[geos-commits] [SCM] GEOS branch master updated. a64c3d737ae771d9734a987c5620dee6720a87df
git at osgeo.org
git at osgeo.org
Tue Jun 18 06:57:47 PDT 2019
the project "GEOS".
via a64c3d737ae771d9734a987c5620dee6720a87df (commit)
via ee679ead0071ecbab99d7957294129c8ec285dee (commit)
via 573caf8e33c70d1e435d9aa5db2e4dbcc93432d4 (commit)
from e83855d40d8ce0645a5d47469e82245e630d3290 (commit)
revisions in full, below.
commit a64c3d737ae771d9734a987c5620dee6720a87df
Merge: e83855d ee679ea
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Jun 18 09:57:30 2019 -0400
Merge branch 'io-unique-ptr'
commit ee679ead0071ecbab99d7957294129c8ec285dee
Date: Mon Jun 17 07:47:48 2019 -0400
Simplify constuction of base class unique_ptr from subclass unique_ptr
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index 39abe92..95df676 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -241,25 +241,25 @@ WKBReader::readGeometry()
switch(geometryType) {
case WKBConstants::wkbPoint :
- result.reset(readPoint().release());
+ result = readPoint();
break;
case WKBConstants::wkbLineString :
- result.reset(readLineString().release());
+ result = readLineString();
break;
case WKBConstants::wkbPolygon :
- result.reset(readPolygon().release());
+ result = readPolygon();
break;
case WKBConstants::wkbMultiPoint :
- result.reset(readMultiPoint().release());
+ result = readMultiPoint();
break;
case WKBConstants::wkbMultiLineString :
- result.reset(readMultiLineString().release());
+ result = readMultiLineString();
break;
case WKBConstants::wkbMultiPolygon :
- result.reset(readMultiPolygon().release());
+ result = readMultiPolygon();
break;
case WKBConstants::wkbGeometryCollection :
- result.reset(readGeometryCollection().release());
+ result = readGeometryCollection();
break;
default:
stringstream err;
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index 7738c89..ff2d360 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -220,30 +220,30 @@ WKTReader::readGeometryTaggedText(StringTokenizer* tokenizer)
string type = getNextWord(tokenizer);
if(type == "POINT") {
- return std::unique_ptr<Geometry>(readPointText(tokenizer).release());
+ return readPointText(tokenizer);
else if(type == "LINESTRING") {
- return std::unique_ptr<Geometry>(readLineStringText(tokenizer));
+ return readLineStringText(tokenizer);
else if(type == "LINEARRING") {
- return std::unique_ptr<Geometry>(readLinearRingText(tokenizer));
+ return readLinearRingText(tokenizer);
else if(type == "POLYGON") {
- return std::unique_ptr<Geometry>(readPolygonText(tokenizer));
+ return readPolygonText(tokenizer);
else if(type == "MULTIPOINT") {
- return std::unique_ptr<Geometry>(readMultiPointText(tokenizer));
+ return readMultiPointText(tokenizer);
else if(type == "MULTILINESTRING") {
- return std::unique_ptr<Geometry>(readMultiLineStringText(tokenizer));
+ return readMultiLineStringText(tokenizer);
else if(type == "MULTIPOLYGON") {
- return std::unique_ptr<Geometry>(readMultiPolygonText(tokenizer));
+ return readMultiPolygonText(tokenizer);
else if(type == "GEOMETRYCOLLECTION") {
- return std::unique_ptr<Geometry>(readGeometryCollectionText(tokenizer));
+ return readGeometryCollectionText(tokenizer);
- throw ParseException("Unknown type", type);
+ throw ParseException("Unknown type", type);
std::unique_ptr<Point>
commit 573caf8e33c70d1e435d9aa5db2e4dbcc93432d4
Date: Sun Jun 16 20:59:46 2019 -0400
Return unique_ptr from WKTReader and WKBReader
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index c2c2c3b..826cb71 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1324,8 +1324,8 @@ extern "C" {
const std::string wktstring(wkt);
WKTReader r(static_cast<GeometryFactory const*>(handle->geomFactory));
- Geometry* g = r.read(wktstring);
- return g;
+ auto g = r.read(wktstring);
+ return g.release();
catch(const std::exception& e) {
handle->ERROR_MESSAGE("%s", e.what());
@@ -1427,8 +1427,8 @@ extern "C" {
std::istringstream is(std::ios_base::binary);
is.str(wkbstring);
is.seekg(0, std::ios::beg); // rewind reader pointer
- Geometry* g = r.read(is);
- return g;
+ auto g = r.read(is);
@@ -1501,8 +1501,8 @@ extern "C" {
is.str(hexstring);
- Geometry* g = r.readHEX(is);
- return g;
+ auto g = r.readHEX(is);
@@ -4638,8 +4638,7 @@ extern "C" {
try {
- Geometry* g = reader->read(wktstring);
- return g;
+ return reader->read(wktstring).release();
@@ -4950,8 +4949,7 @@ extern "C" {
membuf mb((char*)wkb, size);
istream is(&mb);
- Geometry* g = reader->read(is);
- return g;
+ return reader->read(is).release();
@@ -4985,8 +4983,7 @@ extern "C" {
is.str(hexstring);
- Geometry* g = reader->readHEX(is);
- return g;
+ return reader->readHEX(is).release();
diff --git a/doc/example.cpp b/doc/example.cpp
index 68eb354..9d5ad07 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -160,7 +160,7 @@ WKBtest(vector<Geometry*>* geoms)
" fail:" << s.fail() << endl;
#endif
- gout = wkbReader.read(s);
+ gout = wkbReader.read(s).release();
#if DEBUG_STREAM_STATE
cout << "State of stream after READ: ";
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index d507815..affdb1c 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -26,8 +26,8 @@
#include <geos/io/ByteOrderDataInStream.h> // for composition
#include <iosfwd> // ostream, istream
+#include <memory>
#include <vector>
-#include <string>
#define BAD_GEOM_TYPE_MSG "Bad geometry type encountered in"
@@ -93,8 +93,7 @@ public:
* @throws IOException
* @throws ParseException
- geom::Geometry* read(std::istream& is);
- // throws IOException, ParseException
+ std::unique_ptr<geom::Geometry> read(std::istream& is);
* \brief Reads a Geometry from an istream in hex format.
@@ -104,8 +103,7 @@ public:
- geom::Geometry* readHEX(std::istream& is);
+ std::unique_ptr<geom::Geometry> readHEX(std::istream& is);
* \brief Print WKB in HEX form to out stream
@@ -126,32 +124,23 @@ private:
std::vector<double> ordValues;
- geom::Geometry* readGeometry();
+ std::unique_ptr<geom::Geometry> readGeometry();
- geom::Point* readPoint();
+ std::unique_ptr<geom::Point> readPoint();
- geom::LineString* readLineString();
+ std::unique_ptr<geom::LineString> readLineString();
- geom::LinearRing* readLinearRing();
+ std::unique_ptr<geom::LinearRing> readLinearRing();
- geom::Polygon* readPolygon();
+ std::unique_ptr<geom::Polygon> readPolygon();
- geom::MultiPoint* readMultiPoint();
+ std::unique_ptr<geom::MultiPoint> readMultiPoint();
- geom::MultiLineString* readMultiLineString();
+ std::unique_ptr<geom::MultiLineString> readMultiLineString();
- geom::MultiPolygon* readMultiPolygon();
+ std::unique_ptr<geom::MultiPolygon> readMultiPolygon();
- geom::GeometryCollection* readGeometryCollection();
+ std::unique_ptr<geom::GeometryCollection> readGeometryCollection();
std::unique_ptr<geom::CoordinateSequence> readCoordinateSequence(int); // throws IOException
diff --git a/include/geos/io/WKTReader.h b/include/geos/io/WKTReader.h
index 4916995..a43bffa 100644
--- a/include/geos/io/WKTReader.h
+++ b/include/geos/io/WKTReader.h
@@ -24,6 +24,7 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/Geometry.h>
#include <string>
// Forward declarations
@@ -34,7 +35,6 @@ class StringTokenizer;
namespace geom {
class Coordinate;
-class Geometry;
class GeometryCollection;
class Point;
class LineString;
@@ -81,7 +81,7 @@ public:
~WKTReader();
/// Parse a WKT string returning a Geometry
- geom::Geometry* read(const std::string& wellKnownText);
+ std::unique_ptr<geom::Geometry> read(const std::string& wellKnownText);
// Geometry* read(Reader& reader); //Not implemented yet
@@ -92,15 +92,15 @@ protected:
std::string getNextCloserOrComma(io::StringTokenizer* tokenizer);
std::string getNextCloser(io::StringTokenizer* tokenizer);
std::string getNextWord(io::StringTokenizer* tokenizer);
- geom::Geometry* readGeometryTaggedText(io::StringTokenizer* tokenizer);
- geom::Point* readPointText(io::StringTokenizer* tokenizer);
- geom::LineString* readLineStringText(io::StringTokenizer* tokenizer);
- geom::LinearRing* readLinearRingText(io::StringTokenizer* tokenizer);
- geom::MultiPoint* readMultiPointText(io::StringTokenizer* tokenizer);
- geom::Polygon* readPolygonText(io::StringTokenizer* tokenizer);
- geom::MultiLineString* readMultiLineStringText(io::StringTokenizer* tokenizer);
- geom::MultiPolygon* readMultiPolygonText(io::StringTokenizer* tokenizer);
- geom::GeometryCollection* readGeometryCollectionText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::Geometry> readGeometryTaggedText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::Point> readPointText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::LineString> readLineStringText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::LinearRing> readLinearRingText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::MultiPoint> readMultiPointText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::Polygon> readPolygonText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::MultiLineString> readMultiLineStringText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::MultiPolygon> readMultiPolygonText(io::StringTokenizer* tokenizer);
+ std::unique_ptr<geom::GeometryCollection> readGeometryCollectionText(io::StringTokenizer* tokenizer);
private:
const geom::GeometryFactory* geometryFactory;
const geom::PrecisionModel* precisionModel;
index 6b29aac..39abe92 100644
@@ -127,7 +127,7 @@ ASCIIHexToUChar(char val)
// Must be an even number of characters in the istream.
