[geos-commits] [SCM] GEOS branch master updated. 8a99c2f916964a98fe60725ed7c8d0da92a1e79b
git at osgeo.org
git at osgeo.org
Tue May 21 06:16:31 PDT 2019
the project "GEOS".
via 8a99c2f916964a98fe60725ed7c8d0da92a1e79b (commit)
via d7b6fb3c14e18f5b356278bf7b808ab23da1658b (commit)
via 05ef63fce384f3de76698abf50b427ac36e665cd (commit)
from e2057ccb8302429d979c305cbb0c453e27434c6c (commit)
revisions in full, below.
commit 8a99c2f916964a98fe60725ed7c8d0da92a1e79b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu May 16 16:31:28 2019 -0500
Add geos_revision.h back to dist files
diff --git a/Makefile.am b/Makefile.am
index ee5c238..9f8991e 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -30,6 +30,7 @@ EXTRA_DIST = acsite.m4 .editorconfig \
cmake/GetGitRevision.cmake \
cmake/cmake_uninstall.cmake.in \
cmake/geos-config.cmake \
+ geos_revision.h \
README.md
ACLOCAL_AMFLAGS = -I macros
commit d7b6fb3c14e18f5b356278bf7b808ab23da1658b
Merge: e2057cc 05ef63f
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue May 21 09:13:46 2019 -0400
Merge remote-tracking branch 'origin/reduce-travis-matrix'
commit 05ef63fce384f3de76698abf50b427ac36e665cd
Date: Sat May 18 22:30:35 2019 -0400
Reduce Travis build matrix
There is no need to test each compiler/architecture combination using
both build systems. This commit uses CMake as the primary build system
for Travis (since it is significantly faster) and includes one autotools
build for a single compiler/architecture to verify that the autotools
system can continue to be used.
diff --git a/.travis.yml b/.travis.yml
index 77f2a46..f02b214 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -51,18 +51,6 @@ matrix:
addons:
apt:
sources: *sources
- packages: ['g++-7-multilib','gcc-7-multilib','g++-multilib','gcc-multilib','ccache','git2cl']
- env:
- - E="TOOL=autotools && CXX=g++-7 && ARCH=-m32 && CC=gcc-7"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
packages: ['g++-4.8','cmake','ccache']
env:
- E="TOOL=cmake && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
@@ -75,18 +63,6 @@ matrix:
addons:
apt:
sources: *sources
- packages: ['g++-4.8','ccache','git2cl']
- env:
- - E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache','git2cl']
env:
- E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m32 && CC=gcc-4.8"
@@ -111,30 +87,6 @@ matrix:
addons:
apt:
sources: *sources
- packages: ['clang-3.9','ccache','git2cl']
- env:
- - E="TOOL=autotools && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
- packages: ['clang','ccache','git2cl']
- env:
- - E="TOOL=autotools && CXX=clang++ && ARCH=-m64 && CC=clang"
- - os: linux
- cache:
- apt: true
- directories:
- - $HOME/.ccache
- addons:
- apt:
- sources: *sources
packages: ['clang','cmake','ccache']
env:
- E="TOOL=cmake && CXX=clang++ && ARCH=-m64 && CC=clang"
Summary of changes:
.travis.yml | 48 ------------------------------------------------
Makefile.am | 1 +
2 files changed, 1 insertion(+), 48 deletions(-)
hooks/post-receive
More information about the geos-commits
