[geos-commits] [SCM] GEOS branch master updated. 075eb3cd1f6f267697aaae8ba7ba67c766f83170
git at osgeo.org
git at osgeo.org
Sun Jun 16 18:59:06 PDT 2019
the project "GEOS".
via 075eb3cd1f6f267697aaae8ba7ba67c766f83170 (commit)
from c897e468c7c0856d241928b95c92883794544f73 (commit)
revisions in full, below.
commit 075eb3cd1f6f267697aaae8ba7ba67c766f83170
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Jun 12 16:45:14 2019 -0400
Convert Location into an enum class
diff --git a/include/geos/algorithm/PointLocation.h b/include/geos/algorithm/PointLocation.h
index 5cd0bf9..01647f3 100644
--- a/include/geos/algorithm/PointLocation.h
+++ b/include/geos/algorithm/PointLocation.h
@@ -22,6 +22,7 @@
#include <geos/export.h>
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Location.h>
namespace geos {
namespace algorithm { // geos::algorithm
@@ -67,19 +68,19 @@ public:
static bool isInRing(const geom::Coordinate& p, const geom::CoordinateSequence* ring);
/** \brief
- * Determines whether a point lies in the interior, on the boundary, or in the
- * exterior of a ring. The ring may be oriented in either direction.
- * This method does **not** first check the point against the envelope of
- * the ring.
- * @param p point to check for ring inclusion
- * @param ring an array of coordinates representing the ring (which must have
- * first point identical to last point)
+ * Determines whether a point lies in the interior, on the boundary, or in the
+ * exterior of a ring. The ring may be oriented in either direction.
+ * This method does *not* first check the point against the envelope of
+ * the ring.
+ * @param p point to check for ring inclusion
+ * @param ring an array of coordinates representing the ring (which must have
+ * first point identical to last point)
* @return the [Location](@ref geom::Location) of p relative to the ring
- static int locateInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
- static int locateInRing(const geom::Coordinate& p, const geom::CoordinateSequence& ring);
+ static geom::Location locateInRing(const geom::Coordinate& p, const std::vector<const geom::Coordinate*>& ring);
+ static geom::Location locateInRing(const geom::Coordinate& p, const geom::CoordinateSequence& ring);
diff --git a/include/geos/algorithm/PointLocator.h b/include/geos/algorithm/PointLocator.h
index 644b6dd..da66f84 100644
--- a/include/geos/algorithm/PointLocator.h
+++ b/include/geos/algorithm/PointLocator.h
@@ -67,7 +67,7 @@ public:
* @return the Location of the point relative to the input Geometry
- int locate(const geom::Coordinate& p, const geom::Geometry* geom);
+ geom::Location locate(const geom::Coordinate& p, const geom::Geometry* geom);
* Convenience method to test a point for intersection with
@@ -91,15 +91,15 @@ private:
void computeLocation(const geom::Coordinate& p, const geom::Geometry* geom);
- void updateLocationInfo(int loc);
+ void updateLocationInfo(geom::Location loc);
- int locate(const geom::Coordinate& p, const geom::Point* pt);
+ geom::Location locate(const geom::Coordinate& p, const geom::Point* pt);
- int locate(const geom::Coordinate& p, const geom::LineString* l);
+ geom::Location locate(const geom::Coordinate& p, const geom::LineString* l);
- int locateInPolygonRing(const geom::Coordinate& p, const geom::LinearRing* ring);
+ geom::Location locateInPolygonRing(const geom::Coordinate& p, const geom::LinearRing* ring);
- int locate(const geom::Coordinate& p, const geom::Polygon* poly);
+ geom::Location locate(const geom::Coordinate& p, const geom::Polygon* poly);
diff --git a/include/geos/algorithm/RayCrossingCounter.h b/include/geos/algorithm/RayCrossingCounter.h
index d0aef85..1181013 100644
--- a/include/geos/algorithm/RayCrossingCounter.h
+++ b/include/geos/algorithm/RayCrossingCounter.h
@@ -21,6 +21,7 @@
#define GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
#include <vector>
@@ -87,11 +88,11 @@ public:
* @param ring an array of Coordinates forming a ring
* @return the location of the point in the ring
- static int locatePointInRing(const geom::Coordinate& p,
+ static geom::Location locatePointInRing(const geom::Coordinate& p,
/// Semantically equal to the above, just different args encoding
RayCrossingCounter(const geom::Coordinate& p_point)
@@ -134,7 +135,7 @@ public:
- int getLocation();
+ geom::Location getLocation();
/** \brief
* Tests whether the point lies in or on the ring, polygon or
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
index 95d7de5..2cb4f84 100644
--- a/include/geos/algorithm/RayCrossingCounterDD.h
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -21,6 +21,7 @@
#define GEOS_ALGORITHM_RAYCROSSINGCOUNTERDD_H
#include <geos/algorithm/ttmath/ttmath.h>
#include <vector>
@@ -84,11 +85,11 @@ public:
/** \brief
@@ -146,7 +147,7 @@ public:
/** \brief
* Tests whether the point lies in or on the ring, polygon or multipolygon
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index 3914e21..f1dc458 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -112,7 +112,7 @@ public:
* @param p the point to test
* @return the location of the point in the geometry
- int locate(const geom::Coordinate* /*const*/ p) override;
+ geom::Location locate(const geom::Coordinate* /*const*/ p) override;
diff --git a/include/geos/algorithm/locate/PointOnGeometryLocator.h b/include/geos/algorithm/locate/PointOnGeometryLocator.h
index 39e0b7f..c755de4 100644
--- a/include/geos/algorithm/locate/PointOnGeometryLocator.h
+++ b/include/geos/algorithm/locate/PointOnGeometryLocator.h
@@ -16,6 +16,8 @@
#ifndef GEOS_ALGORITHM_LOCATE_POINTONGEOMETRYLOCATOR_H
#define GEOS_ALGORITHM_LOCATE_POINTONGEOMETRYLOCATOR_H
namespace geos {
namespace geom {
class Coordinate;
@@ -46,7 +48,7 @@ public:
- virtual int locate(const geom::Coordinate* /*const*/ p) = 0;
+ virtual geom::Location locate(const geom::Coordinate* /*const*/ p) = 0;
} // geos::algorithm::locate
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 22d7c8f..d1e84ef 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -48,7 +48,7 @@ class SimplePointInAreaLocator : public PointOnGeometryLocator {
public:
- static int locate(const geom::Coordinate& p,
+ static geom::Location locate(const geom::Coordinate& p,
/** \brief
@@ -67,8 +67,9 @@ public:
* @param poly the geometry to test
* @return the Location of the point in the polygon
- static int locatePointInPolygon(const geom::Coordinate& p,
+ static geom::Location locatePointInPolygon(const geom::Coordinate& p,
/** \brief
* Determines whether a point is contained in a [Geometry](@ref geom::Geometry),
* or lies on its boundary.
@@ -88,7 +89,7 @@ public:
: g(p_g)
- int
+ geom::Location
locate(const geom::Coordinate* p) override
return locate(*p, g);
@@ -96,7 +97,7 @@ public:
private:
- static int locateInGeometry(const geom::Coordinate& p,
+ static geom::Location locateInGeometry(const geom::Coordinate& p,
const geom::Geometry* g;
diff --git a/include/geos/geom/IntersectionMatrix.h b/include/geos/geom/IntersectionMatrix.h
index e1c1dcb..a2353c7 100644
--- a/include/geos/geom/IntersectionMatrix.h
+++ b/include/geos/geom/IntersectionMatrix.h
@@ -19,7 +19,10 @@
#ifndef GEOS_GEOM_INTERSECTIONMATRIX_H
#define GEOS_GEOM_INTERSECTIONMATRIX_H
+#include <array>
#include <string>
#include <geos/inline.h>
@@ -143,7 +146,7 @@ public:
* second Geometry.
* @param dimensionValue - the new value of the element.
- void set(int row, int column, int dimensionValue);
+ void set(Location row, Location column, int dimensionValue);
/** \brief
* Changes the elements of this IntersectionMatrix to the dimension
@@ -167,7 +170,7 @@ public:
* to compare the element. The order of dimension values
* from least to greatest is {DONTCARE, TRUE, FALSE, 0, 1, 2}.
- void setAtLeast(size_t row, size_t column, int minimumDimensionValue);
+ void setAtLeast(Location row, Location column, int minimumDimensionValue);
/** \brief
* If row >= 0 and column >= 0, changes the specified element
@@ -189,7 +192,7 @@ public:
- void setAtLeastIfValid(int row, int column, int minimumDimensionValue);
+ void setAtLeastIfValid(Location row, Location column, int minimumDimensionValue);
/** \brief
* For each element in this IntersectionMatrix, changes the element to
@@ -226,7 +229,9 @@ public:
* @return the dimension value at the given matrix position.
- int get(int row, int column) const;
+ int get(geom::Location row, geom::Location column) const {
+ return matrix[static_cast<size_t>(row)][static_cast<size_t>(column)];
/** \brief
* Returns true if this IntersectionMatrix is FF*FF****.
@@ -368,7 +373,7 @@ private:
static const int secondDim; // = 3;
// Internal buffer for 3x3 matrix.
- int matrix[3][3];
+ std::array<std::array<int, 3>, 3> matrix;
}; // class IntersectionMatrix
diff --git a/include/geos/geom/Location.h b/include/geos/geom/Location.h
index 359bb9b..896a4dd 100644
--- a/include/geos/geom/Location.h
+++ b/include/geos/geom/Location.h
@@ -31,46 +31,38 @@ namespace geom { // geos::geom
* HREF="http://www.opengis.org/techno/specs.htm">OpenGIS Simple Features
* Specification for SQL</A> .
-class GEOS_DLL Location {
-public:
- enum Value {
+enum class GEOS_DLL Location : char {
+ * Used for uninitialized location values.
+ UNDEF = -1, // Instead of NULL
- * Used for uninitialized location values.
- UNDEF = -1, // Instead of NULL
+ * DE-9IM row index of the interior of the first geometry and
+ * column index of the interior of the second geometry.
+ * Location value for the interior of a geometry.
+ INTERIOR = 0,
- * DE-9IM row index of the interior of the first geometry and
- * column index of the interior of the second geometry.
- * Location value for the interior of a geometry.
- INTERIOR = 0,
+ * DE-9IM row index of the boundary of the first geometry and
+ * column index of the boundary of the second geometry.
+ * Location value for the boundary of a geometry.
+ BOUNDARY = 1,
- * DE-9IM row index of the boundary of the first geometry and
- * column index of the boundary of the second geometry.
- * Location value for the boundary of a geometry.
- BOUNDARY = 1,
- * DE-9IM row index of the exterior of the first geometry and
- * column index of the exterior of the second geometry.
- * Location value for the exterior of a geometry.
- EXTERIOR = 2
- static char toLocationSymbol(int locationValue);
+ * DE-9IM row index of the exterior of the first geometry and
+ * column index of the exterior of the second geometry.
+ * Location value for the exterior of a geometry.
