[geos-commits] [SCM] GEOS branch master updated. c897e468c7c0856d241928b95c92883794544f73
git at osgeo.org
git at osgeo.org
Sun Jun 16 17:30:37 PDT 2019
the project "GEOS".
via c897e468c7c0856d241928b95c92883794544f73 (commit)
via f53d0bc506f78607850c696e3ca294be3fdf9340 (commit)
from 67bdb2e1fbdbc8db4d4bc0d21bd6e3ab6ebe71b0 (commit)
revisions in full, below.
commit c897e468c7c0856d241928b95c92883794544f73
Merge: 67bdb2e f53d0bc
Author: Daniel Baston <dbaston at gmail.com>
Date: Sun Jun 16 20:30:26 2019 -0400
Merge branch 'polygon-linearring'
commit f53d0bc506f78607850c696e3ca294be3fdf9340
Date: Thu Jun 13 20:27:12 2019 -0400
Handle Polygon rings as LinearRings
This removes the need for numerous dynamic casts.
Related:
JTS 992948a3312be5ad9bf97fc50b3c3a0de3acece1
JTS af8aee0ba345d5f5f8c845c721d9df20fac3bd3d
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 111dc08..c2c2c3b 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -74,6 +74,7 @@
#include <geos/linearref/LengthIndexedLine.h>
#include <geos/triangulate/DelaunayTriangulationBuilder.h>
#include <geos/triangulate/VoronoiDiagramBuilder.h>
+#include <geos/util.h>
#include <geos/util/IllegalArgumentException.h>
#include <geos/util/Interrupt.h>
#include <geos/util/UniqueCoordinateArrayFilter.h>
@@ -4181,17 +4182,24 @@ extern "C" {
try {
using geos::geom::LinearRing;
- std::vector<Geometry*>* vholes = new std::vector<Geometry*>(holes, holes + nholes);
+ auto vholes = geos::detail::make_unique<std::vector<LinearRing*>>(nholes);
+ for (size_t i = 0; i < nholes; i++) {
+ (*vholes)[i] = dynamic_cast<LinearRing*>(holes[i]);
+ if ((*vholes)[i] == nullptr) {
+ handle->ERROR_MESSAGE("Hole is not a LinearRing");
+ return NULL;
LinearRing* nshell = dynamic_cast<LinearRing*>(shell);
if(! nshell) {
handle->ERROR_MESSAGE("Shell is not a LinearRing");
- delete vholes;
return NULL;
const GeometryFactory* gf = handle->geomFactory;
- return gf->createPolygon(nshell, vholes);
+ return gf->createPolygon(nshell, vholes.release());
catch(const std::exception& e) {
handle->ERROR_MESSAGE("%s", e.what());
diff --git a/doc/example.cpp b/doc/example.cpp
index c1294ba..68eb354 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -295,9 +295,8 @@ create_square_polygon(double xoffset, double yoffset, double side)
yoffset + (side / 3), (side / 3));
// If we need to specify any hole, we do it using
- // a vector of Geometry pointers (I don't know why
- // not LinearRings)
- vector<Geometry*>* holes = new vector<Geometry*>;
+ // a vector of LinearRing pointers
+ vector<LinearRing*>* holes = new vector<LinearRing*>;
// We add the newly created geometry to the vector
// of holes.
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index b7aef91..a3dc7a2 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -38,6 +38,7 @@
#include <geos/geom/GeometryComponentFilter.h> // for inheritance
#include <geos/geom/IntersectionMatrix.h>
+#include <algorithm>
#include <string>
#include <iostream>
#include <vector>
@@ -835,13 +836,19 @@ protected:
mutable std::unique_ptr<Envelope> envelope;
/// Returns true if the array contains any non-empty Geometrys.
- static bool hasNonEmptyElements(const std::vector<Geometry*>* geometries);
+ template<typename T>
+ static bool hasNonEmptyElements(const std::vector<T*>* geometries) {
+ return std::any_of(geometries->begin(), geometries->end(), [](const Geometry* g) { return !g->isEmpty(); });
/// Returns true if the CoordinateSequence contains any null elements.
static bool hasNullElements(const CoordinateSequence* list);
/// Returns true if the vector contains any null elements.
