** the same definition as the SFS `contains`,
+ * which would exclude the envelope boundary.
- * @param other the <code>Envelope</code> to check
- * @return true if <code>other</code> is contained in this
- * <code>Envelope</code>
+ * @param other the Envelope to check
+ * @return `true` if `other` is contained in this Envelope
* @see covers(Envelope)
@@ -355,13 +345,11 @@ public:
/** \brief
- * Returns <code>true</code> if the given point lies in
- * or on the envelope.
+ * Returns `true` if the given point lies in or on the envelope.
- * @param p the point which this <code>Envelope</code> is
- * being checked for containing
- * @return <code>true</code> if the point lies in the interior or
- * on the boundary of this <code>Envelope</code>.
+ * @param p the point which this Envelope is being checked for containing
+ * @return `true` if the point lies in the interior or on the boundary
+ * of this Envelope.
bool
contains(const Coordinate& p) const
@@ -370,19 +358,14 @@ public:
/** \brief
- * @param x the x-coordinate of the point which this
- * <code>Envelope</code> is
- * @param y the y-coordinate of the point which this
- * <code>Envelope</code> is being checked for containing
- * @return <code>true</code> if <code>(x, y)</code> lies in
- * the interior or on the boundary of this
- * <code>Envelope</code>.
+ * @param x the x-coordinate of the point which this Envelope is
+ * being checked for containing
+ * @param y the y-coordinate of the point which this Envelope is being
+ * checked for containing
+ * @return `true` if `(x, y)` lies in the interior or on the boundary
bool
contains(double x, double y) const
@@ -390,67 +373,55 @@ public:
return covers(x, y);
- * Check if the point p
- * intersects (lies inside) the region of this Envelope.
+ /** \brief
+ * Check if the point p intersects (lies inside) the region of this Envelope.
* @param p the Coordinate to be tested
* @return true if the point intersects this Envelope
bool intersects(const Coordinate& p) const;
- * Check if the point (x, y)
+ /** \brief
+ * Check if the point (x, y) intersects (lies inside) the region of this Envelope.
- * @param x the x-ordinate of the point
- * @param y the y-ordinate of the point
- * @return <code>true</code> if the point intersects this Envelope
+ * @param x the x-ordinate of the point
+ * @param y the y-ordinate of the point
+ * @return `true` if the point intersects this Envelope
bool intersects(double x, double y) const;
- * Check if the region defined by other Envelope
- * intersects (intersects) the region of this Envelope.
- * @param other the Envelope which this Envelope is
- * being checked for intersection
+ /** \brief
+ * Check if the region defined by other Envelope intersects the region of this Envelope.
- * @return true if the Envelopes intersects
+ * @param other the Envelope which this Envelope is being checked for intersection
+ * @return true if the Envelopes intersects
bool intersects(const Envelope* other) const;
bool intersects(const Envelope& other) const;
- * Tests if the given point lies in or on the envelope.
- *@param x the x-coordinate of the point which this <code>Envelope</code> is
- *@param y the y-coordinate of the point which this <code>Envelope</code> is
- *@return <code>true</code> if <code>(x, y)</code> lies in the interior or
+ /** \brief
+ * Tests if the given point lies in or on the envelope.
+ * @param x the x-coordinate of the point which this Envelope is being checked for containing
+ * @param y the y-coordinate of the point which this Envelope is being checked for containing
+ * @return `true` if `(x, y)` lies in the interior or on the boundary of this Envelope.
bool covers(double x, double y) const;
- *@param p the point which this <code>Envelope</code> is
- *@return <code>true</code> if the point lies in the interior or
+ /** \brief
+ * @return `true` if the point lies in the interior or on the boundary of this Envelope.
bool covers(const Coordinate* p) const;
- * Tests if the <code>Envelope other</code> lies wholely inside
- * this <code>Envelope</code> (inclusive of the boundary).
+ /** \brief
+ * Tests if the Envelope `other` lies wholly inside this Envelope (inclusive of the boundary).
- * @return true if this <code>Envelope</code> covers the
+ * @return true if this Envelope covers the `other`
bool covers(const Envelope& other) const;
@@ -462,31 +433,24 @@ public:
/** \brief
- * Returns <code>true</code> if the <code>Envelope other</code>
- * spatially equals this <code>Envelope</code>.
- * @param other the <code>Envelope</code> which this
- * <code>Envelope</code> is being checked for equality
+ * Returns `true` if the Envelope `other` spatially equals this Envelope.
- * @return <code>true</code> if this and <code>other</code>
- * Envelope objs are spatially equal
+ * @param other the Envelope which this Envelope is being checked for equality
+ * @return `true` if this and `other` Envelope objects are spatially equal
bool equals(const Envelope* other) const;
/** \brief
- * Returns a <code>string</code> of the form
- * <I>Env[minx:maxx,miny:maxy]</I> .
+ * Returns a `string` of the form `Env[minx:maxx,miny:maxy]`.
- * @return a <code>string</code> of the form
+ * @return a `string` of the form `Env[minx:maxx,miny:maxy]`
std::string toString(void) const;
/** \brief
- * Computes the distance between this and another
+ * Computes the distance between this and another Envelope.
- * The distance between overlapping Envelopes is 0. Otherwise, the
+ * The distance between overlapping Envelopes is 0. Otherwise, the
* distance is the Euclidean distance between the closest points.
double distance(const Envelope* env) const;
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index b7aef91..f8a82ce 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -671,7 +671,7 @@ public:
* - Unioning a set of {@link LineString}s has the effect of fully noding
* and dissolving the linework.
* - Unioning a set of {@link Polygon}s will always
- * return a {@link Polygonal} geometry (unlike {link #union(Geometry)},
+ * return a {@link Polygonal} geometry (unlike Geometry::Union(const Geometry* other) const),
* which may return geometrys of lower dimension if a topology collapse
* occurred.
@@ -815,7 +815,7 @@ public:
std::unique_ptr<Point> getInteriorPoint() const;
* \brief
* Notifies this Geometry that its Coordinates have been changed
* by an external party (using a CoordinateFilter, for example).
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index fd0f51e..10ce548 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -64,7 +64,7 @@ namespace geom { // geos::geom
* A linestring must have either 0 or 2 or more points.
* If these conditions are not met, the constructors throw
- * an {@link IllegalArgumentException}.
+ * an {@link util::IllegalArgumentException}.
class GEOS_DLL LineString: public virtual Geometry, public Lineal {
diff --git a/include/geos/geom/LinearRing.h b/include/geos/geom/LinearRing.h
index 4b5a7be..50c9a23 100644
--- a/include/geos/geom/LinearRing.h
+++ b/include/geos/geom/LinearRing.h
@@ -40,24 +40,22 @@ namespace geom { // geos::geom
* \brief
- * Models an OGC SFS <code>LinearRing</code>.
+ * Models an OGC SFS LinearRing. A LinearRing is a LineString which is both
+ * closed and simple.
- * A LinearRing is a LineString which is both closed and simple.
- * In other words,
- * the first and last coordinate in the ring must be equal,
- * and the interior of the ring must not self-intersect.
- * Either orientation of the ring is allowed.
+ * In other words, the first and last coordinate in the ring must be equal,
+ * and the interior of the ring must not self-intersect. Either orientation
+ * of the ring is allowed.
- * A ring must have either 0 or 4 or more points.
- * The first and last points must be equal (in 2D).
- * If these conditions are not met, the constructors throw
+ * A ring must have either 0 or 4 or more points. The first and last points
+ * must be equal (in 2D). If these conditions are not met, the constructors
+ * throw an {@link geos::util::IllegalArgumentException}
class GEOS_DLL LinearRing : public LineString {
public:
+ /** \brief
* The minimum number of vertices allowed in a valid non-empty ring (= 4).
* Empty rings with 0 vertices are also valid.
@@ -66,7 +64,7 @@ public:
LinearRing(const LinearRing& lr);
- * \brief Constructs a <code>LinearRing</code> with the given points.
+ * \brief Constructs a LinearRing with the given points.
* @param points points forming a closed and simple linestring, or
* <code>null</code> or an empty array to create the empty
diff --git a/include/geos/geom/MultiLineString.h b/include/geos/geom/MultiLineString.h
index fcf9e20..181c6ea 100644
--- a/include/geos/geom/MultiLineString.h
+++ b/include/geos/geom/MultiLineString.h
@@ -47,7 +47,7 @@ namespace geom { // geos::geom
#pragma warning(disable:4250) // T1 inherits T2 via dominance
#endif
-/// Models a collection of (@link LineString}s.
+/// Models a collection of [LineStrings](@ref geom::LineString).
class GEOS_DLL MultiLineString: public GeometryCollection, public Lineal {
public:
@@ -61,12 +61,12 @@ public:
* \brief
- * Returns Dimension::False if all LineStrings in the collection
+ * Returns Dimension::False if all [LineStrings](@ref geom::LineString) in the collection
* are closed, 0 otherwise.
int getBoundaryDimension() const override;
- /// Returns a (possibly empty) MultiPoint
+ /// Returns a (possibly empty) [MultiPoint](@ref geom::MultiPoint)
std::unique_ptr<Geometry> getBoundary() const override;
std::string getGeometryType() const override;
@@ -93,22 +93,20 @@ public:
protected:
- * \brief Constructs a <code>MultiLineString</code>.
+ * \brief Constructs a MultiLineString.
- * @param newLines
- * The <code>LineStrings</code>s for this
- * <code>MultiLineString</code>, or <code>null</code>
- * or an empty array to create the empty geometry.
- * Elements may be empty <code>LineString</code>s,
- * but not <code>null</code>s.
+ * @param newLines The [LineStrings](@ref geom::LineString) for this
+ * MultiLineString, or `null`
+ * or an empty array to create the empty geometry.
+ * Elements may be empty LineString,
+ * but not `null`s.
- * Constructed object will take ownership of
- * the vector and its elements.
+ * @param newFactory The GeometryFactory used to create this geometry.
+ * Caller must keep the factory alive for the life-time
+ * of the constructed MultiLineString.
- * @param newFactory
- * The GeometryFactory used to create this geometry.
- * Caller must keep the factory alive for the life-time
- * of the constructed MultiLineString.
+ * @note Constructed object will take ownership of
+ * the vector and its elements.
MultiLineString(std::vector<Geometry*>* newLines,
diff --git a/include/geos/geom/PrecisionModel.h b/include/geos/geom/PrecisionModel.h
index e2ee2fd..f196522 100644
--- a/include/geos/geom/PrecisionModel.h
+++ b/include/geos/geom/PrecisionModel.h
@@ -233,9 +233,8 @@ public:
double getOffsetY() const;
- /** \brief
- * Sets <code>internal</code> to the precise representation of
- * <code>external</code>.
+ * Sets ´internal` to the precise representation of `external`.
* @param external the original coordinate
* @param internal the coordinate whose values will be changed to the
diff --git a/include/geos/geom/util/GeometryExtracter.h b/include/geos/geom/util/GeometryExtracter.h
index 3a3c0f0..df2a4ce 100644
--- a/include/geos/geom/util/GeometryExtracter.h
+++ b/include/geos/geom/util/GeometryExtracter.h
@@ -42,7 +42,7 @@ public:
* and adds them to the provided container.
* @param geom the geometry from which to extract
- * @param list the list to add the extracted elements to
+ * @param lst the list to add the extracted elements to
template <class ComponentType, class TargetContainer>
static void
diff --git a/include/geos/geom/util/GeometryTransformer.h b/include/geos/geom/util/GeometryTransformer.h
index b596a08..410a22d 100644
--- a/include/geos/geom/util/GeometryTransformer.h
+++ b/include/geos/geom/util/GeometryTransformer.h
@@ -54,34 +54,31 @@ namespace geom { // geos.geom
namespace util { // geos.geom.util
/** \brief
- * A framework for processes which transform an input {@link Geometry} into
- * an output {@link Geometry}, possibly changing its structure and type(s).
+ * A framework for processes which transform an input Geometry into
+ * an output Geometry, possibly changing its structure and type(s).
- * This class is a framework for implementing subclasses
- * which perform transformations on
- * various different Geometry subclasses.
+ * This class is a framework for implementing subclasses which perform
+ * transformations on various different Geometry subclasses.
* It provides an easy way of applying specific transformations
* to given geometry types, while allowing unhandled types to be simply copied.
* Also, the framework ensures that if subcomponents change type
* the parent geometries types change appropriately to maintain valid structure.
- * Subclasses will override whichever <code>transformX</code> methods
+ * Subclasses will override whichever `transformX` methods
* they need to to handle particular Geometry types.
* A typically usage would be a transformation that may transform Polygons into
- * Polygons, LineStrings
- * or Points. This class would likely need to override the
- * {@link transformMultiPolygon} method to ensure that if input Polygons
- * change type the result is a GeometryCollection,
- * not a MultiPolygon
+ * Polygons, LineStrings or Points. This class would likely need to override the
+ * `GeometryTransformer::transformMultiPolygon(const MultiPolygon* geom,
+ * const Geometry* parent)` method to ensure that if input Polygons change type
+ * the result is a GeometryCollection, not a MultiPolygon
* The default behaviour of this class is to simply recursively transform
* each Geometry component into an identical object by copying.
- * Note that all <code>transformX</code> methods may return <code>null</code>,
- * to avoid creating empty geometry objects. This will be handled correctly
- * by the transformer.
- * The {@link transform} method itself will always
- * return a geometry object.
+ * Note that all `transformX` methods may return `null`, to avoid creating
+ * empty geometry objects. This will be handled correctly by the transformer.
+ * The `GeometryTransformer::transform(const Geometry* nInputGeom)` method
+ * itself will always return a geometry object.
* @see GeometryEditor
@@ -105,9 +102,9 @@ protected:
const GeometryFactory* factory;
+ /** \brief
* Convenience method which provides standard way of
- * creating a {@link CoordinateSequence}
+ * creating a CoordinateSequence.
* @param coords the coordinate array to copy
* @return a coordinate sequence for the array
@@ -159,29 +156,29 @@ private:
// these could eventually be exposed to clients
- * <code>true</code> if empty geometries should not be included in the result
+ * `true` if empty geometries should not be included in the result
bool pruneEmptyGeometry;
- * <code>true</code> if a homogenous collection result
+ * `true` if a homogenous collection result
* from a {@link GeometryCollection} should still
* be a general GeometryCollection
bool preserveGeometryCollectionType;
- * <code>true</code> if the output from a collection argument should still be a collection
+ * `true` if the output from a collection argument should still be a collection
// bool preserveCollections;
- * <code>true</code> if the type of the input should be preserved
+ * `true` if the type of the input should be preserved
bool preserveType;
- * <code>true</code> if transformed invalid interior rings should be skipped
+ * `true` if transformed invalid interior rings should be skipped
bool skipTransformedInvalidInteriorRings;
diff --git a/include/geos/geomgraph/DirectedEdgeStar.h b/include/geos/geomgraph/DirectedEdgeStar.h
index c258ff8..bbdd24a 100644
--- a/include/geos/geomgraph/DirectedEdgeStar.h
+++ b/include/geos/geomgraph/DirectedEdgeStar.h
@@ -46,7 +46,7 @@ namespace geomgraph { // geos.geomgraph
* \brief
- * A DirectedEdgeStar is an ordered list of <b>outgoing</b> DirectedEdges around a node.
+ * A DirectedEdgeStar is an ordered list of **outgoing** DirectedEdges around a node.
* It supports labelling the edges as well as linking the edges to form both
* MaximalEdgeRings and MinimalEdgeRings.
@@ -84,24 +84,23 @@ public:
DirectedEdge* getRightmostEdge();
/** \brief
- * Compute the labelling for all dirEdges in this star, as well
- * as the overall labelling
+ * Compute the labelling for all dirEdges in this star, as well as the overall labelling
void computeLabelling(std::vector<GeometryGraph*>* geom) override; // throw(TopologyException *);
/** \brief
- * For each dirEdge in the star,
- * merge the label from the sym dirEdge into the label
+ * For each dirEdge in the star, merge the label from the sym dirEdge into the label
void mergeSymLabels();
- /// Update incomplete dirEdge labels from the labelling for the node
+ /// \brief Update incomplete dirEdge labels from the labelling for the node
void updateLabelling(const Label& nodeLabel);
+ /** \brief
* Traverse the star of DirectedEdges, linking the included edges together.
- * To link two dirEdges, the <next> pointer for an incoming dirEdge
+ * To link two dirEdges, the `next` pointer for an incoming dirEdge
* is set to the next outgoing edge.
* DirEdges are only linked if:
@@ -109,10 +108,9 @@ public:
* - they belong to an area (i.e. they have sides)
* - they are marked as being in the result
- * Edges are linked in CCW order (the order they are stored).
- * This means that rings have their face on the Right
- * (in other words,
- * the topological location of the face is given by the RHS label of the DirectedEdge)
+ * Edges are linked in CCW order (the order they are stored). This means
+ * that rings have their face on the Right (in other words, the topological
+ * location of the face is given by the RHS label of the DirectedEdge)
* PRECONDITION: No pair of dirEdges are both marked as being in the result
diff --git a/include/geos/geomgraph/EdgeNodingValidator.h b/include/geos/geomgraph/EdgeNodingValidator.h
index a8f0118..2c10245 100644
--- a/include/geos/geomgraph/EdgeNodingValidator.h
+++ b/include/geos/geomgraph/EdgeNodingValidator.h
@@ -76,15 +76,13 @@ private:
public:
/** \brief
- * Checks whether the supplied {@link Edge}s
- * are correctly noded.
+ * Checks whether the supplied {@link Edge}s are correctly noded.
- * Throws a {@link TopologyException} if they are not.
+ * Throws a [TopologyException](@ref util::TopologyException) if they are not.
* @param edges a collection of Edges.
* @throws TopologyException if the SegmentStrings are not
* correctly noded
static void
checkValid(std::vector<Edge*>& edges)
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index 311b827..a1e70f8 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -67,8 +67,8 @@ class EdgeSetIntersector;
namespace geos {
- * A GeometryGraph is a graph that models a given Geometry
+/** \brief
+ * A GeometryGraph is a graph that models a given Geometry.
class GEOS_DLL GeometryGraph: public PlanarGraph {
using PlanarGraph::add;
@@ -197,18 +197,17 @@ public:
* \brief
- * Compute self-nodes, taking advantage of the Geometry type to
- * minimize the number of intersection tests. (E.g. rings are
- * not tested for self-intersection, since
- * they are assumed to be valid).
+ * Compute self-nodes, taking advantage of the Geometry type to minimize
+ * the number of intersection tests. (E.g. rings are not tested for
+ * self-intersection, since they are assumed to be valid).
* @param li the LineIntersector to use
- * @param computeRingSelfNodes if <false>, intersection checks are
- * optimized to not test rings for self-intersection
+ * @param computeRingSelfNodes if `false`, intersection checks are optimized
+ * to not test rings for self-intersection
+ * @param env an Envelope
* @return the SegmentIntersector used, containing information about
- * the intersections found
+ * the intersections found
index::SegmentIntersector*
computeSelfNodes(
diff --git a/include/geos/geomgraph/Position.h b/include/geos/geomgraph/Position.h
index 16df86e..f276013 100644
--- a/include/geos/geomgraph/Position.h
+++ b/include/geos/geomgraph/Position.h
@@ -32,29 +32,33 @@
namespace geos {
+/** \brief
+ * A Position indicates the position of a Location relative to a graph
+ * component (Node, Edge, or Area).
class GEOS_DLL Position {
public:
enum {
- * An indicator that a Location is <i>on</i>
+ /** \brief
+ * An indicator that a Location is *on*
* a GraphComponent
ON = 0,
+ /** \brief
* An indicator that a Location is to the
- * <i>left</i> of a GraphComponent
+ * *left* of a GraphComponent
LEFT,
+ /** \brief
- * <i>right</i> of a GraphComponent
+ * *right* of a GraphComponent
RIGHT
+ /** \brief
* Returns LEFT if the position is RIGHT, RIGHT if
* the position is LEFT, or the position otherwise.
diff --git a/include/geos/index/bintree/Bintree.h b/include/geos/index/bintree/Bintree.h
index 10141a7..3f776d2 100644
--- a/include/geos/index/bintree/Bintree.h
+++ b/include/geos/index/bintree/Bintree.h
@@ -38,34 +38,33 @@ namespace index { // geos::index
namespace bintree { // geos::index::bintree
/** \brief
- * An BinTree (or "Binary Interval Tree")
- * is a 1-dimensional version of a quadtree.
+ * A BinTree (or "Binary Interval Tree") is a 1-dimensional version of a quadtree.
- * It indexes 1-dimensional intervals (which of course may
- * be the projection of 2-D objects on an axis).
- * It supports range searching
- * (where the range may be a single point).
+ * It indexes 1-dimensional intervals (which of course may be the projection
+ * of 2-D objects on an axis). It supports range searching (where the range
+ * may be a single point).
* This implementation does not require specifying the extent of the inserted
- * items beforehand. It will automatically expand to accomodate any extent
+ * items beforehand. It will automatically expand to accomodate any extent
* of dataset.
- * This index is different to the Interval Tree of Edelsbrunner
- * or the Segment Tree of Bentley.
+ * This index is different to the "Interval Tree of Edelsbrunner"
+ * or the "Segment Tree of Bentley".
class GEOS_DLL Bintree {
public:
+ /** \brief
* Ensure that the Interval for the inserted item has non-zero extents.
- * Use the current minExtent to pad it, if necessary
- * NOTE: in GEOS this function always return a newly allocated object
+ * Use the current minExtent to pad it, if necessary.
+ * @note In GEOS this function always return a newly allocated object
* with ownership transferred to caller. TODO: change this ?
- * @param itemInterval
- * Source interval, ownership left to caller, no references hold.