+ EXTERIOR = 2
+std::ostream& operator<<(std::ostream& os, const Location& loc);
} // namespace geos::geom
} // namespace geos
-//#ifdef GEOS_INLINE
-//# include "geos/geom/Location.inl"
-//#endif
#endif // ndef GEOS_GEOM_LOCATION_H
diff --git a/include/geos/geom/prep/AbstractPreparedPolygonContains.h b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
index 9325bfa..95a1fd2 100644
--- a/include/geos/geom/prep/AbstractPreparedPolygonContains.h
+++ b/include/geos/geom/prep/AbstractPreparedPolygonContains.h
@@ -106,7 +106,7 @@ protected:
* @param outermostLoc outermost Location of all points in geom
* @return true if the test geometry is contained/covered in the target
- bool evalPointTestGeom(const geom::Geometry* geom, geom::Location::Value outermostLoc);
+ bool evalPointTestGeom(const geom::Geometry* geom, geom::Location outermostLoc);
* Computes the full topological predicate.
diff --git a/include/geos/geom/prep/PreparedPolygonPredicate.h b/include/geos/geom/prep/PreparedPolygonPredicate.h
index d983982..7fb9710 100644
--- a/include/geos/geom/prep/PreparedPolygonPredicate.h
+++ b/include/geos/geom/prep/PreparedPolygonPredicate.h
@@ -71,7 +71,7 @@ protected:
* @param testGeom a geometry to test
* @return the outermost Location
- geom::Location::Value getOutermostTestComponentLocation(const geom::Geometry* testGeom) const;
+ geom::Location getOutermostTestComponentLocation(const geom::Geometry* testGeom) const;
/** \brief
* Tests whether all components of the test Geometry
diff --git a/include/geos/geomgraph/Depth.h b/include/geos/geomgraph/Depth.h
index cb247f9..371b0a1 100644
--- a/include/geos/geomgraph/Depth.h
+++ b/include/geos/geomgraph/Depth.h
@@ -22,6 +22,7 @@
#define GEOS_GEOMGRAPH_DEPTH_H
#include <string>
@@ -38,13 +39,13 @@ namespace geomgraph { // geos.geomgraph
class GEOS_DLL Depth {
public:
- static int depthAtLocation(int location);
+ static int depthAtLocation(geom::Location location);
Depth();
virtual ~Depth(); // FIXME: shoudn't be virtual!
int getDepth(int geomIndex, int posIndex) const;
void setDepth(int geomIndex, int posIndex, int depthValue);
- int getLocation(int geomIndex, int posIndex) const;
- void add(int geomIndex, int posIndex, int location);
+ geom::Location getLocation(int geomIndex, int posIndex) const;
+ void add(int geomIndex, int posIndex, geom::Location location);
bool isNull() const;
bool isNull(int geomIndex) const;
bool isNull(int geomIndex, int posIndex) const;
diff --git a/include/geos/geomgraph/DirectedEdge.h b/include/geos/geomgraph/DirectedEdge.h
index 74cf390..5f2ba1e 100644
--- a/include/geos/geomgraph/DirectedEdge.h
+++ b/include/geos/geomgraph/DirectedEdge.h
@@ -25,6 +25,7 @@
#include <string>
#include <geos/geomgraph/EdgeEnd.h> // for inheritance
@@ -51,7 +52,7 @@ public:
* E.g. if crossing from the INTERIOR to the EXTERIOR the depth
* decreases, so the factor is -1
- static int depthFactor(int currLocation, int nextLocation);
+ static int depthFactor(geom::Location currLocation, geom::Location nextLocation);
//DirectedEdge();
//virtual ~DirectedEdge();
diff --git a/include/geos/geomgraph/EdgeEndStar.h b/include/geos/geomgraph/EdgeEndStar.h
index 28dd076..054ddc2 100644
--- a/include/geos/geomgraph/EdgeEndStar.h
+++ b/include/geos/geomgraph/EdgeEndStar.h
@@ -24,10 +24,12 @@
#include <geos/geomgraph/EdgeEnd.h> // for EdgeEndLT
#include <geos/geom/Coordinate.h> // for p0,p1
+#include <array>
#include <set>
#include <string>
#include <vector>
@@ -148,15 +150,15 @@ protected:
private:
- virtual int getLocation(int geomIndex,
- const geom::Coordinate& p,
- std::vector<GeometryGraph*>* geom);
+ virtual geom::Location getLocation(int geomIndex,
+ const geom::Coordinate& p,
+ std::vector<GeometryGraph*>* geom);
/** \brief
* The location of the point for this star in
* Geometry i Areas
- int ptInAreaLocation[2];
+ std::array<geom::Location, 2> ptInAreaLocation;
virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
diff --git a/include/geos/geomgraph/GeometryGraph.h b/include/geos/geomgraph/GeometryGraph.h
index a1e70f8..a33b4d5 100644
--- a/include/geos/geomgraph/GeometryGraph.h
+++ b/include/geos/geomgraph/GeometryGraph.h
@@ -123,14 +123,14 @@ private:
void addPoint(const geom::Point* p);
void addPolygonRing(const geom::LinearRing* lr,
- int cwLeft, int cwRight);
+ geom::Location cwLeft, geom::Location cwRight);
void addPolygon(const geom::Polygon* p);
void addLineString(const geom::LineString* line);
void insertPoint(int argIndex, const geom::Coordinate& coord,
- int onLocation);
+ geom::Location onLocation);
/** \brief
* Adds candidate boundary points using the current
@@ -151,7 +151,7 @@ private:
* Otherwise, just add it as a regular node.
void addSelfIntersectionNode(int argIndex,
- const geom::Coordinate& coord, int loc);
+ const geom::Coordinate& coord, geom::Location loc);
// Declare type as noncopyable
GeometryGraph(const GeometryGraph& other) = delete;
@@ -161,9 +161,9 @@ public:
static bool isInBoundary(int boundaryCount);
- static int determineBoundary(int boundaryCount);
+ static geom::Location determineBoundary(int boundaryCount);
const algorithm::BoundaryNodeRule& boundaryNodeRule,
int boundaryCount);
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index b9a1a07..0582460 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
@@ -22,6 +22,7 @@
#define GEOS_GEOMGRAPH_LABEL_H
#include <geos/geomgraph/TopologyLocation.h>
@@ -70,7 +71,7 @@ public:
/** \brief
* Construct a Label with a single location for both Geometries.
- Label(int onLoc);
+ Label(geom::Location onLoc);
/** \brief
* Construct a Label with the location specified
@@ -79,14 +80,14 @@ public:
* Other geometry location will be set to
- Label(int geomIndex, int onLoc);
+ Label(int geomIndex, geom::Location onLoc);
/** \brief
* Construct a Label with On, Left and Right locations for both Geometries.
* Initialize the locations for both Geometries to the given values.
- Label(int onLoc, int leftLoc, int rightLoc);
+ Label(geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc);
/// Copy ctor
Label(const Label& l);
@@ -106,23 +107,23 @@ public:
* Initialize the locations for the other Geometry to
- Label(int geomIndex, int onLoc, int leftLoc, int rightLoc);
+ Label(int geomIndex, geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc);
void flip();
- int getLocation(int geomIndex) const;
+ geom::Location getLocation(int geomIndex) const;
- void setLocation(int geomIndex, int posIndex, int location);
+ void setLocation(int geomIndex, int posIndex, geom::Location location);
- void setLocation(int geomIndex, int location);
+ void setLocation(int geomIndex, geom::Location location);
- void setAllLocations(int geomIndex, int location);
+ void setAllLocations(int geomIndex, geom::Location location);
- void setAllLocationsIfNull(int geomIndex, int location);
+ void setAllLocationsIfNull(int geomIndex, geom::Location location);
- void setAllLocationsIfNull(int location);
+ void setAllLocationsIfNull(geom::Location location);
/** \brief
* Merge this label with another one.
@@ -148,7 +149,7 @@ public:
bool isEqualOnSide(const Label& lbl, int side) const;
- bool allPositionsEqual(int geomIndex, int loc) const;
+ bool allPositionsEqual(int geomIndex, geom::Location loc) const;
/** \brief
* Converts one GeometryLocation to a Line location
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index 06da110..c28fbad 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -92,7 +92,7 @@ public:
virtual void mergeLabel(const Label& label2);
- virtual void setLabel(int argIndex, int onLocation);
+ virtual void setLabel(int argIndex, geom::Location onLocation);
/** \brief
* Updates the label of a node to BOUNDARY,
@@ -108,7 +108,7 @@ public:
* in the boundary.
* The merged location is the maximum of the two input values.
- virtual int computeMergedLocation(const Label& label2, int eltIndex);
+ virtual geom::Location computeMergedLocation(const Label& label2, int eltIndex);
virtual std::string print();
diff --git a/include/geos/geomgraph/TopologyLocation.h b/include/geos/geomgraph/TopologyLocation.h
index 5a568f5..d56803d 100644
--- a/include/geos/geomgraph/TopologyLocation.h
+++ b/include/geos/geomgraph/TopologyLocation.h
@@ -23,6 +23,7 @@
#include <vector>
#include <string>
@@ -78,15 +79,15 @@ public:
* @see Location
- TopologyLocation(int on, int left, int right);
+ TopologyLocation(geom::Location on, geom::Location left, geom::Location right);
- TopologyLocation(int on);
+ TopologyLocation(geom::Location on);
TopologyLocation(const TopologyLocation& gl);
TopologyLocation& operator= (const TopologyLocation& gl);
- int get(std::size_t posIndex) const;
+ geom::Location get(std::size_t posIndex) const;
* @return true if all locations are Location::UNDEF
@@ -106,20 +107,20 @@ public:
void flip();
- void setAllLocations(int locValue);
+ void setAllLocations(geom::Location locValue);
- void setAllLocationsIfNull(int locValue);
+ void setAllLocationsIfNull(geom::Location locValue);
- void setLocation(std::size_t locIndex, int locValue);
+ void setLocation(std::size_t locIndex, geom::Location locValue);
- void setLocation(int locValue);
+ void setLocation(geom::Location locValue);
/// Warning: returns reference to owned memory
- const std::vector<int>& getLocations() const;
+ const std::vector<geom::Location>& getLocations() const;
- void setLocations(int on, int left, int right);
+ void setLocations(geom::Location on, geom::Location left, geom::Location right);
- bool allPositionsEqual(int loc) const;
+ bool allPositionsEqual(geom::Location loc) const;
/** \brief
* merge updates only the UNDEF attributes of this object
@@ -131,7 +132,7 @@ public:
private:
- std::vector<int> location;
+ std::vector<geom::Location> location;
std::ostream& operator<< (std::ostream&, const TopologyLocation&);
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index beb8219..62a1593 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -21,6 +21,7 @@
#define GEOS_OP_BUFFER_OFFSETCURVESETBUILDER_H
#include <vector>
@@ -98,8 +99,8 @@ private:
* @param coord is raw offset curve, ownership transferred here
- void addCurve(geom::CoordinateSequence* coord, int leftLoc,
- int rightLoc);
+ void addCurve(geom::CoordinateSequence* coord, geom::Location leftLoc,
+ geom::Location rightLoc);
void add(const geom::Geometry& g);
@@ -133,8 +134,8 @@ private:
* (if it is CW)
void addPolygonRing(const geom::CoordinateSequence* coord,
- double offsetDistance, int side, int cwLeftLoc,
- int cwRightLoc);
+ double offsetDistance, int side, geom::Location cwLeftLoc,
+ geom::Location cwRightLoc);
* The ringCoord is assumed to contain no repeated points.