- static bool hasNullElements(const std::vector<Geometry*>* lrs);
+ static bool hasNullElements(const std::vector<T*>* geometries) {
+ return std::any_of(geometries->begin(), geometries->end(), [](const Geometry* g) { return g == nullptr; });
// static void reversePointOrder(CoordinateSequence* coordinates);
// static Coordinate& minCoordinate(CoordinateSequence* coordinates);
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index e90cef9..a44b8f9 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -249,11 +249,11 @@ public:
/// Construct a Polygon taking ownership of given arguments
Polygon* createPolygon(LinearRing* shell,
- std::vector<Geometry*>* holes) const;
+ std::vector<LinearRing*>* holes) const;
/// Construct a Polygon with a deep-copy of given arguments
Polygon* createPolygon(const LinearRing& shell,
- const std::vector<Geometry*>& holes) const;
+ const std::vector<LinearRing*>& holes) const;
/// Construct an EMPTY LineString
LineString* createLineString() const;
diff --git a/include/geos/geom/Polygon.h b/include/geos/geom/Polygon.h
index 5013830..ff0fa38 100644
--- a/include/geos/geom/Polygon.h
+++ b/include/geos/geom/Polygon.h
@@ -27,6 +27,7 @@
#include <geos/geom/Geometry.h> // for inheritance
#include <geos/geom/Polygonal.h> // for inheritance
#include <geos/geom/Envelope.h> // for proper use of unique_ptr<>
+#include <geos/geom/LinearRing.h>
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
#include <geos/inline.h>
@@ -39,7 +40,6 @@ namespace geom { // geos::geom
class Coordinate;
class CoordinateArraySequence;
class CoordinateSequenceFilter;
-class LinearRing;
class LineString;
@@ -109,13 +109,13 @@ public:
bool isEmpty() const override;
/// Returns the exterior ring (shell)
- const LineString* getExteriorRing() const;
+ const LinearRing* getExteriorRing() const;
/// Returns number of interior rings (hole)
size_t getNumInteriorRing() const;
/// Get nth interior ring (hole)
- const LineString* getInteriorRingN(std::size_t n) const;
+ const LinearRing* getInteriorRingN(std::size_t n) const;
std::string getGeometryType() const override;
GeometryTypeId getGeometryTypeId() const override;
@@ -169,12 +169,12 @@ protected:
* Polygon will take ownership of Shell and Holes LinearRings
- Polygon(LinearRing* newShell, std::vector<Geometry*>* newHoles,
+ Polygon(LinearRing* newShell, std::vector<LinearRing*>* newHoles,
const GeometryFactory* newFactory);
LinearRing* shell;
- std::vector<Geometry*>* holes; //Actually vector<LinearRing *>
+ std::vector<LinearRing*>* holes;
Envelope::Ptr computeEnvelopeInternal() const override;
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 5371a19..c218dd2 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -75,7 +75,7 @@ private:
std::unique_ptr<geom::CoordinateArraySequence> ringPts;
std::unique_ptr<algorithm::locate::PointOnGeometryLocator> ringLocator;
- std::unique_ptr<std::vector<geom::Geometry*>> holes;
+ std::unique_ptr<std::vector<geom::LinearRing*>> holes;
EdgeRing* shell = nullptr;
bool is_hole;
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index 6239249..379083c 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -160,10 +160,10 @@ public:
interiorPoint = *polygon.getCoordinate();
- const LinearRing* shell = dynamic_cast<const LinearRing*>(polygon.getExteriorRing());
+ const LinearRing* shell = polygon.getExteriorRing();
scanRing(*shell, crossings);
for (size_t i = 0; i < polygon.getNumInteriorRing(); i++) {