+ * @param itemInterval source interval, ownership left to caller, no references hold
+ * @param minExtent minimal extent
static Interval* ensureExtent(const Interval* itemInterval,
double minExtent);
diff --git a/include/geos/index/chain/MonotoneChainBuilder.h b/include/geos/index/chain/MonotoneChainBuilder.h
index bcd14fe..aa82fcf 100644
--- a/include/geos/index/chain/MonotoneChainBuilder.h
+++ b/include/geos/index/chain/MonotoneChainBuilder.h
@@ -41,8 +41,8 @@ namespace index { // geos::index
namespace chain { // geos::index::chain
/** \brief
- * Constructs {@link MonotoneChain}s
- * for sequences of {@link Coordinate}s.
+ * Constructs [MonotoneChains](@ref index::chain::MonotoneChain)
+ * for sequences of [Coordinates](@ref geom::Coordinate).
* TODO: use vector<const Coordinate*> instead ?
@@ -55,7 +55,8 @@ public:
/** \brief
* Return a newly-allocated vector of newly-allocated
* MonotoneChain objects for the given CoordinateSequence.
- * Remember to deep-delete the result.
+ * @note Remember to deep-delete the result.
static std::unique_ptr<std::vector<std::unique_ptr<MonotoneChain>>> getChains(
const geom::CoordinateSequence* pts,
@@ -64,7 +65,8 @@ public:
/** \brief
* Fill the provided vector with newly-allocated MonotoneChain objects
* for the given CoordinateSequence.
- * Remember to delete vector elements!
+ * @note Remember to delete vector elements!
static void getChains(const geom::CoordinateSequence* pts,
void* context,
@@ -79,9 +81,9 @@ public:
/** \brief
* Fill the given vector with start/end indexes of the monotone chains
* The last entry in the array points to the end point of the point
- * array,
- * for use as a sentinel.
+ * array, for use as a sentinel.
static void getChainStartIndices(const geom::CoordinateSequence& pts,
std::vector<std::size_t>& startIndexList);
@@ -96,16 +98,17 @@ public:
private:
+ /** \brief
* Finds the index of the last point in a monotone chain
* starting at a given point.
* Any repeated points (0-length segments) will be included
* in the monotone chain returned.
* @return the index of the last point in the monotone chain
* starting at <code>start</code>.
- * NOTE: aborts if 'start' is >= pts.getSize()
+ * @note aborts if 'start' is >= pts.getSize()
static std::size_t findChainEnd(const geom::CoordinateSequence& pts,
std::size_t start);
diff --git a/include/geos/index/chain/MonotoneChainOverlapAction.h b/include/geos/index/chain/MonotoneChainOverlapAction.h
index 893e3be..bfafc82 100644
--- a/include/geos/index/chain/MonotoneChainOverlapAction.h
+++ b/include/geos/index/chain/MonotoneChainOverlapAction.h
@@ -36,9 +36,9 @@ namespace geos {
+/** \brief
* The action for the internal iterator for performing
- * overlap queries on a MonotoneChain
+ * overlap queries on a MonotoneChain.
class GEOS_DLL MonotoneChainOverlapAction {
@@ -55,9 +55,11 @@ public:
virtual
~MonotoneChainOverlapAction() {}
- * This function can be overridden if the original chains are needed
+ /** \brief
+ * This function can be overridden if the original chains are needed.
+ * @param mc1 a MonotoneChain
+ * @param mc2 a MonotoneChain
* @param start1 the index of the start of the overlapping segment
* from mc1
* @param start2 the index of the start of the overlapping segment
@@ -66,11 +68,12 @@ public:
virtual void overlap(MonotoneChain& mc1, std::size_t start1,
MonotoneChain& mc2, std::size_t start2);
+ /** \brief
* This is a convenience function which can be overridden to
- * obtain the actual line segments which overlap
- * @param seg1
- * @param seg2
+ * obtain the actual line segments which overlap.
+ * **param** `seg1`
+ * **param** `seg2`
virtual void
overlap(const geom::LineSegment& /*seg1*/,
diff --git a/include/geos/index/strtree/AbstractSTRtree.h b/include/geos/index/strtree/AbstractSTRtree.h
index 589be45..d9dcf24 100644
--- a/include/geos/index/strtree/AbstractSTRtree.h
+++ b/include/geos/index/strtree/AbstractSTRtree.h
@@ -195,7 +195,7 @@ protected:
// Ownership to caller (TODO: return by unique_ptr)
virtual AbstractNode* createNode(int level) = 0;
+ /** \brief
* Sorts the childBoundables then divides them into groups of size M, where
* M is the node capacity.
@@ -257,9 +257,9 @@ protected:
public:
+ /** \brief
* Constructs an AbstractSTRtree with the specified maximum number of child
- * nodes that a node may have
+ * nodes that a node may have.
AbstractSTRtree(std::size_t newNodeCapacity)
@@ -283,16 +283,18 @@ public:
virtual ~AbstractSTRtree();
+ /** \brief
* Creates parent nodes, grandparent nodes, and so forth up to the root
- * node, for the data that has been inserted into the tree. Can only be
+ * node, for the data that has been inserted into the tree.
+ * Can only be
* called once, and thus can be called only after all of the data has been
* inserted into the tree.
virtual void build();
- * Returns the maximum number of child nodes that a node may have
+ /** \brief
+ * Returns the maximum number of child nodes that a node may have.
virtual std::size_t
getNodeCapacity()
@@ -303,26 +305,28 @@ public:
virtual void query(const void* searchBounds, const AbstractNode* node, std::vector<void*>* matches);
- * Iterate over all items added thus far. Explicitly does not build
- * the tree.
+ * Iterate over all items added thus far. Explicitly does not build
+ * the tree.
void iterate(ItemVisitor& visitor);
* @param level -1 to get items
+ * @param top an AbstractNode
+ * @param boundables a BoundableList
virtual void boundablesAtLevel(int level, AbstractNode* top,
BoundableList* boundables);
- * Gets a tree structure (as a nested list)
- * corresponding to the structure of the items and nodes in this tree.
- * <p>
- * The returned {@link List}s contain either {@link Object} items,
- * or Lists which correspond to subtrees of the tree
- * Subtrees which do not contain any items are not included.
- * <p>
+ /** \brief
+ * Gets a tree structure (as a nested list) corresponding to the structure
+ * of the items and nodes in this tree.
+ * The returned Lists contain either Object items, or Lists which
+ * correspond to subtrees of the tree Subtrees which do not contain
+ * any items are not included.
* Builds the tree if necessary.
* @note The caller is responsible for releasing the list
diff --git a/include/geos/index/strtree/BoundablePair.h b/include/geos/index/strtree/BoundablePair.h
index 5490705..4c7c62c 100644
--- a/include/geos/index/strtree/BoundablePair.h
+++ b/include/geos/index/strtree/BoundablePair.h
@@ -23,9 +23,14 @@
#include <geos/index/strtree/ItemDistance.h>
#include <queue>
+namespace geos {
+namespace index {
+namespace strtree {
- * A pair of {@link Boundable}s, whose leaf items
- * support a distance metric between them.
+ * @brief A pair of [Boundables](@ref Boundable), whose
+ * leaf items support a distance metric between them.
* Used to compute the distance between the members,
* and to expand a member relative to the other
* in order to produce new branches of the
@@ -36,10 +41,6 @@
* @author Martin Davis
-namespace geos {
-namespace index {
-namespace strtree {
class BoundablePair {
private:
const Boundable* boundable1;
@@ -68,20 +69,22 @@ public:
const Boundable* getBoundable(int i) const;
+ /** \brief
* Computes the distance between the {@link Boundable}s in this pair.
* The boundables are either composites or leaves.
* If either is composite, the distance is computed as the minimum distance
* between the bounds.
- * If both are leaves, the distance is computed by {@link #itemDistance(ItemBoundable, ItemBoundable)}.
+ * If both are leaves, the distance is computed by
+ * ItemDistance::distance(const ItemBoundable* item1, const ItemBoundable* item2).
- * @return
+ * @return the distance between the items
double distance() const;
- * Gets the minimum possible distance between the Boundables in
- * this pair.
+ /** \brief
+ * Gets the minimum possible distance between the Boundables in this pair.
* If the members are both items, this will be the
* exact distance between them.
* Otherwise, this distance will be a lower bound on
@@ -98,7 +101,7 @@ public:
bool isLeaves() const;
+ /** \brief
* Computes the maximum distance between any
* two items in the pair of nodes.
diff --git a/include/geos/index/strtree/ItemDistance.h b/include/geos/index/strtree/ItemDistance.h
index 6a05a12..4c312c3 100644
--- a/include/geos/index/strtree/ItemDistance.h
+++ b/include/geos/index/strtree/ItemDistance.h
@@ -24,9 +24,16 @@
namespace geos {
namespace index {
namespace strtree {
+/** \brief
+ * A function method which computes the distance between two [ItemBoundables](\ref ItemBoundable)
+ * in an STRtree. Used for Nearest Neighbour searches.
+ * \author Martin Davis
class GEOS_DLL ItemDistance {
public:
+ /** \brief
* Computes the distance between two items.
* @param item1
diff --git a/include/geos/index/strtree/SIRtree.h b/include/geos/index/strtree/SIRtree.h
index 34be136..fc8ba26 100644
--- a/include/geos/index/strtree/SIRtree.h
+++ b/include/geos/index/strtree/SIRtree.h
@@ -62,6 +62,7 @@ public:
* Returns items whose bounds intersect the given bounds.
* @param x1 possibly equal to x2
+ * @param x2
std::vector<void*>*
query(double x1, double x2)
diff --git a/include/geos/linearref/ExtractLineByLocation.h b/include/geos/linearref/ExtractLineByLocation.h
index b278dc1..e9516ec 100644
--- a/include/geos/linearref/ExtractLineByLocation.h
+++ b/include/geos/linearref/ExtractLineByLocation.h
@@ -27,8 +27,8 @@
namespace geos {
namespace linearref { // geos::linearref
- * Extracts the subline of a linear {@link Geometry} between
+/** \brief
+ * Extracts the subline of a linear [Geometry](@ref geom::Geometry) between
* two {@link LinearLocation}s on the line.
class ExtractLineByLocation {
@@ -56,9 +56,10 @@ private:
std::unique_ptr<geom::Geometry> computeLinear(const LinearLocation& start, const LinearLocation& end);
public:
- * Computes the subline of a {@link LineString} between
- * two {@link LineStringLocation}s on the line.
+ /** \brief
+ * Computes the subline of a [LineString](@ref geom::LineString) between
+ * two {@link LinearLocation}s on the line.
* If the start location is after the end location,
* the computed geometry is reversed.
@@ -71,9 +72,10 @@ public:
ExtractLineByLocation(const geom::Geometry* line);
+ /** \brief
* Extracts a subline of the input.
- * If <code>end < start</code> the linear geometry computed will be reversed.
+ * If `end < start` the linear geometry computed will be reversed.
* @param start the start location
* @param end the end location
diff --git a/include/geos/linearref/LengthIndexedLine.h b/include/geos/linearref/LengthIndexedLine.h
index ee0de1a..1516a69 100644
--- a/include/geos/linearref/LengthIndexedLine.h
+++ b/include/geos/linearref/LengthIndexedLine.h
@@ -30,8 +30,9 @@ namespace geos {
/** \brief
- * Supports linear referencing along a linear {@link Geometry}
+ * Supports linear referencing along a linear geom::Geometry
* using the length along the line as the index.
* Negative length values are taken as measured in the reverse direction
* from the end of the geometry.
* Out-of-range index values are handled by clamping
@@ -50,7 +51,7 @@ private:
public:
/** \brief
- * Constructs an object which allows a linear {@link Geometry}
+ * Constructs an object which allows a linear [Geometry](@ref geom::Geometry)
* to be linearly referenced using length as an index.
* @param linearGeom the linear geometry to reference along
@@ -59,8 +60,9 @@ public:
LengthIndexedLine(const geom::Geometry* linearGeom);
/** \brief
- * Computes the {@link Coordinate} for the point
+ * Computes the [Coordinate](@ref geom::Coordinate) for the point
* on the line at the given index.
* If the index is out of range the first or last point on the
* line will be returned.
* The Z-ordinate of the computed point will be interpolated from
@@ -74,7 +76,7 @@ public:
* \brief
* on the line at the given index, offset by the given distance.
@@ -87,14 +89,15 @@ public:
* @param index the index of the desired point
* @param offsetDistance the distance the point is offset from the segment
- * (positive is to the left, negative is to the right)
+ * (positive is to the left, negative is to the right)
* @return the Coordinate at the given index
geom::Coordinate extractPoint(double index, double offsetDistance) const;
- * Computes the {@link LineString} for the interval
+ /** \brief
+ * Computes the [LineString](@ref geom::LineString) for the interval
* on the line between the given indices.
* If the endIndex lies before the startIndex,
@@ -105,13 +108,14 @@ public:
std::unique_ptr<geom::Geometry> extractLine(double startIndex, double endIndex) const;
+ /** \brief
* Computes the minimum index for a point on the line.
* If the line is not simple (i.e. loops back on itself)
* a single point may have more than one possible index.
* In this case, the smallest index is returned.
- * The supplied point does not <i>necessarily</i> have to lie precisely
+ * The supplied point does not *necessarily* have to lie precisely
* on the line, but if it is far from the line the accuracy and
* performance of this function is not guaranteed.
* Use {@link #project} to compute a guaranteed result for points
@@ -124,17 +128,18 @@ public:
double indexOf(const geom::Coordinate& pt) const;
- * Finds the index for a point on the line
- * which is greater than the given index.
- * If no such index exists, returns <tt>minIndex</tt>.
+ /** \brief
+ * Finds the index for a point on the line which is
+ * greater than the given index.
+ * If no such index exists, returns `minIndex`.
* This method can be used to determine all indexes for
* a point which occurs more than once on a non-simple line.
* It can also be used to disambiguate cases where the given point lies
* slightly off the line and is equidistant from two different
* points on the line.
+ * The supplied point does not `*necessarily* have to lie precisely
@@ -148,9 +153,10 @@ public:
double indexOfAfter(const geom::Coordinate& pt, double minIndex) const;
+ /** \brief
* Computes the indices for a subline of the line.
- * (The subline must <b>conform</b> to the line; that is,
+ * (The subline must **conform** to the line; that is,
* all vertices in the subline (except possibly the first and last)
* must be vertices of the line and occcur in the same order).
@@ -160,8 +166,9 @@ public:
double* indicesOf(const geom::Geometry* subLine) const;
+ /** \brief
* Computes the index for the closest point on the line to the given point.
* If more than one point has the closest distance the first one along the line
* is returned.
* (The point does not necessarily have to lie precisely on the line.)
@@ -171,30 +178,30 @@ public:
double project(const geom::Coordinate& pt) const;
+ /** \brief
* Returns the index of the start of the line
* @return the start index
double getStartIndex() const;
+ /** \brief
* Returns the index of the end of the line
* @return the end index
double getEndIndex() const;
+ /** \brief
* Tests whether an index is in the valid index range for the line.
* @param index the index to test
- * @return <code>true</code> if the index is in the valid range
+ * @return `true` if the index is in the valid range
bool isValidIndex(double index) const;
- * Computes a valid index for this line
- * by clamping the given index to the valid range of index values
+ /** \brief
+ * Computes a valid index for this line by clamping the given index
+ * to the valid range of index values.
* @return a valid index value
diff --git a/include/geos/linearref/LengthLocationMap.h b/include/geos/linearref/LengthLocationMap.h
index cb33543..1b2a92d 100644
--- a/include/geos/linearref/LengthLocationMap.h
+++ b/include/geos/linearref/LengthLocationMap.h
@@ -29,8 +29,8 @@ namespace geos {
- * Computes the {@link LinearLocation} for a given length
- * along a linear {@link Geometry}.
+ * Computes the LinearLocation for a given length
+ * along a linear [Geometry](@ref geom::Geometry).
* Negative lengths are measured in reverse from end of the linear geometry.
* Out-of-range values are clamped.
@@ -52,12 +52,12 @@ public:
* \brief
- * given length along a linear {@link Geometry}.
+ * given length along a linear [Geometry](@ref geom::Geometry).
- * @param line the linear geometry to use
+ * @param linearGeom the linear geometry to use
* @param length the length index of the location
- * @return the {@link LinearLocation} for the length
+ * @return the LinearLocation for the length
static LinearLocation
getLocation(const geom::Geometry* linearGeom, double length)
@@ -68,14 +68,14 @@ public:
* \brief
+ * given length along a linear [Geometry].
- * @param resolveLower if true lengths are resolved to the
+ * @param resolveLower if `true` lengths are resolved to the
* lowest possible index
getLocation(const geom::Geometry* linearGeom, double length, bool resolveLower)
@@ -85,12 +85,12 @@ public:
- * Computes the length for a given {@link LinearLocation}
- * on a linear {@link Geometry}.
+ * Computes the length for a given LinearLocation
+ * on a linear [Geometry](@ref geom::Geometry).
- * @param loc the {@link LinearLocation} index of the location
- * @return the length for the {@link LinearLocation}
+ * @param loc the LinearLocation index of the location
+ * @return the length for the LinearLocation
static double getLength(const geom::Geometry* linearGeom, const LinearLocation& loc);
@@ -98,21 +98,23 @@ public:
* \brief
- * Compute the {@link LinearLocation} corresponding to a length.
+ * Compute the LinearLocation corresponding to a length.
* Ambiguous indexes are resolved to the lowest possible location value,
- * depending on the value of <tt>resolveLower</tt>.
+ * depending on the value of `resolveLower`.
+ * lowest possible index
* @return the corresponding LinearLocation
LinearLocation getLocation(double length, bool resolveLower) const;
* \brief
diff --git a/include/geos/linearref/LinearGeometryBuilder.h b/include/geos/linearref/LinearGeometryBuilder.h
index b96750a..3201863 100644
--- a/include/geos/linearref/LinearGeometryBuilder.h
+++ b/include/geos/linearref/LinearGeometryBuilder.h
@@ -31,9 +31,9 @@
namespace geos {
- * Builds a linear geometry ({@link LineString} or {@link MultiLineString})
- * incrementally (point-by-point).
+/** \brief
+ * Builds a linear geometry ([LineString](@ref geom::LineString) or
+ * [MultiLineString](@ref geom::MultiLineString)) incrementally (point-by-point).
* @version 1.7
@@ -57,39 +57,43 @@ public:
~LinearGeometryBuilder();
+ /** \brief
* Allows invalid lines to be ignored rather than causing Exceptions.
* An invalid line is one which has only one unique point.
- * @param ignoreInvalidLines <code>true</code> if short lines are
+ * @param ignoreInvalidLines `true` if short lines are
* to be ignored
void setIgnoreInvalidLines(bool ignoreInvalidLines);
+ /** \brief
- * @param fixInvalidLines <code>true</code> if short lines are
+ * @param fixInvalidLines `true` if short lines are
* to be ignored
void setFixInvalidLines(bool fixInvalidLines);
+ /** \brief
* Adds a point to the current line.
* @param pt the Coordinate to add
void add(const geom::Coordinate& pt);
+ /** \brief
+ * @param allowRepeatedPoints if set to `false`, repeated coordinates are
+ * collapsed
void add(const geom::Coordinate& pt, bool allowRepeatedPoints);
- /// NOTE strk: why return by value ?
+ // NOTE strk: why return by value ?
geom::Coordinate getLastCoordinate() const;
/// Terminate the current LineString.
diff --git a/include/geos/linearref/LinearIterator.h b/include/geos/linearref/LinearIterator.h
index be4ffe9..ad2318d 100644
--- a/include/geos/linearref/LinearIterator.h
+++ b/include/geos/linearref/LinearIterator.h
@@ -36,38 +36,38 @@ namespace linearref {
* The standard usage pattern for a LinearIterator is:
- * <pre>
* for (LinearIterator it = new LinearIterator(...); it.hasNext(); it.next()) {
* int ci = it.getComponentIndex(); // for example
* int vi = it.getVertexIndex(); // for example
- * </pre>
* @version 1.7
class LinearIterator {
public:
+ /** \brief
* Creates an iterator initialized to the start of a linear Geometry
* @param linear the linear geometry to iterate over
LinearIterator(const geom::Geometry* linear);
+ /** \brief
* Creates an iterator starting at
- * a {@link LinearLocation} on a linear {@link Geometry}
+ * a LinearLocation on a linear geom::Geometry
* @param start the location to start at
LinearIterator(const geom::Geometry* linear, const LinearLocation& start);
- * Creates an iterator starting at
- * a component and vertex in a linear {@link Geometry}
+ /** \brief
+ * Creates an iterator starting at a component and vertex in a
+ * linear geom::Geometry
* @param componentIndex the component to start at
@@ -75,57 +75,57 @@ public:
LinearIterator(const geom::Geometry* linear, size_t componentIndex, size_t vertexIndex);
+ /** \brief
* Tests whether there are any vertices left to iterator over.
- * @return <code>true</code> if there are more vertices to scan
+ * @return `true` if there are more vertices to scan
bool hasNext() const;
+ /** \brief
* Moves the iterator ahead to the next vertex and (possibly) linear component.
void next();
+ /** \brief
* Checks whether the iterator cursor is pointing to the
- * endpoint of a component {@link LineString}.
+ * endpoint of a component geom::LineString.
- * @return <code>true</true> if the iterator is at an endpoint
+ * @return `true` if the iterator is at an endpoint
bool isEndOfLine() const;
+ /** \brief
* The component index of the vertex the iterator is currently at.
* @return the current component index
size_t getComponentIndex() const;
+ /** \brief
* The vertex index of the vertex the iterator is currently at.
* @return the current vertex index
size_t getVertexIndex() const;
- * Gets the {@link LineString} component the iterator is current at.
+ /** \brief
+ * Gets the geom::LineString component the iterator is current at.
* @return a linestring
const geom::LineString* getLine() const;
- * Gets the first {@link Coordinate} of the current segment.
+ /** \brief
+ * Gets the first geom::Coordinate of the current segment.
* (the coordinate of the current vertex).
- * @return a {@link Coordinate}
+ * @return a Coordinate
geom::Coordinate getSegmentStart() const;
- * Gets the second {@link Coordinate} of the current segment.
+ /** \brief
+ * Gets the second geom::Coordinate of the current segment.
* (the coordinate of the next vertex).