@@ -200,7 +201,7 @@ public:
/// @param rightLoc right location
void addCurves(const std::vector<geom::CoordinateSequence*>& lineList,
- int leftLoc, int rightLoc);
+ geom::Location leftLoc, geom::Location rightLoc);
diff --git a/include/geos/operation/overlay/OverlayOp.h b/include/geos/operation/overlay/OverlayOp.h
index c9ae800..1a3d4ba 100644
--- a/include/geos/operation/overlay/OverlayOp.h
+++ b/include/geos/operation/overlay/OverlayOp.h
@@ -23,6 +23,7 @@
#include <geos/algorithm/PointLocator.h> // for composition
#include <geos/geom/Dimension.h> // for Dimension::DimensionType
#include <geos/geomgraph/EdgeList.h> // for composition
#include <geos/geomgraph/PlanarGraph.h> // for inline (GeometryGraph->PlanarGraph)
#include <geos/operation/GeometryGraphOperation.h> // for inheritance
@@ -118,7 +119,7 @@ public:
/// @return true if the locations correspond to the opCode
- static bool isResultOfOp(int loc0, int loc1, OpCode opCode);
+ static bool isResultOfOp(geom::Location loc0, geom::Location loc1, OpCode opCode);
/// \brief Construct an OverlayOp with the given Geometry args.
diff --git a/include/geos/operation/overlay/validate/FuzzyPointLocator.h b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
index 3d093cc..13f2fbe 100644
--- a/include/geos/operation/overlay/validate/FuzzyPointLocator.h
+++ b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
@@ -61,7 +61,7 @@ public:
FuzzyPointLocator(const geom::Geometry& geom, double nTolerance);
- geom::Location::Value getLocation(const geom::Coordinate& pt);
+ geom::Location getLocation(const geom::Coordinate& pt);
private:
diff --git a/include/geos/operation/overlay/validate/OverlayResultValidator.h b/include/geos/operation/overlay/validate/OverlayResultValidator.h
index a4127b8..069b4d6 100644
--- a/include/geos/operation/overlay/validate/OverlayResultValidator.h
+++ b/include/geos/operation/overlay/validate/OverlayResultValidator.h
@@ -113,7 +113,7 @@ private:
bool testValid(OverlayOp::OpCode overlayOp, const geom::Coordinate& pt);
bool isValidResult(OverlayOp::OpCode overlayOp,
- std::vector<geom::Location::Value>& location);
+ std::vector<geom::Location>& location);
static double computeBoundaryDistanceTolerance(
const geom::Geometry& g0, const geom::Geometry& g1);
diff --git a/src/algorithm/PointLocation.cpp b/src/algorithm/PointLocation.cpp
index 03dd7cf..ca38f95 100644
--- a/src/algorithm/PointLocation.cpp
+++ b/src/algorithm/PointLocation.cpp
@@ -67,7 +67,7 @@ PointLocation::isInRing(const geom::Coordinate& p,
/* public static */
-int
+geom::Location
PointLocation::locateInRing(const geom::Coordinate& p,
@@ -75,7 +75,7 @@ PointLocation::locateInRing(const geom::Coordinate& p,
/* public static */
-int
+geom::Location
diff --git a/src/algorithm/PointLocator.cpp b/src/algorithm/PointLocator.cpp
index 6b4ef7c..5854f89 100644
--- a/src/algorithm/PointLocator.cpp
+++ b/src/algorithm/PointLocator.cpp
@@ -38,7 +38,7 @@ namespace geos {
namespace algorithm { // geos.algorithm
-int
+Location
PointLocator::locate(const Coordinate& p, const Geometry* geom)
if(geom->isEmpty()) {
@@ -108,7 +108,7 @@ PointLocator::computeLocation(const Coordinate& p, const Geometry* geom)
/* private */
void
-PointLocator::updateLocationInfo(int loc)
+PointLocator::updateLocationInfo(geom::Location loc)
if(loc == Location::INTERIOR) {
isIn = true;
@@ -119,7 +119,7 @@ PointLocator::updateLocationInfo(int loc)
/* private */
-int
+Location
PointLocator::locate(const Coordinate& p, const Point* pt)
// no point in doing envelope test, since equality test is just as fast
@@ -131,7 +131,7 @@ PointLocator::locate(const Coordinate& p, const Point* pt)
/* private */
-int
+Location
PointLocator::locate(const Coordinate& p, const LineString* l)
if(!l->getEnvelopeInternal()->intersects(p)) {
@@ -151,7 +151,7 @@ PointLocator::locate(const Coordinate& p, const LineString* l)
/* private */
-int
+Location
PointLocator::locateInPolygonRing(const Coordinate& p, const LinearRing* ring)
if(!ring->getEnvelopeInternal()->intersects(p)) {
@@ -170,7 +170,7 @@ PointLocator::locateInPolygonRing(const Coordinate& p, const LinearRing* ring)
/* private */
-int
+Location
PointLocator::locate(const Coordinate& p, const Polygon* poly)
if(poly->isEmpty()) {
@@ -180,7 +180,7 @@ PointLocator::locate(const Coordinate& p, const Polygon* poly)
const LinearRing* shell = poly->getExteriorRing();
assert(shell);
- int shellLoc = locateInPolygonRing(p, shell);
+ Location shellLoc = locateInPolygonRing(p, shell);
if(shellLoc == Location::EXTERIOR) {
return Location::EXTERIOR;
@@ -191,7 +191,7 @@ PointLocator::locate(const Coordinate& p, const Polygon* poly)
// now test if the point lies in or on the holes
for(size_t i = 0, n = poly->getNumInteriorRing(); i < n; ++i) {
const LinearRing* hole = poly->getInteriorRingN(i);
- int holeLoc = locateInPolygonRing(p, hole);
+ Location holeLoc = locateInPolygonRing(p, hole);
if(holeLoc == Location::INTERIOR) {
diff --git a/src/algorithm/RayCrossingCounter.cpp b/src/algorithm/RayCrossingCounter.cpp
index a4ae339..06b1eff 100644
--- a/src/algorithm/RayCrossingCounter.cpp
+++ b/src/algorithm/RayCrossingCounter.cpp
@@ -37,7 +37,7 @@ namespace algorithm {
// public:
-/*static*/ int
+/*static*/ geom::Location
RayCrossingCounter::locatePointInRing(const geom::Coordinate& point,
@@ -56,7 +56,7 @@ RayCrossingCounter::locatePointInRing(const geom::Coordinate& point,
return rcc.getLocation();
-/*static*/ int
@@ -141,7 +141,7 @@ RayCrossingCounter::countSegment(const geom::Coordinate& p1,
-int
+geom::Location
RayCrossingCounter::getLocation()
if(isPointOnSegment) {
diff --git a/src/algorithm/RayCrossingCounterDD.cpp b/src/algorithm/RayCrossingCounterDD.cpp
index bc9430f..eb8d8fb 100644
--- a/src/algorithm/RayCrossingCounterDD.cpp
+++ b/src/algorithm/RayCrossingCounterDD.cpp
@@ -38,7 +38,7 @@ namespace algorithm {
// public:
/*static*/
-int
+geom::Location
RayCrossingCounterDD::locatePointInRing(const geom::Coordinate& point,
@@ -58,7 +58,7 @@ RayCrossingCounterDD::locatePointInRing(const geom::Coordinate& point,
/*static*/
-int
+geom::Location
@@ -151,7 +151,7 @@ RayCrossingCounterDD::countSegment(const geom::Coordinate& p1,
-int
+geom::Location
RayCrossingCounterDD::getLocation()
diff --git a/src/algorithm/locate/IndexedPointInAreaLocator.cpp b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
index 7bd347c..410fa36 100644
--- a/src/algorithm/locate/IndexedPointInAreaLocator.cpp
+++ b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
@@ -96,7 +96,7 @@ IndexedPointInAreaLocator::IndexedPointInAreaLocator(const geom::Geometry& g)
buildIndex(areaGeom);
-int
+geom::Location
IndexedPointInAreaLocator::locate(const geom::Coordinate* /*const*/ p)
algorithm::RayCrossingCounter rcc(*p);
diff --git a/src/algorithm/locate/SimplePointInAreaLocator.cpp b/src/algorithm/locate/SimplePointInAreaLocator.cpp
index b08ebc1..8affb66 100644
--- a/src/algorithm/locate/SimplePointInAreaLocator.cpp
+++ b/src/algorithm/locate/SimplePointInAreaLocator.cpp
@@ -37,7 +37,7 @@ namespace locate { // geos.algorithm
* and multi-element Geometries. The algorithm for multi-element Geometries
* is more complex, since it has to take into account the boundaryDetermination rule
-int
+geom::Location
SimplePointInAreaLocator::locate(const Coordinate& p, const Geometry* geom)
@@ -59,7 +59,7 @@ SimplePointInAreaLocator::isContained(const Coordinate& p, const Geometry* geom)
return Location::EXTERIOR != locate(p, geom);
-int
+geom::Location
SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry* geom)
if(const Polygon* poly = dynamic_cast<const Polygon*>(geom)) {
@@ -72,7 +72,7 @@ SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry*
if(const GeometryCollection* col = dynamic_cast<const GeometryCollection*>(geom)) {
for(auto g2 : *col) {
assert(g2 != geom);
- int loc = locateInGeometry(p, g2);
+ Location loc = locateInGeometry(p, g2);
if(loc != Location::EXTERIOR) {
return loc;
@@ -81,7 +81,7 @@ SimplePointInAreaLocator::locateInGeometry(const Coordinate& p, const Geometry*
-int
+geom::Location
SimplePointInAreaLocator::locatePointInPolygon(const Coordinate& p, const Polygon* poly)
@@ -93,7 +93,7 @@ SimplePointInAreaLocator::locatePointInPolygon(const Coordinate& p, const Polygo
const LineString* shell = poly->getExteriorRing();
const CoordinateSequence* cl;
cl = shell->getCoordinatesRO();
- int shellLoc = PointLocation::locateInRing(p, *cl);
+ Location shellLoc = PointLocation::locateInRing(p, *cl);
if(shellLoc != Location::INTERIOR) {
return shellLoc;
@@ -103,7 +103,7 @@ SimplePointInAreaLocator::locatePointInPolygon(const Coordinate& p, const Polygo
const LineString* hole = poly->getInteriorRingN(i);
if(hole->getEnvelopeInternal()->contains(p)) {
cl = hole->getCoordinatesRO();
- int holeLoc = RayCrossingCounter::locatePointInRing(p, *cl);
+ Location holeLoc = RayCrossingCounter::locatePointInRing(p, *cl);
if(holeLoc == Location::BOUNDARY) {
return Location::BOUNDARY;
diff --git a/src/geom/IntersectionMatrix.cpp b/src/geom/IntersectionMatrix.cpp
index 740187b..f30216e 100644
--- a/src/geom/IntersectionMatrix.cpp
+++ b/src/geom/IntersectionMatrix.cpp