- const LinearRing* hole = dynamic_cast<const LinearRing*>(polygon.getInteriorRingN(i));
+ const LinearRing* hole = polygon.getInteriorRingN(i);
scanRing(*hole, crossings);
findBestMidpoint(crossings);
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index a32143f..6b4ef7c 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -177,7 +177,7 @@ PointLocator::locate(const Coordinate& p, const Polygon* poly)
return Location::EXTERIOR;
- const LinearRing* shell = dynamic_cast<const LinearRing*>(poly->getExteriorRing());
+ const LinearRing* shell = poly->getExteriorRing();
assert(shell);
int shellLoc = locateInPolygonRing(p, shell);
@@ -190,7 +190,7 @@ PointLocator::locate(const Coordinate& p, const Polygon* poly)
// now test if the point lies in or on the holes
for(size_t i = 0, n = poly->getNumInteriorRing(); i < n; ++i) {
- const LinearRing* hole = dynamic_cast<const LinearRing*>(poly->getInteriorRingN(i));
+ const LinearRing* hole = poly->getInteriorRingN(i);
int holeLoc = locateInPolygonRing(p, hole);
if(holeLoc == Location::INTERIOR) {
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index c466552..a050d0e 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -136,17 +136,6 @@ Geometry::Geometry(const Geometry& geom)
bool
-Geometry::hasNonEmptyElements(const vector<Geometry*>* geometries)
- for(size_t i = 0; i < geometries->size(); i++) {
- if(!(*geometries)[i]->isEmpty()) {
- return true;
- return false;
-bool
Geometry::hasNullElements(const CoordinateSequence* list)
size_t npts = list->getSize();
@@ -158,18 +147,6 @@ Geometry::hasNullElements(const CoordinateSequence* list)
return false;
-bool
-Geometry::hasNullElements(const vector<Geometry*>* lrs)
- size_t n = lrs->size();
- for(size_t i = 0; i < n; ++i) {
- if((*lrs)[i] == nullptr) {
- return true;
- return false;
/* public */
bool
Geometry::isWithinDistance(const Geometry* geom, double cDistance) const
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index c958227..e7f3d2d 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -598,7 +598,7 @@ GeometryFactory::createPolygon() const
/*public*/
Polygon*
-GeometryFactory::createPolygon(LinearRing* shell, vector<Geometry*>* holes)
+GeometryFactory::createPolygon(LinearRing* shell, vector<LinearRing*>* holes)
const
return new Polygon(shell, holes, this);
@@ -606,13 +606,13 @@ const
/*public*/
Polygon*
-GeometryFactory::createPolygon(const LinearRing& shell, const vector<Geometry*>& holes)
+GeometryFactory::createPolygon(const LinearRing& shell, const vector<LinearRing*>& holes)
const
- LinearRing* newRing = dynamic_cast<LinearRing*>(shell.clone().release());
- vector<Geometry*>* newHoles = new vector<Geometry*>(holes.size());
+ LinearRing* newRing = new LinearRing(shell);
+ vector<LinearRing*>* newHoles = new vector<LinearRing*>(holes.size());
for(size_t i = 0; i < holes.size(); i++) {
- (*newHoles)[i] = holes[i]->clone().release();
+ (*newHoles)[i] = new LinearRing(*(holes[i]));
Polygon* g = nullptr;
try {
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 2fe58e8..99b0685 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -57,19 +57,15 @@ Polygon::Polygon(const Polygon& p)
shell = new LinearRing(*p.shell);
size_t nholes = p.holes->size();
- holes = new vector<Geometry*>(nholes);
+ holes = new vector<LinearRing*>(nholes);
for(size_t i = 0; i < nholes; ++i) {
- // TODO: holes is a vector of Geometry, anyway
- // so there's no point in casting here,
- // just use ->clone instead !