// Throws a ParseException if there are an odd number of characters.
-Geometry*
+std::unique_ptr<Geometry>
WKBReader::readHEX(istream& is)
// setup input/output stream
@@ -164,14 +164,14 @@ WKBReader::readHEX(istream& is)
return this->read(os);
-Geometry*
WKBReader::read(istream& is)
dis.setInStream(&is); // will default to machine endian
return readGeometry();
-Geometry*
// determine byte order
@@ -237,29 +237,29 @@ WKBReader::readGeometry()
ordValues.resize(inputDimension);
- Geometry* result;
+ std::unique_ptr<Geometry> result;
- result = readPoint();
+ result.reset(readPoint().release());
break;
- result = readLineString();
+ result.reset(readLineString().release());
break;
- result = readPolygon();
+ result.reset(readPolygon().release());
break;
- result = readMultiPoint();
+ result.reset(readMultiPoint().release());
break;
- result = readMultiLineString();
+ result.reset(readMultiLineString().release());
break;
- result = readMultiPolygon();
+ result.reset(readMultiPolygon().release());
break;
- result = readGeometryCollection();
+ result.reset(readGeometryCollection().release());
break;
default:
stringstream err;
@@ -271,19 +271,19 @@ WKBReader::readGeometry()
return result;
-Point*
+std::unique_ptr<Point>
WKBReader::readPoint()
readCoordinate();
if(inputDimension == 3) {
- return factory.createPoint(Coordinate(ordValues[0], ordValues[1], ordValues[2]));
+ return std::unique_ptr<Point>(factory.createPoint(Coordinate(ordValues[0], ordValues[1], ordValues[2])));
else {
- return factory.createPoint(Coordinate(ordValues[0], ordValues[1]));
+ return std::unique_ptr<Point>(factory.createPoint(Coordinate(ordValues[0], ordValues[1])));
-LineString*
+std::unique_ptr<LineString>
WKBReader::readLineString()
int size = dis.readInt();
@@ -291,10 +291,10 @@ WKBReader::readLineString()
cout << "WKB npoints: " << size << endl;
#endif
auto pts = readCoordinateSequence(size);
- return factory.createLineString(pts.release());
+ return std::unique_ptr<LineString>(factory.createLineString(pts.release()));
-LinearRing*
+std::unique_ptr<LinearRing>
WKBReader::readLinearRing()
@@ -302,10 +302,10 @@ WKBReader::readLinearRing()
#endif
- return factory.createLinearRing(pts.release());
+ return std::unique_ptr<LinearRing>(factory.createLinearRing(pts.release()));
-Polygon*
+std::unique_ptr<Polygon>
WKBReader::readPolygon()
int numRings = dis.readInt();
@@ -314,7 +314,7 @@ WKBReader::readPolygon()
cout << "WKB numRings: " << numRings << endl;
#endif
- LinearRing* shell = nullptr;
+ std::unique_ptr<LinearRing> shell;
if(numRings > 0) {
shell = readLinearRing();
@@ -324,7 +324,7 @@ WKBReader::readPolygon()
try {
holes = new vector<LinearRing*>(numRings - 1);
for(int i = 0; i < numRings - 1; i++) {
- (*holes)[i] = readLinearRing();
+ (*holes)[i] = readLinearRing().release();
catch(...) {
@@ -332,14 +332,13 @@ WKBReader::readPolygon()
delete(*holes)[i];
delete holes;
- delete shell;
throw;
- return factory.createPolygon(shell, holes);
+ return std::unique_ptr<Polygon>(factory.createPolygon(shell.release(), holes));
-MultiPoint*
+std::unique_ptr<MultiPoint>
WKBReader::readMultiPoint()
int numGeoms = dis.readInt();
@@ -347,13 +346,13 @@ WKBReader::readMultiPoint()
try {
for(int i = 0; i < numGeoms; i++) {
- Geometry* g = readGeometry();
- if(!dynamic_cast<Point*>(g)) {
+ auto g = readGeometry();
+ if(!dynamic_cast<Point*>(g.get())) {
stringstream err;
err << BAD_GEOM_TYPE_MSG << " MultiPoint";
throw ParseException(err.str());
- (*geoms)[i] = g;
+ (*geoms)[i] = g.release();
catch(...) {
@@ -363,10 +362,10 @@ WKBReader::readMultiPoint()
delete geoms;
throw;
- return factory.createMultiPoint(geoms);
+ return std::unique_ptr<MultiPoint>(factory.createMultiPoint(geoms));
-MultiLineString*
+std::unique_ptr<MultiLineString>
WKBReader::readMultiLineString()
@@ -374,13 +373,13 @@ WKBReader::readMultiLineString()
try {
- if(!dynamic_cast<LineString*>(g)) {
+ if(!dynamic_cast<LineString*>(g.get())) {
stringstream err;
err << BAD_GEOM_TYPE_MSG << " LineString";
- (*geoms)[i] = g;
catch(...) {
@@ -390,10 +389,10 @@ WKBReader::readMultiLineString()
delete geoms;
throw;
- return factory.createMultiLineString(geoms);
+ return std::unique_ptr<MultiLineString>(factory.createMultiLineString(geoms));
-MultiPolygon*
+std::unique_ptr<MultiPolygon>
WKBReader::readMultiPolygon()
@@ -401,13 +400,13 @@ WKBReader::readMultiPolygon()
try {
- if(!dynamic_cast<Polygon*>(g)) {
+ if(!dynamic_cast<Polygon*>(g.get())) {
stringstream err;
err << BAD_GEOM_TYPE_MSG << " Polygon";
- (*geoms)[i] = g;
catch(...) {
@@ -417,10 +416,10 @@ WKBReader::readMultiPolygon()
delete geoms;
throw;
- return factory.createMultiPolygon(geoms);
+ return std::unique_ptr<MultiPolygon>(factory.createMultiPolygon(geoms));
-GeometryCollection*
+std::unique_ptr<GeometryCollection>
WKBReader::readGeometryCollection()
@@ -428,7 +427,7 @@ WKBReader::readGeometryCollection()
try {
- (*geoms)[i] = (readGeometry());
+ (*geoms)[i] = readGeometry().release();
catch(...) {
@@ -438,7 +437,7 @@ WKBReader::readGeometryCollection()
delete geoms;
throw;
- return factory.createGeometryCollection(geoms);
+ return std::unique_ptr<GeometryCollection>(factory.createGeometryCollection(geoms));
std::unique_ptr<CoordinateSequence>
index 544fd38..7738c89 100644
@@ -59,15 +59,12 @@ using namespace geos::geom;
namespace geos {
namespace io { // geos.io
-Geometry*
WKTReader::read(const string& wellKnownText)
- //unique_ptr<StringTokenizer> tokenizer(new StringTokenizer(wellKnownText));
CLocalizer clocale;
StringTokenizer tokenizer(wellKnownText);
- Geometry* g = nullptr;
- g = readGeometryTaggedText(&tokenizer);
- return g;
+ return readGeometryTaggedText(&tokenizer);
@@ -77,7 +74,6 @@ WKTReader::getCoordinates(StringTokenizer* tokenizer)
string nextToken = getNextEmptyOrOpener(tokenizer);
if(nextToken == "EMPTY") {
return geometryFactory->getCoordinateSequenceFactory()->create();
- //new CoordinateArraySequence();
Coordinate coord;
@@ -219,76 +215,76 @@ WKTReader::getNextWord(StringTokenizer* tokenizer)
return "";
-Geometry*
- return readPointText(tokenizer);
+ return std::unique_ptr<Geometry>(readPointText(tokenizer).release());
- return readLineStringText(tokenizer);
+ return std::unique_ptr<Geometry>(readLineStringText(tokenizer));
- return readLinearRingText(tokenizer);
+ return std::unique_ptr<Geometry>(readLinearRingText(tokenizer));
- return readPolygonText(tokenizer);
+ return std::unique_ptr<Geometry>(readPolygonText(tokenizer));
- return readMultiPointText(tokenizer);
+ return std::unique_ptr<Geometry>(readMultiPointText(tokenizer));
- return readMultiLineStringText(tokenizer);
+ return std::unique_ptr<Geometry>(readMultiLineStringText(tokenizer));
- return readMultiPolygonText(tokenizer);
+ return std::unique_ptr<Geometry>(readMultiPolygonText(tokenizer));
- return readGeometryCollectionText(tokenizer);
+ return std::unique_ptr<Geometry>(readGeometryCollectionText(tokenizer));
-Point*
WKTReader::readPointText(StringTokenizer* tokenizer)
size_t dim;
- return geometryFactory->createPoint(Coordinate::getNull());
+ return std::unique_ptr<Point>(geometryFactory->createPoint(Coordinate::getNull()));
