[geos-commits] [SCM] GEOS branch master updated. f2600b74c5ad1889824651d24fed784fa32e47c2
Mon Mar 25 18:40:05 PDT 2019
the project "GEOS".
       via  f2600b74c5ad1889824651d24fed784fa32e47c2 (commit)
       via  e7e4a239771cf361964a276f65bff45f56ba3bec (commit)
       via  6f9916f751954904b1f6b98e0398eebff9021a11 (commit)
      from  adfd98a3de0872db6d44541f12f83a7c610dcf23 (commit)
revisions in full, below.
commit f2600b74c5ad1889824651d24fed784fa32e47c2
Author: Daniel Baston <dbaston at gmail.com>
Date:   Mon Mar 25 17:46:21 2019 -0400
    Fix make distcheck failures
diff --git a/include/geos/operation/polygonize/Makefile.am b/include/geos/operation/polygonize/Makefile.am
index f9e83ce..4329213 100644
--- a/include/geos/operation/polygonize/Makefile.am
+++ b/include/geos/operation/polygonize/Makefile.am
@@ -1,16 +1,16 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-#SUBDIRS =
+#SUBDIRS =
-#EXTRA_DIST =
+#EXTRA_DIST =
 geosdir = $(includedir)/geos/operation/polygonize
 geos_HEADERS = \
+    BuildArea.h \
     EdgeRing.h \
     PolygonizeDirectedEdge.h \
     PolygonizeEdge.h \
     PolygonizeGraph.h \
-    Polygonizer.h \
-    BuildArea.h
+    Polygonizer.h
diff --git a/include/geos/operation/valid/Makefile.am b/include/geos/operation/valid/Makefile.am
index 8e1c3ad..8d62486 100644
--- a/include/geos/operation/valid/Makefile.am
+++ b/include/geos/operation/valid/Makefile.am
@@ -1,9 +1,9 @@
-#SUBDIRS =
+#SUBDIRS =
-#EXTRA_DIST =
+#EXTRA_DIST =
 geosdir = $(includedir)/geos/operation/valid
@@ -11,8 +11,9 @@ geos_HEADERS = \
     ConnectedInteriorTester.h   \
     ConsistentAreaTester.h      \
     IsValidOp.h                 \
+    MakeValid.h                 \
     QuadtreeNestedRingTester.h  \
     RepeatedPointTester.h       \
     SimpleNestedRingTester.h    \
     SweeplineNestedRingTester.h \
-    TopologyValidationError.h
+    TopologyValidationError.h
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index abb7e28..fc34b9d 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -120,8 +120,8 @@ FAILING_XMLTESTS = \
 	$(srcdir)/tests/issue/issue-geos-488.xml \
 	$(srcdir)/tests/issue/issue-geos-344.xml \
 	$(srcdir)/tests/robust/TestRobustRelateFloat.xml \
-	$(srcdir)/misc/TestBigNastyBuffer.xml \
-	$(srcdir)/misc/TestSameDirection.xml
+	$(srcdir)/tests/misc/TestBigNastyBuffer.xml \
+	$(srcdir)/tests/misc/TestSameDirection.xml
commit e7e4a239771cf361964a276f65bff45f56ba3bec
Date:   Mon Mar 25 20:58:55 2019 -0400
    Install git2cl for Travis autotools builds
diff --git a/.travis.yml b/.travis.yml
index c772453..7f6d5b0 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -39,7 +39,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-7','ccache']
+          packages: ['g++-7','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
@@ -51,7 +51,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-7-multilib','gcc-7-multilib','g++-multilib','gcc-multilib','ccache']
+          packages: ['g++-7-multilib','gcc-7-multilib','g++-multilib','gcc-multilib','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=g++-7 && ARCH=-m32 && CC=gcc-7"
@@ -75,7 +75,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-4.8','ccache']
+          packages: ['g++-4.8','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
@@ -87,7 +87,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache']
+          packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m32 && CC=gcc-4.8"
@@ -111,7 +111,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['clang-3.9','ccache']
+          packages: ['clang-3.9','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
@@ -123,7 +123,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['clang','ccache']
+          packages: ['clang','ccache','git2cl']
       env:
         - E="TOOL=autotools && CXX=clang++ && ARCH=-m64 && CC=clang"
commit 6f9916f751954904b1f6b98e0398eebff9021a11
Date:   Mon Mar 25 16:53:15 2019 -0400
    Run make distcheck on Travis
diff --git a/tools/ci/common.sh b/tools/ci/common.sh
index 5611b0e..91deae1 100644
--- a/tools/ci/common.sh
+++ b/tools/ci/common.sh
@@ -33,10 +33,3 @@ run_make()
     [ $TCI_NUMTHREADS -gt 0 ] && make -j $TCI_NUMTHREADS || make
-run_test()
-    [ -f CMakeCache.txt ] && \
-        ctest --output-on-failure . || \
-        make check
diff --git a/tools/ci/script_autotools.sh b/tools/ci/script_autotools.sh
index 4d4daf0..1cb8804 100755
--- a/tools/ci/script_autotools.sh
+++ b/tools/ci/script_autotools.sh
@@ -6,7 +6,7 @@
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
-# by the Free Software Foundation.
+# by the Free Software Foundation.
 # See the COPYING file for more information.
 source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
@@ -16,4 +16,5 @@ cd ${TRAVIS_BUILD_DIR}
 cd -
 ${TRAVIS_BUILD_DIR}/configure
 run_make
-run_test
+make check
+make distcheck
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index 2400418..22e1eed 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -6,11 +6,11 @@
 cmake ${TRAVIS_BUILD_DIR}
 run_make
-run_test
+ctest --output-on-failure .
Summary of changes:
 .travis.yml                                   | 12 ++++++------
 include/geos/operation/polygonize/Makefile.am | 10 +++++-----
 include/geos/operation/valid/Makefile.am      |  9 +++++----
 tests/xmltester/Makefile.am                   |  4 ++--
 tools/ci/common.sh                            |  7 -------
 tools/ci/script_autotools.sh                  |  5 +++--
 tools/ci/script_cmake.sh                      |  4 ++--
 7 files changed, 23 insertions(+), 28 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