- const LinearRing* lr = dynamic_cast<const LinearRing*>((*p.holes)[i]);
- LinearRing* h = new LinearRing(*lr);
+ LinearRing* h = new LinearRing(*(*p.holes)[i]);
(*holes)[i] = h;
/*protected*/
-Polygon::Polygon(LinearRing* newShell, vector<Geometry*>* newHoles,
+Polygon::Polygon(LinearRing* newShell, vector<LinearRing*>* newHoles,
const GeometryFactory* newFactory):
Geometry(newFactory)
@@ -84,7 +80,7 @@ Polygon::Polygon(LinearRing* newShell, vector<Geometry*>* newHoles,
if(newHoles == nullptr) {
- holes = new vector<Geometry*>();
+ holes = new vector<LinearRing*>();
else {
if(hasNullElements(newHoles)) {
@@ -117,7 +113,7 @@ Polygon::getCoordinates() const
// Add holes points
size_t nholes = holes->size();
- const LinearRing* lr = dynamic_cast<const LinearRing*>((*holes)[i]);
+ const LinearRing* lr = (*holes)[i];
const CoordinateSequence* childCoords = lr->getCoordinatesRO();
childCoords->toVector(*cl);
@@ -129,8 +125,7 @@ size_t
Polygon::getNumPoints() const
size_t numPoints = shell->getNumPoints();
- for(size_t i = 0, n = holes->size(); i < n; ++i) {
+ for(const LinearRing* lr : *holes) {
numPoints += lr->getNumPoints();
return numPoints;
@@ -171,7 +166,7 @@ Polygon::isEmpty() const
return shell->isEmpty();
-const LineString*
+const LinearRing*
Polygon::getExteriorRing() const
return shell;
@@ -183,11 +178,10 @@ Polygon::getNumInteriorRing() const
return holes->size();
-const LineString*
+const LinearRing*
Polygon::getInteriorRingN(size_t n) const
- const LinearRing* lr = dynamic_cast<const LinearRing*>((*holes)[n]);
- return lr;
+ return (*holes)[n];
string
@@ -221,7 +215,7 @@ Polygon::getBoundary() const
(*rings)[0] = gf->createLineString(*shell).release();
- const LinearRing* hole = dynamic_cast<const LinearRing*>((*holes)[i]);
+ const LinearRing* hole = (*holes)[i];
assert(hole);
LineString* ls = gf->createLineString(*hole).release();
(*rings)[i + 1] = ls;
@@ -269,8 +263,7 @@ void
Polygon::apply_ro(CoordinateFilter* filter) const
shell->apply_ro(filter);
lr->apply_ro(filter);
@@ -279,8 +272,7 @@ void
Polygon::apply_rw(const CoordinateFilter* filter)
shell->apply_rw(filter);
- LinearRing* lr = dynamic_cast<LinearRing*>((*holes)[i]);
+ for(LinearRing* lr : *holes) {
lr->apply_rw(filter);
@@ -307,8 +299,7 @@ void
Polygon::normalize()
normalize(shell, true);
normalize(lr, false);
sort(holes->begin(), holes->end(), GeometryGreaterThen());
@@ -364,8 +355,7 @@ Polygon::getArea() const
double area = 0.0;
area += fabs(algorithm::Area::ofRing(shell->getCoordinatesRO()));
const CoordinateSequence* h = lr->getCoordinatesRO();
area -= fabs(algorithm::Area::ofRing(h));
@@ -508,13 +498,13 @@ Polygon::reverse() const
auto* exteriorRingReversed = dynamic_cast<LinearRing*>(shell->reverse().release());
- auto* interiorRingsReversed = new std::vector<Geometry*> {holes->size()};
+ auto* interiorRingsReversed = new std::vector<LinearRing*> {holes->size()};
std::transform(holes->begin(),
holes->end(),
interiorRingsReversed->begin(),
[](const Geometry * g) {
- return g->reverse().release();
+ return dynamic_cast<LinearRing*>(g->reverse().release());
return std::unique_ptr<Geometry>(getFactory()->createPolygon(exteriorRingReversed, interiorRingsReversed));
diff --git a/src/geom/util/GeometryEditor.cpp b/src/geom/util/GeometryEditor.cpp
index 64d0946..320d9b5 100644
--- a/src/geom/util/GeometryEditor.cpp
+++ b/src/geom/util/GeometryEditor.cpp
@@ -130,7 +130,7 @@ GeometryEditor::editPolygon(const Polygon* polygon, GeometryEditorOperation* ope
return factory->createPolygon(nullptr, nullptr);
for(size_t i = 0, n = newPolygon->getNumInteriorRing(); i < n; ++i) {
Geometry* hole_geom = edit(newPolygon->getInteriorRingN(i),