Coordinate coord;
getPreciseCoordinate(tokenizer, coord, dim);
getNextCloser(tokenizer);
- return geometryFactory->createPoint(coord);
+ return std::unique_ptr<Point>(geometryFactory->createPoint(coord));
-LineString*
WKTReader::readLineStringText(StringTokenizer* tokenizer)
auto coords = getCoordinates(tokenizer);
LineString* ret = geometryFactory->createLineString(coords.release());
- return ret;
+ return std::unique_ptr<LineString>(ret);
-LinearRing*
WKTReader::readLinearRingText(StringTokenizer* tokenizer)
LinearRing* ret;
ret = geometryFactory->createLinearRing(coords.release());
- return ret;
+ return std::unique_ptr<LinearRing>(ret);
-MultiPoint*
WKTReader::readMultiPointText(StringTokenizer* tokenizer)
- return geometryFactory->createMultiPoint();
+ return std::unique_ptr<MultiPoint>(geometryFactory->createMultiPoint());
int tok = tokenizer->peekNextToken();
@@ -307,8 +303,7 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
while(nextToken == ",");
- MultiPoint* ret = geometryFactory->createMultiPoint(*coords);
- return ret;
+ return std::unique_ptr<MultiPoint>(geometryFactory->createMultiPoint(*coords));
else if(tok == '(') {
@@ -316,12 +311,12 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
vector<Geometry*>* points = new vector<Geometry*>();
try {
do {
- Point* point = readPointText(tokenizer);
- points->push_back(point);
+ auto point = readPointText(tokenizer);
+ points->push_back(point.release());
nextToken = getNextCloserOrComma(tokenizer);
- return geometryFactory->createMultiPoint(points);
+ return std::unique_ptr<MultiPoint>(geometryFactory->createMultiPoint(points));
catch(...) {
// clean up
@@ -365,58 +360,52 @@ WKTReader::readMultiPointText(StringTokenizer* tokenizer)
-Polygon*
WKTReader::readPolygonText(StringTokenizer* tokenizer)
Polygon* poly = nullptr;
- return geometryFactory->createPolygon(nullptr, nullptr);
+ return std::unique_ptr<Polygon>(geometryFactory->createPolygon(nullptr, nullptr));
vector<LinearRing*>* holes = new vector<LinearRing*>();
try {
- shell = readLinearRingText(tokenizer);
+ auto shell = readLinearRingText(tokenizer);
while(nextToken == ",") {
- LinearRing* hole = readLinearRingText(tokenizer);
- holes->push_back(hole);
+ auto hole = readLinearRingText(tokenizer);
+ holes->push_back(hole.release());
- poly = geometryFactory->createPolygon(shell, holes);
+ poly = geometryFactory->createPolygon(shell.get(), holes);
+ shell.release(); // release separately because Polygon constructor may throw
catch(...) {
for(unsigned int i = 0; i < holes->size(); i++) {
delete(*holes)[i];
delete holes;
- delete shell;
throw;
- return poly;
+ return std::unique_ptr<Polygon>(poly);
-MultiLineString*
WKTReader::readMultiLineStringText(StringTokenizer* tokenizer)
- return geometryFactory->createMultiLineString(nullptr);
+ return std::unique_ptr<MultiLineString>(geometryFactory->createMultiLineString(nullptr));
vector<Geometry*>* lineStrings = new vector<Geometry*>();
- LineString* lineString = nullptr;
+ std::unique_ptr<LineString> lineString;
try {
- lineString = readLineStringText(tokenizer);
- lineStrings->push_back(lineString);
- lineString = nullptr;
- nextToken = getNextCloserOrComma(tokenizer);
- while(nextToken == ",") {
+ do {
+ lineStrings->push_back(lineString.release());
+ } while (nextToken == ",");
catch(...) {
for(size_t i = 0; i < lineStrings->size(); i++) {
@@ -426,31 +415,24 @@ WKTReader::readMultiLineStringText(StringTokenizer* tokenizer)
throw;
MultiLineString* ret = geometryFactory->createMultiLineString(lineStrings);
- //for (int i=0; i<lineStrings->size(); i++) delete (*lineStrings)[i];
- //delete lineStrings;
- return ret;
+ return std::unique_ptr<MultiLineString>(ret);
-MultiPolygon*
WKTReader::readMultiPolygonText(StringTokenizer* tokenizer)
- return geometryFactory->createMultiPolygon(nullptr);
+ return std::unique_ptr<MultiPolygon>(geometryFactory->createMultiPolygon(nullptr));
vector<Geometry*>* polygons = new vector<Geometry*>();
- Polygon* polygon = nullptr;
+ std::unique_ptr<Polygon> polygon;
try {
- polygon = readPolygonText(tokenizer);
- polygons->push_back(polygon);
- polygon = nullptr;
+ do {
+ polygons->push_back(polygon.release());
+ } while(nextToken == ",");
catch(...) {
for(size_t i = 0; i < polygons->size(); i++) {
@@ -460,31 +442,24 @@ WKTReader::readMultiPolygonText(StringTokenizer* tokenizer)
throw;
MultiPolygon* ret = geometryFactory->createMultiPolygon(polygons);
- //for (int i=0; i<polygons->size(); i++) delete (*polygons)[i];
- //delete polygons;
- return ret;
+ return std::unique_ptr<MultiPolygon>(ret);
WKTReader::readGeometryCollectionText(StringTokenizer* tokenizer)
- return geometryFactory->createGeometryCollection(nullptr);
+ return std::unique_ptr<GeometryCollection>(geometryFactory->createGeometryCollection(nullptr));
vector<Geometry*>* geoms = new vector<Geometry*>();
- Geometry* geom = nullptr;
+ std::unique_ptr<Geometry> geom;
try {
- geom = readGeometryTaggedText(tokenizer);
- geoms->push_back(geom);
- geom = nullptr;
+ do {
- geom = nullptr;
+ geoms->push_back(geom.release());
catch(...) {
for(size_t i = 0; i < geoms->size(); i++) {
@@ -494,9 +469,7 @@ WKTReader::readGeometryCollectionText(StringTokenizer* tokenizer)
throw;
GeometryCollection* ret = geometryFactory->createGeometryCollection(geoms);
- //for (int i=0; i<geoms->size(); i++) delete (*geoms)[i];
- //delete geoms;
- return ret;
+ return std::unique_ptr<GeometryCollection>(ret);
} // namespace geos.io
diff --git a/tests/unit/algorithm/InteriorPointAreaTest.cpp b/tests/unit/algorithm/InteriorPointAreaTest.cpp
index 32cd3c8..4b30808 100644
--- a/tests/unit/algorithm/InteriorPointAreaTest.cpp
+++ b/tests/unit/algorithm/InteriorPointAreaTest.cpp
@@ -66,7 +66,7 @@ void object::test<1>
// invalid polygon - classic hourglass-shape with a self intersection
// without a node
- geom.reset(reader.read("POLYGON((6 54, 15 54, 6 47, 15 47, 6 54))"));
+ geom = reader.read("POLYGON((6 54, 15 54, 6 47, 15 47, 6 54))");
InteriorPointArea interiorPointArea(geom.get());
interiorPointArea.getInteriorPoint(result);
diff --git a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
index 17176b1..076e88b 100644
--- a/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
+++ b/tests/unit/algorithm/MinimumBoundingCircleTest.cpp
@@ -55,14 +55,14 @@ struct test_minimumboundingcircle_data {
geos::geom::Coordinate& centreOut, double radiusOut)
- geom.reset(reader.read(wktIn));
+ geom = reader.read(wktIn);
MinimumBoundingCircle mbc(geom.get());
std::vector<Coordinate> exPts = mbc.getExtremalPoints();
std::unique_ptr<Geometry> actual(geomFact->createMultiPoint(exPts));
double actualRadius = mbc.getRadius();
geos::geom::Coordinate actualCentre = mbc.getCentre();
- geomOut.reset(reader.read(wktOut));
+ geomOut = reader.read(wktOut);
bool isEqual = actual->equals(geomOut.get());
// need this hack because apparently equals does not work for MULTIPOINT EMPTY
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index 4b54e4c..d06ce2e 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -141,9 +141,9 @@ void object::test<4>
geos::io::WKBReader reader(*factory);