- * If the iterator is at the end of a line, <code>null</code> is returned.
+ * If the iterator is at the end of a line, `null` is returned.
- * @return a {@link Coordinate} or <code>null</code>
+ * @return a Coordinate or `null`
geom::Coordinate getSegmentEnd() const;
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index 3f8f77b..2d78102 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -33,12 +33,13 @@ namespace linearref { // geos::linearref
/** \brief
- * Represents a location along a {@link LineString} or {@link MultiLineString}.
+ * Represents a location along a [LineString](@ref geom::LineString)
+ * or [MultiLineString](@ref geom::MultiLineString).
- * The referenced geometry is not maintained within
- * this location, but must be provided for operations which require it.
- * Various methods are provided to manipulate the location value
- * and query the geometry it references.
+ * The referenced geometry is not maintained within this location, but
+ * must be provided for operations which require it.
+ * Various methods are provided to manipulate the location value and
+ * query the geometry it references.
class LinearLocation {
private:
@@ -46,9 +47,10 @@ private:
size_t segmentIndex;
double segmentFraction;
+ /** \brief
* Ensures the individual values are locally valid.
- * Does <b>not</b> ensure that the indexes are valid for
+ * Does **not** ensure that the indexes are valid for
* a particular linear geometry.
* @see clamp
@@ -56,16 +58,19 @@ private:
void normalize();
public:
- * Gets a location which refers to the end of a linear {@link Geometry}.
+ /** \brief
+ * Gets a location which refers to the end of a linear
+ * [Geometry](@ref geom::Geometry).
- * @return a new <tt>LinearLocation</tt>
+ * @return a new `LinearLocation`
static LinearLocation getEndLocation(const geom::Geometry* linear);
- * Computes the {@link Coordinate} of a point a given fraction
- * along the line segment <tt>(p0, p1)</tt>.
+ /** \brief
+ * Computes the [Coordinate](@ref geom::Coordinate) of a point a given
+ * fraction along the line segment `(p0, p1)`.
* If the fraction is greater than 1.0 the last
* point of the segment is returned.
* If the fraction is less than or equal to 0.0 the first point
@@ -76,37 +81,36 @@ public:
* @param p0 the first point of the line segment
* @param p1 the last point of the line segment
* @param frac the length to the desired point
- * @return the <tt>Coordinate</tt> of the desired point
+ * @return the Coordinate of the desired point
static geom::Coordinate pointAlongSegmentByFraction(const geom::Coordinate& p0, const geom::Coordinate& p1,
double frac);
+ /** \brief
* Creates a location referring to the start of a linear geometry
LinearLocation(size_t segmentIndex = 0, double segmentFraction = 0.0);
LinearLocation(size_t componentIndex, size_t segmentIndex, double segmentFraction);
- * Ensures the indexes are valid for a given linear {@link Geometry}.
+ /** \brief
+ * Ensures the indexes are valid for a given linear [Geometry](@ref geom::Geometry).
* @param linear a linear geometry
void clamp(const geom::Geometry* linear);
- * Snaps the value of this location to
- * the nearest vertex on the given linear {@link Geometry},
- * if the vertex is closer than <tt>minDistance</tt>.
+ /** \brief
+ * Snaps the value of this location to the nearest vertex on the given linear
+ * [Geometry](@ref geom::Geometry), if the vertex is closer than `minDistance`.
* @param linearGeom a linear geometry
* @param minDistance the minimum allowable distance to a vertex
void snapToVertex(const geom::Geometry* linearGeom, double minDistance);
+ /** \brief
* Gets the length of the segment in the given
* Geometry containing this location.
@@ -115,92 +119,91 @@ public:
double getSegmentLength(const geom::Geometry* linearGeom) const;
+ /** \brief
* Sets the value of this location to
- * refer the end of a linear geometry
+ * refer the end of a linear geometry.
* @param linear the linear geometry to set
void setToEnd(const geom::Geometry* linear);
+ /** \brief
* Gets the component index for this location.
* @return the component index
- * Gets the segment index for this location
+ /** \brief
+ * Gets the segment index for this location.
* @return the segment index
size_t getSegmentIndex() const;
- * Gets the segment fraction for this location
+ /** \brief
+ * Gets the segment fraction for this location.
* @return the segment fraction
double getSegmentFraction() const;
- * Tests whether this location refers to a vertex
+ /** \brief
+ * Tests whether this location refers to a vertex.
* @return true if the location is a vertex
bool isVertex() const;
- * Gets the {@link Coordinate} along the
- * given linear {@link Geometry} which is
- * referenced by this location.
+ /** \brief
+ * Gets the [Coordinate](@ref geom::Coordinate) along the given linear
+ * [Geometry](@ref geom::Geometry) which is referenced by this location.
* @param linearGeom the linear geometry referenced by this location
- * @return the <tt>Coordinate</tt> at the location
+ * @return the Coordinate at the location
geom::Coordinate getCoordinate(const geom::Geometry* linearGeom) const;
- * Gets a {@link LineSegment} representing the segment of the
- * given linear {@link Geometry} which contains this location.
+ /** \brief
+ * Gets a [LineSegment](@ref geom::LineSegment) representing the segment of the
+ * given linear [Geometry](@ref geom::Geometry) which contains this location.
- * @return the <tt>LineSegment</tt> containing the location
+ * @return the LineSegment containing the location
std::unique_ptr<geom::LineSegment> getSegment(const geom::Geometry* linearGeom) const;
+ /** \brief
* Tests whether this location refers to a valid
- * location on the given linear {@link Geometry}.
+ * location on the given linear [Geometry](@ref geom::Geometry).
* @return true if this location is valid
bool isValid(const geom::Geometry* linearGeom) const;
- * Compares this object with the specified object for order.
+ /** \brief
+ * Compares this object with the specified object for order.
- *@param other the <code>LineStringLocation</code> with which this <code>Coordinate</code>
- * is being compared
- *@return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
- * is less than, equal to, or greater than the specified <code>LineStringLocation</code>
+ * @param other the LinearLocation with which this Coordinate is being compared
+ * @return a negative integer, zero, or a positive integer as this
+ * LinearLocation is less than, equal to, or greater than
+ * the specified LinearLocation
int compareTo(const LinearLocation& other) const;
+ /** \brief
* Compares this object with the specified index values for order.
* @param componentIndex1 a component index
* @param segmentIndex1 a segment index
* @param segmentFraction1 a segment fraction
- * @return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
- * is less than, equal to, or greater than the specified locationValues
+ * @return a negative integer, zero, or a positive integer as this LinearLocation
+ * is less than, equal to, or greater than the specified locationValues
int compareLocationValues(size_t componentIndex1, size_t segmentIndex1, double segmentFraction1) const;
+ /** \brief
* Compares two sets of location values for order.
* @param componentIndex0 a component index
@@ -209,17 +212,17 @@ public:
* @param componentIndex1 another component index
* @param segmentIndex1 another segment index
* @param segmentFraction1 another segment fraction
- * as the first set of location values
- * is less than, equal to, or greater than the second set of locationValues
+ * as the first set of location values
+ * is less than, equal to, or greater than the second set of locationValues
static int compareLocationValues(
size_t componentIndex0, size_t segmentIndex0, double segmentFraction0,
size_t componentIndex1, size_t segmentIndex1, double segmentFraction1);
- * Tests whether two locations
- * are on the same segment in the parent {@link Geometry}.
+ /** \brief
+ * Tests whether two locations are on the same
+ * segment in the parent [Geometry](@ref geom::Geometry).
* @param loc a location on the same geometry
* @return true if the locations are on the same segment of the parent geometry
diff --git a/include/geos/linearref/LocationIndexOfLine.h b/include/geos/linearref/LocationIndexOfLine.h
index ea179d2..f7a3b3d 100644
--- a/include/geos/linearref/LocationIndexOfLine.h
+++ b/include/geos/linearref/LocationIndexOfLine.h
@@ -27,37 +27,38 @@
namespace geos {
- * Determines the location of a subline along a linear {@link Geometry}.
+/** \brief
+ * Determines the location of a subline along a linear [Geometry](@ref geom::Geometry).
* The location is reported as a pair of {@link LinearLocation}s.
- * <p>
- * <b>Note:</b> Currently this algorithm is not guaranteed to
- * return the correct substring in some situations where
- * an endpoint of the test line occurs more than once in the input line.
- * (However, the common case of a ring is always handled correctly).
+ * @note Currently this algorithm is not guaranteed to
+ * return the correct substring in some situations where
+ * an endpoint of the test line occurs more than once in the input line.
+ * (However, the common case of a ring is always handled correctly).
class LocationIndexOfLine {
- * MD - this algorithm has been extracted into a class
- * because it is intended to validate that the subline truly is a subline,
- * and also to use the internal vertex information to unambiguously locate the subline.
+ * MD - this algorithm has been extracted into a class
+ * because it is intended to validate that the subline truly is a subline,
+ * and also to use the internal vertex information to unambiguously locate the subline.
private:
const geom::Geometry* linearGeom;
public:
/** \brief
- * The location is reported as a pair of {@link LinearLocation}s.
+ * The location is reported as a pair of [LinearLocations](@ref LinearLocation).
- * Caller must take of releasing with delete[]
+ * @note Caller must take of releasing with delete[]
static LinearLocation* indicesOf(const geom::Geometry* linearGeom, const geom::Geometry* subLine);
diff --git a/include/geos/linearref/LocationIndexOfPoint.h b/include/geos/linearref/LocationIndexOfPoint.h
index 330ac85..6036edb 100644
--- a/include/geos/linearref/LocationIndexOfPoint.h
+++ b/include/geos/linearref/LocationIndexOfPoint.h
@@ -28,12 +28,12 @@
namespace geos {
- * Computes the {@link LinearLocation} of the point
- * on a linear {@link Geometry} nearest a given {@link Coordinate}.
- * The nearest point is not necessarily unique; this class
- * always computes the nearest point closest to
- * the start of the geometry.
+/** \brief
+ * Computes the LinearLocation of the point on a linear [Geometry](@ref geom::Geometry)
+ * nearest a given [Coordinate](@ref geom::Coordinate).
+ * The nearest point is not necessarily unique; this class always computes
+ * the nearest point closest to the start of the geometry.
class LocationIndexOfPoint {
@@ -50,26 +50,26 @@ public:
LocationIndexOfPoint(const geom::Geometry* linearGeom);
- * Find the nearest location along a linear {@link Geometry} to a given point.
+ /** \brief
+ * Find the nearest location along a linear [Geometry](@ref geom::Geometry)
+ * to a given point.
* @param inputPt the coordinate to locate
* @return the location of the nearest point
LinearLocation indexOf(const geom::Coordinate& inputPt) const;
- * Find the nearest {@link LinearLocation} along the linear {@link Geometry}
- * to a given {@link Coordinate}
- * after the specified minimum {@link LinearLocation}.
+ /** \brief
+ * Find the nearest LinearLocation along the linear [Geometry](@ref geom::Geometry)
+ * to a given [Coordinate](@ref geom::Coordinate) after the specified minimum LinearLocation.
* If possible the location returned will be strictly greater than the
- * <code>minLocation</code>.
- * If this is not possible, the
- * value returned will equal <code>minLocation</code>.
- * (An example where this is not possible is when
- * minLocation = [end of line] ).
+ * `minLocation`.
+ * If this is not possible, the value returned will equal `minLocation`.
+ * (An example where this is not possible is when `minLocation = [end of line]`).
- * @param minLocation the minimum location for the point location
+ * @param minIndex the minimum location for the point location
LinearLocation indexOfAfter(const geom::Coordinate& inputPt, const LinearLocation* minIndex) const;
diff --git a/include/geos/linearref/LocationIndexedLine.h b/include/geos/linearref/LocationIndexedLine.h
index 1dd90d6..bd65911 100644
--- a/include/geos/linearref/LocationIndexedLine.h
+++ b/include/geos/linearref/LocationIndexedLine.h
@@ -33,9 +33,9 @@ namespace linearref { // geos::linearref
* \brief
- * using {@link LinearLocation}s as the index.
+ * [Geometry](@ref geom::Geometry) using
+ * [LinearLocations](@ref LinearLocation) as the index.
class GEOS_DLL LocationIndexedLine {
private:
@@ -54,9 +54,9 @@ public:
* \brief
* Constructs an object which allows linear referencing along
- * a given linear {@link Geometry}.
+ * a given linear [Geometry](@ref geom::Geometry).
- * @param linearGeom the linear geometry to reference along
+ * @param p_linearGeom the linear geometry to reference along
LocationIndexedLine(const geom::Geometry* p_linearGeom)
: linearGeom(p_linearGeom)
@@ -66,7 +66,7 @@ public:
* \brief
@@ -86,7 +86,7 @@ public:
* \brief
@@ -99,7 +99,7 @@ public:
geom::Coordinate
@@ -115,7 +115,7 @@ public:
* \brief
@@ -249,7 +249,7 @@ public:
bool
isValidIndex(const LinearLocation& index) const
diff --git a/include/geos/noding/BasicSegmentString.h b/include/geos/noding/BasicSegmentString.h
index aad4bc0..f5a5342 100644
--- a/include/geos/noding/BasicSegmentString.h
+++ b/include/geos/noding/BasicSegmentString.h
@@ -37,24 +37,22 @@ namespace algorithm {
namespace geos {
namespace noding { // geos.noding
- * Represents a list of contiguous line segments,
- * and supports noding the segments.
- * The line segments are represented by an array of {@link Coordinate}s.
- * Intended to optimize the noding of contiguous segments by
- * reducing the number of allocated objects.
- * SegmentStrings can carry a context object, which is useful
- * for preserving topological or parentage information.
+/** \brief
+ * Represents a list of contiguous line segments, and supports noding the segments.
+ * The line segments are represented by an array of [Coordinates](@ref geom::Coordinate).
+ * Intended to optimize the noding of contiguous segments by reducing the number
+ * of allocated objects. SegmentStrings can carry a context object, which is
+ * useful for preserving topological or parentage information.
* All noded substrings are initialized with the same context object.
class GEOS_DLL BasicSegmentString : public SegmentString {
public:
- /// Construct a BasicSegmentString.
- /// @param newPts CoordinateSequence representing the string,
- /// externally owned
+ /// \brief Construct a BasicSegmentString.
+ /// @param newPts CoordinateSequence representing the string, externally owned
/// @param newContext the context associated to this SegmentString
BasicSegmentString(geom::CoordinateSequence* newPts,
@@ -67,23 +65,23 @@ public:
~BasicSegmentString() override
- /// see dox in SegmentString.h
+ // see dox in SegmentString.h
size_t
size() const override
return pts->size();
const geom::Coordinate& getCoordinate(size_t i) const override;
+ /// @see SegmentString::getCoordinates() const
geom::CoordinateSequence* getCoordinates() const override;
bool isClosed() const override;
std::ostream& print(std::ostream& os) const override;
/** \brief
diff --git a/include/geos/noding/FastNodingValidator.h b/include/geos/noding/FastNodingValidator.h
index 9347007..de9184e 100644
--- a/include/geos/noding/FastNodingValidator.h
+++ b/include/geos/noding/FastNodingValidator.h
@@ -42,10 +42,10 @@ namespace noding { // geos.noding
* Indexing is used to improve performance.
* By default validation stops after a single
* non-noded intersection is detected.
- * Alternatively, it can be requested to detect all intersections
- * by using {@link #setFindAllIntersections(boolean)}.
+ * Alternatively, it can be requested to detect all intersections by
+ * using `setFindAllIntersections(boolean)`.
-* The validator does not check for topology collapse situations
+ * The validator does not check for topology collapse situations
* (e.g. where two segment strings are fully co-incident).
* The validator checks for the following situations which indicated incorrect noding:
@@ -54,7 +54,7 @@ namespace noding { // geos.noding
* - Intersections at an interior vertex (i.e. with an endpoint or another interior vertex)
* The client may either test the {@link #isValid()} condition,
- * or request that a suitable {@link TopologyException} be thrown.
+ * or request that a suitable [TopologyException](@ref util::TopologyException) be thrown.
class FastNodingValidator {
@@ -70,7 +70,7 @@ public:
+ /** \brief
* Checks for an intersection and
* reports if one is found.
@@ -83,7 +83,7 @@ public:
return isValidVar;
+ /** \brief
* Returns an error message indicating the segments containing
* the intersection.
@@ -91,7 +91,7 @@ public:
std::string getErrorMessage() const;
+ /** \brief
* Checks for an intersection and throws
* a TopologyException if one is found.
diff --git a/include/geos/noding/FastSegmentSetIntersectionFinder.h b/include/geos/noding/FastSegmentSetIntersectionFinder.h
index 6a4770e..91bbb42 100644
--- a/include/geos/noding/FastSegmentSetIntersectionFinder.h
+++ b/include/geos/noding/FastSegmentSetIntersectionFinder.h
@@ -39,7 +39,7 @@ namespace geos {
namespace noding { // geos::noding
/** \brief
- * Finds if two sets of {@link SegmentStrings}s intersect.
+ * Finds if two sets of [SegmentStrings](@ref noding::SegmentString) intersect.
* Uses indexing for fast performance and to optimize repeated tests
* against a target set of lines.
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index 79cca47..89a2549 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -46,13 +46,15 @@ class LineIntersector;
namespace geos {
+/** \brief
* Computes the intersections between two line segments in SegmentString
* and adds them to each string.
- * The {@link SegmentIntersector} is passed to a {@link Noder}.
- * The {@link addIntersections} method is called whenever the {@link Noder}
- * detects that two SegmentStrings <i>might</i> intersect.
- * This class is an example of the <i>Strategy</i> pattern.
+ * The SegmentIntersector is passed to a Noder.
+ * The NodedSegmentString::addIntersections(algorithm::LineIntersector* li, size_t segmentIndex, size_t geomIndex)
+ * method is called whenever the Noder
+ * detects that two SegmentStrings *might* intersect.
+ * This class is an example of the *Strategy* pattern.
class GEOS_DLL IntersectionAdder: public SegmentIntersector {
@@ -118,7 +120,7 @@ public:
- * @return the proper intersection point, or <code>NULL</code>
+ * @return the proper intersection point, or `NULL`
* if none was found
const geom::Coordinate*
@@ -133,13 +135,14 @@ public:
return hasIntersectionVar;
+ /** \brief
* A proper intersection is an intersection which is interior to
- * at least two line segments. Note that a proper intersection
- * is not necessarily in the interior of the entire Geometry,
- * since another edge may have an endpoint equal to the intersection,
- * which according to SFS semantics can result in the point being
- * on the Boundary of the Geometry.
+ * at least two line segments.
+ * Note that a proper intersection is not necessarily in the interior
+ * of the entire Geometry, since another edge may have an endpoint equal
+ * to the intersection, which according to SFS semantics can result in
+ * the point being on the Boundary of the Geometry.
bool
hasProperIntersection()
@@ -147,10 +150,9 @@ public:
return hasProper;
+ /** \brief
* A proper interior intersection is a proper intersection which is
- * <b>not</b> contained in the set of boundary nodes set for this
- * SegmentIntersector.
+ * *not* contained in the set of boundary nodes set for this SegmentIntersector.
bool
hasProperInteriorIntersection()
@@ -158,7 +160,7 @@ public:
return hasProperInterior;
+ /** \brief
* An interior intersection is an intersection which is
* in the interior of some segment.
@@ -169,11 +171,10 @@ public:
- * This method is called by clients
- * of the {@link SegmentIntersector} class to process
- * intersections for two segments of the SegmentStrings being
- * intersected.
+ /** \brief
+ * This method is called by clients of the SegmentIntersector class to
+ * process intersections for two segments of the SegmentStrings being intersected.
* Note that some clients (such as MonotoneChains) may optimize away
* this call for segment pairs which they have determined do not
* intersect (e.g. by an disjoint envelope test).
@@ -189,8 +190,8 @@ public:
return (i1 > i2 ? i1 - i2 : i2 - i1) == 1;
- * Always process all intersections
+ /** \brief
+ * Always process all intersections.
* @return false always
diff --git a/include/geos/noding/IntersectionFinderAdder.h b/include/geos/noding/IntersectionFinderAdder.h
index f18dec2..198fb4d 100644
--- a/include/geos/noding/IntersectionFinderAdder.h
+++ b/include/geos/noding/IntersectionFinderAdder.h
@@ -54,7 +54,7 @@ class GEOS_DLL IntersectionFinderAdder: public SegmentIntersector {
public:
+ /** \brief
* Creates an intersection finder which finds all proper intersections
* and stores them in the provided Coordinate array
@@ -68,12 +68,12 @@ public:
interiorIntersections(v)
- * intersections for two segments of the {@link SegmentStrings}
- * being intersected.
- * Note that some clients (such as {@link MonotoneChain}s) may
+ /** \brief
+ * class to process intersections for two segments of the
+ * {@link SegmentString}s being intersected.
+ * Note that some clients (such as `MonotoneChains`) may
* optimize away this call for segment pairs which they have
* determined do not intersect
* (e.g. by an disjoint envelope test).
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index 90cb2ea..54d0c37 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
@@ -48,7 +48,7 @@ namespace noding { // geos::noding
* intersections are detected.
* Iterated noding using a FLOATING precision model is not guaranteed to converge,
- * due to roundoff error. This problem is detected and an exception is thrown.
+ * due to roundoff error. This problem is detected and an exception is thrown.
* Clients can choose to rerun the noding using a lower precision model.
@@ -82,9 +82,10 @@ public:
~IteratedNoder() override {}
+ /** \brief
* Sets the maximum number of noding iterations performed before
* the noding is aborted.
* Experience suggests that this should rarely need to be changed
* from the default.
* The default is MAX_ITER.
@@ -104,13 +105,13 @@ public:
- * Fully nodes a list of {@link SegmentStrings}, i.e. peforms noding iteratively
+ /** \brief
+ * Fully nodes a list of {@link SegmentString}s, i.e. peforms noding iteratively
* until no intersections are found between segments.
- * Maintains labelling of edges correctly through
- * the noding.
- * @param segStrings a collection of SegmentStrings to be noded
+ * Maintains labelling of edges correctly through the noding.