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 1bd9637..49f3f08 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -292,10 +292,9 @@ GeometryTransformer::transformPolygon(
isAllValidLinearRings = false;
- vector<Geometry*>* holes = new vector<Geometry*>();
+ vector<LinearRing*>* holes = new vector<LinearRing*>();
for(size_t i = 0, n = geom->getNumInteriorRing(); i < n; i++) {
- const LinearRing* p_lr = dynamic_cast<const LinearRing*>(
- geom->getInteriorRingN(i));
+ const LinearRing* p_lr = geom->getInteriorRingN(i);
assert(p_lr);
Geometry::Ptr hole(transformLinearRing(p_lr, geom));
@@ -311,7 +310,7 @@ GeometryTransformer::transformPolygon(
- holes->push_back(hole.release());
+ holes->push_back(dynamic_cast<LinearRing*>(hole.release()));
if(isAllValidLinearRings) {
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index d24e4c0..89d2749 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -165,10 +165,9 @@ EdgeRing::toPolygon(const GeometryFactory* p_geometryFactory)
testInvariant();
size_t nholes = holes.size();
- vector<Geometry*>* holeLR = new vector<Geometry*>(nholes);
+ vector<LinearRing*>* holeLR = new vector<LinearRing*>(nholes);
- Geometry* hole = holes[i]->getLinearRing()->clone().release();
- (*holeLR)[i] = hole;
+ (*holeLR)[i] = new LinearRing(*(holes[i]->getLinearRing()));
// We don't use "clone" here because
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index d18f47d..eaa140b 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -275,20 +275,14 @@ GeometryGraph::addPolygonRing(const LinearRing* lr, int cwLeft, int cwRight)
void
GeometryGraph::addPolygon(const Polygon* p)
- const LineString* ls;
- const LinearRing* lr;
+ const LinearRing* lr = p->getExteriorRing();
- ls = p->getExteriorRing();
- assert(dynamic_cast<const LinearRing*>(ls));
- lr = static_cast<const LinearRing*>(ls);
addPolygonRing(lr, Location::EXTERIOR, Location::INTERIOR);
for(size_t i = 0, n = p->getNumInteriorRing(); i < n; ++i) {
// Holes are topologically labelled opposite to the shell, since
// the interior of the polygon lies on their opposite side
// (on the left, if the hole is oriented CW)
- ls = p->getInteriorRingN(i);
+ lr = p->getInteriorRingN(i);
addPolygonRing(lr, Location::INTERIOR, Location::EXTERIOR);
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 4b04b6d..6b29aac 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -319,12 +319,12 @@ WKBReader::readPolygon()
shell = readLinearRing();
- vector<Geometry*>* holes = nullptr;
+ vector<LinearRing*>* holes = nullptr;
if(numRings > 1) {
try {
- holes = new vector<Geometry*>(numRings - 1);
+ holes = new vector<LinearRing*>(numRings - 1);
for(int i = 0; i < numRings - 1; i++) {
- (*holes)[i] = (Geometry*)readLinearRing();
+ (*holes)[i] = readLinearRing();
catch(...) {
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index b697292..544fd38 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -375,7 +375,7 @@ WKTReader::readPolygonText(StringTokenizer* tokenizer)
return geometryFactory->createPolygon(nullptr, nullptr);
try {
shell = readLinearRingText(tokenizer);
nextToken = getNextCloserOrComma(tokenizer);
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 802cd51..ed3522c 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -226,8 +226,7 @@ OffsetCurveSetBuilder::addPolygon(const Polygon* p)
offsetSide = Position::RIGHT;
- // FIXME: avoid the C-style cast
- const LinearRing* shell = (const LinearRing*)p->getExteriorRing();
+ const LinearRing* shell = p->getExteriorRing();
// optimization - don't bother computing buffer
// if the polygon would be completely eroded
diff --git a/src/operation/intersection/RectangleIntersection.cpp b/src/operation/intersection/RectangleIntersection.cpp