std::istringstream sOuter(outer);
- geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sOuter));
+ geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sOuter).release());
std::istringstream sInner(inner);
- geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sInner));
+ geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sInner).release());
ensure(nullptr != geom1_);
ensure(nullptr != geom2_);
@@ -162,9 +162,9 @@ void object::test<4>
@@ -199,9 +199,9 @@ void object::test<5>
@@ -221,9 +221,9 @@ void object::test<5>
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 918d29a..ca760b9 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -237,9 +237,9 @@ void object::test<8>
std::string
line("0102000000070000009909bf203f1f37c05c1d66d6954249404afe386d871d37c0a7eb1124b54149409c266328061c37c056d8bff5db42494098266328061c37c0034f7b5c2a42494060065c5aa01837c08ac001de3a4449408401b189bb1637c0b04e471a4f43494014ef84a6d11537c0b20dabfb62434940");
std::stringstream sPoint(point);
- geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sPoint));
+ geom2_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sPoint).release());
std::stringstream sLine(line);
- geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sLine));
+ geom1_ = reinterpret_cast<GEOSGeometry*>(reader.readHEX(sLine).release());
prepGeom1_ = GEOSPrepare(geom1_);
ensure(nullptr != prepGeom1_);
@@ -289,9 +289,9 @@ void object::test<10>
@@ -314,9 +314,9 @@ void object::test<10>
@@ -353,9 +353,9 @@ void object::test<11>
@@ -378,9 +378,9 @@ void object::test<11>
diff --git a/tests/unit/geom/Geometry/coversTest.cpp b/tests/unit/geom/Geometry/coversTest.cpp
index 8134892..75d2128 100644
--- a/tests/unit/geom/Geometry/coversTest.cpp
+++ b/tests/unit/geom/Geometry/coversTest.cpp
@@ -94,9 +94,7 @@ void object::test<3>
ensure(g2->coveredBy(g1.get()));
ensure(! g1->contains(g2.get()));
- g2.reset(reader.read(
- "POINT(0 2)"
+ g2 = reader.read("POINT(0 2)");
ensure(g1->covers(g2.get()));
diff --git a/tests/unit/geom/Geometry/isRectangleTest.cpp b/tests/unit/geom/Geometry/isRectangleTest.cpp
index 0572c0c..89f90b1 100644
--- a/tests/unit/geom/Geometry/isRectangleTest.cpp
+++ b/tests/unit/geom/Geometry/isRectangleTest.cpp
@@ -38,13 +38,11 @@ void object::test<1>
const std::string wkt("POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0))");
- geos::geom::Geometry* g = reader.read(wkt);
+ auto g = reader.read(wkt);
- geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(g);
+ geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(g.get());
ensure("Geometry is not a Polygon: " + wkt, poly != nullptr);
ensure(poly->isRectangle());
- delete g;
// 2 - Test of another valid rectangle
@@ -54,13 +52,11 @@ void object::test<2>
const std::string wkt("POLYGON ((0 0, 0 200, 100 200, 100 0, 0 0))");
- delete g;
// 3 - Test of rectangle with hole
@@ -71,13 +67,11 @@ void object::test<3>
const std::string wkt("POLYGON ((0 0, 0 100, 100 100, 100 0, 0 0), \
(10 10, 10 90, 90 90, 90 10, 10 10) ))");
ensure(!poly->isRectangle());
- delete g;
// 4 - Test of non-rectilinear rectangle
@@ -87,13 +81,11 @@ void object::test<4>
const std::string wkt("POLYGON ((0 0, 0 100, 99 100, 100 0, 0 0))");
- delete g;
// 5 - Test of rectangle with too many points
@@ -103,13 +95,11 @@ void object::test<5>
const std::string wkt("POLYGON ((0 0, 0 100, 100 50, 100 100, 100 0, 0 0))");
- delete g;
// 6 - Test of rectangle with too few points
@@ -119,13 +109,11 @@ void object::test<6>
const std::string wkt("POLYGON ((0 0, 0 100, 100 0, 0 0))");
- delete g;
// 7 - Test of rectangle with points in wrong order
@@ -135,13 +123,11 @@ void object::test<7>
const std::string wkt("POLYGON ((0 0, 0 100, 100 0, 100 100, 0 0))");
- delete g;
} // namespace tut
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index 255d92e..8bf5085 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -760,10 +760,10 @@ void object::test<20>
ensure(exterior->getLength() != 0.0);
// Create collection of holes
- GeometryPtr geo = reader_.read(("LINEARRING(7 7, 12 7, 12 12, 7 12, 7 7)"));
+ auto geo = reader_.read(("LINEARRING(7 7, 12 7, 12 12, 7 12, 7 7)"));
ensure(geo != nullptr);
- LinearRingPtr hole = dynamic_cast<LinearRingPtr>(geo);
+ LinearRingPtr hole = dynamic_cast<LinearRingPtr>(geo.release());
ensure(hole != nullptr);
ensure(hole->isRing());
ensure_equals(hole->getNumPoints(), interiorSize);
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index a04cbd1..d80397b 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -320,19 +320,16 @@ template<>
void object::test<15>
- GeometryPtr geo = reader_.read("LINESTRING (0 0, 5 5, 10 5, 10 10)");
+ auto geo = reader_.read("LINESTRING (0 0, 5 5, 10 5, 10 10)");
- LineStringPtr line = dynamic_cast<LineStringPtr>(geo);
+ LineStringPtr line = dynamic_cast<LineStringPtr>(geo.get());
ensure(line != nullptr);
ensure(!line->isEmpty());
ensure(!line->isClosed());
ensure(!line->isRing());
ensure(line->getCoordinateDimension() == 2);
- // FREE TESTED LINESTRING
- factory_->destroyGeometry(line);
// Test of getEnvelope() for non-empty linestring
@@ -341,19 +338,16 @@ template<>
void object::test<16>
auto envelope = line->getEnvelope();
ensure(envelope != nullptr);
ensure(!envelope->isEmpty());
ensure_equals(envelope->getDimension(), geos::geom::Dimension::A);
// Test of getBoundary() for non-empty linestring
@@ -362,10 +356,10 @@ template<>
void object::test<17>
auto boundary = line->getBoundary();
@@ -373,9 +367,6 @@ void object::test<17>
ensure(!boundary->isEmpty());
ensure_equals(boundary->getGeometryTypeId(), geos::geom::GEOS_MULTIPOINT);
ensure_equals(boundary->getDimension(), geos::geom::Dimension::P);
// Test of convexHull() for non-empty linestring
@@ -384,10 +375,10 @@ template<>
void object::test<18>
auto hull = line->convexHull();
@@ -395,9 +386,6 @@ void object::test<18>
ensure(!hull->isEmpty());
ensure_equals(hull->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
ensure_equals(hull->getDimension(), geos::geom::Dimension::A);
// Test of getGeometryTypeId() for non-empty linestring
@@ -406,13 +394,10 @@ template<>
void object::test<19>
ensure_equals(geo->getGeometryTypeId(), geos::geom::GEOS_LINESTRING);
- factory_->destroyGeometry(geo);
// Test of getDimension() for non-empty linestring
@@ -421,13 +406,10 @@ template<>
ensure_equals(geo->getDimension(), geos::geom::Dimension::L);
// Test of getBoundaryDimension() for non-empty linestring
@@ -436,13 +418,10 @@ template<>
void object::test<21>
ensure_equals(geo->getBoundaryDimension(), geos::geom::Dimension::P);
// Test of getNumPoints() for non-empty linestring
@@ -452,13 +431,10 @@ void object::test<22>
const size_t size = 4;
ensure_equals(geo->getNumPoints(), size);
// Test of getLength() for non-empty linestring
@@ -469,16 +445,13 @@ void object::test<23>
const double tolerance = 0.0001;
const double expected = 2 * 14.142135600000000;
- GeometryPtr geo = reader_.read("LINESTRING (0 0, 10 10, 20 0)");
+ auto geo = reader_.read("LINESTRING (0 0, 10 10, 20 0)");
ensure(geo->getLength() != 0.0);
const double diff = std::fabs(geo->getLength() - expected);
ensure(diff <= tolerance);