@@ -50,25 +50,19 @@ IntersectionMatrix::IntersectionMatrix(const string& elements)
/*public*/
IntersectionMatrix::IntersectionMatrix(const IntersectionMatrix& other)
- matrix[Location::INTERIOR][Location::INTERIOR] = other.matrix[Location::INTERIOR][Location::INTERIOR];
- matrix[Location::INTERIOR][Location::BOUNDARY] = other.matrix[Location::INTERIOR][Location::BOUNDARY];
- matrix[Location::INTERIOR][Location::EXTERIOR] = other.matrix[Location::INTERIOR][Location::EXTERIOR];
- matrix[Location::BOUNDARY][Location::INTERIOR] = other.matrix[Location::BOUNDARY][Location::INTERIOR];
- matrix[Location::BOUNDARY][Location::BOUNDARY] = other.matrix[Location::BOUNDARY][Location::BOUNDARY];
- matrix[Location::BOUNDARY][Location::EXTERIOR] = other.matrix[Location::BOUNDARY][Location::EXTERIOR];
- matrix[Location::EXTERIOR][Location::INTERIOR] = other.matrix[Location::EXTERIOR][Location::INTERIOR];
- matrix[Location::EXTERIOR][Location::BOUNDARY] = other.matrix[Location::EXTERIOR][Location::BOUNDARY];
- matrix[Location::EXTERIOR][Location::EXTERIOR] = other.matrix[Location::EXTERIOR][Location::EXTERIOR];
+ matrix = other.matrix;
/*public*/
void
IntersectionMatrix::add(IntersectionMatrix* other)
- for(int i = 0; i < firstDim; i++) {
- for(int j = 0; j < secondDim; j++) {
- setAtLeast(i, j, other->get(i, j));
+ for(size_t i = 0; i < firstDim; i++) {
+ for(size_t j = 0; j < secondDim; j++) {
+ setAtLeast(static_cast<Location>(i), static_cast<Location>(j),
+ other->get(static_cast<Location>(i), static_cast<Location>(j)));
@@ -82,8 +76,8 @@ IntersectionMatrix::matches(const string& requiredDimensionSymbols) const
<< "[" << requiredDimensionSymbols << "] instead" << endl;
throw util::IllegalArgumentException(s.str());
- for(int ai = 0; ai < firstDim; ai++) {
- for(int bi = 0; bi < secondDim; bi++) {
+ for(size_t ai = 0; ai < firstDim; ai++) {
+ for(size_t bi = 0; bi < secondDim; bi++) {
if(!matches(matrix[ai][bi], requiredDimensionSymbols[3 * ai + bi])) {
return false;
@@ -143,12 +137,9 @@ IntersectionMatrix::matches(const string& actualDimensionSymbols,
/*public*/
void
-IntersectionMatrix::set(int row, int col, int dimensionValue)
+IntersectionMatrix::set(Location row, Location col, int dimensionValue)
- assert(row >= 0 && row < firstDim);
- assert(col >= 0 && col < secondDim);
- matrix[row][col] = dimensionValue;
+ matrix[static_cast<size_t>(row)][static_cast<size_t>(col)] = dimensionValue;
/*public*/
@@ -166,24 +157,18 @@ IntersectionMatrix::set(const string& dimensionSymbols)
/*public*/
void
-IntersectionMatrix::setAtLeast(size_t row, size_t col, int minimumDimensionValue)
+IntersectionMatrix::setAtLeast(Location row, Location col, int minimumDimensionValue)
- assert(row < firstDim);
- assert(col < secondDim);
- if(matrix[row][col] < minimumDimensionValue) {
- matrix[row][col] = minimumDimensionValue;
+ if(get(row, col) < minimumDimensionValue) {
+ set(row, col, minimumDimensionValue);
/*public*/
void
-IntersectionMatrix::setAtLeastIfValid(int row, int col, int minimumDimensionValue)
+IntersectionMatrix::setAtLeastIfValid(Location row, Location col, int minimumDimensionValue)
- if(row >= 0 && col >= 0) {
+ if(static_cast<size_t>(row) >= 0 && static_cast<size_t>(col) >= 0) {
setAtLeast(row, col, minimumDimensionValue);
@@ -195,8 +180,8 @@ IntersectionMatrix::setAtLeast(string minimumDimensionSymbols)
auto limit = minimumDimensionSymbols.length();
for(size_t i = 0; i < limit; i++) {
- auto row = i / firstDim;
- auto col = i % secondDim;
+ auto row = static_cast<Location>(i / firstDim);
+ auto col = static_cast<Location>(i % secondDim);
setAtLeast(row, col, Dimension::toDimensionValue(minimumDimensionSymbols[i]));
@@ -207,33 +192,23 @@ IntersectionMatrix::setAll(int dimensionValue)
- matrix[ai][bi] = dimensionValue;
+ set(static_cast<Location>(ai), static_cast<Location>(bi), dimensionValue);
/*public*/
-int
-IntersectionMatrix::get(int row, int col) const
- return matrix[row][col];
-/*public*/
bool
IntersectionMatrix::isDisjoint() const
return
- matrix[Location::INTERIOR][Location::INTERIOR] == Dimension::False
+ get(Location::INTERIOR, Location::INTERIOR) == Dimension::False
- matrix[Location::INTERIOR][Location::BOUNDARY] == Dimension::False
+ get(Location::INTERIOR, Location::BOUNDARY) == Dimension::False
- matrix[Location::BOUNDARY][Location::INTERIOR] == Dimension::False
+ get(Location::BOUNDARY, Location::INTERIOR) == Dimension::False
- matrix[Location::BOUNDARY][Location::BOUNDARY] == Dimension::False;
+ get(Location::BOUNDARY, Location::BOUNDARY) == Dimension::False;
/*public*/
@@ -261,10 +236,10 @@ IntersectionMatrix::isTouches(int dimensionOfGeometryA,
(dimensionOfGeometryA == Dimension::P && dimensionOfGeometryB == Dimension::A)
(dimensionOfGeometryA == Dimension::P && dimensionOfGeometryB == Dimension::L)) {
- return matrix[Location::INTERIOR][Location::INTERIOR] == Dimension::False &&
- (matches(matrix[Location::INTERIOR][Location::BOUNDARY], 'T') ||
- matches(matrix[Location::BOUNDARY][Location::INTERIOR], 'T') ||
- matches(matrix[Location::BOUNDARY][Location::BOUNDARY], 'T'));
+ return get(Location::INTERIOR, Location::INTERIOR) == Dimension::False &&
+ (matches(get(Location::INTERIOR, Location::BOUNDARY), 'T') ||
+ matches(get(Location::BOUNDARY, Location::INTERIOR), 'T') ||
+ matches(get(Location::BOUNDARY, Location::BOUNDARY), 'T'));
return false;
@@ -277,17 +252,17 @@ IntersectionMatrix::isCrosses(int dimensionOfGeometryA,
if((dimensionOfGeometryA == Dimension::P && dimensionOfGeometryB == Dimension::L) ||
(dimensionOfGeometryA == Dimension::P && dimensionOfGeometryB == Dimension::A) ||
(dimensionOfGeometryA == Dimension::L && dimensionOfGeometryB == Dimension::A)) {
- return matches(matrix[Location::INTERIOR][Location::INTERIOR], 'T') &&
- matches(matrix[Location::INTERIOR][Location::EXTERIOR], 'T');
+ return matches(get(Location::INTERIOR, Location::INTERIOR), 'T') &&
+ matches(get(Location::INTERIOR, Location::EXTERIOR), 'T');
if((dimensionOfGeometryA == Dimension::L && dimensionOfGeometryB == Dimension::P) ||
(dimensionOfGeometryA == Dimension::A && dimensionOfGeometryB == Dimension::P) ||
(dimensionOfGeometryA == Dimension::A && dimensionOfGeometryB == Dimension::L)) {
- matches(matrix[Location::EXTERIOR][Location::INTERIOR], 'T');
+ matches(get(Location::EXTERIOR, Location::INTERIOR), 'T');
if(dimensionOfGeometryA == Dimension::L && dimensionOfGeometryB == Dimension::L) {
- return matrix[Location::INTERIOR][Location::INTERIOR] == 0;
+ return get(Location::INTERIOR, Location::INTERIOR) == 0;
return false;
@@ -296,18 +271,18 @@ IntersectionMatrix::isCrosses(int dimensionOfGeometryA,
bool
IntersectionMatrix::isWithin() const
- matrix[Location::INTERIOR][Location::EXTERIOR] == Dimension::False &&
- matrix[Location::BOUNDARY][Location::EXTERIOR] == Dimension::False;
+ get(Location::INTERIOR, Location::EXTERIOR) == Dimension::False &&
+ get(Location::BOUNDARY, Location::EXTERIOR) == Dimension::False;
/*public*/
bool
IntersectionMatrix::isContains() const
- matrix[Location::EXTERIOR][Location::INTERIOR] == Dimension::False &&
- matrix[Location::EXTERIOR][Location::BOUNDARY] == Dimension::False;
+ get(Location::EXTERIOR, Location::INTERIOR) == Dimension::False &&
+ get(Location::EXTERIOR, Location::BOUNDARY) == Dimension::False;
/*public*/
@@ -318,11 +293,11 @@ IntersectionMatrix::isEquals(int dimensionOfGeometryA,
if(dimensionOfGeometryA != dimensionOfGeometryB) {
return false;
- matrix[Location::EXTERIOR][Location::BOUNDARY] == Dimension::False &&
+ get(Location::EXTERIOR, Location::BOUNDARY) == Dimension::False &&
/*public*/
@@ -332,14 +307,14 @@ IntersectionMatrix::isOverlaps(int dimensionOfGeometryA,
if((dimensionOfGeometryA == Dimension::P && dimensionOfGeometryB == Dimension::P) ||
(dimensionOfGeometryA == Dimension::A && dimensionOfGeometryB == Dimension::A)) {
- matches(matrix[Location::INTERIOR][Location::EXTERIOR], 'T') &&
+ matches(get(Location::INTERIOR, Location::EXTERIOR), 'T') &&
- return matrix[Location::INTERIOR][Location::INTERIOR] == 1 &&
+ return get(Location::INTERIOR, Location::INTERIOR) == 1 &&
return false;
@@ -349,20 +324,20 @@ bool
IntersectionMatrix::isCovers() const
bool hasPointInCommon =
- matches(matrix[Location::INTERIOR][Location::INTERIOR], 'T')
+ matches(get(Location::INTERIOR, Location::INTERIOR), 'T')
- matches(matrix[Location::INTERIOR][Location::BOUNDARY], 'T')
+ matches(get(Location::INTERIOR, Location::BOUNDARY), 'T')
- matches(matrix[Location::BOUNDARY][Location::BOUNDARY], 'T');
+ matches(get(Location::BOUNDARY, Location::BOUNDARY), 'T');
return hasPointInCommon
Dimension::False
Dimension::False;
@@ -371,21 +346,21 @@ bool
IntersectionMatrix::isCoveredBy() const
return
hasPointInCommon
Dimension::False
Dimension::False;
@@ -410,8 +385,8 @@ string
IntersectionMatrix::toString() const
string result("");
result += Dimension::toDimensionSymbol(matrix[ai][bi]);
diff --git a/src/geom/Location.cpp b/src/geom/Location.cpp
index cd1d51d..d96ef93 100644
--- a/src/geom/Location.cpp
+++ b/src/geom/Location.cpp
@@ -22,29 +22,24 @@ using namespace std;
namespace geos {
- * Converts the location value to a location symbol, for example, <code>EXTERIOR => 'e'</code>.