index a297b9e..23febb6 100644
--- a/src/operation/intersection/RectangleIntersection.cpp
+++ b/src/operation/intersection/RectangleIntersection.cpp
@@ -421,7 +421,7 @@ RectangleIntersection::clip_polygon_to_linestrings(const geom::Polygon* g,
for(size_t i = 0, n = g->getNumInteriorRing(); i < n; ++i) {
if(clip_linestring_parts(g->getInteriorRingN(i), parts, rect)) {
// clones
- LinearRing* hole = dynamic_cast<LinearRing*>(g->getInteriorRingN(i)->clone().release());
+ LinearRing* hole = new LinearRing(*(g->getInteriorRingN(i)));
// becomes exterior
Polygon* poly = _gf->createPolygon(hole, nullptr);
toParts.add(poly);
@@ -490,10 +490,10 @@ RectangleIntersection::clip_polygon_to_polygons(const geom::Polygon* g,
RectangleIntersectionBuilder holeparts(*_gf);
- const LineString* hole = g->getInteriorRingN(i);
+ const LinearRing* hole = g->getInteriorRingN(i);
if(clip_linestring_parts(hole, holeparts, rect)) {
// becomes exterior
- LinearRing* cloned = dynamic_cast<LinearRing*>(hole->clone().release());
+ LinearRing* cloned = new LinearRing(*hole);
Polygon* poly = _gf->createPolygon(cloned, nullptr);
parts.add(poly);
diff --git a/src/operation/intersection/RectangleIntersectionBuilder.cpp b/src/operation/intersection/RectangleIntersectionBuilder.cpp
index daf8b6c..ffb52f6 100644
--- a/src/operation/intersection/RectangleIntersectionBuilder.cpp
+++ b/src/operation/intersection/RectangleIntersectionBuilder.cpp
@@ -402,7 +402,7 @@ RectangleIntersectionBuilder::reconnectPolygons(const Rectangle& rect)
// Build the exterior rings first
- typedef std::vector< geom::Geometry*> LinearRingVect;
+ typedef std::vector< geom::LinearRing*> LinearRingVect;
typedef std::pair< geom::LinearRing*, LinearRingVect* > ShellAndHoles;
typedef std::list< ShellAndHoles > ShellAndHolesList;
@@ -480,10 +480,10 @@ RectangleIntersectionBuilder::reconnectPolygons(const Rectangle& rect)
for(std::list<geom::Polygon*>::iterator i = polygons.begin(), e = polygons.end(); i != e; ++i) {
geom::Polygon* poly = *i;
- const geom::LineString* hole = poly->getExteriorRing();
+ const geom::LinearRing* hole = poly->getExteriorRing();
if(exterior.size() == 1) {
- exterior.front().second->push_back(hole->clone().release());
+ exterior.front().second->push_back(new LinearRing(*hole));
else {
using geos::algorithm::PointLocation;
@@ -493,7 +493,7 @@ RectangleIntersectionBuilder::reconnectPolygons(const Rectangle& rect)
const CoordinateSequence* shell_cs = p.first->getCoordinatesRO();
if(PointLocation::isInRing(c, shell_cs)) {
// add hole to shell
- p.second->push_back(hole->clone().release());
+ p.second->push_back(new LinearRing(*hole));
break;
diff --git a/src/operation/polygonize/EdgeRing.cpp b/src/operation/polygonize/EdgeRing.cpp
index a94f104..437a0e3 100644
--- a/src/operation/polygonize/EdgeRing.cpp
+++ b/src/operation/polygonize/EdgeRing.cpp
@@ -187,7 +187,7 @@ void
EdgeRing::addHole(LinearRing* hole)
if(holes == nullptr) {
- holes.reset(new vector<Geometry*>());
+ holes.reset(new vector<LinearRing*>());
holes->push_back(hole);
diff --git a/src/operation/valid/IsValidOp.cpp b/src/operation/valid/IsValidOp.cpp
index 387218a..c3c1489 100644
--- a/src/operation/valid/IsValidOp.cpp
+++ b/src/operation/valid/IsValidOp.cpp
@@ -429,24 +429,15 @@ IsValidOp::checkNoSelfIntersectingRing(EdgeIntersectionList& eiList)
void
IsValidOp::checkHolesInShell(const Polygon* p, GeometryGraph* graph)
- assert(dynamic_cast<const LinearRing*>(p->getExteriorRing()));
- const LinearRing* shell = static_cast<const LinearRing*>(
- p->getExteriorRing());
- const Geometry* shellgeom = static_cast<const Geometry*>(shell);