+ * @param inputSegmentStrings a collection of SegmentStrings to be noded
* @throws TopologyException if the iterated noding fails to converge.
void computeNodes(std::vector<SegmentString*>* inputSegmentStrings) override; // throw(GEOSException);
diff --git a/include/geos/noding/MCIndexNoder.h b/include/geos/noding/MCIndexNoder.h
index d5ba28c..00d2431 100644
--- a/include/geos/noding/MCIndexNoder.h
+++ b/include/geos/noding/MCIndexNoder.h
@@ -52,11 +52,12 @@ namespace noding { // geos.noding
/** \brief
* Nodes a set of SegmentString using a index based
- * on index::chain::MonotoneChain and a index::SpatialIndex.
+ * on [MonotoneChain](@ref index::chain::MonotoneChain)
+ * and a [SpatialIndex](@ref index::SpatialIndex).
- * The {@link SpatialIndex} used should be something that supports
- * envelope (range) queries efficiently (such as a index::quadtree::Quadtree
- * or index::strtree::STRtree.
+ * The [SpatialIndex](@ref index::SpatialIndex) used should be something that supports
+ * envelope (range) queries efficiently (such as a [Quadtree](@ref index::quadtree::Quadtree)
+ * or [STRtree](@ref index::strtree::STRtree)).
* Last port: noding/MCIndexNoder.java rev. 1.4 (JTS-1.7)
@@ -86,7 +87,7 @@ public:
~MCIndexNoder() override;
- /// Return a reference to this instance's std::vector of MonotoneChains
+ /// \brief Return a reference to this instance's std::vector of MonotoneChains
std::vector<index::chain::MonotoneChain*>&
getMonotoneChains()
diff --git a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
index aed9dc5..888e837 100644
--- a/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
+++ b/include/geos/noding/MCIndexSegmentSetMutualIntersector.h
@@ -46,8 +46,9 @@ namespace geos {
/** \brief
- * Intersects two sets of {@link SegmentStrings} using a index based
- * on {@link MonotoneChain}s and a {@link SpatialIndex}.
+ * Intersects two sets of [SegmentStrings](@ref SegmentString) using a index based
+ * on [MonotoneChains](@ref index::chain::MonotoneChain) and a
+ * [SpatialIndex](@ref index::SpatialIndex).
* @version 1.7
@@ -99,9 +100,9 @@ private:
MonoChains monoChains;
- * envelope (range) queries efficiently (such as a {@link Quadtree}
- * or {@link STRtree}.
+ * The index::SpatialIndex used should be something that supports
+ * envelope (range) queries efficiently (such as a index::quadtree::Quadtree
+ * or index::strtree::STRtree).
index::SpatialIndex* index;
int indexCounter;
diff --git a/include/geos/noding/NodedSegmentString.h b/include/geos/noding/NodedSegmentString.h
index 55eadc5..6db0d2d 100644
--- a/include/geos/noding/NodedSegmentString.h
+++ b/include/geos/noding/NodedSegmentString.h
@@ -46,7 +46,7 @@ namespace noding { // geos::noding
@@ -86,14 +86,14 @@ public:
const SegmentString::NonConstVect& segStrings);
+ /** \brief
* Creates a new segment string from a list of vertices.
* @param newPts CoordinateSequence representing the string,
* ownership transferred.
* @param newContext the user-defined data of this segment string
- * (may be null)
+ * (may be null)
NodedSegmentString(geom::CoordinateSequence* newPts, const void* newContext)
: NodableSegmentString(newContext)
@@ -106,8 +106,9 @@ public:
delete pts;
+ /** \brief
* Adds an intersection node for a given point and segment to this segment string.
* If an intersection already exists for this exact location, the existing
* node will be returned.
@@ -161,13 +162,13 @@ public:
* Gets the octant of the segment starting at vertex index.
* @param index the index of the vertex starting the segment.
- * Must not be the last index in the vertex list
+ * Must not be the last index in the vertex list
* @return the octant of the segment at the vertex
int getSegmentOctant(size_t index) const;
/** \brief
- * Add {SegmentNode}s for one or both
+ * Add {@link SegmentNode}s for one or both
* intersections found for a segment of an edge to the edge
* intersection list.
diff --git a/include/geos/noding/Noder.h b/include/geos/noding/Noder.h
index 41625d0..dd292fd 100644
--- a/include/geos/noding/Noder.h
+++ b/include/geos/noding/Noder.h
@@ -36,8 +36,8 @@ namespace noding { // geos.noding
/** \brief
* Computes all intersections between segments in a set of SegmentString.
- * Intersections found are represented as {@link SegmentNode}s and added to the
- * {@link SegmentString}s in which they occur.
+ * Intersections found are represented as [SegmentNodes](@ref SegmentNode) and
+ * added to the [SegmentStrings](@ref SegmentString) in which they occur.
* As a final step in the noding a new set of segment strings split
* at the nodes may be returned.
@@ -49,7 +49,7 @@ namespace noding { // geos.noding
class GEOS_DLL Noder {
public:
/** \brief
- * Computes the noding for a collection of {@link SegmentString}s.
+ * Computes the noding for a collection of [SegmentStrings](@ref SegmentString).
* Some Noders may add all these nodes to the input SegmentStrings;
* others may only add some or none at all.
@@ -59,7 +59,7 @@ public:
virtual void computeNodes(std::vector<SegmentString*>* segStrings) = 0;
/** \brief
- * Returns a {@link Collection} of fully noded {@link SegmentStrings}.
+ * Returns a collection of fully noded [SegmentStrings](@ref SegmentString).
* The SegmentStrings have the same context as their parent.
* @return a newly allocated std::vector of const SegmentStrings.
diff --git a/include/geos/noding/NodingIntersectionFinder.h b/include/geos/noding/NodingIntersectionFinder.h
index dbf9471..a45f7c1 100644
--- a/include/geos/noding/NodingIntersectionFinder.h
+++ b/include/geos/noding/NodingIntersectionFinder.h
@@ -39,7 +39,7 @@ namespace noding { // geos.noding
* Non-noded intersections include:
* - intersections which lie in the interior of a segment
- * - intersections at a vertex in the interior of a {@link SegmentString}
+ * - intersections at a vertex in the interior of a SegmentString
* (e.g. with a segment string endpoint or other interior vertex)
* @version 1.7
@@ -88,7 +88,7 @@ public:
return interiorIntersection;
+ /** \brief
* Gets the count of intersections found.
* @return the intersection count
@@ -99,15 +99,16 @@ public:
return intersectionCount;
- * Sets whether only end segments should be tested for interior intersection.
- * This is a performance optimization that may be used if
- * the segments have been previously noded by an appropriate algorithm.
- * It may be known that any potential noding failures will occur only in
- * end segments.
+ /** \brief
+ * Sets whether only end segments should be tested for interior intersection.
+ * This is a performance optimization that may be used if the segments
+ * have been previously noded by an appropriate algorithm.
+ * It may be known that any potential noding failures will occur only in
+ * end segments.
* @param isCESO whether to test only end segments
void
setCheckEndSegmentsOnly(bool isCESO)
@@ -115,15 +116,16 @@ public:
- * Sets whether all intersections should be computed.
- * When this is <code>false</code> (the default value)
- * the value of {@link #isDone()} is <code>true</code> after the first intersection is found.
- * <p>
- * Default is <code>false</code>.
- * @param findAllIntersections whether all intersections should be computed
+ /** \brief
+ * Sets whether all intersections should be computed.
+ * When this is `false` (the default value) the value of
+ * #isDone() is `true` after the first intersection is found.
+ * Default is `false`.
+ * @param fAI whether all intersections should be computed
void
setFindAllIntersections(bool fAI)
@@ -142,11 +144,11 @@ public:
/** \brief
- * intersections for two segments of the {@link SegmentStrings} being intersected.
+ * This method is called by clients of the SegmentIntersector class to process
+ * intersections for two segments of the [SegmentStrings](@ref SegmentString)
+ * being intersected.
- * Note that some clients (such as {@link MonotoneChain}s) may optimize away
+ * @note Some clients (such as `MonotoneChains`) may optimize away
* this call for segment pairs which they have determined do not intersect
@@ -173,48 +175,49 @@ private:
NodingIntersectionFinder(const NodingIntersectionFinder& other) = delete;
NodingIntersectionFinder& operator=(const NodingIntersectionFinder& rhs) = delete;
- * Tests if two vertices with at least one in a segmentString interior
- * are equal.
- * @param p0 a segment vertex
- * @param p1 a segment vertex
- * @param isEnd0 true if vertex is a segmentString endpoint
- * @param isEnd1 true if vertex is a segmentString endpoint
- * @return true if an intersection is found
+ /** \brief
+ * Tests if two vertices with at least one in a segmentString interior
+ * are equal.
+ * @param p0 a segment vertex
+ * @param p1 a segment vertex
+ * @param isEnd0 true if vertex is a segmentString endpoint
+ * @param isEnd1 true if vertex is a segmentString endpoint
+ * @return true if an intersection is found
bool isInteriorVertexIntersection(
bool isEnd0, bool isEnd1);
- * Tests if an intersection occurs between a segmentString interior vertex and another vertex.
- * Note that intersections between two endpoint vertices are valid noding,
- * and are not flagged.
- * @param p00 a segment vertex
- * @param p01 a segment vertex
- * @param p10 a segment vertex
- * @param p11 a segment vertex
- * @param isEnd00 true if vertex is a segmentString endpoint
- * @param isEnd01 true if vertex is a segmentString endpoint
- * @param isEnd10 true if vertex is a segmentString endpoint
- * @param isEnd11 true if vertex is a segmentString endpoint
+ /** \brief
+ * Tests if an intersection occurs between a SegmentString interior vertex and another vertex.
+ * @note intersections between two endpoint vertices are valid noding,
+ * and are not flagged.
+ * @param p00 a segment vertex
+ * @param p01 a segment vertex
+ * @param p10 a segment vertex
+ * @param p11 a segment vertex
+ * @param isEnd00 true if vertex is a segmentString endpoint
+ * @param isEnd01 true if vertex is a segmentString endpoint
+ * @param isEnd10 true if vertex is a segmentString endpoint
+ * @param isEnd11 true if vertex is a segmentString endpoint
const geom::Coordinate& p00, const geom::Coordinate& p01,
const geom::Coordinate& p10, const geom::Coordinate& p11,
bool isEnd00, bool isEnd01, bool isEnd10, bool isEnd11);
- * Tests whether a segment in a {@link SegmentString} is an end segment.
- * (either the first or last).
- * @param segStr a segment string
- * @param index the index of a segment in the segment string
- * @return true if the segment is an end segment
+ /** \brief
+ * Tests whether a segment in a SegmentString is an end segment.
+ * (either the first or last).
+ * @param segStr a segment string
+ * @param index the index of a segment in the segment string
+ * @return true if the segment is an end segment
bool isEndSegment(const SegmentString* segStr, size_t index);
diff --git a/include/geos/noding/OrientedCoordinateArray.h b/include/geos/noding/OrientedCoordinateArray.h
index 43eb97f..dead361 100644
--- a/include/geos/noding/OrientedCoordinateArray.h
+++ b/include/geos/noding/OrientedCoordinateArray.h
@@ -50,7 +50,7 @@ public:
* Creates a new {@link OrientedCoordinateArray}
* for the given {@link geom::CoordinateSequence}.
- * @param pts the coordinates to orient
+ * @param p_pts the coordinates to orient
OrientedCoordinateArray(const geom::CoordinateSequence& p_pts)
diff --git a/include/geos/noding/SegmentIntersectionDetector.h b/include/geos/noding/SegmentIntersectionDetector.h
index c892d83..402f9d5 100644
--- a/include/geos/noding/SegmentIntersectionDetector.h
+++ b/include/geos/noding/SegmentIntersectionDetector.h
this->findAllTypes = p_findAllTypes;
+ /** \brief
* Tests whether an intersection was found.
* @return true if an intersection was found
@@ -97,10 +97,10 @@ public:
return _hasIntersection;
+ /** \brief
* Tests whether a proper intersection was found.
- * @return true if a proper intersection was found
+ * @return `true` if a proper intersection was found
bool
hasProperIntersection() const
@@ -108,7 +108,7 @@ public:
return _hasProperIntersection;
+ /** \brief
* Tests whether a non-proper intersection was found.
* @return true if a non-proper intersection was found
@@ -119,7 +119,7 @@ public:
return _hasNonProperIntersection;
+ /** \brief
* Gets the computed location of the intersection.
* Due to round-off, the location may not be exact.
@@ -132,7 +132,7 @@ public:
+ /** \brief
* Gets the endpoints of the intersecting segments.
* @return an array of the segment endpoints (p00, p01, p10, p11)
@@ -160,13 +160,13 @@ public:
- * this call for segment pairs which they have determined do not intersect
- * (e.g. by an disjoint envelope test).
+ /** \brief
+ * intersections for two segments of the {@link SegmentString}s being intersected.
+ * this call for segment pairs which they have determined do not intersect
+ * (e.g. by an disjoint envelope test).
void processIntersections(noding::SegmentString* e0, size_t segIndex0,
noding::SegmentString* e1, size_t segIndex1) override;
diff --git a/include/geos/noding/SegmentSetMutualIntersector.h b/include/geos/noding/SegmentSetMutualIntersector.h
index 0da42e0..56e9714 100644
--- a/include/geos/noding/SegmentSetMutualIntersector.h
+++ b/include/geos/noding/SegmentSetMutualIntersector.h
@@ -45,11 +45,11 @@ public:
~SegmentSetMutualIntersector() {}
- * Sets the {@link SegmentIntersector} to use with this intersector.
+ * Sets the SegmentIntersector to use with this intersector.
* The SegmentIntersector will either rocord or add intersection nodes
* for the input segment strings.
- * @param segInt the segment intersector to use
+ * @param si the segment intersector to use
void
setSegmentIntersector(SegmentIntersector* si)
@@ -59,14 +59,14 @@ public:
- * @param segStrings a collection of {@link SegmentString}s to node
+ * @param segStrings a collection of [SegmentStrings](@ref SegmentString) to node
virtual void setBaseSegments(SegmentString::ConstVect* segStrings) = 0;
- * Computes the intersections for two collections of {@link SegmentString}s.
+ * Computes the intersections for two collections of [SegmentStrings](@ref SegmentString).
- * @param segStrings1 a collection of {@link SegmentString}s to node
virtual void process(SegmentString::ConstVect* segStrings) = 0;
diff --git a/include/geos/noding/SegmentString.h b/include/geos/noding/SegmentString.h
index 4b64e72..407efa7 100644
--- a/include/geos/noding/SegmentString.h
+++ b/include/geos/noding/SegmentString.h
@@ -51,8 +51,8 @@ public:
friend std::ostream& operator<< (std::ostream& os,
const SegmentString& ss);
- /// Construct a SegmentString.
+ /// \brief Construct a SegmentString.
SegmentString(const void* newContext)
@@ -63,7 +63,7 @@ public:
virtual
~SegmentString() {}
+ /** \brief
* Gets the user-defined data for this segment string.
* @return the user-defined data
@@ -74,7 +74,7 @@ public:
return context;
+ /** \brief
* Sets the user-defined data for this segment string.
* @param data an Object containing user-defined data
@@ -94,7 +94,7 @@ public:
/// Return a pointer to the CoordinateSequence associated
/// with this SegmentString.
- /// Note that the CoordinateSequence is owned by this SegmentString!
+ /// @note The CoordinateSequence is owned by this SegmentString!
virtual geom::CoordinateSequence* getCoordinates() const = 0;
diff --git a/include/geos/noding/SegmentStringUtil.h b/include/geos/noding/SegmentStringUtil.h
index a745817..5dddbce 100644
--- a/include/geos/noding/SegmentStringUtil.h
+++ b/include/geos/noding/SegmentStringUtil.h
@@ -37,12 +37,12 @@ namespace noding { // geos::noding
class SegmentStringUtil {
public:
/** \brief
- * Extracts all linear components from a given {@link Geometry}
- * to {@link SegmentString}s.
+ * Extracts all linear components from a given [Geometry](@ref geom::Geometry)
+ * to [SegmentStrings](@ref SegmentString)
* The SegmentString data item is set to be the source Geometry.
- * @param geom the geometry to extract from
+ * @param g the geometry to extract from
* @param segStr a List of SegmentStrings (output parameter).
* Ownership of elements pushed to the vector
* is transferred to caller.
diff --git a/include/geos/noding/SinglePassNoder.h b/include/geos/noding/SinglePassNoder.h
index 5a800d5..f185ad0 100644
--- a/include/geos/noding/SinglePassNoder.h
+++ b/include/geos/noding/SinglePassNoder.h
@@ -35,10 +35,11 @@ namespace geos {
+/** \brief
* Base class for {@link Noder}s which make a single
* pass to find intersections.
- * This allows using a custom {@link SegmentIntersector}
+ * This allows using a custom SegmentIntersector
* (which for instance may simply identify intersections, rather than
* insert them).
@@ -60,8 +61,9 @@ public:
~SinglePassNoder() override {}
+ /** \brief
* Sets the SegmentIntersector to use with this noder.
* A SegmentIntersector will normally add intersection nodes
* to the input segment strings, but it may not - it may
* simply record the presence of intersections.
@@ -75,15 +77,16 @@ public:
segInt = newSegInt;
+ /** \brief
void computeNodes(std::vector<SegmentString*>* segStrings) override = 0;
+ /** \brief
+ * Returns a Collection of fully noded {@link SegmentString}s.
* @return a Collection of SegmentStrings
diff --git a/include/geos/noding/snapround/MCIndexPointSnapper.h b/include/geos/noding/snapround/MCIndexPointSnapper.h
index 15dbc30..722ef1a 100644
--- a/include/geos/noding/snapround/MCIndexPointSnapper.h
+++ b/include/geos/noding/snapround/MCIndexPointSnapper.h
@@ -42,8 +42,8 @@ namespace noding { // geos::noding
namespace snapround { // geos::noding::snapround
/** \brief
- * "Snaps" all {@link SegmentString}s in a {@link SpatialIndex} containing
- * {@link MonotoneChain}s to a given {@link HotPixel}.
+ * "Snaps" all [SegmentStrings](@ref SegmentString) in a [SpatialIndex](@ref index::SpatialIndex) containing
+ * [MonotoneChains](@ref index::chain::MonotoneChain) to a given HotPixel.
class GEOS_DLL MCIndexPointSnapper {
@@ -56,17 +56,17 @@ public:
index(nIndex)
+ /** \brief
* Snaps (nodes) all interacting segments to this hot pixel.
- * The hot pixel may represent a vertex of an edge,
- * in which case this routine uses the optimization
- * of not noding the vertex itself
+ * The hot pixel may represent a vertex of an edge, in which case this
+ * routine uses the optimization of not noding the vertex itself.
* @param hotPixel the hot pixel to snap to
* @param parentEdge the edge containing the vertex,
- * if applicable, or <code>null</code>
+ * if applicable, or `null`
* @param vertexIndex the index of the vertex, if applicable, or -1
- * @return <code>true</code> if a node was added for this pixel
+ * @return `true` if a node was added for this pixel
bool snap(HotPixel& hotPixel, SegmentString* parentEdge,
diff --git a/include/geos/opOverlay.h b/include/geos/opOverlay.h
index 4aefaae..41a24c2 100644
--- a/include/geos/opOverlay.h
+++ b/include/geos/opOverlay.h
@@ -24,7 +24,8 @@ namespace operation {
* spatial functions.
* The Overlay Algorithm is used in spatial analysis methods for computing
- * set-theoretic operations (boolean combinations) of input {@link Geometry}s.
+ * set-theoretic operations (boolean combinations) of input
+ * [Geometrys](@ref geom::Geometry).
* The algorithm for computing the overlay uses the intersection operations
* supported by topology graphs.
* To compute an overlay it is necessary to explicitly compute the resultant
diff --git a/include/geos/operation/IsSimpleOp.h b/include/geos/operation/IsSimpleOp.h
index 0af00d7..2fad86e 100644
--- a/include/geos/operation/IsSimpleOp.h
+++ b/include/geos/operation/IsSimpleOp.h
@@ -69,15 +69,15 @@ namespace operation { // geos.operation
* This definition relies on the definition of boundary points.
* The SFS uses the Mod-2 rule to determine which points are on the boundary of
- * lineal geometries, but this class supports
- * using other {@link BoundaryNodeRule}s as well.
+ * lineal geometries, but this class supports using other
+ * [BoundaryNodeRules](@ref algorithm::BoundaryNodeRule) as well.
- * Simplicity is defined for each {@link Geometry} subclass as follows:
+ * Simplicity is defined for each [Geometry](@ref geom::Geometry) subclass as follows:
* - Valid polygonal geometries are simple by definition, so
- * <code>isSimple</code> trivially returns true.
+ * `isSimple` trivially returns true.
* (Hint: in order to check if a polygonal geometry has self-intersections,
- * use {@link Geometry::isValid}).
+ * use geom::Geometry::isValid()).
* - Linear geometries are simple iff they do not self-intersect at points
* other than boundary points.
@@ -88,7 +88,7 @@ namespace operation { // geos.operation
* - Zero-dimensional geometries (points) are simple iff they have no
* repeated points.
- * - Empty <code>Geometry</code>s are always simple
+ * - Empty `Geometry`s are always simple
* @see algorithm::BoundaryNodeRule
@@ -124,21 +124,21 @@ public:
IsSimpleOp(const geom::Geometry& geom,
const algorithm::BoundaryNodeRule& boundaryNodeRule);
+ /** \brief
* Tests whether the geometry is simple.
* @return true if the geometry is simple
bool isSimple();
+ /** \brief
* Gets a coordinate for the location where the geometry
- * fails to be simple.
- * (i.e. where it has a non-boundary self-intersection).
+ * fails to be simple (i.e. where it has a non-boundary self-intersection).
* {@link #isSimple} must be called before this method is called.
* @return a coordinate for the location of the non-boundary
- * self-intersection. Ownership retained.
+ * self-intersection. Ownership retained.