- *@param locationValue either EXTERIOR, BOUNDARY, INTERIOR or NULL
- *@return either 'e', 'b', 'i' or '-'
-char
+std::ostream&
+operator<<(std::ostream& os, const Location& loc)
- switch(locationValue) {
- case EXTERIOR:
- return 'e';
- case BOUNDARY:
- return 'b';
- case INTERIOR:
- return 'i';
- case UNDEF: //NULL
- return '-';
- default:
- ostringstream s;
- s << "Unknown location value: " << locationValue;
- throw util::IllegalArgumentException(s.str());
+ switch(loc) {
+ case Location::EXTERIOR:
+ os << 'e';
+ break;
+ case Location::BOUNDARY:
+ os << 'b';
+ break;
+ case Location::INTERIOR:
+ os << 'i';
+ break;
+ case Location::UNDEF:
+ os << '-';
+ break;
+ return os;
diff --git a/src/geom/prep/AbstractPreparedPolygonContains.cpp b/src/geom/prep/AbstractPreparedPolygonContains.cpp
index 2cf2c6a..314a3bd 100644
--- a/src/geom/prep/AbstractPreparedPolygonContains.cpp
+++ b/src/geom/prep/AbstractPreparedPolygonContains.cpp
@@ -181,8 +181,7 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
return true;
-bool AbstractPreparedPolygonContains::evalPointTestGeom(const Geometry *geom,
+bool AbstractPreparedPolygonContains::evalPointTestGeom(const Geometry *geom, Location outermostLoc) {
// If we had a point on the ourside of the polygon,
// we aren't covered or contained.
if (outermostLoc == Location::EXTERIOR) {
diff --git a/src/geom/prep/PreparedPolygonPredicate.cpp b/src/geom/prep/PreparedPolygonPredicate.cpp
index cd6d4c5..83f8257 100644
--- a/src/geom/prep/PreparedPolygonPredicate.cpp
+++ b/src/geom/prep/PreparedPolygonPredicate.cpp
@@ -39,16 +39,16 @@ namespace prep { // geos.geom.prep
// protected:
struct LocationMatchingFilter : public GeometryComponentFilter {
- explicit LocationMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+ explicit LocationMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, Location loc) :
pt_locator(locator), test_loc(loc), found(false) {}
algorithm::locate::PointOnGeometryLocator* pt_locator;
- const int test_loc;
+ const Location test_loc;
bool found;
void filter_ro(const Geometry* g) override {
const Coordinate* pt = g->getCoordinate();
- const int loc = pt_locator->locate(pt);
+ const auto loc = pt_locator->locate(pt);
if (loc == test_loc) {
found = true;
@@ -61,16 +61,16 @@ struct LocationMatchingFilter : public GeometryComponentFilter {
struct LocationNotMatchingFilter : public GeometryComponentFilter {
- explicit LocationNotMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, int loc) :
+ explicit LocationNotMatchingFilter(algorithm::locate::PointOnGeometryLocator* locator, Location loc) :
bool found;
if (loc != test_loc) {
found = true;
@@ -89,12 +89,12 @@ struct OutermostLocationFilter : public GeometryComponentFilter {
done(false) {}
+ Location outermost_loc;
bool done;
- auto loc = static_cast<Location::Value>(pt_locator->locate(pt));
+ auto loc = pt_locator->locate(pt);
if (outermost_loc == Location::UNDEF || outermost_loc == Location::INTERIOR) {
outermost_loc = loc;
@@ -108,12 +108,12 @@ struct OutermostLocationFilter : public GeometryComponentFilter {
return done;
+ Location getOutermostLocation() {
return outermost_loc;
+Location
PreparedPolygonPredicate::getOutermostTestComponentLocation(const geom::Geometry* testGeom) const
OutermostLocationFilter filter(prepPoly->getPointLocator());
@@ -161,7 +161,7 @@ PreparedPolygonPredicate::isAnyTargetComponentInAreaTest(
for(std::size_t i = 0, ni = targetRepPts->size(); i < ni; i++) {
const geom::Coordinate* pt = (*targetRepPts)[i];
- const int loc = piaLoc.locate(pt);
+ const Location loc = piaLoc.locate(pt);
if(geom::Location::EXTERIOR != loc) {
return true;
diff --git a/src/geomgraph/Depth.cpp b/src/geomgraph/Depth.cpp
index e86fa48..a9bd7d2 100644
--- a/src/geomgraph/Depth.cpp
+++ b/src/geomgraph/Depth.cpp
@@ -34,7 +34,7 @@ namespace geos {
int
-Depth::depthAtLocation(int location)
+Depth::depthAtLocation(geom::Location location)
if(location == Location::EXTERIOR) {
return 0;
@@ -72,7 +72,7 @@ Depth::setDepth(int geomIndex, int posIndex, int depthValue)
depth[geomIndex][posIndex] = depthValue;
-int
+Location
Depth::getLocation(int geomIndex, int posIndex) const
if(depth[geomIndex][posIndex] <= 0) {
@@ -82,7 +82,7 @@ Depth::getLocation(int geomIndex, int posIndex) const
void
-Depth::add(int geomIndex, int posIndex, int location)
+Depth::add(int geomIndex, int posIndex, Location location)
if(location == Location::INTERIOR) {
depth[geomIndex][posIndex]++;
@@ -159,7 +159,7 @@ Depth::add(const Label& lbl)
for(int i = 0; i < 2; i++) {
for(int j = 1; j < 3; j++) {
- int loc = lbl.getLocation(i, j);
+ Location loc = lbl.getLocation(i, j);
if(loc == Location::EXTERIOR || loc == Location::INTERIOR) {
// initialize depth if it is null, otherwise
// add this location value
diff --git a/src/geomgraph/DirectedEdge.cpp b/src/geomgraph/DirectedEdge.cpp
index 6e0307e..5e94845 100644
--- a/src/geomgraph/DirectedEdge.cpp
+++ b/src/geomgraph/DirectedEdge.cpp
@@ -44,7 +44,7 @@ namespace geomgraph { // geos.geomgraph
/* public static */
int
-DirectedEdge::depthFactor(int currLocation, int nextLocation)
+DirectedEdge::depthFactor(Location currLocation, Location nextLocation)
if(currLocation == Location::EXTERIOR && nextLocation == Location::INTERIOR) {
return 1;
diff --git a/src/geomgraph/DirectedEdgeStar.cpp b/src/geomgraph/DirectedEdgeStar.cpp
index 60fbf84..e4c7827 100644
--- a/src/geomgraph/DirectedEdgeStar.cpp
+++ b/src/geomgraph/DirectedEdgeStar.cpp
@@ -155,7 +155,7 @@ DirectedEdgeStar::computeLabelling(std::vector<GeometryGraph*>* geom)
assert(e);
const Label& eLabel = e->getLabel();
for(int i = 0; i < 2; ++i) {
- int eLoc = eLabel.getLocation(i);
+ Location eLoc = eLabel.getLocation(i);
if(eLoc == Location::INTERIOR || eLoc == Location::BOUNDARY) {
label.setLocation(i, Location::INTERIOR);
@@ -378,7 +378,7 @@ DirectedEdgeStar::findCoveredLineEdges()
* - INTERIOR if the edge is outgoing
* - EXTERIOR if the edge is incoming
- int startLoc = Location::UNDEF;
+ Location startLoc = Location::UNDEF;
EdgeEndStar::iterator endIt = end();
for(EdgeEndStar::iterator it = begin(); it != endIt; ++it) {
@@ -411,7 +411,7 @@ DirectedEdgeStar::findCoveredLineEdges()
* (Interior or Exterior) for the result area.
* If L edges are found, mark them as covered if they are in the interior
- int currLoc = startLoc;
+ Location currLoc = startLoc;
assert(*it);
assert(dynamic_cast<DirectedEdge*>(*it));
diff --git a/src/geomgraph/EdgeEndStar.cpp b/src/geomgraph/EdgeEndStar.cpp
index 4d601d0..b3a67ff 100644
--- a/src/geomgraph/EdgeEndStar.cpp
+++ b/src/geomgraph/EdgeEndStar.cpp
@@ -163,7 +163,7 @@ EdgeEndStar::computeLabelling(std::vector<GeometryGraph*>* geomGraph)
Label& label = e->getLabel();
for(int geomi = 0; geomi < 2; ++geomi) {
if(label.isAnyNull(geomi)) {
- int loc = Location::UNDEF;
+ Location loc = Location::UNDEF;
if(hasDimensionalCollapseEdge[geomi]) {
loc = Location::EXTERIOR;
@@ -191,7 +191,7 @@ EdgeEndStar::computeEdgeEndLabels(
/*public*/
-int
+Location
EdgeEndStar::getLocation(int geomIndex,
const Coordinate& p, std::vector<GeometryGraph*>* geom)
@@ -227,12 +227,12 @@ EdgeEndStar::checkAreaLabelsConsistent(int geomIndex)
// initialize startLoc to location of last L side (if any)
assert(*rbegin());
const Label& startLabel = (*rbegin())->getLabel();
- int startLoc = startLabel.getLocation(geomIndex, Position::LEFT);
+ Location startLoc = startLabel.getLocation(geomIndex, Position::LEFT);
// Found unlabelled area edge
assert(startLoc != Location::UNDEF);
for(EdgeEndStar::iterator it = begin(), itEnd = end(); it != itEnd; ++it) {
EdgeEnd* e = *it;
@@ -244,8 +244,8 @@ EdgeEndStar::checkAreaLabelsConsistent(int geomIndex)
// Found non-area edge
assert(eLabel.isArea(geomIndex));
- int leftLoc = eLabel.getLocation(geomIndex, Position::LEFT);
- int rightLoc = eLabel.getLocation(geomIndex, Position::RIGHT);
+ Location leftLoc = eLabel.getLocation(geomIndex, Position::LEFT);
+ Location rightLoc = eLabel.getLocation(geomIndex, Position::RIGHT);
// check that edge is really a boundary between inside and outside!
if(leftLoc == rightLoc) {
return false;
@@ -268,7 +268,7 @@ EdgeEndStar::propagateSideLabels(int geomIndex)
// Since edges are stored in CCW order around the node,
// As we move around the ring we move from the right to the
// left side of the edge
EdgeEndStar::iterator beginIt = begin();
@@ -290,7 +290,7 @@ EdgeEndStar::propagateSideLabels(int geomIndex)
return;
for(it = beginIt; it != endIt; ++it) {
EdgeEnd* e = *it;
assert(e);
@@ -303,11 +303,11 @@ EdgeEndStar::propagateSideLabels(int geomIndex)
// set side labels (if any)
// if (label.isArea()) //ORIGINAL
if(label.isArea(geomIndex)) {
- int leftLoc = label.getLocation(geomIndex,
- Position::LEFT);
+ Location leftLoc = label.getLocation(geomIndex,
+ Position::LEFT);
- int rightLoc = label.getLocation(geomIndex,
- Position::RIGHT);
+ Location rightLoc = label.getLocation(geomIndex,
+ Position::RIGHT);
// if there is a right location, that is the next
// location to propagate
diff --git a/src/geomgraph/EdgeRing.cpp b/src/geomgraph/EdgeRing.cpp
index 89d2749..e6e54c9 100644
--- a/src/geomgraph/EdgeRing.cpp
+++ b/src/geomgraph/EdgeRing.cpp
@@ -307,7 +307,7 @@ EdgeRing::mergeLabel(const Label& deLabel, int geomIndex)
testInvariant();
- int loc = deLabel.getLocation(geomIndex, Position::RIGHT);
+ Location loc = deLabel.getLocation(geomIndex, Position::RIGHT);
// no information to be had from this label
if(loc == Location::UNDEF) {
return;
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index eaa140b..c5b14c3 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -91,7 +91,7 @@ GeometryGraph::isInBoundary(int boundaryCount)
return boundaryCount % 2 == 1;
-int
+Location
GeometryGraph::determineBoundary(int boundaryCount)
return isInBoundary(boundaryCount) ? Location::BOUNDARY : Location::INTERIOR;
@@ -236,7 +236,7 @@ GeometryGraph::addPoint(const Point* p)
* the left and right locations must be interchanged.
