[geos-commits] [SCM] GEOS branch master updated. 84ba018a9f88e1118ab9d05d3b42bc383a4176f0
git at osgeo.org
git at osgeo.org
Tue Jun 18 07:01:57 PDT 2019
the project "GEOS".
via 84ba018a9f88e1118ab9d05d3b42bc383a4176f0 (commit)
via b7dd304e54341a78815394b2a465852d3658c89c (commit)
via 2e503e6c434961a1fff3a6ebe46d6fbfbf325911 (commit)
via 9b7a1db25859f6f5a77b61ebee2bab0163d16b4c (commit)
from a64c3d737ae771d9734a987c5620dee6720a87df (commit)
revisions in full, below.
commit 84ba018a9f88e1118ab9d05d3b42bc383a4176f0
Merge: a64c3d7 b7dd304
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Jun 18 10:01:38 2019 -0400
Merge branch 'geometryeditor-uniqueptr'
commit b7dd304e54341a78815394b2a465852d3658c89c
Date: Mon Jun 17 21:09:09 2019 -0400
Return unique_ptr from GeometryCombiner
diff --git a/include/geos/geom/util/GeometryCombiner.h b/include/geos/geom/util/GeometryCombiner.h
index 8fcf5be..c40ea22 100644
--- a/include/geos/geom/util/GeometryCombiner.h
+++ b/include/geos/geom/util/GeometryCombiner.h
@@ -19,6 +19,7 @@
#ifndef GEOS_GEOM_UTIL_GEOMETRYCOMBINER_H
#define GEOS_GEOM_UTIL_GEOMETRYCOMBINER_H
+#include <memory>
#include <vector>
// Forward declarations
@@ -52,7 +53,7 @@ public:
* @param geoms the geometries to combine (ownership left to caller)
* @return the combined geometry
- static Geometry* combine(std::vector<Geometry*> const& geoms);
+ static std::unique_ptr<Geometry> combine(std::vector<Geometry*> const& geoms);
* Combines two geometries.
@@ -61,7 +62,7 @@ public:
* @param g1 a geometry to combine (ownership left to caller)
- static Geometry* combine(const Geometry* g0, const Geometry* g1);
+ static std::unique_ptr<Geometry> combine(const Geometry* g0, const Geometry* g1);
* Combines three geometries.
@@ -71,7 +72,7 @@ public:
* @param g2 a geometry to combine (ownership left to caller)
- static Geometry* combine(const Geometry* g0, const Geometry* g1, const Geometry* g2);
+ static std::unique_ptr<Geometry> combine(const Geometry* g0, const Geometry* g1, const Geometry* g2);
private:
GeometryFactory const* geomFactory;
@@ -100,7 +101,7 @@ public:
* @return a Geometry which is the combination of the inputs
- Geometry* combine();
+ std::unique_ptr<Geometry> combine();
private:
void extractElements(Geometry* geom, std::vector<Geometry*>& elems);
diff --git a/src/geom/util/GeometryCombiner.cpp b/src/geom/util/GeometryCombiner.cpp
index 5580b92..f174c51 100644
--- a/src/geom/util/GeometryCombiner.cpp
+++ b/src/geom/util/GeometryCombiner.cpp
@@ -25,14 +25,14 @@ namespace geos {
namespace geom { // geos.geom
namespace util { // geos.geom.util
-Geometry*
+std::unique_ptr<Geometry>
GeometryCombiner::combine(std::vector<Geometry*> const& geoms)
GeometryCombiner combiner(geoms);
return combiner.combine();
-Geometry*
GeometryCombiner::combine(const Geometry* g0, const Geometry* g1)
std::vector<Geometry*> geoms;
@@ -43,7 +43,7 @@ GeometryCombiner::combine(const Geometry* g0, const Geometry* g1)
-Geometry*
GeometryCombiner::combine(const Geometry* g0, const Geometry* g1,
const Geometry* g2)
@@ -67,26 +67,24 @@ GeometryCombiner::extractFactory(std::vector<Geometry*> const& geoms)
return geoms.empty() ? nullptr : geoms.front()->getFactory();
-Geometry*
GeometryCombiner::combine()
std::vector<Geometry*> elems;
- std::vector<Geometry*>::const_iterator end = inputGeoms.end();
- for(std::vector<Geometry*>::const_iterator i = inputGeoms.begin();
- i != end; ++i) {
- extractElements(*i, elems);
+ for(const auto& geom : inputGeoms) {
+ extractElements(geom, elems);
if(elems.empty()) {
if(geomFactory != nullptr) {
