[geos-commits] [SCM] GEOS branch master updated. adfd98a3de0872db6d44541f12f83a7c610dcf23
git at osgeo.org
git at osgeo.org
Mon Mar 25 13:35:21 PDT 2019
the project "GEOS".
via adfd98a3de0872db6d44541f12f83a7c610dcf23 (commit)
from cf7e1808c3e45708c33420bc38095007773e9019 (commit)
revisions in full, below.
commit adfd98a3de0872db6d44541f12f83a7c610dcf23
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Mar 18 17:31:42 2019 -0400
Add test case for DistanceOp::closestPoints
diff --git a/tests/unit/operation/distance/DistanceOpTest.cpp b/tests/unit/operation/distance/DistanceOpTest.cpp
index 6408c87..0b3fd82 100644
--- a/tests/unit/operation/distance/DistanceOpTest.cpp
+++ b/tests/unit/operation/distance/DistanceOpTest.cpp
@@ -9,11 +9,14 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/Geometry.h>
+#include <geos/geom/LineSegment.h>
+#include <geos/geom/LineString.h>
#include <geos/geom/PrecisionModel.h>
#include <geos/algorithm/PointLocator.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKBReader.h>
#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
// std
#include <memory>
#include <string>
@@ -499,6 +502,59 @@ void object::test<19>
ensure_equals(g1->distance(g2.get()), 0);
+// Test case reported in Shapely
+// https://github.com/Toblerity/Shapely/issues/560
+template<>
+template<>
+void object::test<20>()
+ using geos::operation::distance::DistanceOp;
+ using geos::geom::Coordinate;
+ using geos::geom::LineSegment;
+ using geos::geom::Geometry;
+ using geos::geom::LineString;
+ using geos::geom::GeometryFactory;
+ using geos::geom::CoordinateArraySequence;
+ auto gfact = GeometryFactory::create();
+ CSPtr seq0(new CoordinateArraySequence(2));
+ CSPtr seq1(new CoordinateArraySequence(2));
+ Coordinate a0{1, 5.0/3.0};
+ Coordinate a1{2, 10.0/3.0};
+ Coordinate b0{3, 5};
+ Coordinate b1{0, 0};
+ seq0->setAt(a0, 0);
+ seq0->setAt(a1, 1);
+ seq1->setAt(b0, 0);
+ seq1->setAt(b1, 1);
+ GeomPtr g0(gfact->createLineString(seq0.release()));
+ GeomPtr g1(gfact->createLineString(seq1.release()));
+ DistanceOp dist(g0.get(), g1.get());
+ CSPtr seq(dist.closestPoints());
+ // input lines overlap, so generated point should intersect both geometries
+ ensure(geos::geom::LineSegment(a0, a1).distance(seq->getAt(0)) < 1e-8);
+ ensure(geos::geom::LineSegment(a0, a1).distance(seq->getAt(1)) < 1e-8);
+ ensure(geos::geom::LineSegment(b0, b1).distance(seq->getAt(0)) < 1e-8);
+ ensure(geos::geom::LineSegment(b0, b1).distance(seq->getAt(1)) < 1e-8);
+ // reverse argument order and check again
+ dist = DistanceOp(g1.get(), g0.get());
+ seq.reset(dist.closestPoints());
// TODO: finish the tests by adding:
// LINESTRING - *all*
// MULTILINESTRING - *all*
Summary of changes:
tests/unit/operation/distance/DistanceOpTest.cpp | 56 ++++++++++++++++++++++++
1 file changed, 56 insertions(+)
hooks/post-receive
More information about the geos-commits