// Test of getArea() for non-empty linestring
@@ -487,29 +460,23 @@ template<>
void object::test<24>
ensure_equals(geo->getArea(), 0.0);
-// Test of getGeometryType() for non-empty Polygon
+// Test of getGeometryType() for non-empty LineString
template<>
template<>
void object::test<25>
const std::string type("LineString");
ensure_equals(geo->getGeometryType(), type);
- // FREE MEMORY
template<>
diff --git a/tests/unit/geom/LinearRingTest.cpp b/tests/unit/geom/LinearRingTest.cpp
index 9a912d7..8bfb1af 100644
--- a/tests/unit/geom/LinearRingTest.cpp
+++ b/tests/unit/geom/LinearRingTest.cpp
@@ -53,7 +53,7 @@ struct test_linearring_data {
// Create non-empty LinearRing
GeometryPtr geo = nullptr;
- geo = reader_.read("LINEARRING(0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10)");
+ geo = reader_.read("LINEARRING(0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10)").release();
ring_ = dynamic_cast<LinearRingPtr>(geo);
@@ -396,12 +396,8 @@ void object::test<28>
try {
- GeometryPtr geo = reader_.read("LINEARRING(0 0, 5 5, 10 10)");
+ auto geo = reader_.read("LINEARRING(0 0, 5 5, 10 10)");
- // FREE TESTED LINEARRING
fail("IllegalArgumentException expected.");
catch(geos::util::IllegalArgumentException const& e) {
@@ -410,7 +406,7 @@ void object::test<28>
-// TTest of exception thrown when constructing a self-intersecting LinearRing
+// Test of exception thrown when constructing a self-intersecting LinearRing
template<>
template<>
void object::test<29>
@@ -418,17 +414,14 @@ void object::test<29>
try {
// Construct LinearRing self-intersecting in point (5,5)
- GeometryPtr geo = reader_.read("LINEARRING(0 0, 5 5, 10 10, 15 5, 5 5, 0 10)");
+ auto geo = reader_.read("LINEARRING(0 0, 5 5, 10 10, 15 5, 5 5, 0 10)");
- LinearRingPtr ring = dynamic_cast<LinearRingPtr>(geo);
+ LinearRingPtr ring = dynamic_cast<LinearRingPtr>(geo.get());
ensure(ring != nullptr);
ensure(!ring->isValid());
diff --git a/tests/unit/geom/MultiPointTest.cpp b/tests/unit/geom/MultiPointTest.cpp
index a2bace0..67c68d3 100644
--- a/tests/unit/geom/MultiPointTest.cpp
+++ b/tests/unit/geom/MultiPointTest.cpp
@@ -40,9 +40,8 @@ struct test_multipoint_data {
, empty_mp_(factory_->createMultiPoint()), mp_size_(5)
// Create non-empty MultiPoint
- GeometryPtr geo = nullptr;
- geo = reader_.read("MULTIPOINT(0 0, 5 5, 10 10, 15 15, 20 20)");
- mp_ = dynamic_cast<MultiPointPtr>(geo);
+ auto geo = reader_.read("MULTIPOINT(0 0, 5 5, 10 10, 15 15, 20 20)");
+ mp_ = dynamic_cast<MultiPointPtr>(geo.release());
~test_multipoint_data()
@@ -107,8 +106,8 @@ void object::test<3>
const size_t size0 = 0;
- GeometryPtr geo = reader_.read("MULTIPOINT EMPTY");
- MultiPointPtr mp = dynamic_cast<MultiPointPtr>(geo);
+ auto geo = reader_.read("MULTIPOINT EMPTY");
+ MultiPointPtr mp = dynamic_cast<MultiPointPtr>(geo.get());
ensure(mp->isEmpty());
ensure(mp->isSimple());
@@ -116,9 +115,6 @@ void object::test<3>
ensure(mp->getCentroid() == nullptr);
ensure_equals(mp->getNumPoints(), size0);
ensure_equals(mp->getNumGeometries(), size0);
- // FREE MEMORY
// Test of isEmpty() for empty MultiPoint
@@ -378,12 +374,9 @@ void object::test<28>
try {
- GeometryPtr geo = reader_.read("MULTIPOINT(0 0, 5)");
+ auto geo = reader_.read("MULTIPOINT(0 0, 5)");
fail("ParseException expected.");
catch(geos::io::ParseException const& e) {
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index a935f42..f6e7ec1 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -47,9 +47,8 @@ struct test_point_data {
, reader_(factory_.get()), empty_point_(factory_->createPoint())
// Create non-empty Point
- geo = reader_.read("POINT(1.234 5.678)");
- point_ = dynamic_cast<PointPtr>(geo);
+ auto geo = reader_.read("POINT(1.234 5.678)");
+ point_ = dynamic_cast<PointPtr>(geo.release());
~test_point_data()
@@ -404,15 +403,10 @@ template<>
void object::test<32>
- GeometryPtr p1 = reader_.read("POINT(1.234 5.678)");
- GeometryPtr p2 = reader_.read("POINT(1.234 5.678)");
+ auto p1 = reader_.read("POINT(1.234 5.678)");
+ auto p2 = reader_.read("POINT(1.234 5.678)");
- // WARNING! If test fails, memory leaks occur.
- ensure(p1->equals(p2));
- // FREE MEMORY
- factory_->destroyGeometry(p1);
- factory_->destroyGeometry(p2);
+ ensure(p1->equals(p2.get()));
// Test of equals() for non-empty Point (1.23 5.67)
@@ -421,15 +415,10 @@ template<>
void object::test<33>
- GeometryPtr p1 = reader_.read("POINT(1.23 5.67)");
- GeometryPtr p2 = reader_.read("POINT(1.23 5.67)");
+ auto p1 = reader_.read("POINT(1.23 5.67)");
+ auto p2 = reader_.read("POINT(1.23 5.67)");
- // FREE MEMORY
// Test of equals() for non-empty Points (1.235 5.678) and (1.234 5.678)
@@ -438,15 +427,10 @@ template<>
void object::test<34>
- GeometryPtr p1 = reader_.read("POINT(1.235 5.678)");
- ensure(!p1->equals(p2));
+ auto p1 = reader_.read("POINT(1.235 5.678)");
- // FREE MEMORY
+ ensure(!p1->equals(p2.get()));
// Test of equals() for non-empty Points (1.2334 5.678) and (1.2333 5.678)
@@ -455,15 +439,10 @@ template<>
void object::test<35>
- GeometryPtr p1 = reader_.read("POINT(1.2334 5.678)");
- GeometryPtr p2 = reader_.read("POINT(1.2333 5.678)");
+ auto p1 = reader_.read("POINT(1.2334 5.678)");
+ auto p2 = reader_.read("POINT(1.2333 5.678)");
- // FREE MEMORY
// Test of equals() for non-empty Points (1.2334 5.678) and (1.2335 5.678)
@@ -472,15 +451,10 @@ template<>
void object::test<36>
- GeometryPtr p2 = reader_.read("POINT(1.2335 5.678)");
+ auto p2 = reader_.read("POINT(1.2335 5.678)");
- // FREE MEMORY
// Test of equals() for non-empty Points (1.2324 5.678) and (1.2325 5.678)
@@ -489,15 +463,10 @@ template<>
void object::test<37>
- GeometryPtr p1 = reader_.read("POINT(1.2324 5.678)");
- GeometryPtr p2 = reader_.read("POINT(1.2325 5.678)");
+ auto p1 = reader_.read("POINT(1.2324 5.678)");
+ auto p2 = reader_.read("POINT(1.2325 5.678)");
- // FREE MEMORY
// Test of equals() for non-empty Points (1.2324 5.678) and (EMPTY)
@@ -506,15 +475,10 @@ template<>
void object::test<38>
- GeometryPtr p2 = reader_.read("POINT EMPTY");
+ auto p2 = reader_.read("POINT EMPTY");
- // FREE MEMORY
// Test of equals() for non-empty Points with negative coordiantes
@@ -523,26 +487,19 @@ template<>
void object::test<39>
- GeometryPtr pLo = reader_.read("POINT(-1.233 5.678)");
- GeometryPtr pHi = reader_.read("POINT(-1.232 5.678)");
- GeometryPtr p1 = reader_.read("POINT(-1.2326 5.678)");
- GeometryPtr p2 = reader_.read("POINT(-1.2325 5.678)");
- GeometryPtr p3 = reader_.read("POINT(-1.2324 5.678)");
+ auto pLo = reader_.read("POINT(-1.233 5.678)");
+ auto pHi = reader_.read("POINT(-1.232 5.678)");
- ensure(p3->equals(p2));
+ auto p1 = reader_.read("POINT(-1.2326 5.678)");
+ auto p2 = reader_.read("POINT(-1.2325 5.678)");
+ auto p3 = reader_.read("POINT(-1.2324 5.678)");
- ensure(p1->equals(pLo));
- ensure(p2->equals(pHi));
- ensure(p3->equals(pHi));
+ ensure(p3->equals(p2.get()));
- // FREE MEMORY
- factory_->destroyGeometry(pLo);
- factory_->destroyGeometry(pHi);
- factory_->destroyGeometry(p3);
+ ensure(p1->equals(pLo.get()));
+ ensure(p2->equals(pHi.get()));
+ ensure(p3->equals(pHi.get()));
// Test of getCoordinateDimension() for 2d/3d.