- return geomFactory->createGeometryCollection(nullptr);
+ return std::unique_ptr<Geometry>(geomFactory->createGeometryCollection(nullptr));
return nullptr;
// return the "simplest possible" geometry
- return geomFactory->buildGeometry(elems);
+ return std::unique_ptr<Geometry>(geomFactory->buildGeometry(elems));
void
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 6134684..ff6fdef 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -241,7 +241,7 @@ CascadedPolygonUnion::unionOptimized(geom::Geometry* g0, geom::Geometry* g1)
geom::Envelope const* g1Env = g1->getEnvelopeInternal();
if(!g0Env->intersects(g1Env)) {
- return geom::util::GeometryCombiner::combine(g0, g1);
+ return geom::util::GeometryCombiner::combine(g0, g1).release();
if(g0->getNumGeometries() <= 1 && g1->getNumGeometries() <= 1) {
@@ -318,13 +318,13 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
std::unique_ptr<geom::Geometry> ret;
if(polysOn.empty()) {
disjointPolys.push_back(u.get());
- ret.reset(geom::util::GeometryCombiner::combine(disjointPolys));
+ ret = geom::util::GeometryCombiner::combine(disjointPolys);
else {
// TODO: could be further tweaked to only union with polysOn
// and combine with polysOff, but then it'll need again to
// recurse in the check for disjoint/intersecting
ret.reset(unionActual(ret.get(), u.get()));
diff --git a/src/operation/union/CascadedUnion.cpp b/src/operation/union/CascadedUnion.cpp
index 2dbc52c..8d7a96f 100644
--- a/src/operation/union/CascadedUnion.cpp
+++ b/src/operation/union/CascadedUnion.cpp
@@ -152,7 +152,7 @@ CascadedUnion::unionOptimized(geom::Geometry* g0, geom::Geometry* g1)
@@ -176,7 +176,7 @@ CascadedUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
std::unique_ptr<geom::Geometry> u(unionActual(g0Int.get(), g1Int.get()));
- return geom::util::GeometryCombiner::combine(disjointPolys);
+ return geom::util::GeometryCombiner::combine(disjointPolys).release();
geom::Geometry*
diff --git a/src/precision/PrecisionReducerCoordinateOperation.cpp b/src/precision/PrecisionReducerCoordinateOperation.cpp
index 69affc1..91649df 100644
--- a/src/precision/PrecisionReducerCoordinateOperation.cpp
+++ b/src/precision/PrecisionReducerCoordinateOperation.cpp
@@ -57,7 +57,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
// remove repeated points, to simplify returned geometry as
// much as possible.
- auto noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords.get());
+ std::unique_ptr<CoordinateSequence> noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords.get());
* Check to see if the removal of repeated points
diff --git a/src/precision/SimpleGeometryPrecisionReducer.cpp b/src/precision/SimpleGeometryPrecisionReducer.cpp
index bd99dd3..54e82ac 100644
--- a/src/precision/SimpleGeometryPrecisionReducer.cpp
+++ b/src/precision/SimpleGeometryPrecisionReducer.cpp
@@ -87,7 +87,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
commit 2e503e6c434961a1fff3a6ebe46d6fbfbf325911
Date: Mon Jun 17 13:13:00 2019 -0400
Use unique_ptr in GeometryEditor
diff --git a/include/geos/geom/util/CoordinateOperation.h b/include/geos/geom/util/CoordinateOperation.h
index 8f5701f..2c79cf4 100644
--- a/include/geos/geom/util/CoordinateOperation.h
+++ b/include/geos/geom/util/CoordinateOperation.h
@@ -45,8 +45,8 @@ public:
* Return a newly created geometry, ownership to caller
- Geometry* edit(const Geometry* geometry,
- const GeometryFactory* factory) override;
+ std::unique_ptr<Geometry> edit(const Geometry* geometry,
+ const GeometryFactory* factory) override;
* Edits the array of Coordinate from a Geometry.