* @return the null coordinate if the geometry is simple
@@ -147,7 +147,7 @@ public:
return nonSimpleLocation.get();
+ /** \brief
* Reports whether a geom::LineString is simple.
* @param geom the lineal geometry to test
@@ -157,7 +157,7 @@ public:
bool isSimple(const geom::LineString* geom);
+ /** \brief
* Reports whether a geom::MultiLineString is simple.
@@ -167,7 +167,7 @@ public:
bool isSimple(const geom::MultiLineString* geom);
+ /** \brief
* A MultiPoint is simple iff it has no repeated points
* @deprecated use isSimple()
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index 43e3433..3a0174c 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
* This allows choosing fast but non-robust noding, or slower
* but robust noding.
- * @param noder the noder to use
+ * @param newNoder the noder to use
void
setNoder(noding::Noder* newNoder)
diff --git a/include/geos/operation/buffer/BufferOp.h b/include/geos/operation/buffer/BufferOp.h
index 04cefca..b814d81 100644
--- a/include/geos/operation/buffer/BufferOp.h
+++ b/include/geos/operation/buffer/BufferOp.h
@@ -54,9 +54,9 @@ namespace buffer { // geos.operation.buffer
* the Minkowski sum (or difference) of the geometry
* with a circle with radius equal to the absolute value of the buffer
* distance.
- * In the CAD/CAM world buffers are known as <i>offset curves</i>.
+ * In the CAD/CAM world buffers are known as *offset curves*.
* In morphological analysis the operation of positive and negative buffering
- * is referred to as <i>erosion</i> and <i>dilation</i>.
+ * is referred to as *erosion* and *dilation*.
* The buffer operation always returns a polygonal result.
* The negative or zero-distance buffer of lines and points is always
@@ -80,7 +80,7 @@ class GEOS_DLL BufferOp {
private:
+ /** \brief
* A number of digits of precision which leaves some computational "headroom"
* for floating point operations.
@@ -145,7 +145,7 @@ public:
CAP_SQUARE = BufferParameters::CAP_SQUARE
+ /** \brief
* Computes the buffer for a geometry for a given buffer distance
* and accuracy of approximation.
@@ -153,6 +153,7 @@ public:
* @param distance the buffer distance
* @param quadrantSegments the number of segments used to
* approximate a quarter circle
+ * @param endCapStyle line buffer end cap style (default: BufferParameters::CAP_ROUND)
* @return the buffer of the input geometry
@@ -162,8 +163,8 @@ public:
BufferParameters::DEFAULT_QUADRANT_SEGMENTS,
int endCapStyle = BufferParameters::CAP_ROUND);
- * Initializes a buffer computation for the given geometry
+ /** \brief
+ * Initializes a buffer computation for the given geometry.
* @param g the geometry to buffer
@@ -175,9 +176,9 @@ public:
+ /** \brief
- * with the given set of parameters
+ * with the given set of parameters.
* @param params the buffer parameters to use. This class will
@@ -191,8 +192,9 @@ public:
+ /** \brief
* Specifies the end cap style of the generated buffer.
* The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
* The default is CAP_ROUND.
@@ -200,14 +202,14 @@ public:
inline void setEndCapStyle(int nEndCapStyle);
+ /** \brief
* Sets the number of segments used to approximate a angle fillet
* @param nQuadrantSegments the number of segments in a fillet for a quadrant
inline void setQuadrantSegments(int nQuadrantSegments);
+ /** \brief
* Sets whether the computed buffer should be single-sided.
* A single-sided buffer is constructed on only one side
@@ -222,14 +224,14 @@ public:
* The End Cap Style for single-sided buffers is
* always ignored,
- * and forced to the equivalent of <tt>CAP_FLAT</tt>.
+ * and forced to the equivalent of `CAP_FLAT`.
- * @param isSingleSided true if a single-sided buffer
+ * @param isSingleSided `true` if a single-sided buffer
* should be constructed
inline void setSingleSided(bool isSingleSided);
+ /** \brief
* Returns the buffer computed for a geometry for a given buffer
* distance.
diff --git a/include/geos/operation/buffer/OffsetCurveBuilder.h b/include/geos/operation/buffer/OffsetCurveBuilder.h
index 7588e98..2d3b424 100644
--- a/include/geos/operation/buffer/OffsetCurveBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveBuilder.h
@@ -77,7 +77,7 @@ public:
bufParams(nBufParams)
+ /** \brief
* Gets the buffer parameters being used to generate the curve.
* @return the buffer parameters being used
@@ -88,11 +88,14 @@ public:
return bufParams;
+ /** \brief
* This method handles single points as well as lines.
- * Lines are assumed to <b>not</b> be closed (the function will not
+ * Lines are assumed to **not** be closed (the function will not
* fail for closed lines, but will generate superfluous line caps).
+ * @param inputPts input points
+ * @param distance offset distance
* @param lineList the std::vector to which the newly created
* CoordinateSequences will be pushed_back.
* Caller is responsible to delete these new elements.
@@ -101,12 +104,14 @@ public:
double distance,
std::vector<geom::CoordinateSequence*>& lineList);
+ /** \brief
* @param lineList the std::vector to which newly created
* Caller will be responsible to delete them.
@@ -115,16 +120,19 @@ public:
* @param rightSide indicates that the right side buffer will
* be obtained/skipped
- * NOTE: this is a GEOS extension
+ * @note This is a GEOS extension.
void getSingleSidedLineCurve(const geom::CoordinateSequence* inputPts,
double distance, std::vector<geom::CoordinateSequence*>& lineList,
bool leftSide, bool rightSide) ;
+ /** \brief
* This method handles the degenerate cases of single points and lines,
* as well as rings.
+ * @param side a [Position](@ref geomgraph::Position)
* @param lineList the std::vector to which CoordinateSequences will
* be pushed_back
@@ -141,10 +149,10 @@ private:
const BufferParameters& bufParams;
+ /** \brief
* Use a value which results in a potential distance error which is
- * significantly less than the error due to
- * the quadrant segment discretization.
+ * significantly less than the error due to the quadrant segment discretization.
* For QS = 8 a value of 100 is reasonable.
* This should produce a maximum of 1% distance error.
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index 751f6e4..beb8219 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -188,15 +188,16 @@ public:
* Each offset curve has an attached {@link geomgraph::Label} indicating
* its left and right location.
- * @return a Collection of SegmentStrings representing the raw
- * buffer curves
+ * @return a Collection of SegmentStrings representing the raw buffer curves
std::vector<noding::SegmentString*>& getCurves();
- /// Add raw curves for a set of CoordinateSequences
+ /// \brief Add raw curves for a set of CoordinateSequences.
/// @param lineList is a list of CoordinateSequence, ownership
- /// of which is transferred here.
+ /// of which is transferred here
+ /// @param leftLoc left location
+ /// @param rightLoc right location
void addCurves(const std::vector<geom::CoordinateSequence*>& lineList,
int leftLoc, int rightLoc);
diff --git a/include/geos/operation/distance/ConnectedElementLocationFilter.h b/include/geos/operation/distance/ConnectedElementLocationFilter.h
index 4703cbd..36bff6e 100644
--- a/include/geos/operation/distance/ConnectedElementLocationFilter.h
+++ b/include/geos/operation/distance/ConnectedElementLocationFilter.h
@@ -40,11 +40,11 @@ namespace operation { // geos::operation
namespace distance { // geos::operation::distance
/** \brief
- * A ConnectedElementPointFilter extracts a single point
- * from each connected element in a Geometry
- * (e.g. a polygon, linestring or point)
- * and returns them in a list. The elements of the list are
- * DistanceOp::GeometryLocation.
+ * A ConnectedElementPointFilter extracts a single point from each connected
+ * element in a Geometry (e.g. a polygon, linestring or point) and returns
+ * them in a list.
+ * The elements of the list are GeometryLocation.
class GEOS_DLL ConnectedElementLocationFilter: public geom::GeometryFilter {
private:
@@ -53,11 +53,13 @@ private:
ConnectedElementLocationFilter() = default;
public:
- * Returns a list containing a point from each Polygon, LineString, and Point
- * found inside the specified geometry. Thus, if the specified geometry is
- * not a GeometryCollection, an empty list will be returned. The elements of the list
- * are {@link com.vividsolutions.jts.operation.distance.GeometryLocation}s.
+ /** \brief
+ * Returns a list containing a point from each Polygon, LineString, and
+ * Point found inside the specified geometry.
+ * Thus, if the specified geometry is not a GeometryCollection,
+ * an empty list will be returned. The elements of the list
+ * are [GeometryLocations](@ref operation::distance::GeometryLocation).
static std::vector<std::unique_ptr<GeometryLocation>> getLocations(const geom::Geometry* geom);
diff --git a/include/geos/operation/intersection/Rectangle.h b/include/geos/operation/intersection/Rectangle.h
index 8536581..8f0506c 100644
--- a/include/geos/operation/intersection/Rectangle.h
+++ b/include/geos/operation/intersection/Rectangle.h
@@ -64,7 +64,7 @@ public:
Rectangle(double x1, double y1, double x2, double y2);
- * \@return the minimum x-coordinate of the rectangle
+ * @return the minimum x-coordinate of the rectangle
double
xmin() const
@@ -73,7 +73,7 @@ public:
- * \@return the minimum y-coordinate of the rectangle
+ * @return the minimum y-coordinate of the rectangle
double
@@ -84,7 +84,7 @@ public:
- * \@return the maximum x-coordinate of the rectangle
+ * @return the maximum x-coordinate of the rectangle
double
@@ -95,7 +95,7 @@ public:
- * \@return the maximum y-coordinate of the rectangle
+ * @return the maximum y-coordinate of the rectangle
double
@@ -105,9 +105,9 @@ public:
- * \@return the rectangle as a polygon geometry
+ * @return the rectangle as a polygon geometry
- * Ownership transferred to caller
+ * @note Ownership transferred to caller
geom::Polygon* toPolygon(const geom::GeometryFactory& f) const;
@@ -133,9 +133,9 @@ public:
- * @brief Test if the given position is on a {@link Rectangle] edge
- * @param pos {@link Rectangle} {@link Position}
- * @return true, if the position is on an edge
+ * @brief Test if the given position is on a Rectangle edge
+ * @param pos Rectangle::Position
+ * @return `true`, if the position is on an edge
static bool
@@ -145,10 +145,10 @@ public:
- * @brief Test if the given positions are on the same {@link Rectangle} edge
- * @param pos1 {@link Rectangle} {@link Position} of first coordinate
- * @param pos2 {@link Rectangle} {@link Position} of second coordinate
- * @return true, if the positions are on the same edge
+ * @brief Test if the given positions are on the same Rectangle edge
+ * @param pos1 [Position](@ref Rectangle::Position) of first coordinate
+ * @param pos2 [Position](@ref Rectangle::Position) of second coordinate
+ * @return `true`, if the positions are on the same edge
static bool
@@ -158,10 +158,10 @@ public:
- * @brief Establish position of coordinate with respect to a {@link Rectangle}
+ * @brief Establish position of coordinate with respect to a Rectangle
* @param x x-coordinate
* @param y y-coordinate
- * @return {@link Position} of the coordinate
+ * @return [Position](@ref Rectangle::Position) of the coordinate
Position
@@ -194,8 +194,8 @@ public:
* @brief Next edge in clock-wise direction
- * @return next {@Rectangle} {@link Position} in clock-wise direction
+ * @param pos [Position](@ref Rectangle::Position)
+ * @return next [Position](@ref Rectangle::Position) in clock-wise direction
static Position
diff --git a/include/geos/operation/intersection/RectangleIntersection.h b/include/geos/operation/intersection/RectangleIntersection.h
index aff9d03..d15920f 100644
--- a/include/geos/operation/intersection/RectangleIntersection.h
+++ b/include/geos/operation/intersection/RectangleIntersection.h
@@ -51,7 +51,8 @@ namespace operation { // geos::operation
namespace intersection { // geos::operation::intersection
- * \brief Speed-optimized clipping of a {@link Geometry} with a rectangle.
+ * \brief
+ * Speed-optimized clipping of a [Geometry](@ref geom::Geometry) with a rectangle.
* Two different methods are provided. The first performs normal
* clipping, the second clips the boundaries of polygons, not
@@ -67,35 +68,34 @@ namespace intersection { // geos::operation::intersection
* of the rectangle. Hence clipping may be faster than calculating
* the envelope of the geometry for trivial overlap tests.
- * The input geometry must be valid. In particular all {@link LinearRing}s must
- * be properly closed, or the algorithm may not terminate.
+ * The input geometry must be valid. In particular all [LinearRings](@ref geom::LinearRing)
+ * must be properly closed, or the algorithm may not terminate.
class GEOS_DLL RectangleIntersection {
public:
- * \brief Clip geometry with a rectangle
+ * \brief Clip geometry with a rectangle.
- * @param geom a {@link Geometry}
- * @param rect a {@link Rectangle}
+ * @param geom a [Geometry](@ref geom::Geometry)
+ * @param rect a Rectangle
* @return the clipped geometry
- * @return NULL if the geometry is outside the {@link Rectangle}
+ * @return `NULL` if the geometry is outside the Rectangle
static std::unique_ptr<geom::Geometry> clip(const geom::Geometry& geom,
const Rectangle& rect);
- * \brief Clip boundary of a geometry with a rectangle
+ * \brief Clip boundary of a geometry with a rectangle.
* Any polygon which intersects the rectangle will be converted to
* a polyline or a multipolyline - including the holes.
static std::unique_ptr<geom::Geometry> clipBoundary(const geom::Geometry& geom,
diff --git a/include/geos/operation/intersection/RectangleIntersectionBuilder.h b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
index 47383e0..cb7c909 100644
--- a/include/geos/operation/intersection/RectangleIntersectionBuilder.h
+++ b/include/geos/operation/intersection/RectangleIntersectionBuilder.h
@@ -52,11 +52,11 @@ namespace intersection { // geos::operation::intersection
* \brief Rebuild geometries from subpaths left by clipping with a rectangle
* The RectangleIntersectionBuilder is used to maintain lists of polygons,
- * linestrings and points left from clipping a {@link Geometry} with a {@link Rectangle}.
- * Once all clipping has been done, the class builds a valid {@link Geometry} from
+ * linestrings and points left from clipping a geom::Geometry with a Rectangle.
+ * Once all clipping has been done, the class builds a valid geom::Geometry from
* the components.
- * This is a utility class needed by {@link RectangleIntersection}, and is not
+ * @note This is a utility class needed by RectangleIntersection, and is not
* intended for public use.
diff --git a/include/geos/operation/linemerge/LineMergeDirectedEdge.h b/include/geos/operation/linemerge/LineMergeDirectedEdge.h
index a19bd22..bdbfd6b 100644
--- a/include/geos/operation/linemerge/LineMergeDirectedEdge.h
+++ b/include/geos/operation/linemerge/LineMergeDirectedEdge.h
@@ -41,34 +41,34 @@ namespace linemerge { // geos::operation::linemerge
* \brief
- * A planargraph::DirectedEdge of a LineMergeGraph.
+ * A [DirectedEdge](@ref planargraph::DirectedEdge) of a LineMergeGraph.
class GEOS_DLL LineMergeDirectedEdge: public planargraph::DirectedEdge {
public:
- * Constructs a LineMergeDirectedEdge connecting the <code>from</code>
- * node to the <code>to</code> node.
+ /** \brief
+ * Constructs a LineMergeDirectedEdge connecting the `from`
+ * node to the `to` node.
- * @param directionPt
- * specifies this DirectedEdge's direction (given by an
- * imaginary line from the <code>from</code> node to
- * <code>directionPt</code>)
- * @param edgeDirection
- * whether this DirectedEdge's direction is the same as or
- * opposite to that of the parent Edge (if any)
+ * @param from `from` node
+ * @param to `to` node
+ * @param directionPt specifies this DirectedEdge's direction (given by an
+ * imaginary line from the `from` node to
+ * `directionPt`)
+ * @param edgeDirection whether this DirectedEdge's direction is the same as or
+ * opposite to that of the parent Edge (if any)
LineMergeDirectedEdge(planargraph::Node* from,
planargraph::Node* to,
const geom::Coordinate& directionPt,
bool edgeDirection);
- * Returns the directed edge that starts at this directed edge's end point, or null
- * if there are zero or multiple directed edges starting there.
- * @return
+ /** \brief
+ * Returns the directed edge that starts at this directed edge's end point, or null
+ * if there are zero or multiple directed edges starting there.
+ * @return the directed edge
+ * @return `null` if there are zero or multiple directed edges starting there
LineMergeDirectedEdge* getNext();
diff --git a/include/geos/operation/linemerge/LineSequencer.h b/include/geos/operation/linemerge/LineSequencer.h
index 5c6a9f0..cba7397 100644
--- a/include/geos/operation/linemerge/LineSequencer.h
+++ b/include/geos/operation/linemerge/LineSequencer.h
@@ -62,10 +62,8 @@ namespace linemerge { // geos::operation::linemerge
* components of the input. Each linestring is oriented
* so that identical endpoints are adjacent in the list.
- * A typical use case is to convert a set of
- * unoriented geometric links
- * from a linear network
- * (e.g. such as block faces on a bus route)
+ * A typical use case is to convert a set of unoriented geometric links
+ * from a linear network (e.g. such as block faces on a bus route)
* into a continuous oriented path through the network.
* The input linestrings may form one or more connected sets.
@@ -74,12 +72,10 @@ namespace linemerge { // geos::operation::linemerge
* The computed output is a single MultiLineString containing the ordered
* linestrings in the sequence.
- * The sequencing employs the classic <b>Eulerian path</b> graph algorithm.
- * Since Eulerian paths are not uniquely determined,
- * further rules are used to
- * make the computed sequence preserve as much as possible of the input
- * ordering.
- * Within a connected subset of lines, the ordering rules are:
+ * The sequencing employs the classic **Eulerian path** graph algorithm.
+ * Since Eulerian paths are not uniquely determined, further rules are used
+ * to make the computed sequence preserve as much as possible of the input
+ * ordering. Within a connected subset of lines, the ordering rules are:
* - If there is degree-1 node which is the start
* node of an linestring, use that node as the start of the sequence
@@ -87,13 +83,11 @@ namespace linemerge { // geos::operation::linemerge
* node of an linestring, use that node as the end of the sequence
* - If the sequence has no degree-1 nodes, use any node as the start
- * Note that not all arrangements of lines can be sequenced.
- * For a connected set of edges in a graph,
- * <i>Euler's Theorem</i> states that there is a sequence
- * containing each edge once
- * <b>if and only if</b> there are no more than 2 nodes of odd degree.
- * If it is not possible to find a sequence, the isSequenceable method
- * will return <code>false</code>.
+ * @note Not all arrangements of lines can be sequenced. For a connected
+ * set of edges in a graph, *Euler's Theorem* states that there is a sequence
+ * containing each edge once **if and only if** there are no more than
+ * 2 nodes of odd degree. If it is not possible to find a sequence, the
+ * `isSequenceable` method will return `false`.
class GEOS_DLL LineSequencer {
@@ -210,23 +204,24 @@ public:
isSequenceableVar(false)
- * Tests whether a {@link Geometry} is sequenced correctly.
- * {@llink LineString}s are trivially sequenced.
- * {@link MultiLineString}s are checked for correct sequencing.
- * Otherwise, <code>isSequenced</code> is defined
- * to be <code>true</code> for geometries that are not lineal.
+ /** \brief
+ * Tests whether a [Geometry](@ref geom::Geometry) is sequenced correctly.
+ * [LineStrings](@ref geom::LineString) are trivially sequenced.
+ * [MultiLineStrings](@ref geom::MultiLineString) are checked for
+ * correct sequencing. Otherwise, `isSequenced` is defined
+ * to be `true` for geometries that are not lineal.
* @param geom the geometry to test
- * @return true if the geometry is sequenced or is not lineal
+ * @return `true` if the geometry is sequenced or is not lineal
static bool isSequenced(const geom::Geometry* geom);
+ /** \brief
* Tests whether the arrangement of linestrings has a valid
* sequence.
- * @return <code>true</code> if a valid sequence exists.
+ * @return `true` if a valid sequence exists.
bool
isSequenceable()
@@ -235,8 +230,9 @@ public:
return isSequenceableVar;
- * Adds a {@link Geometry} to be sequenced.
+ /** \brief
+ * Adds a [Geometry](@ref geom::Geometry) to be sequenced.
* May be called multiple times.
* Any dimension of Geometry may be added; the constituent
* linework will be extracted.
@@ -260,7 +256,7 @@ public:
+ /** \brief
* Act as a GeometryComponentFilter so to extract
* the linearworks
@@ -272,13 +268,13 @@ public:
+ /** \brief
* Returns the LineString or MultiLineString
* built by the sequencing process, if one exists.
* @param release release ownership of computed Geometry
* @return the sequenced linestrings,
- * or <code>null</code> if a valid sequence
+ * or `null` if a valid sequence
* does not exist.
geom::Geometry*
diff --git a/include/geos/operation/overlay/MaximalEdgeRing.h b/include/geos/operation/overlay/MaximalEdgeRing.h
index 3a583ac..e3c3772 100644
--- a/include/geos/operation/overlay/MaximalEdgeRing.h
+++ b/include/geos/operation/overlay/MaximalEdgeRing.h
@@ -46,7 +46,7 @@ namespace operation { // geos::operation
namespace overlay { // geos::operation::overlay
/** \brief
- * A ring of {@link edges} which may contain nodes of degree > 2.
+ * A ring of [DirectedEdges](@ref geomgraph::DirectedEdge) which may contain nodes of degree > 2.
* A MaximalEdgeRing may represent two different spatial entities:
@@ -57,7 +57,7 @@ namespace overlay { // geos::operation::overlay
* the interior of the polygon is strongly connected.
* These are the form of rings used to define polygons under some spatial data models.
- * However, under the OGC SFS model, {@link MinimalEdgeRings} are required.
+ * However, under the OGC SFS model, [MinimalEdgeRings](@ref MinimalEdgeRing) are required.