@@ -551,17 +508,13 @@ template<>
void object::test<40>
- GeometryPtr p = reader_.read("POINT(-1.233 5.678 1.0)");
+ auto p = reader_.read("POINT(-1.233 5.678 1.0)");
ensure(p->getCoordinateDimension() == 3);
- delete p;
p = reader_.read("POINT(-1.233 5.678)");
ensure(p->getCoordinateDimension() == 2);
- delete p;
template<>
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index 21f3279..c164b12 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -39,7 +39,7 @@ struct test_polygon_data {
geos::io::WKTReader reader_;
PolygonAutoPtr empty_poly_;
- PolygonPtr poly_;
+ PolygonAutoPtr poly_;
const size_t poly_size_;
test_polygon_data()
@@ -48,16 +48,9 @@ struct test_polygon_data {
, empty_poly_(factory_->createPolygon()), poly_size_(7)
- // Create non-empty LinearRing
- geo = reader_.read("POLYGON((0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))");
- poly_ = dynamic_cast<PolygonPtr>(geo);
- ~test_polygon_data()
- // FREE MEMORY
- factory_->destroyGeometry(poly_);
+ // Create non-empty Polygon
+ auto geo = reader_.read("POLYGON((0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))");
+ poly_.reset(dynamic_cast<PolygonPtr>(geo.release()));
private:
@@ -402,11 +395,9 @@ void object::test<27>
ensure(poly_ != nullptr);
- GeometryPtr geo = poly_->clone().release();
+ auto geo = poly_->clone();
- ensure(geo->equals(poly_));
+ ensure(geo->equals(poly_.get()));
// Test of getExteriorRing() for non-empty Polygon
@@ -441,12 +432,11 @@ void object::test<30>
const size_t holesNum = 1;
- geo = reader_.read("POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0), (1 1, 1 10, 10 10, 10 1, 1 1) )");
+ auto geo = reader_.read("POLYGON ((0 0, 100 0, 100 100, 0 100, 0 0), (1 1, 1 10, 10 10, 10 1, 1 1) )");
ensure_equals(geo->getGeometryTypeId(), geos::geom::GEOS_POLYGON);
- PolygonPtr poly = dynamic_cast<PolygonPtr>(geo);
+ PolygonPtr poly = dynamic_cast<PolygonPtr>(geo.get());
ensure(poly != nullptr);
ensure_equals(poly->getNumInteriorRing(), holesNum);
@@ -455,11 +445,9 @@ void object::test<30>
ensure(interior->isRing());
ensure_equals(interior->getGeometryTypeId(), geos::geom::GEOS_LINEARRING);
-// Test of getCoordiante() for non-empty Polygon
+// Test of getCoordinate() for non-empty Polygon
template<>
template<>
void object::test<31>
@@ -474,7 +462,7 @@ void object::test<31>
ensure_equals(coord->y, 10);
-// Test of getCoordiantes() for non-empty Polygon
+// Test of getCoordinates() for non-empty Polygon
template<>
template<>
diff --git a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
index a042c17..4338a8c 100644
--- a/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometry/touchesTest.cpp
@@ -27,8 +27,8 @@ struct test_preparedgeometrytouches_data {
geos::geom::GeometryFactory::Ptr factory;
geos::io::WKTReader reader;
- GeometryPtr g1;
- GeometryPtr g2;
+ std::unique_ptr<geos::geom::Geometry> g1;
+ std::unique_ptr<geos::geom::Geometry> g2;
std::unique_ptr<PreparedGeometry> pg1;
std::unique_ptr<PreparedGeometry> pg2;
@@ -40,11 +40,6 @@ struct test_preparedgeometrytouches_data {
, pg1(nullptr)
, pg2(nullptr)
- ~test_preparedgeometrytouches_data()
- factory->destroyGeometry(g1);
- factory->destroyGeometry(g2);
typedef test_group<test_preparedgeometrytouches_data> group;
@@ -68,11 +63,11 @@ void object::test<1>
g2 = reader.read(
"POINT (0 0)"
- pg1 = prep::PreparedGeometryFactory::prepare(g1);
- pg2 = prep::PreparedGeometryFactory::prepare(g2);
+ pg1 = prep::PreparedGeometryFactory::prepare(g1.get());
+ pg2 = prep::PreparedGeometryFactory::prepare(g2.get());
- ensure(!pg1->touches(g2));
- ensure(!pg2->touches(g1));
+ ensure(!pg1->touches(g2.get()));
+ ensure(!pg2->touches(g1.get()));
// 2 - Line/Point do not touch if point is not on boundary
@@ -87,11 +82,11 @@ void object::test<2>
g2 = reader.read(
"POINT (1 1)"
// 3 - Line/Point touch
@@ -106,11 +101,11 @@ void object::test<3>
g2 = reader.read(
"POINT (0 2)"
- ensure(pg1->touches(g2));
- ensure(pg2->touches(g1));
+ ensure(pg1->touches(g2.get()));
+ ensure(pg2->touches(g1.get()));
// 4 - Line/Point touch (FP coordinates)
@@ -125,11 +120,11 @@ void object::test<4>
g2 = reader.read(
"POINT (-257704.820935236 574364.179187424)"
} // namespace tut
diff --git a/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp b/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
index f2c2168..b5e7e18 100644
--- a/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
+++ b/tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp
@@ -26,7 +26,7 @@ namespace tut {
// Common data used by tests
struct test_preparedgeometryfactory_data {
typedef geos::geom::GeometryFactory GeometryFactory;
- GeometryPtr g_;
+ std::unique_ptr<geos::geom::Geometry> g_;
std::unique_ptr<geos::geom::prep::PreparedGeometry> pg_;
geos::geom::PrecisionModel pm_;
geos::geom::GeometryFactory::Ptr factory_;
@@ -41,13 +41,6 @@ struct test_preparedgeometryfactory_data {
assert(nullptr == pg_);
- ~test_preparedgeometryfactory_data()
- // FREE MEMORY per test case
- factory_->destroyGeometry(g_);
- g_ = nullptr;
typedef test_group<test_preparedgeometryfactory_data> group;
@@ -114,13 +107,13 @@ template<>
- g_ = factory_->createEmptyGeometry();
+ g_.reset(factory_->createEmptyGeometry());
ensure(nullptr != g_);
- pg_ = prep::PreparedGeometryFactory::prepare(g_);
+ pg_ = prep::PreparedGeometryFactory::prepare(g_.get());
ensure(nullptr != pg_);
- ensure_equals_geometry(g_, pg_.get());
+ ensure_equals_geometry(g_.get(), pg_.get());
// Test create empty GEOMETRY
@@ -129,14 +122,14 @@ template<>
prep::PreparedGeometryFactory pgf;
- pg_ = pgf.create(g_);
+ pg_ = pgf.create(g_.get());
// Test prepare empty POINT
@@ -145,13 +138,13 @@ template<>
- g_ = factory_->createPoint();
+ g_.reset(factory_->createPoint());
// Test create empty POINT
@@ -160,14 +153,14 @@ template<>
// Test prepare empty LINESTRING
@@ -176,13 +169,13 @@ template<>
- g_ = factory_->createLineString();
+ g_.reset(factory_->createLineString());
// Test create empty LINESTRING
@@ -191,13 +184,13 @@ template<>
void object::test<9>
// Test prepare empty POLYGON
@@ -206,13 +199,13 @@ template<>
- g_ = factory_->createPolygon();
+ g_.reset(factory_->createPolygon());
// Test create empty POLYGON
@@ -221,14 +214,14 @@ template<>
// Test prepare empty MULTIPOINT
@@ -237,13 +230,13 @@ template<>
void object::test<12>
- g_ = factory_->createMultiPoint();
+ g_.reset(factory_->createMultiPoint());
// Test create empty MULTIPOINT
@@ -252,14 +245,14 @@ template<>
void object::test<13>
// Test prepare empty MULTILINESTRING
@@ -268,13 +261,13 @@ template<>
void object::test<14>
- g_ = factory_->createMultiLineString();
+ g_.reset(factory_->createMultiLineString());
// Test create empty MULTILINESTRING
@@ -283,14 +276,14 @@ template<>
// Test prepare empty MULTIPOLYGON
@@ -299,13 +292,13 @@ template<>
- g_ = factory_->createMultiPolygon();
+ g_.reset(factory_->createMultiPolygon());
// Test create empty MULTIPOLYGON
@@ -314,14 +307,14 @@ template<>
// Test prepare non-empty POINT
@@ -333,10 +326,10 @@ void object::test<18>
g_ = reader_.read("POINT(1.234 5.678)");
// Test create non-empty POINT
@@ -349,10 +342,10 @@ void object::test<19>
// Test prepare non-empty LINESTRING
@@ -364,10 +357,10 @@ void object::test<20>
g_ = reader_.read("LINESTRING (0 0, 5 5, 10 5, 10 10)");
// Test create non-empty LINESTRING
@@ -380,10 +373,10 @@ void object::test<21>
@@ -395,10 +388,10 @@ void object::test<22>
g_ = reader_.read("POLYGON((0 10, 5 5, 10 5, 15 10, 10 15, 5 15, 0 10))");
@@ -411,10 +404,10 @@ void object::test<23>
// Test prepare non-empty MULTIPOINT
@@ -426,10 +419,10 @@ void object::test<24>
g_ = reader_.read("MULTIPOINT(0 0, 5 5, 10 10, 15 15, 20 20)");
// Test create non-empty MULTIPOINT
@@ -442,10 +435,10 @@ void object::test<25>
// Test prepare non-empty MULTILINESTRING
@@ -457,10 +450,10 @@ void object::test<26>
g_ = reader_.read("MULTILINESTRING ((20 120, 120 20), (20 20, 120 120))");
// Test create non-empty MULTILINESTRING
@@ -473,10 +466,10 @@ void object::test<27>
// Test prepare non-empty POLYGON
@@ -488,10 +481,10 @@ void object::test<28>
g_ = reader_.read("MULTIPOLYGON(((0 0, 10 0, 10 10, 0 10, 0 0),(2 2, 2 6, 6 4, 2 2)),((60 60, 60 50, 70 40, 60 60)))");
// Test create non-empty POLYGON
@@ -504,10 +497,10 @@ void object::test<29>
} // namespace tut
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index 793e1a3..bf29c88 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -57,13 +57,11 @@ template<>
- geos::geom::Geometry* geom = wktreader.read("POINT(-117 33)");
+ auto geom = wktreader.read("POINT(-117 33)");
std::stringstream result_stream;
wkbwriter.setOutputDimension(3);
wkbwriter.write(*geom, result_stream);
- delete geom;
- geom = nullptr;
ensure(result_stream.str().length() == 21);
@@ -76,8 +74,6 @@ void object::test<1>
ensure(geom->getCoordinate()->x == -117.0);
ensure(geom->getCoordinate()->y == 33.0);
ensure(std::isnan(geom->getCoordinate()->z) != 0);
- delete geom;
// 2 - Test writing a 3D geometry with the WKBWriter in 3D output dimension.