@@ -56,11 +56,11 @@ public:
* @return an edited coordinate array (which may be the same as
* the input)
- virtual CoordinateSequence* edit(const CoordinateSequence* coordinates,
- const Geometry* geometry) = 0;
+ virtual std::unique_ptr<CoordinateSequence> edit(const CoordinateSequence* coordinates,
+ const Geometry* geometry) = 0;
- ~CoordinateOperation() override {}
+ ~CoordinateOperation() override = default;
diff --git a/include/geos/geom/util/GeometryEditor.h b/include/geos/geom/util/GeometryEditor.h
index 77cbaa8..229bc7d 100644
--- a/include/geos/geom/util/GeometryEditor.h
+++ b/include/geos/geom/util/GeometryEditor.h
@@ -22,6 +22,7 @@
#define GEOS_GEOM_UTIL_GEOMETRYEDITOR_H
#include <geos/export.h>
+#include <memory>
namespace geos {
@@ -82,12 +83,12 @@ private:
const GeometryFactory* factory;
- Polygon* editPolygon(const Polygon* polygon,
- GeometryEditorOperation* operation);
+ std::unique_ptr<Polygon> editPolygon(const Polygon* polygon,
+ GeometryEditorOperation* operation);
- GeometryCollection* editGeometryCollection(
- const GeometryCollection* collection,
+ std::unique_ptr<GeometryCollection> editGeometryCollection(
+ const GeometryCollection* collection,
public:
@@ -117,8 +118,8 @@ public:
* @return a new Geometry which is the result of the editing
- GeometryEditorOperation* operation); // final
+ GeometryEditorOperation* operation); // final
} // namespace geos.geom.util
diff --git a/include/geos/geom/util/GeometryEditorOperation.h b/include/geos/geom/util/GeometryEditorOperation.h
index 4824903..8757a7d 100644
--- a/include/geos/geom/util/GeometryEditorOperation.h
+++ b/include/geos/geom/util/GeometryEditorOperation.h
@@ -17,6 +17,7 @@
#define GEOS_GEOM_UTIL_GEOMETRYEDITOROPERATION_H
+#include <memory>
namespace geos {
@@ -50,8 +51,8 @@ public:
* @return a new Geometry which is a modification of the input Geometry
- virtual Geometry* edit(const Geometry* geometry,
- const GeometryFactory* factory) = 0;
+ virtual std::unique_ptr<Geometry> edit(const Geometry* geometry,
+ const GeometryFactory* factory) = 0;
virtual
~GeometryEditorOperation() {}
diff --git a/include/geos/precision/PrecisionReducerCoordinateOperation.h b/include/geos/precision/PrecisionReducerCoordinateOperation.h
index 195c502..83fe7ec 100644
--- a/include/geos/precision/PrecisionReducerCoordinateOperation.h
+++ b/include/geos/precision/PrecisionReducerCoordinateOperation.h
@@ -57,8 +57,8 @@ public:
/// Ownership of returned CoordinateSequence to caller
/// virtual function
- geom::CoordinateSequence* edit(const geom::CoordinateSequence* coordinates,
- const geom::Geometry* geom) override;
+ std::unique_ptr<geom::CoordinateSequence> edit(const geom::CoordinateSequence* coordinates,
+ const geom::Geometry* geom) override;
} // namespace geos.precision
diff --git a/include/geos/precision/SimpleGeometryPrecisionReducer.h b/include/geos/precision/SimpleGeometryPrecisionReducer.h
index cd8b1b3..e39a732 100644
--- a/include/geos/precision/SimpleGeometryPrecisionReducer.h
+++ b/include/geos/precision/SimpleGeometryPrecisionReducer.h
@@ -16,6 +16,7 @@
#define GEOS_PRECISION_SIMPLEGEOMETRYPRECISIONREDUCER_H
+#include <memory>
namespace geos {
@@ -80,7 +81,7 @@ public:
const geom::PrecisionModel* getPrecisionModel();
bool getRemoveCollapsed();
- geom::Geometry* reduce(const geom::Geometry* geom);
+ std::unique_ptr<geom::Geometry> reduce(const geom::Geometry* geom);
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index e7f3d2d..bc8c430 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -67,11 +67,11 @@ public:
gfCoordinateOperation(const CoordinateSequenceFactory* gsf)
: _gsf(gsf)
- CoordinateSequence*
edit(const CoordinateSequence* coordSeq,
const Geometry*) override
- return _gsf->create(*coordSeq).release();
+ return _gsf->create(*coordSeq);
@@ -777,8 +777,7 @@ GeometryFactory::createGeometry(const Geometry* g) const