* A MaximalEdgeRing can be converted to a list of MinimalEdgeRings using the
* {@link #buildMinimalRings() } method.
diff --git a/include/geos/operation/overlay/MinimalEdgeRing.h b/include/geos/operation/overlay/MinimalEdgeRing.h
index 74f3abd..c7fdfd5 100644
--- a/include/geos/operation/overlay/MinimalEdgeRing.h
+++ b/include/geos/operation/overlay/MinimalEdgeRing.h
@@ -44,11 +44,11 @@ namespace operation { // geos::operation
/** \brief
- * A ring of {@link Edge}s with the property that no node
+ * A ring of [Edges](@ref geomgraph::Edge) with the property that no node
* has degree greater than 2.
- * These are the form of rings required
- * to represent polygons under the OGC SFS spatial data model.
+ * These are the form of rings required to represent polygons
+ * under the OGC SFS spatial data model.
* @see operation::overlay::MaximalEdgeRing
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index 2e2445e..c9ae800 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -61,7 +61,7 @@ namespace geos {
-/// Computes the geometric overlay of two Geometry.
+/// \brief Computes the geometric overlay of two Geometry.
/// The overlay can be used to determine any
/// boolean combination of the geometries.
@@ -70,7 +70,7 @@ class GEOS_DLL OverlayOp: public GeometryGraphOperation {
public:
- /// The spatial functions supported by this class.
+ /// \brief The spatial functions supported by this class.
/// These operations implement various boolean combinations of
/// the resultants of the overlay.
opSYMDIFFERENCE = 4
+ /** \brief
* Computes an overlay operation for the given geometry arguments.
* @param geom0 the first geometry argument
@@ -100,13 +100,13 @@ public:
OpCode opCode);
//throw(TopologyException *);
- * Tests whether a point with a given topological {@link Label}
+ /** \brief
+ * Tests whether a point with a given topological [Label](@ref geomgraph::Label)
* relative to two geometries is contained in
* the result of overlaying the geometries using
* a given overlay operation.
- * The method handles arguments of {@link Location#NONE} correctly
+ * The method handles arguments of [Location::UNDEF](@ref geom::Location::UNDEF) correctly
* @param label the topological label of the point
* @param opCode the code for the overlay operation to test
@@ -114,13 +114,13 @@ public:
static bool isResultOfOp(const geomgraph::Label& label, OpCode opCode);
- /// This method will handle arguments of Location.NULL correctly
+ /// \brief This method will handle arguments of Location.NULL correctly
/// @return true if the locations correspond to the opCode
static bool isResultOfOp(int loc0, int loc1, OpCode opCode);
- /// Construct an OverlayOp with the given Geometry args.
+ /// \brief Construct an OverlayOp with the given Geometry args.
/// Ownership of passed args will remain to caller, and
/// the OverlayOp won't change them in any way.
@@ -129,7 +129,7 @@ public:
~OverlayOp() override; // FIXME: virtual ?
+ /** \brief
* Gets the result of the overlay for a given overlay operation.
* Note: this method can be called once only.
@@ -141,7 +141,7 @@ public:
geom::Geometry* getResultGeometry(OpCode overlayOpCode);
// throw(TopologyException *);
+ /** \brief
* Gets the graph constructed to compute the overlay.
* @return the overlay graph
@@ -156,8 +156,8 @@ public:
* This method is used to decide if a point node should be included
* in the result or not.
- * @return true if the coord point is covered by a result Line
- * or Area geometry
+ * @return `true` if the coord point is covered by a result Line
+ * or Area geometry
bool isCoveredByLA(const geom::Coordinate& coord);
@@ -165,7 +165,7 @@ public:
* This method is used to decide if an L edge should be included
- * @return true if the coord point is covered by a result Area geometry
+ * @return `true` if the coord point is covered by a result Area geometry
bool isCoveredByA(const geom::Coordinate& coord);
diff --git a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
index 8bda9bb..4d4843a 100644
--- a/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
+++ b/include/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h
@@ -39,12 +39,10 @@ namespace snap { // geos::operation::overlay::snap
* Performs an overlay operation using snapping and enhanced precision
* to improve the robustness of the result.
- * This class only uses snapping
- * if an error is detected when running the standard JTS overlay code.
- * Errors detected include thrown exceptions
- * (in particular, {@link TopologyException})
+ * This class only uses snapping if an error is detected when running
+ * the standard JTS overlay code. Errors detected include thrown exceptions
+ * (in particular, [TopologyException](@ref util::TopologyException))
* and invalid overlay computations.
class SnapIfNeededOverlayOp {
diff --git a/include/geos/operation/predicate/RectangleIntersects.h b/include/geos/operation/predicate/RectangleIntersects.h
index c8831ff..d4d4a45 100644
--- a/include/geos/operation/predicate/RectangleIntersects.h
+++ b/include/geos/operation/predicate/RectangleIntersects.h
@@ -41,7 +41,7 @@ namespace predicate { // geos::operation::predicate
* for cases where one Geometry is a rectangle.
* This class works for all input geometries, including
- * {@link GeometryCollection}s.
+ * [GeometryCollections](@ref geom::GeometryCollection).
* As a further optimization,
* this class can be used to test
diff --git a/include/geos/operation/relate/RelateOp.h b/include/geos/operation/relate/RelateOp.h
index 9b41950..ed46b08 100644
--- a/include/geos/operation/relate/RelateOp.h
+++ b/include/geos/operation/relate/RelateOp.h
@@ -41,17 +41,17 @@ namespace operation { // geos::operation
namespace relate { // geos::operation::relate
/** \brief
- * Implements the SFS <tt>relate()</tt> operation on two
+ * Implements the SFS `relate()` operation on two
* geom::Geometry objects.
* This class supports specifying a custom algorithm::BoundaryNodeRule
* to be used during the relate computation.
- * <b>Note:</b> custom Boundary Node Rules do not (currently)
+ * @note Custom Boundary Node Rules do not (currently)
* affect the results of other Geometry methods (such
- * as {@link Geometry::getBoundary}. The results of
- * these methods may not be consistent with the relationship computed by
- * a custom Boundary Node Rule.
+ * as [Geometry::getBoundary()](@ref geom::Geometry::getBoundary() const)).
+ * The results of these methods may not be consistent with the relationship
+ * computed by a custom Boundary Node Rule.
class GEOS_DLL RelateOp: public GeometryGraphOperation {
@@ -76,7 +76,7 @@ public:
/** \brief
* Computes the geom::IntersectionMatrix for the spatial relationship
* between two geom::Geometry objects, using a specified
- * Boundary Node Rule
+ * Boundary Node Rule.
* @param a a Geometry to test. Ownership left to caller.
* @param b a Geometry to test. Ownership left to caller.
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index dc8cd85..638cd64 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -52,21 +52,21 @@ namespace geounion { // geos::operation::geounion
* \brief
* Provides an efficient method of unioning a collection of
- * {@link geom::Polygonal} geometries.
+ * [Polygonal](@ref geom::Polygonal) geometries.
* This algorithm is faster and likely more robust than
* the simple iterated approach of
* repeatedly unioning each polygon to a result geometry.
- * The <tt>buffer(0)</tt> trick is sometimes faster, but can be less robust and
+ * The `buffer(0)` trick is sometimes faster, but can be less robust and
* can sometimes take an exceptionally long time to complete.
* This is particularly the case where there is a high degree of overlap
- * between the polygons. In this case, <tt>buffer(0)</tt> is forced to compute
- * with <i>all</i> line segments from the outset,
+ * between the polygons. In this case, `buffer(0)` is forced to compute
+ * with *all* line segments from the outset,
* whereas cascading can eliminate many segments
* at each stage of processing.
* The best case for buffer(0) is the trivial case
- * where there is <i>no</i> overlap between the input geometries.
+ * where there is `no` overlap between the input geometries.
* However, this case is likely rare in practice.
class GEOS_DLL CascadedPolygonUnion {
@@ -84,12 +84,12 @@ private:
static int const STRTREE_NODE_CAPACITY = 4;
- * Computes a {@link Geometry} containing only {@link Polygonal} components.
+ * Computes a {@link Geometry} containing only [Polygonal](@ref geom::Polygonal) components.
* Extracts the {@link Polygon}s from the input
- * and returns them as an appropriate {@link Polygonal} geometry.
+ * and returns them as an appropriate [Polygonal](@ref geom::Polygonal) geometry.
- * If the input is already <tt>Polygonal</tt>, it is returned unchanged.
+ * If the input is already `Polygonal`, it is returned unchanged.
* A particular use case is to filter out non-polygonal components
* returned from an overlay operation.
@@ -102,19 +102,19 @@ private:
public:
CascadedPolygonUnion();
- * Computes the union of
- * a collection of {@link geom::Polygonal} {@link geom::Geometry}s.
+ /** \brief
+ * Computes the union of a collection of [Polygonal](@ref geom::Polygonal)
- * @param polys a collection of {@link geom::Polygonal}
- * {@link geom::Geometry}s.
+ * @param polys a collection of [Polygonal](@ref geom::Polygonal)
* ownership of elements _and_ vector are left to caller.
static geom::Geometry* Union(std::vector<geom::Polygon*>* polys);
- * Computes the union of a set of {@link geom::Polygonal}
+ /** \brief
+ * Computes the union of a set of [Polygonal](@ref geom::Polygonal)
* @tparam T an iterator yelding something castable to const Polygon *
* @param start start iterator
@@ -132,34 +132,34 @@ public:
return Union(&polys);
+ /** \brief
- * Ownership of elements _and_ vector are left to caller.
+ * Ownership of elements *and* vector are left to caller.
static geom::Geometry* Union(const geom::MultiPolygon* polys);
+ /** \brief
* Creates a new instance to union
* the given collection of {@link geom::Geometry}s.
- * @param geoms a collection of {@link geom::Polygonal}
CascadedPolygonUnion(std::vector<geom::Polygon*>* polys)
: inputPolys(polys),
geomFactory(nullptr)
+ /** \brief
* Computes the union of the input geometries.
* @return the union of the input geometries
- * @return null if no input geometries were provided
+ * @return `null` if no input geometries were provided
geom::Geometry* Union();
diff --git a/include/geos/operation/union/PointGeometryUnion.h b/include/geos/operation/union/PointGeometryUnion.h
index 8ed31c4..3085cd4 100644
--- a/include/geos/operation/union/PointGeometryUnion.h
+++ b/include/geos/operation/union/PointGeometryUnion.h
@@ -38,8 +38,8 @@ namespace geounion { // geos::operation::geounion
* \brief
- * Computes the union of a {@link Puntal} geometry with
- * another arbitrary {@link Geometry}.
+ * Computes the union of a [Puntal](@ref geom::Puntal) geometry with
+ * another arbitrary [Geometry](@ref geom::Geometry).
* Does not copy any component geometries.
diff --git a/include/geos/operation/union/UnaryUnionOp.h b/include/geos/operation/union/UnaryUnionOp.h
index e44e735..f32631c 100644
--- a/include/geos/operation/union/UnaryUnionOp.h
+++ b/include/geos/operation/union/UnaryUnionOp.h
@@ -49,34 +49,38 @@ namespace geos {
+/** \brief
* Unions a collection of Geometry or a single Geometry
* (which may be a collection) together.
* By using this special-purpose operation over a collection of
* geometries it is possible to take advantage of various optimizations
* to improve performance.
- * Heterogeneous {@link GeometryCollection}s are fully supported.
+ * Heterogeneous [GeometryCollections](@ref geom::GeometryCollection)
+ * are fully supported.
* The result obeys the following contract:
- * - Unioning a set of overlapping {@link Polygons}s has the effect of
- * merging the areas (i.e. the same effect as
+ * - Unioning a set of overlapping [Polygons](@ref geom::Polygon) has the effect
+ * of merging the areas (i.e. the same effect as
* iteratively unioning all individual polygons together).
- * - Unioning a set of {@link LineString}s has the effect of
- * <b>fully noding</b> and <b>dissolving</b> the input linework.
+ * - Unioning a set of [LineStrings](@ref geom::LineString) has the effect of
+ * **fully noding** and **dissolving** the input linework.
* In this context "fully noded" means that there will be a node or
* endpoint in the output for every endpoint or line segment crossing
* in the input.
* "Dissolved" means that any duplicate (e.g. coincident) line segments
* or portions of line segments will be reduced to a single line segment
- * in the output. * This is consistent with the semantics of the
- * {@link Geometry#union(Geometry)} operation.
- * If <b>merged</b> linework is required, the {@link LineMerger} class
+ * in the output.
+ * This is consistent with the semantics of the
+ * [Geometry::Union(Geometry* )](@ref geom::Geometry::Union(const Geometry* other) const)
+ * operation. If **merged** linework is required, the
+ * [LineMerger](@ref operation::linemerge::LineMerger) class
* can be used.
- * - Unioning a set of {@link Points}s has the effect of merging
+ * - Unioning a set of [Points](@ref geom::Point) has the effect of merging
* al identical points (producing a set with no duplicates).
- * <tt>UnaryUnion</tt> always operates on the individual components of
+ * `UnaryUnion` always operates on the individual components of
* MultiGeometries.
* So it is possible to use it to "clean" invalid self-intersecting
* MultiPolygons (although the polygon components must all still be
diff --git a/include/geos/operation/valid/ConsistentAreaTester.h b/include/geos/operation/valid/ConsistentAreaTester.h
index e596e2e..d23dfa4 100644
--- a/include/geos/operation/valid/ConsistentAreaTester.h
+++ b/include/geos/operation/valid/ConsistentAreaTester.h
@@ -90,8 +90,8 @@ public:
* Creates a new tester for consistent areas.
- * @param geomGraph the topology graph of the area geometry.
- * Caller keeps responsibility for its deletion
+ * @param newGeomGraph the topology graph of the area geometry.
+ * Caller keeps responsibility for its deletion
ConsistentAreaTester(geomgraph::GeometryGraph* newGeomGraph);
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index 95795ab..0756870 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -56,7 +56,7 @@ namespace valid { // geos::operation::valid
/** \brief
* Implements the algorithsm required to compute the <code>isValid()</code>
- * method for {@link Geometry}s.
+ * method for [Geometrys](@ref geom::Geometry).
class GEOS_DLL IsValidOp {
friend class Unload;
@@ -192,7 +192,7 @@ private:
bool isSelfTouchingRingFormingHoleValid;
public:
+ /** \brief
* Find a point from the list of testCoords
* that is NOT a node in the edge for the list of searchCoords
@@ -203,21 +203,21 @@ public:
const geom::LinearRing* searchRing,
geomgraph::GeometryGraph* graph);
+ /** \brief
* Checks whether a coordinate is valid for processing.
* Coordinates are valid iff their x and y coordinates are in the
* range of the floating point representation.
* @param coord the coordinate to validate
- * @return <code>true</code> if the coordinate is valid
+ * @return `true` if the coordinate is valid
static bool isValid(const geom::Coordinate& coord);
- * Tests whether a {@link Geometry} is valid.
+ /** \brief
+ * Tests whether a geom::Geometry is valid.
* @param geom the Geometry to test
- * @return true if the geometry is valid
+ * @return `true` if the geometry is valid
static bool isValid(const geom::Geometry& geom);
@@ -241,28 +241,25 @@ public:
TopologyValidationError* getValidationError();
/** \brief
- * Sets whether polygons using <b>Self-Touching Rings</b> to form
+ * Sets whether polygons using **Self-Touching Rings** to form
* holes are reported as valid.
* If this flag is set, the following Self-Touching conditions
* are treated as being valid:
- * <ul>
- * <li>the shell ring self-touches to create a hole touching the shell
- * <li>a hole ring self-touches to create two holes touching at a point
- * </ul>
- * <p>
+ * - the shell ring self-touches to create a hole touching the shell
+ * - a hole ring self-touches to create two holes touching at a point
* The default (following the OGC SFS standard)
- * is that this condition is <b>not</b> valid (<code>false</code>).
- * <p>
+ * is that this condition is **not** valid (`false`).
* This does not affect whether Self-Touching Rings
* disconnecting the polygon interior are considered valid
- * (these are considered to be <b>invalid</b> under the SFS,
+ * (these are considered to be **invalid** under the SFS,
* and many other spatial models as well).
- * This includes "bow-tie" shells,
- * which self-touch at a single point causing the interior to
- * be disconnected,
- * and "C-shaped" holes which self-touch at a single point causing
- * an island to be formed.
+ * This includes "bow-tie" shells, which self-touch at a single point
+ * causing the interior to be disconnected, and "C-shaped" holes which
+ * self-touch at a single point causing an island to be formed.
* @param p_isValid states whether geometry with this condition is valid
diff --git a/include/geos/operation/valid/QuadtreeNestedRingTester.h b/include/geos/operation/valid/QuadtreeNestedRingTester.h
index 698a64a..a5600b3 100644
--- a/include/geos/operation/valid/QuadtreeNestedRingTester.h
+++ b/include/geos/operation/valid/QuadtreeNestedRingTester.h
@@ -52,8 +52,8 @@ namespace operation { // geos::operation
/** \brief
- * Tests whether any of a set of {@link LinearRing}s are
- * nested inside another ring in the set, using a {@link Quadtree}
+ * Tests whether any of a set of [LinearRings](@ref geom::LinearRing) are nested
+ * inside another ring in the set, using a [Quadtree](@ref index::quadtree::Quadtree)
* index to speed up the comparisons.
diff --git a/include/geos/operation/valid/SimpleNestedRingTester.h b/include/geos/operation/valid/SimpleNestedRingTester.h
index d6d7de1..963c92b 100644
--- a/include/geos/operation/valid/SimpleNestedRingTester.h
+++ b/include/geos/operation/valid/SimpleNestedRingTester.h
/** \brief
* nested inside another ring in the set, using a simple O(n^2)
* comparison.
diff --git a/include/geos/operation/valid/SweeplineNestedRingTester.h b/include/geos/operation/valid/SweeplineNestedRingTester.h
index 71ba081..8f9ac2d 100644
--- a/include/geos/operation/valid/SweeplineNestedRingTester.h
+++ b/include/geos/operation/valid/SweeplineNestedRingTester.h
@@ -55,9 +55,10 @@ namespace operation { // geos::operation
/** \brief
* nested inside another ring in the set, using an
- * index::sweepline::SweepLineIndex to speed up the comparisons.
+ * [SweepLineIndex](@ref index::sweepline::SweepLineIndex) to speed up
+ * the comparisons.
class GEOS_DLL SweeplineNestedRingTester {
diff --git a/include/geos/operation/valid/TopologyValidationError.h b/include/geos/operation/valid/TopologyValidationError.h
index f290899..cca3721 100644
--- a/include/geos/operation/valid/TopologyValidationError.h
+++ b/include/geos/operation/valid/TopologyValidationError.h
@@ -33,7 +33,7 @@ namespace operation { // geos::operation
/** \brief
- * Contains information about the nature and location of a {@link Geometry}
+ * Contains information about the nature and location of a geom::Geometry
* validation error
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index 98db535..ac4911a 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -72,7 +72,7 @@ public:
* Returns a List containing the parent Edge (possibly null)
* for each of the given DirectedEdges.
- * NOTE: ownership of the returned vector is left to
+ * @note Ownership of the returned vector is left to
* the caller, see the equivalent function taking a vector
* reference to avoid this.
@@ -84,20 +84,22 @@ public:
* Add parent Edge (possibly null) of each of the given DirectedEdges
* to the given parentEdges vector.
- * NOTE: parents are pushed to the parentEdges vector, make sure
+ * @note Parents are pushed to the parentEdges vector, make sure
* it is empty if index-based corrispondence is important.
static void toEdges(std::vector<DirectedEdge*>& dirEdges,
std::vector<Edge*>& parentEdges);
- * \brief Constructs a DirectedEdge connecting the <code>from</code>
+ * \brief Constructs a DirectedEdge connecting the `from`
+ * @param newFrom `from` node
+ * @param newTo `to` node
* (given by an imaginary line from the
- * <code>from</code> node to
+ * `from` node to
+ * `directionPt`)
* @param newEdgeDirection whether this DirectedEdge's direction
* is the same as or opposite to that of the
* parent Edge (if any)
diff --git a/include/geos/planargraph/Edge.h b/include/geos/planargraph/Edge.h
index 089b3df..506a744 100644
--- a/include/geos/planargraph/Edge.h
+++ b/include/geos/planargraph/Edge.h
@@ -74,27 +74,20 @@ protected:
/** \brief The two DirectedEdges associated with this Edge */
std::vector<DirectedEdge*> dirEdge;
- * \brief Constructs an Edge whose DirectedEdges are not yet set.
- * Be sure to call setDirectedEdges(DirectedEdge, DirectedEdge)
public:
/** \brief
- * Constructs a Edge whose DirectedEdges are
- * not yet set.
+ * Constructs a Edge whose DirectedEdges are not yet set.
* Be sure to call
- * {@link setDirectedEdges(DirectedEdge, DirectedEdge)}
+ * {@link #setDirectedEdges(DirectedEdge* de0, DirectedEdge* de1)}
Edge(): dirEdge() {}
* \brief Constructs an Edge initialized with the given DirectedEdges.
- * For each DirectedEdge: sets the Edge, sets the symmetric
+ * For each DirectedEdge: sets the Edge, sets the symmetric
* DirectedEdge, and adds this Edge to its from-Node.
Edge(DirectedEdge* de0, DirectedEdge* de1)
@@ -108,8 +101,8 @@ public:
* \brief Initializes this Edge's two DirectedEdges.
- * sets the Edge, sets the symmetric DirectedEdge, and
- * adds this Edge to its from-Node.