bool isShellEmpty = shell->isEmpty();
- locate::IndexedPointInAreaLocator ipial(*shellgeom);
+ locate::IndexedPointInAreaLocator ipial(*shell);
auto nholes = p->getNumInteriorRing();
- p->getInteriorRingN(i)));
- const LinearRing* hole = static_cast<const LinearRing*>(
- p->getInteriorRingN(i));
+ const LinearRing* hole = p->getInteriorRingN(i);
if (hole->isEmpty()) continue;
@@ -478,11 +469,7 @@ IsValidOp::checkHolesNotNested(const Polygon* p, GeometryGraph* graph)
for (size_t i = 0; i < nholes; ++i) {
- const LinearRing* innerHole = static_cast<const LinearRing*>(
+ const LinearRing* innerHole = p->getInteriorRingN(i);
//empty holes always pass
if (innerHole->isEmpty()) {
@@ -508,8 +495,7 @@ IsValidOp::checkShellsNotNested(const MultiPolygon* mp, GeometryGraph* graph)
const Polygon* p = dynamic_cast<const Polygon*>(
mp->getGeometryN(i));
if (shell->isEmpty()) return;
@@ -542,10 +528,7 @@ IsValidOp::checkShellNotNested(const LinearRing* shell, const Polygon* p,
const CoordinateSequence* shellPts = shell->getCoordinatesRO();
// test if shell is inside polygon shell
- p->getExteriorRing()));
- const LinearRing* polyShell = static_cast<const LinearRing*>(
+ const LinearRing* polyShell = p->getExteriorRing();
const CoordinateSequence* polyPts = polyShell->getCoordinatesRO();
const Coordinate* shellPt = findPtNotNode(shellPts, polyShell, graph);
@@ -578,10 +561,7 @@ IsValidOp::checkShellNotNested(const LinearRing* shell, const Polygon* p,
const Coordinate* badNestedPt = nullptr;
badNestedPt = checkShellInsideHole(shell, hole, graph);
if(badNestedPt == nullptr) {
return;
@@ -682,7 +662,7 @@ IsValidOp::checkInvalidCoordinates(const Polygon* poly)
void
IsValidOp::checkClosedRings(const Polygon* poly)
- const LinearRing* lr = (const LinearRing*)poly->getExteriorRing();
+ const LinearRing* lr = poly->getExteriorRing();
checkClosedRing(lr);
if(validErr) {
return;
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index 4635239..255d92e 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -769,7 +769,7 @@ void object::test<20>
ensure_equals(hole->getNumPoints(), interiorSize);
// REMEMBER TO DEALLOCATE THIS COLLECTION
- std::vector<GeometryPtr> holes;
+ std::vector<LinearRingPtr> holes;
holes.push_back(hole);
// Create polygon using copy ctor
@@ -788,9 +788,8 @@ void object::test<20>
ensure_equals(poly->getNumInteriorRing(), 1u);
// FREE MEMORY
- std::vector<GeometryPtr>::const_iterator it;
- for(it = holes.begin(); it != holes.end(); ++it) {
- delete(*it);
+ for(auto& h : holes) {
+ delete h;
holes.clear();
Summary of changes:
capi/geos_ts_c.cpp | 14 ++++++--
doc/example.cpp | 5 ++-
include/geos/geom/Geometry.h | 11 ++++--
include/geos/geom/GeometryFactory.h | 4 +--
include/geos/geom/Polygon.h | 10 +++---
include/geos/operation/polygonize/EdgeRing.h | 2 +-
src/algorithm/InteriorPointArea.cpp | 4 +--
src/algorithm/PointLocator.cpp | 4 +--
src/geom/Geometry.cpp | 23 ------------
src/geom/GeometryFactory.cpp | 10 +++---
src/geom/Polygon.cpp | 42 +++++++++-------------
src/geom/util/GeometryEditor.cpp | 2 +-
src/geom/util/GeometryTransformer.cpp | 7 ++--
src/geomgraph/EdgeRing.cpp | 5 ++-
src/geomgraph/GeometryGraph.cpp | 10 ++----
src/io/WKBReader.cpp | 6 ++--
src/io/WKTReader.cpp | 2 +-
src/operation/buffer/OffsetCurveSetBuilder.cpp | 3 +-
.../intersection/RectangleIntersection.cpp | 6 ++--
.../intersection/RectangleIntersectionBuilder.cpp | 8 ++---
src/operation/polygonize/EdgeRing.cpp | 2 +-
src/operation/valid/IsValidOp.cpp | 36 +++++--------------
tests/unit/geom/GeometryFactoryTest.cpp | 7 ++--
23 files changed, 87 insertions(+), 136 deletions(-)
hooks/post-receive
More information about the geos-commits