//return g->clone();
util::GeometryEditor editor(this);
gfCoordinateOperation coordOp(coordinateListFactory);
- Geometry* ret = editor.edit(g, &coordOp);
- return ret;
+ return editor.edit(g, &coordOp).release();
/*public*/
diff --git a/src/geom/util/CoordinateOperation.cpp b/src/geom/util/CoordinateOperation.cpp
index 5a50d30..7676fb7 100644
--- a/src/geom/util/CoordinateOperation.cpp
+++ b/src/geom/util/CoordinateOperation.cpp
@@ -26,30 +26,28 @@ namespace geos {
-Geometry*
CoordinateOperation::edit(const Geometry* geometry,
- const LinearRing* ring = dynamic_cast<const LinearRing*>(geometry);
- if(ring) {
+ if(const LinearRing* ring = dynamic_cast<const LinearRing*>(geometry)) {
const CoordinateSequence* coords = ring->getCoordinatesRO();
- CoordinateSequence* newCoords = edit(coords, geometry);
+ auto newCoords = edit(coords, geometry);
// LinearRing instance takes over ownership of newCoords instance
- return factory->createLinearRing(newCoords);
+ return std::unique_ptr<Geometry>(factory->createLinearRing(newCoords.release()));
- const LineString* line = dynamic_cast<const LineString*>(geometry);
- if(line) {
+ if(const LineString* line = dynamic_cast<const LineString*>(geometry)) {
const CoordinateSequence* coords = line->getCoordinatesRO();
- return factory->createLineString(newCoords);
+ return std::unique_ptr<Geometry>(factory->createLineString(newCoords.release()));
- if(typeid(*geometry) == typeid(Point)) {
- auto coords = geometry->getCoordinates();
- CoordinateSequence* newCoords = edit(coords.get(), geometry);
- return factory->createPoint(newCoords);
+ if(const Point* point = dynamic_cast<const Point*>(geometry)) {
+ auto coords = point->getCoordinatesRO();
+ return std::unique_ptr<Geometry>(factory->createPoint(newCoords.release()));
- return geometry->clone().release();
+ return geometry->clone();
diff --git a/src/geom/util/GeometryEditor.cpp b/src/geom/util/GeometryEditor.cpp
index 320d9b5..940417d 100644
--- a/src/geom/util/GeometryEditor.cpp
+++ b/src/geom/util/GeometryEditor.cpp
@@ -32,13 +32,12 @@
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/util/GeometryEditorOperation.h>
#include <geos/util/UnsupportedOperationException.h>
+#include <geos/util.h>
#include <vector>
#include <cassert>
#include <typeinfo>
-using namespace std;
namespace geos {
@@ -72,7 +71,7 @@ GeometryEditor::GeometryEditor(const GeometryFactory* newFactory)
* @param operation the edit operation to carry out
* @return a new {@link Geometry} which is the result of the editing
-Geometry*
GeometryEditor::edit(const Geometry* geometry, GeometryEditorOperation* operation)
// if client did not supply a GeometryFactory, use the one from the input Geometry
@@ -102,17 +101,16 @@ GeometryEditor::edit(const Geometry* geometry, GeometryEditorOperation* operatio
return nullptr;
-Polygon*
+std::unique_ptr<Polygon>
GeometryEditor::editPolygon(const Polygon* polygon, GeometryEditorOperation* operation)
- Polygon* newPolygon = dynamic_cast<Polygon*>(
- operation->edit(polygon, factory)
+ std::unique_ptr<Polygon> newPolygon(dynamic_cast<Polygon*>(
+ operation->edit(polygon, factory).release()
if(newPolygon->isEmpty()) {
//RemoveSelectedPlugIn relies on this behaviour. [Jon Aquino]
if(newPolygon->getFactory() != factory) {
- Polygon* ret = factory->createPolygon(nullptr, nullptr);
- delete newPolygon;
+ std::unique_ptr<Polygon> ret(factory->createPolygon(nullptr, nullptr));
return ret;
else {
@@ -120,64 +118,56 @@ GeometryEditor::editPolygon(const Polygon* polygon, GeometryEditorOperation* ope
- Geometry* editResult = edit(newPolygon->getExteriorRing(), operation);
+ std::unique_ptr<LinearRing> shell(dynamic_cast<LinearRing*>(
+ edit(newPolygon->getExteriorRing(), operation).release()));
- LinearRing* shell = dynamic_cast<LinearRing*>(editResult);