+ * - sets the Edge, sets the symmetric DirectedEdge, and
+ * - adds this Edge to its from-Node.
void setDirectedEdges(DirectedEdge* de0, DirectedEdge* de1);
diff --git a/include/geos/planargraph/PlanarGraph.h b/include/geos/planargraph/PlanarGraph.h
index 2001948..f871736 100644
--- a/include/geos/planargraph/PlanarGraph.h
+++ b/include/geos/planargraph/PlanarGraph.h
@@ -219,9 +219,8 @@ public:
- * \brief
* Returns the Edges that have been added to this PlanarGraph
- * @see #add(Edge)
+ * @see PlanarGraph::add(Edge* edge)
std::vector<Edge*>*
getEdges()
diff --git a/include/geos/planargraph/Subgraph.h b/include/geos/planargraph/Subgraph.h
index c724f7a..d5a4748 100644
--- a/include/geos/planargraph/Subgraph.h
+++ b/include/geos/planargraph/Subgraph.h
@@ -38,21 +38,21 @@ class Edge;
namespace geos {
namespace planargraph { // geos.planargraph
-/// A subgraph of a PlanarGraph.
+/// \brief A subgraph of a PlanarGraph.
-/// A subgraph may contain any subset of geomgraph::Edges
+/// A subgraph may contain any subset of {@link Edge}s
/// from the parent graph.
-/// It will also automatically contain all geomgraph::DirectedEdge
-/// and geomgraph::Node associated with those edges.
+/// It will also automatically contain all {@link DirectedEdge}s
+/// and {@link Node}s associated with those edges.
/// No new objects are created when edges are added -
/// all associated components must already exist in the parent graph.
-/// @@ Actually we'll be copying Coordinates in NodeMap.
+/// @note Actually we'll be copying Coordinates in NodeMap.
/// I guess that'll need to be changed soon.
class GEOS_DLL Subgraph {
public:
+ /** \brief
* Creates a new subgraph of the given PlanarGraph
* @param parent the parent graph
@@ -62,8 +62,8 @@ public:
parentGraph(parent)
- * Gets the {@link PlanarGraph} which this subgraph
+ /** \brief
+ * Gets the PlanarGraph which this subgraph
* is part of.
* @return the parent PlanarGraph
@@ -74,22 +74,23 @@ public:
return parentGraph;
- * Adds an {@link Edge} to the subgraph.
- * The associated {@link DirectedEdge}s and {@link planarNode}s
+ /** \brief
+ * Adds an Edge to the subgraph.
+ * The associated {@link DirectedEdge}s and {@link Node}s
* are also added.
* @param e the edge to add
* @return a pair with first element being an iterator
* to the Edge in set and second element
- * being a boolean value indicating wheter
- * the Edge has been inserted now or was
- * already in the set.
+ * being a boolean value indicating wheter
+ * the Edge has been inserted now or was
+ * already in the set.
std::pair<std::set<Edge*>::iterator, bool> add(Edge* e);
+ /** \brief
* Returns an iterator over the DirectedEdge in this graph,
* in the order in which they were added.
@@ -104,8 +105,8 @@ public:
- * Returns an {@link Iterator} over the {@link Edge}s in this
+ /** \brief
+ * Returns an iterator over the {@link Edge}s in this
* graph, in the order in which they were added.
* @return an iterator over the edges
@@ -123,8 +124,8 @@ public:
return edges.end();
- * Returns a iterators over the planarNodesMap::container
+ /** \brief
+ * Returns a iterators over the planar NodeMap::container
* in this graph.
NodeMap::container::iterator
@@ -148,10 +149,11 @@ public:
return nodeMap.begin();
- * Tests whether an {@link Edge} is contained in this subgraph
+ /** \brief
+ * Tests whether an {@link Edge} is contained in this subgraph.
* @param e the edge to test
- * @return <code>true</code> if the edge is contained in this subgraph
+ * @return `true` if the edge is contained in this subgraph
bool
contains(Edge* e)
diff --git a/include/geos/precision/CommonBitsOp.h b/include/geos/precision/CommonBitsOp.h
index 435c6c9..9a33786 100644
--- a/include/geos/precision/CommonBitsOp.h
+++ b/include/geos/precision/CommonBitsOp.h
@@ -77,20 +77,20 @@ private:
public:
+ /** \brief
* Creates a new instance of class, which reshifts result Geometry
CommonBitsOp();
+ /** \brief
* Creates a new instance of class, specifying whether
- * the result {@link Geometry}s should be reshifted.
+ * the result {@link geom::Geometry}s should be reshifted.
- * @param returnToOriginalPrecision
+ * @param nReturnToOriginalPrecision
CommonBitsOp(bool nReturnToOriginalPrecision);
+ /** \brief
* Computes the set-theoretic intersection of two Geometry,
* using enhanced precision.
* @param geom0 the first Geometry
@@ -102,7 +102,7 @@ public:
const geom::Geometry* geom0,
const geom::Geometry* geom1);
+ /** \brief
* Computes the set-theoretic union of two Geometry,
@@ -114,7 +114,7 @@ public:
+ /** \brief
* Computes the set-theoretic difference of two Geometry,
@@ -126,7 +126,7 @@ public:
+ /** \brief
* Computes the set-theoretic symmetric difference of two geometries,
@@ -138,7 +138,7 @@ public:
+ /** \brief
* Computes the buffer a geometry,
* @param geom0 the Geometry to buffer
@@ -149,7 +149,7 @@ public:
double distance);
+ /** \brief
* If required, returning the result to the orginal precision
* if required.
diff --git a/include/geos/simplify/TaggedLinesSimplifier.h b/include/geos/simplify/TaggedLinesSimplifier.h
index d8fa3f7..4a12e66 100644
--- a/include/geos/simplify/TaggedLinesSimplifier.h
+++ b/include/geos/simplify/TaggedLinesSimplifier.h
@@ -69,18 +69,14 @@ public:
void setDistanceTolerance(double tolerance);
+ /** \brief
* Simplify a set of {@link TaggedLineString}s
- * @param iterator_type
- * an iterator, must support assignment, increment,
- * inequality and dereference operators.
- * Dereference operator must return a TaggedLineString*
- * @param begin iterator to the first element
- * to be simplified.
- * @param end an iterator to one-past-last element
+ * @tparam iterator_type an iterator, must support assignment, increment,
+ * inequality and dereference operators. Dereference
+ * operator must return a `TaggedLineString*`.
+ * @param begin iterator to the first element to be simplified.
+ * @param end an iterator to one-past-last element to be simplified.
template <class iterator_type>
void
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index 3f79bd6..ce53f6c 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -105,7 +105,7 @@ public:
* Sets the sites (vertices) which will be triangulated
* from a collection of {@link geom::Coordinate}s.
- * @param geom a CoordinateSequence.
+ * @param coords a CoordinateSequence.
void setSites(const geom::CoordinateSequence& coords);
diff --git a/include/geos/triangulate/VoronoiDiagramBuilder.h b/include/geos/triangulate/VoronoiDiagramBuilder.h
index 81f47f4..780d503 100644
--- a/include/geos/triangulate/VoronoiDiagramBuilder.h
+++ b/include/geos/triangulate/VoronoiDiagramBuilder.h
@@ -33,10 +33,10 @@ class GeometryFactory;
namespace triangulate { //geos.triangulate
- * A utility class which creates Voronoi Diagrams
- * from collections of points.
- * The diagram is returned as a {@link GeometryCollection} of {@link Polygon}s,
+/** \brief
+ * A utility class which creates Voronoi Diagrams from collections of points.
+ * The diagram is returned as a geom::GeometryCollection of {@link geom::Polygon}s,
* clipped to the larger of a supplied envelope or to an envelope determined
* by the input sites.
@@ -45,7 +45,7 @@ namespace triangulate { //geos.triangulate
class GEOS_DLL VoronoiDiagramBuilder {
public:
+ /** \brief
* Creates a new Voronoi diagram builder.
@@ -53,7 +53,7 @@ public:
~VoronoiDiagramBuilder();
+ /** \brief
* Sets the sites (point or vertices) which will be diagrammed.
* All vertices of the given geometry will be used as sites.
@@ -61,16 +61,17 @@ public:
void setSites(const geom::Geometry& geom);
+ /** \brief
- * from a collection of {@link Coordinate}s.
+ * from a collection of {@link geom::Coordinate}s.
* @param coords a collection of Coordinates.
+ /** \brief
* Sets the envelope to clip the diagram to.
* The diagram will be clipped to the larger
* of this envelope or an envelope surrounding the sites.
@@ -80,34 +81,35 @@ public:
void setClipEnvelope(const geom::Envelope* clipEnv);
+ /** \brief
* Sets the snapping tolerance which will be used
* to improved the robustness of the triangulation computation.
* A tolerance of 0.0 specifies that no snapping will take place.
* @param tolerance the tolerance distance to use
void setTolerance(double tolerance);
- * Gets the {@link QuadEdgeSubdivision} which models the computed diagram.
+ /** \brief
+ * Gets the quadedge::QuadEdgeSubdivision which models the computed diagram.
* @return the subdivision containing the triangulation
std::unique_ptr<quadedge::QuadEdgeSubdivision> getSubdivision();
- * Gets the faces of the computed diagram as a {@link GeometryCollection}
- * of {@link Polygon}s, clipped as specified.
+ /** \brief
+ * Gets the faces of the computed diagram as a geom::GeometryCollection
+ * of {@link geom::Polygon}s, clipped as specified.
* @param geomFact the geometry factory to use to create the output
* @return the faces of the diagram
std::unique_ptr<geom::GeometryCollection> getDiagram(const geom::GeometryFactory& geomFact);
- * of {@link LineString}s, clipped as specified.
+ /** \brief
+ * of {@link geom::LineString}s, clipped as specified.
diff --git a/include/geos/triangulate/quadedge/QuadEdge.h b/include/geos/triangulate/quadedge/QuadEdge.h
index 0ed90b9..20d7da2 100644
--- a/include/geos/triangulate/quadedge/QuadEdge.h
+++ b/include/geos/triangulate/quadedge/QuadEdge.h
@@ -28,21 +28,21 @@ namespace geos {
namespace quadedge { //geos.triangulate.quadedge
+/** \brief
* A class that represents the edge data structure which implements the quadedge algebra.
* The quadedge algebra was described in a well-known paper by Guibas and Stolfi,
* "Primitives for the manipulation of general subdivisions and the computation of Voronoi diagrams",
- * <i>ACM Transactions on Graphics</i>, 4(2), 1985, 75-123.
+ * *ACM Transactions on Graphics*, 4(2), 1985, 75-123.
- * Each edge object is part of a quartet of 4 edges,
- * linked via their <tt>_rot</tt> references.
+ * Each edge object is part of a quartet of 4 edges, linked via their `_rot` references.
* Any edge in the group may be accessed using a series of {@link #rot()} operations.
- * Quadedges in a subdivision are linked together via their <tt>next</tt> references.
+ * Quadedges in a subdivision are linked together via their `next` references.
* The linkage between the quadedge quartets determines the topology
* of the subdivision.
* The edge class does not contain separate information for vertice or faces; a vertex is implicitly
- * defined as a ring of edges (created using the <tt>next</tt> field).
+ * defined as a ring of edges (created using the `next` field).
* @author JTS: David Skea
* @author JTS: Martin Davis
@@ -50,7 +50,7 @@ namespace quadedge { //geos.triangulate.quadedge
class GEOS_DLL QuadEdge {
public:
+ /** \brief
* Creates a new QuadEdge quartet from {@link Vertex} o to {@link Vertex} d.
* @param o the origin Vertex
@@ -60,21 +60,23 @@ public:
static std::unique_ptr<QuadEdge> makeEdge(const Vertex& o, const Vertex& d);
+ /** \brief
* Creates a new QuadEdge connecting the destination of a to the origin of
* b, in such a way that all three have the same left face after the
- * connection is complete. Additionally, the data pointers of the new edge
- * are set.
+ * connection is complete.
+ * Additionally, the data pointers of the new edge are set.
* @return the new QuadEdge* The caller is reponsible for
- * freeing the returned pointer
+ * freeing the returned pointer
static std::unique_ptr<QuadEdge> connect(QuadEdge& a, QuadEdge& b);
+ /** \brief
* Splices two edges together or apart.
* Splice affects the two edge rings around the origins of a and b, and, independently, the two
- * edge rings around the left faces of <tt>a</tt> and <tt>b</tt>.
+ * edge rings around the left faces of `a` and `b`.
* In each case, (i) if the two rings are distinct,
* Splice will combine them into one, or (ii) if the two are the same ring, Splice will break it
* into two separate pieces. Thus, Splice can be used both to attach the two edges together, and
@@ -86,7 +88,7 @@ public:
static void splice(QuadEdge& a, QuadEdge& b);
+ /** \brief
* Turns an edge counterclockwise inside its enclosing quadrilateral.
* @param e the quadedge to turn
@@ -110,54 +112,57 @@ private:
public:
virtual ~QuadEdge();
+ /** \brief
* Free the QuadEdge quartet associated with this QuadEdge by a connect()
* or makeEdge() call.
- * DO NOT call this function on a QuadEdge that was not returned
+ * @note DO NOT call this function on a QuadEdge that was not returned
* by connect() or makeEdge().
virtual void free();
- * Gets the primary edge of this quadedge and its <tt>sym</tt>.
+ /** \brief
+ * Gets the primary edge of this quadedge and its `sym`.
* The primary edge is the one for which the origin
* and destination coordinates are ordered
- * according to the standard {@link Coordinate} ordering
+ * according to the standard geom::Coordinate ordering
* @return the primary quadedge
const QuadEdge& getPrimary() const;
+ /** \brief
* Sets the external data value for this edge.
* @param data an object containing external data
virtual void setData(void* data);
+ /** \brief
* Gets the external data value for this edge.
* @return the data object
virtual void* getData();
+ /** \brief
* Marks this quadedge as being deleted.
* This does not free the memory used by
* this quadedge quartet, but indicates
* that this quadedge quartet no longer participates
* in a subdivision.
- * NOTE: called "delete" in JTS
+ * @note called "delete" in JTS
void remove();
+ /** \brief
* Tests whether this edge has been deleted.
- * @return true if this edge has not been deleted.
+ * @return `true` if this edge has not been deleted.
inline bool
isLive()
@@ -166,7 +171,7 @@ public:
+ /** \brief
* Sets the connected edge
* @param p_next edge
@@ -182,7 +187,7 @@ public:
+ /** \brief
* Gets the dual of this edge, directed from its right to its left.
* @return the rotated edge
@@ -193,7 +198,7 @@ public:
return *_rot;
+ /** \brief
* Gets the dual of this edge, directed from its left to its right.
* @return the inverse rotated edge.
@@ -204,7 +209,7 @@ public:
return rot().sym();
+ /** \brief
* Gets the edge from the destination to the origin of this edge.
* @return the sym of the edge
@@ -215,7 +220,7 @@ public:
return rot().rot();
+ /** \brief
* Gets the next CCW edge around the origin of this edge.
* @return the next linked edge.
@@ -226,7 +231,7 @@ public:
return *next;
+ /** \brief
* Gets the next CW edge around (from) the origin of this edge.
* @return the previous edge.
@@ -237,7 +242,7 @@ public:
return rot().oNext().rot();
+ /** \brief
* Gets the next CCW edge around (into) the destination of this edge.
* @return the next destination edge.
@@ -248,7 +253,7 @@ public:
return sym().oNext().sym();
+ /** \brief
* Gets the next CW edge around (into) the destination of this edge.
* @return the previous destination edge.
@@ -259,7 +264,7 @@ public:
return invRot().oNext().invRot();
+ /** \brief
* Gets the CCW edge around the left face following this edge.
* @return the next left face edge.
@@ -270,7 +275,7 @@ public:
return invRot().oNext().rot();
+ /** \brief
* Gets the CCW edge around the left face before this edge.
* @return the previous left face edge.
@@ -281,7 +286,7 @@ public:
return oNext().sym();
+ /** \brief
* Gets the edge around the right face ccw following this edge.
* @return the next right face edge.
@@ -292,7 +297,7 @@ public:
return rot().oNext().invRot();
+ /** \brief
* Gets the edge around the right face ccw before this edge.
* @return the previous right face edge.
@@ -306,7 +311,7 @@ public:
* Data Access
+ /** \brief
* Sets the vertex for this edge's origin
* @param o the origin vertex
@@ -317,7 +322,7 @@ public:
vertex = o;
+ /** \brief
* Sets the vertex for this edge's destination
* @param d the destination vertex
@@ -328,7 +333,7 @@ public:
sym().setOrig(d);
+ /** \brief
* Gets the vertex for the edge's origin
* @return the origin vertex
@@ -339,7 +344,7 @@ public:
return vertex;
+ /** \brief
* Gets the vertex for the edge's destination
* @return the destination vertex
@@ -350,7 +355,7 @@ public:
return sym().orig();
+ /** \brief
* Gets the length of the geometry of this quadedge.
* @return the length of the quadedge
@@ -361,26 +366,26 @@ public:
return orig().getCoordinate().distance(dest().getCoordinate());
+ /** \brief
* Tests if this quadedge and another have the same line segment geometry,
* regardless of orientation.
* @param qe a quadege
- * @return true if the quadedges are based on the same line segment regardless of orientation
+ * @return `true` if the quadedges are based on the same line segment regardless of orientation
bool equalsNonOriented(const QuadEdge& qe) const;
+ /** \brief
* with the same orientation.
bool equalsOriented(const QuadEdge& qe) const;
- * Creates a {@link LineSegment} representing the
+ /** \brief
+ * Creates a {@link geom::LineSegment} representing the
* geometry of this edge.
* @return a LineSegment
diff --git a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
index eb16295..85a7f08 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h
@@ -50,24 +50,23 @@ class TriangleVisitor;
const double EDGE_COINCIDENCE_TOL_FACTOR = 1000;
- * A class that contains the {@link QuadEdge}s representing a planar
+/** \brief
+ * A class that contains the [QuadEdges](@ref QuadEdge) representing a planar
* subdivision that models a triangulation.
- * The subdivision is constructed using the
- * quadedge algebra defined in the classs {@link QuadEdge}.
- * All metric calculations
- * are done in the {@link Vertex} class.
- * In addition to a triangulation, subdivisions
- * support extraction of Voronoi diagrams.
+ * The subdivision is constructed using the quadedge algebra defined in the class QuadEdge.
+ * All metric calculations are done in the Vertex class.
+ * In addition to a triangulation, subdivisions support extraction of Voronoi diagrams.
* This is easily accomplished, since the Voronoi diagram is the dual
* of the Delaunay triangulation.
- * <p>
* Subdivisions can be provided with a tolerance value. Inserted vertices which
* are closer than this value to vertices already in the subdivision will be
* ignored. Using a suitable tolerance value can prevent robustness failures
* from happening during Delaunay triangulation.
- * <p>
- * Subdivisions maintain a <b>frame</b> triangle around the client-created
+ * Subdivisions maintain a **frame** triangle around the client-created
* edges. The frame is used to provide a bounded "container" for all edges
* within a TIN. Normally the frame edges, frame connecting edges, and frame
* triangles are not included in client processing.
@@ -80,14 +79,13 @@ class GEOS_DLL QuadEdgeSubdivision {
public:
typedef std::vector<QuadEdge*> QuadEdgeList;
- * Gets the edges for the triangle to the left of the given {@link QuadEdge}.
+ /** \brief
+ * Gets the edges for the triangle to the left of the given QuadEdge.
* @param startQE
* @param triEdge
- * @throws IllegalArgumentException
- * if the edges do not form a triangle
+ * @throws IllegalArgumentException if the edges do not form a triangle
static void getTriangleEdges(const QuadEdge& startQE,
const QuadEdge* triEdge[3]);
@@ -103,15 +101,13 @@ private:
std::unique_ptr<QuadEdgeLocator> locator;
public:
+ /** \brief
* Creates a new instance of a quad-edge subdivision based on a frame triangle
- * that encloses a supplied bounding box. A new super-bounding box that
- * contains the triangle is computed and stored.
+ * that encloses a supplied bounding box.
+ * A new super-bounding box that contains the triangle is computed and stored.
- * @param env
- * the bouding box to surround
- * @param tolerance
- * the tolerance value for determining if two sites are equal
+ * @param env the bouding box to surround
+ * @param tolerance the tolerance value for determining if two sites are equal
QuadEdgeSubdivision(const geom::Envelope& env, double tolerance);
@@ -123,9 +119,8 @@ private:
virtual void initSubdiv(QuadEdge* initEdges[3]);
public:
- * Gets the vertex-equality tolerance value
- * used in this subdivision
+ /** \brief
+ * Gets the vertex-equality tolerance value used in this subdivision
* @return the tolerance value
@@ -135,7 +130,7 @@ public:
return tolerance;
+ /** \brief
* Gets the envelope of the Subdivision (including the frame).
* @return the envelope
@@ -146,7 +141,7 @@ public:
return frameEnv;
+ /** \brief
* Gets the collection of base {@link QuadEdge}s (one for every pair of
* vertices which is connected).
@@ -158,11 +153,11 @@ public:
return quadEdges;
- * Sets the {@link QuadEdgeLocator} to use for locating containing triangles
+ /** \brief
+ * Sets the QuadEdgeLocator to use for locating containing triangles
* in this subdivision.
- * @param locator
+ * @param p_locator
* a QuadEdgeLocator
inline void
@@ -171,7 +166,7 @@ public:
this->locator = std::move(p_locator);
+ /** \brief
* Creates a new quadedge, recording it in the edges list.
* @param o
@@ -180,10 +175,11 @@ public:
virtual QuadEdge& makeEdge(const Vertex& o, const Vertex& d);
+ /** \brief
* Creates a new QuadEdge connecting the destination of a to the origin of b,
* in such a way that all three have the same left face after the connection
- * is complete. The quadedge is recorded in the edges list.
+ * is complete.
+ * The quadedge is recorded in the edges list.
* @param a
* @param b
@@ -191,7 +187,7 @@ public:
virtual QuadEdge& connect(QuadEdge& a, QuadEdge& b);
+ /** \brief
* Deletes a quadedge from the subdivision. Linked quadedges are updated to
* reflect the deletion.
@@ -200,35 +196,37 @@ public:
void remove(QuadEdge& e);
+ /** \brief
* Locates an edge of a triangle which contains a location
- * specified by a Vertex v.
- * The edge returned has the
- * property that either v is on e, or e is an edge of a triangle containing v.
- * The search starts from startEdge amd proceeds on the general direction of v.
- * <p>
+ * specified by a Vertex `v`.