void
-GeometryGraph::addPolygonRing(const LinearRing* lr, int cwLeft, int cwRight)
+GeometryGraph::addPolygonRing(const LinearRing* lr, Location cwLeft, Location cwRight)
// throw IllegalArgumentException (see below)
// skip empty component (see bug #234)
@@ -252,8 +252,8 @@ GeometryGraph::addPolygonRing(const LinearRing* lr, int cwLeft, int cwRight)
invalidPoint = coord->getAt(0); // its now a Coordinate
return;
- int left = cwLeft;
- int right = cwRight;
+ Location left = cwLeft;
+ Location right = cwRight;
* the isCCW call might throw an
@@ -430,7 +430,7 @@ GeometryGraph::computeEdgeIntersections(GeometryGraph* g,
void
GeometryGraph::insertPoint(int p_argIndex, const Coordinate& coord,
- int onLocation)
#if GEOS_DEBUG > 1
cerr << "GeometryGraph::insertPoint(" << coord.toString() << " called" << endl;
@@ -462,14 +462,14 @@ GeometryGraph::insertBoundaryPoint(int p_argIndex, const Coordinate& coord)
int boundaryCount = 1;
// determine the current location for the point (if any)
- int loc = lbl.getLocation(p_argIndex, Position::ON);
+ Location loc = lbl.getLocation(p_argIndex, Position::ON);
if(loc == Location::BOUNDARY) {
boundaryCount++;
// determine the boundary status of the point according to the
// Boundary Determination Rule
- int newLoc = determineBoundary(boundaryNodeRule, boundaryCount);
+ Location newLoc = determineBoundary(boundaryNodeRule, boundaryCount);
lbl.setLocation(p_argIndex, newLoc);
@@ -480,7 +480,7 @@ GeometryGraph::addSelfIntersectionNodes(int p_argIndex)
for(vector<Edge*>::iterator i = edges->begin(), endIt = edges->end();
i != endIt; ++i) {
Edge* e = *i;
- int eLoc = e->getLabel().getLocation(p_argIndex);
+ Location eLoc = e->getLabel().getLocation(p_argIndex);
EdgeIntersectionList& eiL = e->eiList;
for(EdgeIntersectionList::iterator
eiIt = eiL.begin(), eiEnd = eiL.end();
@@ -495,7 +495,7 @@ GeometryGraph::addSelfIntersectionNodes(int p_argIndex)
/*private*/
void
GeometryGraph::addSelfIntersectionNode(int p_argIndex,
- const Coordinate& coord, int loc)
+ const Coordinate& coord, Location loc)
// if this node is already a boundary node, don't change it
if(isBoundaryNode(p_argIndex, coord)) {
@@ -571,7 +571,7 @@ GeometryGraph::GeometryGraph()
/* public static */
-int
+Location
int boundaryCount)
diff --git a/src/geomgraph/Label.cpp b/src/geomgraph/Label.cpp
index b8c14a8..d0a05cb 100644
--- a/src/geomgraph/Label.cpp
+++ b/src/geomgraph/Label.cpp
@@ -46,14 +46,14 @@ Label::toLineLabel(const Label& label)
/*public*/
-Label::Label(int onLoc)
+Label::Label(Location onLoc)
elt[0] = TopologyLocation(onLoc);
elt[1] = TopologyLocation(onLoc);
/*public*/
-Label::Label(int geomIndex, int onLoc)
+Label::Label(int geomIndex, Location onLoc)
assert(geomIndex >= 0 && geomIndex < 2);
elt[0] = TopologyLocation(Location::UNDEF);
@@ -62,7 +62,7 @@ Label::Label(int geomIndex, int onLoc)
/*public*/
-Label::Label(int onLoc, int leftLoc, int rightLoc)
+Label::Label(Location onLoc, Location leftLoc, Location rightLoc)
elt[0] = TopologyLocation(onLoc, leftLoc, rightLoc);
elt[1] = TopologyLocation(onLoc, leftLoc, rightLoc);
@@ -92,7 +92,7 @@ Label::operator=(const Label& l)
/*public*/
-Label::Label(int geomIndex, int onLoc, int leftLoc, int rightLoc)
+Label::Label(int geomIndex, Location onLoc, Location leftLoc, Location rightLoc)
elt[0] = TopologyLocation(Location::UNDEF, Location::UNDEF, Location::UNDEF);
elt[1] = TopologyLocation(Location::UNDEF, Location::UNDEF, Location::UNDEF);
@@ -108,7 +108,7 @@ Label::flip()
/*public*/
-int
+Location
Label::getLocation(int geomIndex, int posIndex) const
@@ -116,7 +116,7 @@ Label::getLocation(int geomIndex, int posIndex) const
/*public*/
-int
+Location
Label::getLocation(int geomIndex) const
@@ -125,7 +125,7 @@ Label::getLocation(int geomIndex) const
/*public*/
void
-Label::setLocation(int geomIndex, int posIndex, int location)
+Label::setLocation(int geomIndex, int posIndex, Location location)
elt[geomIndex].setLocation(posIndex, location);
@@ -133,7 +133,7 @@ Label::setLocation(int geomIndex, int posIndex, int location)
/*public*/
void
-Label::setLocation(int geomIndex, int location)
+Label::setLocation(int geomIndex, Location location)
elt[geomIndex].setLocation(Position::ON, location);
@@ -141,7 +141,7 @@ Label::setLocation(int geomIndex, int location)
/*public*/
void
-Label::setAllLocations(int geomIndex, int location)
+Label::setAllLocations(int geomIndex, Location location)
elt[geomIndex].setAllLocations(location);
@@ -149,7 +149,7 @@ Label::setAllLocations(int geomIndex, int location)
/*public*/
void
-Label::setAllLocationsIfNull(int geomIndex, int location)
+Label::setAllLocationsIfNull(int geomIndex, Location location)
elt[geomIndex].setAllLocationsIfNull(location);
@@ -157,7 +157,7 @@ Label::setAllLocationsIfNull(int geomIndex, int location)
/*public*/
void
-Label::setAllLocationsIfNull(int location)
+Label::setAllLocationsIfNull(Location location)
setAllLocationsIfNull(0, location);
setAllLocationsIfNull(1, location);
@@ -243,7 +243,7 @@ Label::isEqualOnSide(const Label& lbl, int side) const
/*public*/
bool
-Label::allPositionsEqual(int geomIndex, int loc) const
+Label::allPositionsEqual(int geomIndex, Location loc) const
return elt[geomIndex].allPositionsEqual(loc);
diff --git a/src/geomgraph/Node.cpp b/src/geomgraph/Node.cpp
index 40209b3..fcd8a21 100644
--- a/src/geomgraph/Node.cpp
+++ b/src/geomgraph/Node.cpp
@@ -175,8 +175,8 @@ void
Node::mergeLabel(const Label& label2)
- int loc = computeMergedLocation(label2, i);
- int thisLoc = label.getLocation(i);
+ Location loc = computeMergedLocation(label2, i);
+ Location thisLoc = label.getLocation(i);
if(thisLoc == Location::UNDEF) {
label.setLocation(i, loc);
@@ -186,7 +186,7 @@ Node::mergeLabel(const Label& label2)
/*public*/
void
-Node::setLabel(int argIndex, int onLocation)
+Node::setLabel(int argIndex, Location onLocation)
if(label.isNull()) {
label = Label(argIndex, onLocation);
@@ -202,9 +202,9 @@ Node::setLabel(int argIndex, int onLocation)
void
Node::setLabelBoundary(int argIndex)
- int loc = label.getLocation(argIndex);
+ Location loc = label.getLocation(argIndex);
// flip the loc
- int newLoc;
+ Location newLoc;
switch(loc) {
newLoc = Location::INTERIOR;
@@ -222,13 +222,13 @@ Node::setLabelBoundary(int argIndex)
/*public*/
-int
+Location
Node::computeMergedLocation(const Label& label2, int eltIndex)
loc = label.getLocation(eltIndex);
if(!label2.isNull(eltIndex)) {
- int nLoc = label2.getLocation(eltIndex);
+ Location nLoc = label2.getLocation(eltIndex);
if(loc != Location::BOUNDARY) {
loc = nLoc;
diff --git a/src/geomgraph/TopologyLocation.cpp b/src/geomgraph/TopologyLocation.cpp
index 173237d..a7e0918 100644
--- a/src/geomgraph/TopologyLocation.cpp
+++ b/src/geomgraph/TopologyLocation.cpp
@@ -49,7 +49,7 @@ TopologyLocation::~TopologyLocation()
/*public*/
-TopologyLocation::TopologyLocation(int on, int left, int right):
+TopologyLocation::TopologyLocation(Location on, Location left, Location right):
location(3)
location[Position::ON] = on;
@@ -58,7 +58,7 @@ TopologyLocation::TopologyLocation(int on, int left, int right):
/*public*/
-TopologyLocation::TopologyLocation(int on):
+TopologyLocation::TopologyLocation(Location on):
location(1, on)
//(*location)[Position::ON]=on;
@@ -80,7 +80,7 @@ TopologyLocation::operator= (const TopologyLocation& gl)
/*public*/
-int
+Location
TopologyLocation::get(size_t posIndex) const
// should be an assert() instead ?