if(shell->isEmpty()) {
- delete shell;
- return factory->createPolygon(nullptr, nullptr);
+ return std::unique_ptr<Polygon>(factory->createPolygon(nullptr, nullptr));
- vector<LinearRing*>* holes = new vector<LinearRing*>;
+ auto holes = detail::make_unique<std::vector<LinearRing*>>();
for(size_t i = 0, n = newPolygon->getNumInteriorRing(); i < n; ++i) {
- Geometry* hole_geom = edit(newPolygon->getInteriorRingN(i),
- operation);
+ std::unique_ptr<LinearRing> hole(dynamic_cast<LinearRing*>(
+ edit(newPolygon->getInteriorRingN(i), operation).release()));
- LinearRing* hole = dynamic_cast<LinearRing*>(hole_geom);
assert(hole);
if(hole->isEmpty()) {
continue;
- holes->push_back(hole);
+ holes->push_back(hole.release());
- return factory->createPolygon(shell, holes);
+ return std::unique_ptr<Polygon>(factory->createPolygon(shell.release(), holes.release()));
-GeometryCollection*
+std::unique_ptr<GeometryCollection>
GeometryEditor::editGeometryCollection(const GeometryCollection* collection, GeometryEditorOperation* operation)
- GeometryCollection* newCollection = dynamic_cast<GeometryCollection*>(operation->edit(collection, factory));
- vector<Geometry*>* geometries = new vector<Geometry*>();
+ auto newCollection = operation->edit(collection, factory);
+ auto geometries = detail::make_unique<std::vector<Geometry*>>();
for(std::size_t i = 0, n = newCollection->getNumGeometries(); i < n; i++) {
- Geometry* geometry = edit(newCollection->getGeometryN(i),
+ auto geometry = edit(newCollection->getGeometryN(i),
operation);
if(geometry->isEmpty()) {
- delete geometry;
continue;
- geometries->push_back(geometry);
+ geometries->push_back(geometry.release());
- if(typeid(*newCollection) == typeid(MultiPoint)) {
- delete newCollection;
- return factory->createMultiPoint(geometries);
+ if(newCollection->getGeometryTypeId() == GEOS_MULTIPOINT) {
+ return std::unique_ptr<GeometryCollection>(factory->createMultiPoint(geometries.release()));
- else if(typeid(*newCollection) == typeid(MultiLineString)) {
- return factory->createMultiLineString(geometries);
+ else if(newCollection->getGeometryTypeId() == GEOS_MULTILINESTRING) {
+ return std::unique_ptr<GeometryCollection>(factory->createMultiLineString(geometries.release()));
- else if(typeid(*newCollection) == typeid(MultiPolygon)) {
- return factory->createMultiPolygon(geometries);
+ else if(newCollection->getGeometryTypeId() == GEOS_MULTIPOLYGON) {
+ return std::unique_ptr<GeometryCollection>(factory->createMultiPolygon(geometries.release()));
else {
- return factory->createGeometryCollection(geometries);
+ return std::unique_ptr<GeometryCollection>(factory->createGeometryCollection(geometries.release()));
index b907f6f..69affc1 100644
@@ -25,16 +25,16 @@
#include <geos/geom/LineString.h>
#include <geos/geom/LinearRing.h>
#include <geos/operation/valid/RepeatedPointRemover.h>
#include <vector>
using namespace geos::geom;
namespace geos {
namespace precision { // geos.precision
-CoordinateSequence*
+std::unique_ptr<CoordinateSequence>
const Geometry* geom)
@@ -44,7 +44,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
return nullptr;
- vector<Coordinate>* vc = new vector<Coordinate>(csSize);
+ auto vc = detail::make_unique<std::vector<Coordinate>>(csSize);
// copy coordinates and reduce
for(size_t i = 0; i < csSize; ++i) {
@@ -53,12 +53,11 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
// reducedCoords take ownership of 'vc'
- CoordinateSequence* reducedCoords =
- geom->getFactory()->getCoordinateSequenceFactory()->create(vc).release();
+ auto reducedCoords = geom->getFactory()->getCoordinateSequenceFactory()->create(vc.release());
- auto noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords);
+ auto noRepeatedCoords = operation::valid::RepeatedPointRemover::removeRepeatedPoints(reducedCoords.get());