+ * The edge returned has the property that either v is on e,
+ * or e is an edge of a triangle containing v.
+ * The search starts from startEdge and proceeds on the general direction of v.
* This locate algorithm relies on the subdivision being Delaunay. For
* non-Delaunay subdivisions, this may loop for ever.
* @param v the location to search for
* @param startEdge an edge of the subdivision to start searching at
- * @returns a QuadEdge which contains v, or is on the edge of a triangle containing v
- * @throws LocateFailureException
- * if the location algorithm fails to converge in a reasonable
- * number of iterations. The returned pointer should not be
- * freed be the caller.
+ * @return a QuadEdge which contains v, or is on the edge of a triangle containing v
+ * @throws LocateFailureException if the location algorithm fails to converge in a
+ * reasonable number of iterations.
+ * @note The returned pointer **should not** be freed be the caller.
QuadEdge* locateFromEdge(const Vertex& v,
const QuadEdge& startEdge) const;
+ /** \brief
* Finds a quadedge of a triangle containing a location
- * specified by a {@link Vertex}, if one exists.
+ * specified by a [Vertex](@ref triangulate::quadedge::Vertex), if one exists.
+ * @param v the vertex to locate
+ * @return a QuadEdge on the edge of a triangle which touches or contains the location
+ * @return `null` if no such triangle exists.
- * @param x the vertex to locate
- * @return a quadedge on the edge of a triangle which touches or contains the location
- * @return null if no such triangle exists. The returned pointer should not be
inline QuadEdge*
locate(const Vertex& v) const
@@ -236,14 +234,15 @@ public:
return locator->locate(v);
+ /** \brief
- * specified by a {@link Coordinate}, if one exists.
+ * specified by a geom::Coordinate, if one exists.
* @param p the Coordinate to locate
inline QuadEdge*
locate(const geom::Coordinate& p)
@@ -251,97 +250,93 @@ public:
return locator->locate(Vertex(p));
+ /** \brief
* Locates the edge between the given vertices, if it exists in the
* subdivision.
* @param p0 a coordinate
* @param p1 another coordinate
* @return the edge joining the coordinates, if present
- * @return null if no such edge exists
- * @return the caller _should not_ free the returned pointer
+ * @return `null` if no such edge exists
+ * @note the caller **should not** free the returned pointer
QuadEdge* locate(const geom::Coordinate& p0, const geom::Coordinate& p1);
+ /** \brief
* Inserts a new site into the Subdivision, connecting it to the vertices of
* the containing triangle (or quadrilateral, if the split point falls on an
* existing edge).
- * <p>
* This method does NOT maintain the Delaunay condition. If desired, this must
* be checked and enforced by the caller.
- * <p>
* This method does NOT check if the inserted vertex falls on an edge. This
* must be checked by the caller, since this situation may cause erroneous
* triangulation
- * @param v
- * the vertex to insert
+ * @param v the vertex to insert
* @return a new quad edge terminating in v
QuadEdge& insertSite(const Vertex& v);
+ /** \brief
* Tests whether a QuadEdge is an edge incident on a frame triangle vertex.
- * @param e
- * the edge to test
- * @return true if the edge is connected to the frame triangle
+ * @param e the edge to test
+ * @return `true` if the edge is connected to the frame triangle
bool isFrameEdge(const QuadEdge& e) const;
+ /** \brief
* Tests whether a QuadEdge is an edge on the border of the frame facets and
* the internal facets. E.g. an edge which does not itself touch a frame
* vertex, but which touches an edge which does.
- * @param e
- * @return true if the edge is on the border of the frame
+ * @return `true` if the edge is on the border of the frame
bool isFrameBorderEdge(const QuadEdge& e) const;
+ /** \brief
* Tests whether a vertex is a vertex of the outer triangle.
- * @param v
- * the vertex to test
- * @return true if the vertex is an outer triangle vertex
+ * @param v the vertex to test
+ * @return `true` if the vertex is an outer triangle vertex
bool isFrameVertex(const Vertex& v) const;
- * Tests whether a {@link Coordinate} lies on a {@link QuadEdge}, up to a
- * tolerance determined by the subdivision tolerance.
+ /** \brief
+ * Tests whether a [Coordinate](@ref geom::Coordinate) lies on a QuadEdge,
+ * up to a tolerance determined by the subdivision tolerance.
- * @param e
- * a QuadEdge
- * @param p
- * a point
- * @return true if the vertex lies on the edge
+ * @param e a QuadEdge
+ * @param p a point
+ * @return `true` if the vertex lies on the edge
bool isOnEdge(const QuadEdge& e, const geom::Coordinate& p) const;
- * Tests whether a {@link Vertex} is the start or end vertex of a
- * {@link QuadEdge}, up to the subdivision tolerance distance.
+ /** \brief
+ * Tests whether a Vertex is the start or end vertex of a
+ * QuadEdge, up to the subdivision tolerance distance.
* @param e
* @param v
- * @return true if the vertex is a endpoint of the edge
+ * @return `true` if the vertex is a endpoint of the edge
bool isVertexOfEdge(const QuadEdge& e, const Vertex& v) const;
+ /** \brief
* Gets all primary quadedges in the subdivision.
- * A primary edge is a {@link QuadEdge}
- * which occupies the 0'th position in its array of associated quadedges.
- * These provide the unique geometric edges of the triangulation.
- * @param includeFrame true if the frame edges are to be included
+ * A primary edge is a QuadEdge which occupies the 0'th position in its
+ * array of associated quadedges. These provide the unique geometric
+ * edges of the triangulation.
+ * @param includeFrame `true` if the frame edges are to be included
* @return a List of QuadEdges. The caller takes ownership of the returned QuadEdgeList but not the
- * items it contains.
+ * items it contains.
std::unique_ptr<QuadEdgeList> getPrimaryEdges(bool includeFrame);
@@ -356,14 +351,14 @@ private:
typedef std::unordered_set<QuadEdge*> QuadEdgeSet;
typedef std::vector<geom::CoordinateSequence*> TriList;
+ /** \brief
* The quadedges forming a single triangle.
- * Only one visitor is allowed to be active at a
- * time, so this is safe.
+ * Only one visitor is allowed to be active at a time, so this is safe.
QuadEdge* triEdges[3];
+ /** \brief
* Stores the edges for a visited triangle. Also pushes sym (neighbour) edges
* on stack to visit later.
@@ -371,17 +366,16 @@ private:
* @param edgeStack
* @return the visited triangle edges
- * @return null if the triangle should not be visited (for instance, if it is
+ * @return `null` if the triangle should not be visited (for instance, if it is
* outer)
QuadEdge** fetchTriangleToVisit(QuadEdge* edge, QuadEdgeStack& edgeStack, bool includeFrame,
QuadEdgeSet& visitedEdges);
+ /** \brief
* Gets the coordinates for each triangle in the subdivision as an array.
- * true if the frame triangles should be included
+ * @param includeFrame true if the frame triangles should be included
* @param triList a list of Coordinate[4] representing each triangle
void getTriangleCoordinates(TriList* triList, bool includeFrame);
@@ -391,29 +385,35 @@ private:
class TriangleCircumcentreVisitor;
public:
- * Gets the geometry for the edges in the subdivision as a {@link MultiLineString}
+ /** \brief
+ * Gets the geometry for the edges in the subdivision as a [MultiLineString](@ref geom::MultiLineString)
* containing 2-point lines.
* @param geomFact the GeometryFactory to use
- * @return a MultiLineString. The caller takes ownership of the returned object.
+ * @return a MultiLineString
+ * @note The caller takes ownership of the returned object.
std::unique_ptr<geom::MultiLineString> getEdges(const geom::GeometryFactory& geomFact);
- * Gets the geometry for the triangles in a triangulated subdivision as a {@link GeometryCollection}
- * of triangular {@link Polygon}s.
+ /** \brief
+ * Gets the geometry for the triangles in a triangulated subdivision as a
+ * [GeometryCollection](@ref geos::geom::GeometryCollection)
+ * of triangular [Polygons](@ref geos::geom::Polygon).
- * @return a GeometryCollection of triangular Polygons. The caller takes ownership of the returned object.
+ * @return a GeometryCollection of triangular polygons.
std::unique_ptr<geom::GeometryCollection> getTriangles(const geom::GeometryFactory& geomFact);
+ /** \brief
* Gets the cells in the Voronoi diagram for this triangulation.
- * The cells are returned as a {@link GeometryCollection} of {@link Polygon}s
- * The userData of each polygon is set to be the {@link Coordinate}
- * of the cell site. This allows easily associating external
+ * The cells are returned as a [GeometryCollection](@ref geom::GeometryCollection)
+ * of [Polygons](@ref geom::Polygon).
+ * The userData of each polygon is set to be the [Coordinate](@ref geom::Coordinate)
+ * of the cell site. This allows easily associating external
* data associated with the sites to the cells.
* @param geomFact a geometry factory
@@ -421,11 +421,12 @@ public:
std::unique_ptr<geom::GeometryCollection> getVoronoiDiagram(const geom::GeometryFactory& geomFact);
+ /** \brief
- * The cells are returned as a {@link GeometryCollection} of {@link LineString}s
+ * The cells are returned as a [GeometryCollection](@ref geom::GeometryCollection) of
+ * [LineStrings](@ref geom::LineString). The userData of each polygon is set to be the
+ * [Coordinate](@ref geom::Coordinate) of the cell site. This allows easily associating external
@@ -433,23 +434,25 @@ public:
std::unique_ptr<geom::MultiLineString> getVoronoiDiagramEdges(const geom::GeometryFactory& geomFact);
- * Gets a List of {@link Polygon}s for the Voronoi cells
+ /** \brief
+ * Gets a List of [Polygons](@ref geom::Polygon) for the Voronoi cells
* of this triangulation.
- * data associated with the sites to the cells.
+ * of the cell site. This allows easily associating external data associated
+ * with the sites to the cells.
* @return a List of Polygons
std::vector<std::unique_ptr<geom::Geometry>> getVoronoiCellPolygons(const geom::GeometryFactory& geomFact);
- * Gets a List of {@link LineString}s for the Voronoi cells
+ /** \brief
+ * Gets a List of [LineStrings](@ref geom::LineString) for the Voronoi cells
- * The userData of each LineString is set to be the {@link Coordinate}
+ * The userData of each LineString is set to be the [Coordinate](@ref geom::Coordinate)
@@ -457,30 +460,27 @@ public:
std::unique_ptr< std::vector<geom::Geometry*> > getVoronoiCellEdges(const geom::GeometryFactory& geomFact);
- * Gets a collection of {@link QuadEdge}s whose origin
- * vertices are a unique set which includes
- * all vertices in the subdivision.
- * The frame vertices can be included if required.
- * This is useful for algorithms which require traversing the
- * subdivision starting at all vertices.
- * Returning a quadedge for each vertex
- * is more efficient than
- * the alternative of finding the actual vertices
- * using {@link #getVertices} and then locating
+ /** \brief
+ * Gets a collection of [QuadEdges](@ref QuadEdge) whose origin vertices are a unique set
+ * which includes all vertices in the subdivision.
+ * The frame vertices can be included if required. This is useful for algorithms which require
+ * traversing the subdivision starting at all vertices.
+ * Returning a quadedge for each vertex is more efficient than the alternative
+ * of finding the actual vertices using `getVertices()` and then locating
* quadedges attached to them.
- * @param includeFrame true if the frame vertices should be included
+ * @param includeFrame `true` if the frame vertices should be included
* @return a collection of QuadEdge with the vertices of the subdivision as their origins
std::unique_ptr<QuadEdgeSubdivision::QuadEdgeList> getVertexUniqueEdges(bool includeFrame);
- * Gets the Voronoi cell around a site specified
- * by the origin of a QuadEdge.
- * The userData of the polygon is set to be the {@link Coordinate}
- * of the site. This allows attaching external
- * data associated with the site to this cell polygon.
+ /** \brief
+ * Gets the Voronoi cell around a site specified by the origin of a QuadEdge.
+ * The userData of the polygon is set to be the [Coordinate](@ref geom::Coordinate)
+ * of the site. This allows attaching external data associated with the site
+ * to this cell polygon.
* @param qe a quadedge originating at the cell site
* @param geomFact a factory for building the polygon
@@ -488,12 +488,12 @@ public:
std::unique_ptr<geom::Geometry> getVoronoiCellPolygon(const QuadEdge* qe, const geom::GeometryFactory& geomFact);
- * Gets the Voronoi cell edge around a site specified
- * The userData of the LineString is set to be the {@link Coordinate}
+ /** \brief
+ * Gets the Voronoi cell edge around a site specified by the origin of a QuadEdge.
+ * The userData of the LineString is set to be the [Coordinate](@ref geom::Coordinate)
+ * the site to this cell polygon.
diff --git a/include/geos/triangulate/quadedge/Vertex.h b/include/geos/triangulate/quadedge/Vertex.h
index b9137a3..b08f4dd 100644
--- a/include/geos/triangulate/quadedge/Vertex.h
+++ b/include/geos/triangulate/quadedge/Vertex.h
@@ -39,19 +39,17 @@ namespace geos {
- * Models a site (node) in a {@link QuadEdgeSubdivision}.
- * The sites can be points on a line string representing a
- * linear site.
+/** \brief
+ * Models a site (node) in a QuadEdgeSubdivision.
+ * The sites can be points on a line string representing a linear site.
* The vertex can be considered as a vector with a norm, length, inner product, cross
* product, etc. Additionally, point relations (e.g., is a point to the left of a line, the circle
* defined by this point and two others, etc.) are also defined in this class.
- * It is common to want to attach user-defined data to
- * the vertices of a subdivision.
- * One way to do this is to subclass <tt>Vertex</tt>
- * to carry any desired information (see {@link ConstraintVertex}).
+ * It is common to want to attach user-defined data to the vertices of a subdivision.
+ * One way to do this is to subclass `Vertex` to carry any desired information.
diff --git a/include/geos/util/CoordinateArrayFilter.h b/include/geos/util/CoordinateArrayFilter.h
index e7c4d12..90ce416 100644
--- a/include/geos/util/CoordinateArrayFilter.h
+++ b/include/geos/util/CoordinateArrayFilter.h
@@ -26,7 +26,7 @@
namespace geos {
namespace util { // geos::util
+/** \brief
* A CoordinateFilter that adds read-only pointers
* to every Coordinate in a Geometry to a given
* vector.
@@ -37,10 +37,10 @@ class GEOS_DLL CoordinateArrayFilter: public geom::CoordinateFilter {
private:
geom::Coordinate::ConstVect& pts; // target vector reference
public:
+ /** \brief
* Constructs a CoordinateArrayFilter.
- * @param target The destination vector.
+ * @param target The destination vector.
CoordinateArrayFilter(geom::Coordinate::ConstVect& target)
diff --git a/src/operation/valid/IndexedNestedRingTester.h b/src/operation/valid/IndexedNestedRingTester.h
index c72e514..f7b8c33 100644
--- a/src/operation/valid/IndexedNestedRingTester.h
+++ b/src/operation/valid/IndexedNestedRingTester.h
@@ -41,7 +41,7 @@ namespace operation { // geos.operation
namespace valid { // geos.operation.valid
/** \brief
* nested inside another ring in the set, using a spatial
Summary of changes:
include/geos/algorithm/BoundaryNodeRule.h | 56 +++-
include/geos/algorithm/Centroid.h | 50 ++--
include/geos/algorithm/HCoordinate.h | 12 +-
include/geos/algorithm/MinimumDiameter.h | 54 ++--
include/geos/algorithm/Orientation.h | 80 +++---
include/geos/algorithm/PointLocation.h | 93 +++----
include/geos/algorithm/RayCrossingCounter.h | 73 ++---
include/geos/algorithm/RayCrossingCounterDD.h | 83 +++---
.../geos/algorithm/locate/PointOnGeometryLocator.h | 6 +-
.../algorithm/locate/SimplePointInAreaLocator.h | 76 +++---
include/geos/algorithm/ttmath/ttmathtypes.h | 2 +-
include/geos/geom.h | 4 +-
include/geos/geom/CoordinateArraySequence.h | 2 +-
include/geos/geom/CoordinateFilter.h | 18 +-
include/geos/geom/CoordinateSequenceFilter.h | 77 +++---
include/geos/geom/Envelope.h | 268 ++++++++----------
include/geos/geom/Geometry.h | 4 +-
include/geos/geom/LineString.h | 2 +-
include/geos/geom/LinearRing.h | 22 +-
include/geos/geom/MultiLineString.h | 30 +-
include/geos/geom/PrecisionModel.h | 5 +-
include/geos/geom/util/GeometryExtracter.h | 2 +-
include/geos/geom/util/GeometryTransformer.h | 43 ++-
include/geos/geomgraph/DirectedEdgeStar.h | 22 +-
include/geos/geomgraph/EdgeNodingValidator.h | 6 +-
include/geos/geomgraph/GeometryGraph.h | 19 +-
include/geos/geomgraph/Position.h | 18 +-
include/geos/index/bintree/Bintree.h | 27 +-
include/geos/index/chain/MonotoneChainBuilder.h | 19 +-
.../geos/index/chain/MonotoneChainOverlapAction.h | 19 +-
include/geos/index/strtree/AbstractSTRtree.h | 40 +--
include/geos/index/strtree/BoundablePair.h | 29 +-
include/geos/index/strtree/ItemDistance.h | 9 +-
include/geos/index/strtree/SIRtree.h | 1 +
include/geos/linearref/ExtractLineByLocation.h | 16 +-
include/geos/linearref/LengthIndexedLine.h | 55 ++--
include/geos/linearref/LengthLocationMap.h | 40 +--
include/geos/linearref/LinearGeometryBuilder.h | 24 +-
include/geos/linearref/LinearIterator.h | 50 ++--
include/geos/linearref/LinearLocation.h | 119 ++++----
include/geos/linearref/LocationIndexOfLine.h | 37 +--
include/geos/linearref/LocationIndexOfPoint.h | 36 +--
include/geos/linearref/LocationIndexedLine.h | 20 +-
include/geos/noding/BasicSegmentString.h | 32 +--
include/geos/noding/FastNodingValidator.h | 14 +-
.../geos/noding/FastSegmentSetIntersectionFinder.h | 2 +-
include/geos/noding/IntersectionAdder.h | 47 ++--
include/geos/noding/IntersectionFinderAdder.h | 14 +-
include/geos/noding/IteratedNoder.h | 15 +-
include/geos/noding/MCIndexNoder.h | 11 +-
.../noding/MCIndexSegmentSetMutualIntersector.h | 11 +-
include/geos/noding/NodedSegmentString.h | 13 +-
include/geos/noding/Noder.h | 8 +-
include/geos/noding/NodingIntersectionFinder.h | 113 ++++----
include/geos/noding/OrientedCoordinateArray.h | 2 +-
include/geos/noding/SegmentIntersectionDetector.h | 26 +-
include/geos/noding/SegmentSetMutualIntersector.h | 10 +-
include/geos/noding/SegmentString.h | 10 +-
include/geos/noding/SegmentStringUtil.h | 6 +-
include/geos/noding/SinglePassNoder.h | 15 +-
.../geos/noding/snapround/MCIndexPointSnapper.h | 16 +-
include/geos/opOverlay.h | 3 +-
include/geos/operation/IsSimpleOp.h | 28 +-
include/geos/operation/buffer/BufferBuilder.h | 2 +-
include/geos/operation/buffer/BufferOp.h | 30 +-
include/geos/operation/buffer/OffsetCurveBuilder.h | 28 +-
.../geos/operation/buffer/OffsetCurveSetBuilder.h | 11 +-
.../distance/ConnectedElementLocationFilter.h | 22 +-
include/geos/operation/intersection/Rectangle.h | 34 +--
.../operation/intersection/RectangleIntersection.h | 24 +-
.../intersection/RectangleIntersectionBuilder.h | 6 +-
.../operation/linemerge/LineMergeDirectedEdge.h | 34 +--
include/geos/operation/linemerge/LineSequencer.h | 58 ++--
include/geos/operation/overlay/MaximalEdgeRing.h | 4 +-
include/geos/operation/overlay/MinimalEdgeRing.h | 6 +-
include/geos/operation/overlay/OverlayOp.h | 26 +-
.../operation/overlay/snap/SnapIfNeededOverlayOp.h | 8 +-
.../geos/operation/predicate/RectangleIntersects.h | 2 +-
include/geos/operation/relate/RelateOp.h | 12 +-
.../geos/operation/union/CascadedPolygonUnion.h | 56 ++--
include/geos/operation/union/PointGeometryUnion.h | 4 +-
include/geos/operation/union/UnaryUnionOp.h | 26 +-
.../geos/operation/valid/ConsistentAreaTester.h | 4 +-
include/geos/operation/valid/IsValidOp.h | 39 ++-
.../operation/valid/QuadtreeNestedRingTester.h | 4 +-
.../geos/operation/valid/SimpleNestedRingTester.h | 2 +-
.../operation/valid/SweeplineNestedRingTester.h | 5 +-
.../geos/operation/valid/TopologyValidationError.h | 2 +-
include/geos/planargraph/DirectedEdge.h | 14 +-
include/geos/planargraph/Edge.h | 17 +-
include/geos/planargraph/PlanarGraph.h | 3 +-
include/geos/planargraph/Subgraph.h | 46 ++--
include/geos/precision/CommonBitsOp.h | 20 +-
include/geos/simplify/TaggedLinesSimplifier.h | 16 +-
.../triangulate/DelaunayTriangulationBuilder.h | 2 +-
include/geos/triangulate/VoronoiDiagramBuilder.h | 38 +--
include/geos/triangulate/quadedge/QuadEdge.h | 101 +++----
.../triangulate/quadedge/QuadEdgeSubdivision.h | 302 ++++++++++-----------
include/geos/triangulate/quadedge/Vertex.h | 14 +-
include/geos/util/CoordinateArrayFilter.h | 6 +-
src/operation/valid/IndexedNestedRingTester.h | 2 +-
101 files changed, 1561 insertions(+), 1533 deletions(-)
hooks/post-receive
More information about the geos-commits