@@ -86,13 +82,11 @@ template<>
- geos::geom::Geometry* geom = wktreader.read("POINT(-117 33 11)");
+ auto geom = wktreader.read("POINT(-117 33 11)");
- delete geom;
- geom = nullptr;
ensure(result_stream.str().length() == 29);
@@ -103,8 +97,6 @@ void object::test<2>
ensure(geom->getCoordinate()->z == 11.0);
- delete geom;
// 3 - Test writing a 3D geometry with the WKBWriter in 2D output dimension.
@@ -113,13 +105,11 @@ template<>
wkbwriter.setOutputDimension(2);
- delete geom;
- geom = nullptr;
@@ -130,8 +120,6 @@ void object::test<3>
- delete geom;
// 4 - Test that SRID is output only once
@@ -144,7 +132,7 @@ void object::test<4>
typedef geos::geom::Geometry Geom;
typedef std::vector<Geom*> GeomVect;
GeomVect* geoms = new GeomVect;
- geoms->push_back(wktreader.read("POLYGON((0 0,1 0,1 1,0 1,0 0))"));
+ geoms->push_back(wktreader.read("POLYGON((0 0,1 0,1 1,0 1,0 0))").release());
geoms->back()->setSRID(4326);
Geom* geom = gf->createGeometryCollection(geoms);
geom->setSRID(4326);
@@ -169,7 +157,7 @@ template<>
- geos::geom::Geometry* geom = wktreader.read("POLYGON EMPTY");
+ auto geom = wktreader.read("POLYGON EMPTY");
@@ -181,11 +169,8 @@ void object::test<5>
std::string actual = result_stream.str();
ensure_equals(actual, "0103000020E610000000000000");
- geos::geom::Geometry* geom2 = wkbreader.readHEX(result_stream);
- assert(geom->equals(geom2));
- delete geom;
- delete geom2;
+ auto geom2 = wkbreader.readHEX(result_stream);
+ assert(geom->equals(geom2.get()));
} // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index bbf599a..fe370d0 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -125,7 +125,7 @@ void object::test<6>
GeomPtr geom;
try {
- geom.reset(wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))"));
+ geom = wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))");
fail("Didn't get expected exception");
catch(const geos::util::IllegalArgumentException& ex) {
@@ -153,7 +153,7 @@ void object::test<7>
ggm::GeometryFactory::Ptr p_gf = ggm::GeometryFactory::create(&p_pm);
gio::WKTReader wktReader(p_gf.get());
const std::string str = " POINT (0 0) ";
- geom.reset(wktReader.read(str)); //HERE IT FAILS
+ geom = wktReader.read(str); //HERE IT FAILS
auto coords = geom->getCoordinates();
ensure_equals(coords->getDimension(), 2U);
diff --git a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
index d021c8d..1b75338 100644
--- a/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
+++ b/tests/unit/noding/snapround/MCIndexSnapRounderTest.cpp
@@ -84,11 +84,11 @@ struct test_mcidxsnprndr_data {
if(wkt[0] == '0' || wkt[0] == '1') {
WKBReader r;
std::istringstream is(wkt);
- g.reset(r.readHEX(is));
+ g = r.readHEX(is);
else {
WKTReader r;
- g.reset(r.read(wkt));
+ g = r.read(wkt);
return g;
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 1447b8c..b7893ff 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -467,8 +467,8 @@ void object::test<18>
wkt0 = "LINESTRING(0 0, 0 1, 1 1, 1 0, 0 0)";
wkt1 = "LINESTRING(2 0, 10 1, 10 10)";
- g0.reset(wktreader.read(wkt0));
- g1.reset(wktreader.read(wkt1));
+ g0 = wktreader.read(wkt0);
+ g1 = wktreader.read(wkt1);
ensure_equals(DistanceOp::distance(*g0, *g1), 1);
ensure(DistanceOp::isWithinDistance(*g0, *g1, 2));
diff --git a/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp b/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
index e000220..b1461ef 100644
--- a/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
+++ b/tests/unit/operation/overlay/validate/FuzzyPointLocatorTest.cpp
@@ -36,7 +36,7 @@ struct test_fuzzypointlocator_data {
wkbreader()
std::string wkt("POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))");
- g.reset(wktreader.read(wkt));
+ g = wktreader.read(wkt);
diff --git a/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp b/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
index 11f3ff8..79c1e30 100644
--- a/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
+++ b/tests/unit/operation/overlay/validate/OffsetPointGeneratorTest.cpp
@@ -85,7 +85,7 @@ void object::test<1>
using std::vector;
double dist = 10;
OffsetPointGenerator gen(*g, dist);
@@ -110,7 +110,7 @@ void object::test<2>
using std::vector;
std::string wkt("POLYGON((0 0, 10 0, 10 5, 10 10, 0 10, 0 0))");
double dist = 0.0003;
@@ -135,7 +135,7 @@ void object::test<3>
using std::vector;
std::string wkt("POINT(10 -10)");
@@ -160,7 +160,7 @@ void object::test<4>
using std::vector;
std::string wkt("LINESTRING(10 -10, 5 600)");
double dist = 0.03;
@@ -185,7 +185,7 @@ void object::test<5>
using std::vector;
std::string wkt("MULTILINESTRING((10 -10, 5 600), (1045 -12, 0 0, -435 34))");
double dist = 0.2;
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 510172f..933dcc2 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -85,8 +85,8 @@ struct test_polygonizetest_data {
return false;
for(typename T::iterator i = ex.begin(), e = ex.end(); i != e; ++i) {
- if(! contains(ob, *i)) {
- cout << "Expected " << wktwriter.write(*i)
+ if(! contains(ob, i->get())) {
+ cout << "Expected " << wktwriter.write(i->get())
<< " not found" << endl;
return false;
@@ -102,7 +102,7 @@ struct test_polygonizetest_data {
using std::cout;
using std::endl;
- std::vector<Geom*> inputGeoms, expectGeoms;
+ std::vector<std::unique_ptr<geos::geom::Geometry>> inputGeoms, expectGeoms;
for (const auto& wkt : inputWKT) {
inputGeoms.push_back(wktreader.read(wkt));
@@ -111,11 +111,13 @@ struct test_polygonizetest_data {
for (const auto& wkt : expectWKT) {
auto g = wktreader.read(wkt);
g->normalize();
- expectGeoms.push_back(g);
+ expectGeoms.push_back(std::move(g));
Polygonizer polygonizer(onlyPolygonal);
- polygonizer.add(&inputGeoms);
+ for (const auto& p : inputGeoms) {
+ polygonizer.add(p.get());
std::unique_ptr<std::vector<std::unique_ptr<Poly>> > retGeoms;
retGeoms = polygonizer.getPolygons();
@@ -123,8 +125,6 @@ struct test_polygonizetest_data {
g->normalize();
- delAll(inputGeoms);
bool ok = compare(expectGeoms, *retGeoms);
if(! ok) {
cout << "EXPECTED(" << expectGeoms.size() << "): " << std::endl;
@@ -136,8 +136,6 @@ struct test_polygonizetest_data {
ensure("not all expected geometries in the obtained set", 0);
- delAll(expectGeoms);
return ok;
diff --git a/tests/unit/operation/union/CascadedPolygonUnionTest.cpp b/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
index 0ebb2d4..2536c63 100644
--- a/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
+++ b/tests/unit/operation/union/CascadedPolygonUnionTest.cpp
@@ -109,7 +109,7 @@ void object::test<1>
for(char const * const* p = polygons; *p != nullptr; ++p) {
std::string wkt(*p);
geos::geom::Polygon* geom =
- dynamic_cast<geos::geom::Polygon*>(wktreader.read(wkt));
+ dynamic_cast<geos::geom::Polygon*>(wktreader.read(wkt).release());
g.push_back(geom);
diff --git a/tests/unit/operation/union/CoverageUnionTest.cpp b/tests/unit/operation/union/CoverageUnionTest.cpp