@@ -142,14 +142,12 @@ TopologyLocation::flip()
if(location.size() <= 1) {
return;
- int temp = location[Position::LEFT];
- location[Position::LEFT] = location[Position::RIGHT];
- location[Position::RIGHT] = temp;
+ std::swap(location[Position::LEFT], location[Position::RIGHT]);
/*public*/
void
-TopologyLocation::setAllLocations(int locValue)
+TopologyLocation::setAllLocations(Location locValue)
for(size_t i = 0, sz = location.size(); i < sz; ++i) {
location[i] = locValue;
@@ -158,7 +156,7 @@ TopologyLocation::setAllLocations(int locValue)
/*public*/
void
-TopologyLocation::setAllLocationsIfNull(int locValue)
+TopologyLocation::setAllLocationsIfNull(Location locValue)
if(location[i] == Location::UNDEF) {
@@ -169,20 +167,20 @@ TopologyLocation::setAllLocationsIfNull(int locValue)
/*public*/
void
-TopologyLocation::setLocation(size_t locIndex, int locValue)
+TopologyLocation::setLocation(size_t locIndex, Location locValue)
location[locIndex] = locValue;
/*public*/
void
-TopologyLocation::setLocation(int locValue)
+TopologyLocation::setLocation(Location locValue)
setLocation(Position::ON, locValue);
/*public*/
-const vector<int>&
+const vector<Location>&
TopologyLocation::getLocations() const
return location;
@@ -190,7 +188,7 @@ TopologyLocation::getLocations() const
/*public*/
void
-TopologyLocation::setLocations(int on, int left, int right)
+TopologyLocation::setLocations(Location on, Location left, Location right)
assert(location.size() >= 3);
@@ -200,7 +198,7 @@ TopologyLocation::setLocations(int on, int left, int right)
/*public*/
bool
-TopologyLocation::allPositionsEqual(int loc) const
+TopologyLocation::allPositionsEqual(Location loc) const
if(location[i] != loc) {
@@ -241,11 +239,11 @@ std::ostream&
operator<< (std::ostream& os, const TopologyLocation& tl)
if(tl.location.size() > 1) {
- os << Location::toLocationSymbol(tl.location[Position::LEFT]);
+ os << tl.location[Position::LEFT];
- os << Location::toLocationSymbol(tl.location[Position::ON]);
+ os << tl.location[Position::ON];
- os << Location::toLocationSymbol(tl.location[Position::RIGHT]);
+ os << tl.location[Position::RIGHT];
return os;
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index e35a0c2..0bc6d7e 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -109,8 +109,8 @@ static Profiler* profiler = Profiler::instance();
int
BufferBuilder::depthDelta(const Label& label)
- int lLoc = label.getLocation(0, Position::LEFT);
- int rLoc = label.getLocation(0, Position::RIGHT);
+ Location lLoc = label.getLocation(0, Position::LEFT);
+ Location rLoc = label.getLocation(0, Position::RIGHT);
if(lLoc == Location::INTERIOR && rLoc == Location::EXTERIOR) {
return 1;
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index ed3522c..bbc50b3 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -92,7 +92,7 @@ OffsetCurveSetBuilder::getCurves()
/*public*/
void
OffsetCurveSetBuilder::addCurves(const std::vector<CoordinateSequence*>& lineList,
for(size_t i = 0, n = lineList.size(); i < n; ++i) {
CoordinateSequence* coords = lineList[i];
@@ -103,7 +103,7 @@ OffsetCurveSetBuilder::addCurves(const std::vector<CoordinateSequence*>& lineLis
/*private*/
void
OffsetCurveSetBuilder::addCurve(CoordinateSequence* coord,
#if GEOS_DEBUG
std::cerr << __FUNCTION__ << ": coords=" << coord->toString() << std::endl;
@@ -281,7 +281,7 @@ OffsetCurveSetBuilder::addPolygon(const Polygon* p)
/* private */
void
OffsetCurveSetBuilder::addPolygonRing(const CoordinateSequence* coord,
- double offsetDistance, int side, int cwLeftLoc, int cwRightLoc)
+ double offsetDistance, int side, geom::Location cwLeftLoc, geom::Location cwRightLoc)
// don't bother adding ring if it is "flat" and
@@ -290,8 +290,8 @@ OffsetCurveSetBuilder::addPolygonRing(const CoordinateSequence* coord,
return;
- int leftLoc = cwLeftLoc;
- int rightLoc = cwRightLoc;
+ Location leftLoc = cwLeftLoc;
+ Location rightLoc = cwRightLoc;
#if GEOS_DEBUG
std::cerr << "OffsetCurveSetBuilder::addPolygonRing: CCW: " << Orientation::isCCW(coord) << std::endl;
#endif
diff --git a/src/operation/overlay/LineBuilder.cpp b/src/operation/overlay/LineBuilder.cpp
index 99512fd..372c382 100644
--- a/src/operation/overlay/LineBuilder.cpp
+++ b/src/operation/overlay/LineBuilder.cpp
@@ -305,7 +305,7 @@ LineBuilder::labelIsolatedLines(vector<Edge*>* edgesList)
void
LineBuilder::labelIsolatedLine(Edge* e, int targetIndex)
- int loc = ptLocator->locate(e->getCoordinate(),
+ Location loc = ptLocator->locate(e->getCoordinate(),
op->getArgGeometry(targetIndex));
e->getLabel().setLocation(targetIndex, loc);
diff --git a/src/operation/overlay/OverlayOp.cpp b/src/operation/overlay/OverlayOp.cpp
index 65274a6..13361a1 100644
--- a/src/operation/overlay/OverlayOp.cpp
+++ b/src/operation/overlay/OverlayOp.cpp
@@ -97,15 +97,15 @@ OverlayOp::overlayOp(const Geometry* geom0, const Geometry* geom1,
bool
OverlayOp::isResultOfOp(const Label& label, OverlayOp::OpCode opCode)
- int loc0 = label.getLocation(0);
- int loc1 = label.getLocation(1);
+ Location loc0 = label.getLocation(0);
+ Location loc1 = label.getLocation(1);
return isResultOfOp(loc0, loc1, opCode);
/* static public */
bool
-OverlayOp::isResultOfOp(int loc0, int loc1, OverlayOp::OpCode opCode)
+OverlayOp::isResultOfOp(Location loc0, Location loc1, OverlayOp::OpCode opCode)
if(loc0 == Location::BOUNDARY) {
loc0 = Location::INTERIOR;
@@ -406,7 +406,7 @@ OverlayOp::labelIncompleteNode(Node* n, int targetIndex)
cerr << "OverlayOp::labelIncompleteNode(" << n->print() << ", " << targetIndex << ")" << endl;
#endif
const Geometry* targetGeom = arg[targetIndex]->getGeometry();
- int loc = ptLocator.locate(n->getCoordinate(), targetGeom);
+ Location loc = ptLocator.locate(n->getCoordinate(), targetGeom);
n->getLabel().setLocation(targetIndex, loc);
#if GEOS_DEBUG
@@ -606,7 +606,7 @@ OverlayOp::isCovered(const Coordinate& coord, vector<Geometry*>* geomList)
for(size_t i = 0, n = geomList->size(); i < n; ++i) {
Geometry* geom = (*geomList)[i];
- int loc = ptLocator.locate(coord, geom);
+ Location loc = ptLocator.locate(coord, geom);
return true;
@@ -620,7 +620,7 @@ OverlayOp::isCovered(const Coordinate& coord, vector<LineString*>* geomList)
Geometry* geom = (Geometry*)(*geomList)[i];
return true;
@@ -634,7 +634,7 @@ OverlayOp::isCovered(const Coordinate& coord, vector<Polygon*>* geomList)
return true;
@@ -1015,7 +1015,7 @@ struct PointCoveredByAny: public geom::CoordinateFilter {
filter_ro(const Coordinate* coord) override
for(size_t i = 0, n = geoms.size(); i < n; ++i) {
- int loc = locator.locate(*coord, geoms[i]);
+ Location loc = locator.locate(*coord, geoms[i]);
if(loc == Location::INTERIOR ||
return;
diff --git a/src/operation/overlay/validate/FuzzyPointLocator.cpp b/src/operation/overlay/validate/FuzzyPointLocator.cpp
index 4abac71..e9cc604 100644
--- a/src/operation/overlay/validate/FuzzyPointLocator.cpp
+++ b/src/operation/overlay/validate/FuzzyPointLocator.cpp
@@ -123,7 +123,7 @@ FuzzyPointLocator::getLineWork(const geom::Geometry& geom)
/* public */
+Location
FuzzyPointLocator::getLocation(const Coordinate& pt)
unique_ptr<Geometry> point(g.getFactory()->createPoint(pt));
@@ -138,10 +138,7 @@ FuzzyPointLocator::getLocation(const Coordinate& pt)
// now we know point must be clearly inside or outside geometry,
// so return actual location value
- // (the static_cast is needed because PointLocator doesn't cleanly
- // return a Location::Value - it should !!)
- return static_cast<Location::Value>(ptLocator.locate(pt, &g));
+ return ptLocator.locate(pt, &g);
} // namespace geos.operation.overlay.validate
diff --git a/src/operation/overlay/validate/OverlayResultValidator.cpp b/src/operation/overlay/validate/OverlayResultValidator.cpp
index 5900cb5..44e3974 100644
--- a/src/operation/overlay/validate/OverlayResultValidator.cpp
+++ b/src/operation/overlay/validate/OverlayResultValidator.cpp
@@ -172,7 +172,8 @@ bool
OverlayResultValidator::testValid(OverlayOp::OpCode overlayOp,
- std::vector<geom::Location::Value> location(3);
+ // TODO use std::array<geom::Location, 3> ?
+ std::vector<geom::Location> location(3);
location[0] = fpl0.getLocation(pt);
location[1] = fpl1.getLocation(pt);
@@ -203,7 +204,7 @@ OverlayResultValidator::testValid(OverlayOp::OpCode overlayOp,
/* private */
bool
OverlayResultValidator::isValidResult(OverlayOp::OpCode overlayOp,
bool expectedInterior = OverlayOp::isResultOfOp(location[0],
location[1], overlayOp);
diff --git a/src/operation/relate/EdgeEndBundle.cpp b/src/operation/relate/EdgeEndBundle.cpp
index 81f3a14..3f458d8 100644
--- a/src/operation/relate/EdgeEndBundle.cpp
+++ b/src/operation/relate/EdgeEndBundle.cpp
@@ -115,7 +115,7 @@ EdgeEndBundle::computeLabelOn(int geomIndex, const algorithm::BoundaryNodeRule&
for(vector<EdgeEnd*>::iterator it = edgeEnds->begin(); it < edgeEnds->end(); it++) {
EdgeEnd* e = *it;
- int loc = e->getLabel().getLocation(geomIndex);
+ Location loc = e->getLabel().getLocation(geomIndex);
boundaryCount++;
@@ -123,7 +123,7 @@ EdgeEndBundle::computeLabelOn(int geomIndex, const algorithm::BoundaryNodeRule&
foundInterior = true;
if(foundInterior) {
loc = Location::INTERIOR;
@@ -165,7 +165,7 @@ EdgeEndBundle::computeLabelSide(int geomIndex, int side)
EdgeEnd* e = *it;
if(e->getLabel().isArea()) {
- int loc = e->getLabel().getLocation(geomIndex, side);
+ Location loc = e->getLabel().getLocation(geomIndex, side);
label.setLocation(geomIndex, side, Location::INTERIOR);
return;
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index edc010e..fbe5b4c 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -346,7 +346,7 @@ RelateComputer::computeIntersectionNodes(int argIndex)
std::vector<Edge*>* edges = (*arg)[argIndex]->getEdges();
for(std::vector<Edge*>::iterator i = edges->begin(); i < edges->end(); i++) {
Edge* e = *i;
- int eLoc = e->getLabel().getLocation(argIndex);
+ Location eLoc = e->getLabel().getLocation(argIndex);
EdgeIntersectionList& eiL = e->getEdgeIntersectionList();
EdgeIntersectionList::iterator it = eiL.begin();
EdgeIntersectionList::iterator end = eiL.end();
@@ -379,7 +379,7 @@ RelateComputer::labelIntersectionNodes(int argIndex)
Edge* e = *i;
EdgeIntersectionList::iterator eiIt = eiL.begin();
EdgeIntersectionList::iterator eiEnd = eiL.end();
@@ -481,7 +481,7 @@ RelateComputer::labelIsolatedEdge(Edge* e, int targetIndex, const Geometry* targ
// since edge is not in boundary, may not need the full generality of PointLocator?