@@ -79,21 +78,17 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
minLength = 4;
- CoordinateSequence* collapsedCoords = reducedCoords;
if(removeCollapsed) {
- delete reducedCoords;
reducedCoords = nullptr;
- collapsedCoords = nullptr;
- // return null or orginal length coordinate array
+ // return null or original length coordinate array
if(noRepeatedCoords->getSize() < minLength) {
- return collapsedCoords;
+ return reducedCoords;
// ok to return shorter coordinate array
- return noRepeatedCoords.release();
+ return noRepeatedCoords;
index 9ab876a..bd99dd3 100644
@@ -28,11 +28,11 @@
#include <vector>
#include <typeinfo>
using namespace geos::geom::util;
@@ -54,8 +54,8 @@ public:
SimpleGeometryPrecisionReducer* newSgpr);
- CoordinateSequence* edit(const CoordinateSequence* coordinates,
- const Geometry* geom) override;
+ std::unique_ptr<CoordinateSequence> edit(const CoordinateSequence* coordinates,
+ const Geometry* geom) override;
PrecisionReducerCoordinateOperation::PrecisionReducerCoordinateOperation(
@@ -64,7 +64,7 @@ PrecisionReducerCoordinateOperation::PrecisionReducerCoordinateOperation(
sgpr = newSgpr;
@@ -74,7 +74,7 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
auto csSize = cs->size();
for(unsigned int i = 0; i < csSize; ++i) {
@@ -83,12 +83,11 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
@@ -108,19 +107,16 @@ PrecisionReducerCoordinateOperation::edit(const CoordinateSequence* cs,
if(typeid(*geom) == typeid(LinearRing)) {
minLength = 4;
if(sgpr->getRemoveCollapsed()) {
} // anonymous namespace
@@ -164,13 +160,12 @@ SimpleGeometryPrecisionReducer::getRemoveCollapsed()
return removeCollapsed;
-Geometry*
SimpleGeometryPrecisionReducer::reduce(const Geometry* geom)
GeometryEditor geomEdit;
PrecisionReducerCoordinateOperation prco(this);
- Geometry* g = geomEdit.edit(geom, &prco);
- return g;
+ return geomEdit.edit(geom, &prco);
commit 9b7a1db25859f6f5a77b61ebee2bab0163d16b4c
Date: Mon Jun 17 12:30:29 2019 -0400
Remove trivial heap alloc in GeometryPrecisionReducer
diff --git a/src/precision/GeometryPrecisionReducer.cpp b/src/precision/GeometryPrecisionReducer.cpp
index 80997e3..77bf35a 100644
--- a/src/precision/GeometryPrecisionReducer.cpp
+++ b/src/precision/GeometryPrecisionReducer.cpp
@@ -44,14 +44,7 @@ namespace precision { // geos.precision
GeometryPrecisionReducer::reducePointwise(const Geometry& geom)
- unique_ptr<GeometryEditor> geomEdit;
- if(newFactory) {
- geomEdit.reset(new GeometryEditor(newFactory));
- else {
- geomEdit.reset(new GeometryEditor());
+ GeometryEditor geomEdit(newFactory);
* For polygonal geometries, collapses are always removed, in order
@@ -64,7 +57,7 @@ GeometryPrecisionReducer::reducePointwise(const Geometry& geom)
PrecisionReducerCoordinateOperation prco(targetPM, finalRemoveCollapsed);
- std::unique_ptr<Geometry> g(geomEdit->edit(&geom, &prco));
+ std::unique_ptr<Geometry> g(geomEdit.edit(&geom, &prco));
return g;
Summary of changes:
include/geos/geom/util/CoordinateOperation.h | 10 ++--
include/geos/geom/util/GeometryCombiner.h | 9 +--
include/geos/geom/util/GeometryEditor.h | 15 ++---
include/geos/geom/util/GeometryEditorOperation.h | 5 +-
.../PrecisionReducerCoordinateOperation.h | 4 +-
.../precision/SimpleGeometryPrecisionReducer.h | 3 +-
src/geom/GeometryFactory.cpp | 7 +--
src/geom/util/CoordinateOperation.cpp | 26 ++++-----
src/geom/util/GeometryCombiner.cpp | 18 +++---
src/geom/util/GeometryEditor.cpp | 66 +++++++++-------------
src/operation/union/CascadedPolygonUnion.cpp | 6 +-
src/operation/union/CascadedUnion.cpp | 4 +-
src/precision/GeometryPrecisionReducer.cpp | 11 +---
.../PrecisionReducerCoordinateOperation.cpp | 21 +++----
src/precision/SimpleGeometryPrecisionReducer.cpp | 31 +++++-----
15 files changed, 104 insertions(+), 132 deletions(-)
hooks/post-receive
More information about the geos-commits