index 331f9e6..2bf2513 100644
--- a/tests/unit/operation/union/CoverageUnionTest.cpp
+++ b/tests/unit/operation/union/CoverageUnionTest.cpp
@@ -47,7 +47,7 @@ namespace tut {
std::vector<Geometry*> geoms;
for (const auto& wkt : wkt_geoms) {
- geoms.push_back(reader.read(wkt));
+ geoms.push_back(reader.read(wkt).release());
std::unique_ptr<Geometry> coll(gfact->createGeometryCollection(geoms));
@@ -73,7 +73,7 @@ namespace tut {
diff --git a/tests/unit/operation/valid/ValidClosedRingTest.cpp b/tests/unit/operation/valid/ValidClosedRingTest.cpp
index 165f818..84ec86b 100644
--- a/tests/unit/operation/valid/ValidClosedRingTest.cpp
+++ b/tests/unit/operation/valid/ValidClosedRingTest.cpp
@@ -53,7 +53,7 @@ struct test_validclosedring_data {
GeomPtr geom;
try {
- geom.reset(rdr.read(wkt));
+ geom = rdr.read(wkt);
catch(const GEOSException& ex) {
cerr << ex.what() << endl;
diff --git a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
index 8bb1f40..5918bb2 100644
--- a/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
+++ b/tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp
@@ -53,7 +53,7 @@ struct test_ValidSelfTouchingRingFormingHole_data {
GeomPtr geom;
try {
diff --git a/tests/unit/triangulate/DelaunayTest.cpp b/tests/unit/triangulate/DelaunayTest.cpp
index 2fef678..aa8b168 100644
--- a/tests/unit/triangulate/DelaunayTest.cpp
+++ b/tests/unit/triangulate/DelaunayTest.cpp
@@ -44,8 +44,8 @@ runDelaunay(const char* sitesWkt, bool computeTriangles, const char* expectedWkt
WKTReader reader;
std::unique_ptr<Geometry> results;
- Geometry* sites = reader.read(sitesWkt);
- Geometry* expected = reader.read(expectedWkt);
+ auto sites = reader.read(sitesWkt);
+ auto expected = reader.read(expectedWkt);
DelaunayTriangulationBuilder builder;
builder.setTolerance(tolerance);
const GeometryFactory& geomFact(*GeometryFactory::getDefaultInstance());
@@ -61,11 +61,8 @@ runDelaunay(const char* sitesWkt, bool computeTriangles, const char* expectedWkt
results->normalize();
expected->normalize();
- ensure(results->toString(), results->equalsExact(expected, 1e-7));
+ ensure(results->toString(), results->equalsExact(expected.get(), 1e-7));
ensure_equals(results->getCoordinateDimension(), expected->getCoordinateDimension());
- delete sites;
- delete expected;
diff --git a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
index 79f53cd..ec53639 100644
--- a/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
+++ b/tests/unit/triangulate/quadedge/QuadEdgeSubdivisionTest.cpp
@@ -85,9 +85,8 @@ template<>
- Geometry* sites;
QuadEdgeSubdivision* subdiv;
- sites = reader.read("MULTIPOINT ((150 200), (180 270), (275 163))");
+ auto sites = reader.read("MULTIPOINT ((150 200), (180 270), (275 163))");
auto siteCoords = DelaunayTriangulationBuilder::extractUniqueCoordinates(*sites);
Envelope Env = DelaunayTriangulationBuilder::envelope(*siteCoords);
@@ -106,13 +105,11 @@ void object::test<2>
"GEOMETRYCOLLECTION (POLYGON ((-5849.974929324658 2268.0517257497568, -4529.9920486948895 2247.139449440667, 221.20588235294116 210.91176470588235, -684.4227119984187 -2848.644297291955, -5849.974929324658 2268.0517257497568)), POLYGON ((212.5 -3774.5, -684.4227119984187 -2848.644297291955, 221.20588235294116 210.91176470588235, 2448.7167655626645 2188.608343256571, 6235.0370264064295 2248.0370264064295, 212.5 -3774.5)), POLYGON ((-4529.9920486948895 2247.139449440667, 2448.7167655626645 2188.608343256571, 221.20588235294116 210.91176470588235, -4529.9920486948895 2247.139449440667)))";
// std::cout << polys->toString() << std::endl;
- Geometry* expected = reader.read(expected_str);
+ auto expected = reader.read(expected_str);
polys->normalize();
- ensure(polys->equalsExact(expected, 1e-7));
- delete sites;
+ ensure(polys->equalsExact(expected.get(), 1e-7));
delete subdiv;
- delete expected;
// ensure(polys->getCoordinateDimension() == expected->getCoordinateDimension());
diff --git a/tests/xmltester/SimpleWKTTester.cpp b/tests/xmltester/SimpleWKTTester.cpp
index b9bcc3c..55f9441 100644
--- a/tests/xmltester/SimpleWKTTester.cpp
+++ b/tests/xmltester/SimpleWKTTester.cpp
@@ -50,7 +50,7 @@ main(int /*argc*/, char** /*argv*/)
while(!in.eof()) {
getline(in, instr);
if(instr != "") {
- g = r->read(instr);
+ g = r->read(instr).release();
outstr = w->write(g);
out << "----------" << endl;
out << instr << endl;
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 9033659..77635e6 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -592,7 +592,7 @@ XMLTester::parseGeometry(const std::string& in, const char* label)
while(is.get(first_char) && std::isspace(first_char));
is.unget();
- geom::Geometry* ret;
+ std::unique_ptr<geom::Geometry> ret;
switch(first_char) {
case '0':
@@ -619,12 +619,12 @@ XMLTester::parseGeometry(const std::string& in, const char* label)
if(testValidInput) {
- testValid(ret, std::string(label));
+ testValid(ret.get(), std::string(label));
//ret->normalize();
- return ret;
+ return ret.release();
std::string
Summary of changes:
capi/geos_ts_c.cpp | 21 ++-
doc/example.cpp | 2 +-
include/geos/io/WKBReader.h | 35 ++---
include/geos/io/WKTReader.h | 22 ++--
src/io/WKBReader.cpp | 67 +++++-----
src/io/WKTReader.cpp | 119 +++++++----------
tests/unit/algorithm/InteriorPointAreaTest.cpp | 2 +-
tests/unit/algorithm/MinimumBoundingCircleTest.cpp | 4 +-
tests/unit/capi/GEOSContainsTest.cpp | 16 +--
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 20 +--
tests/unit/geom/Geometry/coversTest.cpp | 4 +-
tests/unit/geom/Geometry/isRectangleTest.cpp | 42 ++----
tests/unit/geom/GeometryFactoryTest.cpp | 4 +-
tests/unit/geom/LineStringTest.cpp | 65 +++-------
tests/unit/geom/LinearRingTest.cpp | 17 +--
tests/unit/geom/MultiPointTest.cpp | 17 +--
tests/unit/geom/PointTest.cpp | 115 +++++------------
tests/unit/geom/PolygonTest.cpp | 32 ++---
.../geom/prep/PreparedGeometry/touchesTest.cpp | 41 +++---
.../unit/geom/prep/PreparedGeometryFactoryTest.cpp | 141 ++++++++++-----------
tests/unit/io/WKBWriterTest.cpp | 29 +----
tests/unit/io/WKTReaderTest.cpp | 4 +-
.../noding/snapround/MCIndexSnapRounderTest.cpp | 4 +-
tests/unit/operation/distance/DistanceOpTest.cpp | 4 +-
.../overlay/validate/FuzzyPointLocatorTest.cpp | 2 +-
.../overlay/validate/OffsetPointGeneratorTest.cpp | 10 +-
tests/unit/operation/polygonize/PolygonizeTest.cpp | 16 +--
.../operation/union/CascadedPolygonUnionTest.cpp | 2 +-
tests/unit/operation/union/CoverageUnionTest.cpp | 4 +-
tests/unit/operation/valid/ValidClosedRingTest.cpp | 2 +-
.../valid/ValidSelfTouchingRingFormingHoleTest.cpp | 2 +-
tests/unit/triangulate/DelaunayTest.cpp | 9 +-
.../quadedge/QuadEdgeSubdivisionTest.cpp | 9 +-
tests/xmltester/SimpleWKTTester.cpp | 2 +-
tests/xmltester/XMLTester.cpp | 6 +-
35 files changed, 346 insertions(+), 545 deletions(-)
hooks/post-receive
More information about the geos-commits