// Possibly should use ptInArea locator instead? We probably know here
// that the edge does not touch the bdy of the target Geometry
- int loc = ptLocator.locate(e->getCoordinate(), target);
+ Location loc = ptLocator.locate(e->getCoordinate(), target);
e->getLabel().setAllLocations(targetIndex, loc);
else {
@@ -515,7 +515,7 @@ RelateComputer::labelIsolatedNodes()
void
RelateComputer::labelIsolatedNode(Node* n, int targetIndex)
(*arg)[targetIndex]->getGeometry());
n->getLabel().setAllLocations(targetIndex, loc);
//debugPrintln(n.getLabel());
diff --git a/src/operation/relate/RelateNodeGraph.cpp b/src/operation/relate/RelateNodeGraph.cpp
index 28dbd68..270ce16 100644
--- a/src/operation/relate/RelateNodeGraph.cpp
+++ b/src/operation/relate/RelateNodeGraph.cpp
@@ -97,7 +97,7 @@ RelateNodeGraph::computeIntersectionNodes(GeometryGraph* geomGraph,
vector<Edge*>::iterator edgeIt = edges->begin();
for(; edgeIt < edges->end(); ++edgeIt) {
Edge* e = *edgeIt;
diff --git a/src/operation/union/PointGeometryUnion.cpp b/src/operation/union/PointGeometryUnion.cpp
index baa6382..83e5e6d 100644
--- a/src/operation/union/PointGeometryUnion.cpp
+++ b/src/operation/union/PointGeometryUnion.cpp
@@ -50,7 +50,7 @@ PointGeometryUnion::Union() const
const Point* point = dynamic_cast<const Point*>(pointGeom.getGeometryN(i));
assert(point);
const Coordinate* coord = point->getCoordinate();
- int loc = locater.locate(*coord, &otherGeom);
+ Location loc = locater.locate(*coord, &otherGeom);
if(loc == Location::EXTERIOR) {
exteriorCoords.insert(*coord);
diff --git a/tests/unit/algorithm/LocatePointInRingTest.cpp b/tests/unit/algorithm/LocatePointInRingTest.cpp
index 7edde30..b75307d 100644
--- a/tests/unit/algorithm/LocatePointInRingTest.cpp
+++ b/tests/unit/algorithm/LocatePointInRingTest.cpp
@@ -50,24 +50,24 @@ static GeometryFactory::Ptr gf = GeometryFactory::create(&pm);
static geos::io::WKTReader reader(gf.get());
static void
-runPtLocator(int expected, const Coordinate& pt,
+runPtLocator(Location expected, const Coordinate& pt,
const std::string& wkt)
std::unique_ptr<Geometry> geom(reader.read(wkt));
const Polygon* poly = dynamic_cast<Polygon*>(geom.get());
const CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
- int loc = PointLocation::locateInRing(pt, *cs);
+ Location loc = PointLocation::locateInRing(pt, *cs);
ensure_equals(loc, expected);
static void
-runPtLocatorDD(int expected, const Coordinate& pt,
+runPtLocatorDD(Location expected, const Coordinate& pt,
- int loc = RayCrossingCounterDD::locatePointInRing(pt, *cs);
+ Location loc = RayCrossingCounterDD::locatePointInRing(pt, *cs);
diff --git a/tests/unit/algorithm/PointLocatorTest.cpp b/tests/unit/algorithm/PointLocatorTest.cpp
index 5168448..bc63b07 100644
--- a/tests/unit/algorithm/PointLocatorTest.cpp
+++ b/tests/unit/algorithm/PointLocatorTest.cpp
@@ -47,12 +47,12 @@ static geos::io::WKTReader reader(gf.get());
typedef std::unique_ptr<Geometry> GeomPtr;
void
GeomPtr geom(reader.read(wkt));
geos::algorithm::PointLocator pointLocator;
- int loc = pointLocator.locate(pt, geom.get());
+ Location loc = pointLocator.locate(pt, geom.get());
diff --git a/tests/unit/geom/IntersectionMatrixTest.cpp b/tests/unit/geom/IntersectionMatrixTest.cpp
index c6bdeae..1e52533 100644
--- a/tests/unit/geom/IntersectionMatrixTest.cpp
+++ b/tests/unit/geom/IntersectionMatrixTest.cpp
@@ -5,6 +5,7 @@
// geos
#include <geos/geom/IntersectionMatrix.h>
+#include <geos/geom/Location.h>
// std
#include <memory>
#include <string>
@@ -176,11 +177,13 @@ template<>
void object::test<11>
+ using geos::geom::Location;
// 'im_' is initialized with 'FFFFFFFFF'
ensure_equals(im_.toString(), pattern_false_);
// Do some changes and checks
- im_.set(0, 0, geos::geom::Dimension::P);
+ im_.set(Location::INTERIOR, Location::INTERIOR, geos::geom::Dimension::P);
ensure_equals(im_.toString(), "0FFFFFFFF");
@@ -248,15 +251,17 @@ template<>
void object::test<15>
// 1. No change expected
- im_.setAtLeast(0, 0, geos::geom::Dimension::False);
+ im_.setAtLeast(Location::INTERIOR, Location::INTERIOR, geos::geom::Dimension::False);
// 2. Change is expected
- im_.setAtLeast(0, 0, geos::geom::Dimension::A);
+ im_.setAtLeast(Location::INTERIOR, Location::INTERIOR, geos::geom::Dimension::A);
ensure_equals(im_.toString(), "2FFFFFFFF");
@@ -267,13 +272,15 @@ template<>
void object::test<16>
ensure(im_.toString() != pattern_false_);
- ensure_equals(im_.get(0, 0), geos::geom::Dimension::A);
+ ensure_equals(im_.get(Location::INTERIOR, Location::INTERIOR), geos::geom::Dimension::A);
// Test of get(int row, int column)
@@ -282,17 +289,19 @@ template<>
void object::test<17>
- // Test on the original pattern 'FFFFFFFFF' of the 'im_' object
+ // Test on the original p0attern 'FFFFFFFFF' of the 'im_' object
- ensure_equals(im_.get(0, 0), geos::geom::Dimension::False);
+ ensure_equals(im_.get(Location::INTERIOR, Location::INTERIOR), geos::geom::Dimension::False);
// Change first value and test again
// Change last value and test again
- im_.setAtLeast(2, 2, geos::geom::Dimension::L);
- ensure_equals(im_.get(2, 2), geos::geom::Dimension::L);
+ im_.setAtLeast(Location::EXTERIOR, Location::EXTERIOR, geos::geom::Dimension::L);
+ ensure_equals(im_.get(Location::EXTERIOR, Location::EXTERIOR), geos::geom::Dimension::L);
diff --git a/tests/unit/geom/LocationTest.cpp b/tests/unit/geom/LocationTest.cpp
index cdde19d..3a1d0f0 100644
--- a/tests/unit/geom/LocationTest.cpp
+++ b/tests/unit/geom/LocationTest.cpp
@@ -6,6 +6,7 @@
// geos
#include <geos/util/IllegalArgumentException.h>
+#include <sstream>
namespace tut {
@@ -14,10 +15,10 @@ namespace tut {
// Common data used by tests
struct test_location_data {
- int undef;
- int interior;
- int boundary;
- int exterior;
+ geos::geom::Location undef;
+ geos::geom::Location interior;
+ geos::geom::Location boundary;
+ geos::geom::Location exterior;
test_location_data()
: undef(geos::geom::Location::UNDEF),
interior(geos::geom::Location::INTERIOR),
@@ -44,7 +45,7 @@ void object::test<1>
ensure("NOTE: Location has no default constructor.", true);
-// Test of toLocationSymbol()
+// Test of << operator
template<>
template<>
void object::test<2>
@@ -52,30 +53,25 @@ void object::test<2>
- ensure_equals(Location::toLocationSymbol(exterior), 'e');
- ensure_equals(Location::toLocationSymbol(boundary), 'b');
- ensure_equals(Location::toLocationSymbol(interior), 'i');
- ensure_equals(Location::toLocationSymbol(undef), '-');
+ std::stringstream s;
-// Test of toLocationSymbol() throwing IllegalArgumentException
-template<>
-template<>
-void object::test<3>
- using geos::geom::Location;
+ s << Location::EXTERIOR;
+ ensure_equals(s.str(), "e");
+ s.str(""); // reset
+ s.clear();
+ s << Location::BOUNDARY;
+ ensure_equals(s.str(), "b");
+ s.clear();
- try {
+ s << Location::INTERIOR;
+ ensure_equals(s.str(), "i");
+ s.clear();
- fail("IllegalArgumentException expected");
- catch(geos::util::IllegalArgumentException const& e) {
- const char* msg = e.what(); // ok
- ensure(msg != nullptr);
+ s << Location::UNDEF;
+ ensure_equals(s.str(), "-");
} // namespace tut
Summary of changes:
include/geos/algorithm/PointLocation.h | 25 ++--
include/geos/algorithm/PointLocator.h | 12 +-
include/geos/algorithm/RayCrossingCounter.h | 7 +-
include/geos/algorithm/RayCrossingCounterDD.h | 7 +-
.../algorithm/locate/IndexedPointInAreaLocator.h | 2 +-
.../geos/algorithm/locate/PointOnGeometryLocator.h | 4 +-
.../algorithm/locate/SimplePointInAreaLocator.h | 9 +-
include/geos/geom/IntersectionMatrix.h | 15 ++-
include/geos/geom/Location.h | 58 ++++----
.../geom/prep/AbstractPreparedPolygonContains.h | 2 +-
include/geos/geom/prep/PreparedPolygonPredicate.h | 2 +-
include/geos/geomgraph/Depth.h | 7 +-
include/geos/geomgraph/DirectedEdge.h | 3 +-
include/geos/geomgraph/EdgeEndStar.h | 10 +-
include/geos/geomgraph/GeometryGraph.h | 10 +-
include/geos/geomgraph/Label.h | 25 ++--
include/geos/geomgraph/Node.h | 4 +-
include/geos/geomgraph/TopologyLocation.h | 23 ++--
.../geos/operation/buffer/OffsetCurveSetBuilder.h | 11 +-
include/geos/operation/overlay/OverlayOp.h | 3 +-
.../operation/overlay/validate/FuzzyPointLocator.h | 2 +-
.../overlay/validate/OverlayResultValidator.h | 2 +-
src/algorithm/PointLocation.cpp | 4 +-
src/algorithm/PointLocator.cpp | 16 +--
src/algorithm/RayCrossingCounter.cpp | 6 +-
src/algorithm/RayCrossingCounterDD.cpp | 6 +-
src/algorithm/locate/IndexedPointInAreaLocator.cpp | 2 +-
src/algorithm/locate/SimplePointInAreaLocator.cpp | 12 +-
src/geom/IntersectionMatrix.cpp | 149 +++++++++------------
src/geom/Location.cpp | 37 +++--
src/geom/prep/AbstractPreparedPolygonContains.cpp | 3 +-
src/geom/prep/PreparedPolygonPredicate.cpp | 22 +--
src/geomgraph/Depth.cpp | 8 +-
src/geomgraph/DirectedEdge.cpp | 2 +-
src/geomgraph/DirectedEdgeStar.cpp | 6 +-
src/geomgraph/EdgeEndStar.cpp | 24 ++--
src/geomgraph/EdgeRing.cpp | 2 +-
src/geomgraph/GeometryGraph.cpp | 20 +--
src/geomgraph/Label.cpp | 24 ++--
src/geomgraph/Node.cpp | 16 +--
src/geomgraph/TopologyLocation.cpp | 30 ++---
src/operation/buffer/BufferBuilder.cpp | 4 +-
src/operation/buffer/OffsetCurveSetBuilder.cpp | 10 +-
src/operation/overlay/LineBuilder.cpp | 2 +-
src/operation/overlay/OverlayOp.cpp | 16 +--
.../overlay/validate/FuzzyPointLocator.cpp | 7 +-
.../overlay/validate/OverlayResultValidator.cpp | 5 +-
src/operation/relate/EdgeEndBundle.cpp | 6 +-
src/operation/relate/RelateComputer.cpp | 8 +-
src/operation/relate/RelateNodeGraph.cpp | 2 +-
src/operation/union/PointGeometryUnion.cpp | 2 +-
tests/unit/algorithm/LocatePointInRingTest.cpp | 8 +-
tests/unit/algorithm/PointLocatorTest.cpp | 4 +-
tests/unit/geom/IntersectionMatrixTest.cpp | 31 +++--
tests/unit/geom/LocationTest.cpp | 48 +++----
55 files changed, 383 insertions(+), 402 deletions(-)
hooks/post-receive
More information about the geos-commits
