[geos-commits] [SCM] GEOS branch master updated. ae73bc45bbad44703ed0532b64ed0c2440a9cf90
git at osgeo.org
git at osgeo.org
Tue May 21 08:23:34 PDT 2019
the project "GEOS".
via ae73bc45bbad44703ed0532b64ed0c2440a9cf90 (commit)
from 8a99c2f916964a98fe60725ed7c8d0da92a1e79b (commit)
revisions in full, below.
commit ae73bc45bbad44703ed0532b64ed0c2440a9cf90
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Dec 4 17:25:19 2018 -0500
Remove unstable API warnings for tests
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index a809e5c..ebff39f 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -11,6 +11,7 @@
add_executable(test_bug234 bug234.cpp)
target_link_libraries(test_bug234 PRIVATE geos)
add_test(NAME test_bug234 COMMAND test_bug234)
+target_compile_definitions(test_bug234 PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_executable(test_sweep_line_speed)
target_sources(test_sweep_line_speed
@@ -18,3 +19,4 @@ target_sources(test_sweep_line_speed
TestSweepLineSpeed.cpp
GeometryTestFactory.cpp)
target_link_libraries(test_sweep_line_speed PRIVATE geos)
+target_compile_definitions(test_sweep_line_speed PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/CMakeLists.txt b/tests/perf/CMakeLists.txt
index 11dc524..378f744 100644
--- a/tests/perf/CMakeLists.txt
+++ b/tests/perf/CMakeLists.txt
@@ -11,6 +11,7 @@
add_executable(test_perf_class_sizes ClassSizes.cpp)
target_link_libraries(test_perf_class_sizes PRIVATE geos)
add_test(NAME test_perf_class_sizes COMMAND test_perf_class_sizes)
+target_compile_definitions(test_perf_class_sizes PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_subdirectory(operation)
add_subdirectory(capi)
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index 3b85d89..014a4cc 100644
--- a/tests/perf/capi/CMakeLists.txt
+++ b/tests/perf/capi/CMakeLists.txt
@@ -17,3 +17,4 @@ target_include_directories(test_perf_memleak_mp_prep
$<BUILD_INTERFACE:${CMAKE_BINARY_DIR}/include>)
target_link_libraries(test_perf_memleak_mp_prep PRIVATE geos_c)
add_test(NAME test_perf_memleak_mp_prep COMMAND test_perf_memleak_mp_prep)
+target_compile_definitions(test_perf_memleak_mp_prep PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/operation/buffer/CMakeLists.txt b/tests/perf/operation/buffer/CMakeLists.txt
index de937de..b09efe9 100644
--- a/tests/perf/operation/buffer/CMakeLists.txt
+++ b/tests/perf/operation/buffer/CMakeLists.txt
@@ -11,3 +11,4 @@
add_executable(test_perf_iterated_buffer IteratedBufferStressTest.cpp)
target_link_libraries(test_perf_iterated_buffer PRIVATE geos)
add_test(NAME test_perf_iterated_buffer COMMAND test_perf_iterated_buffer)
+target_compile_definitions(test_perf_iterated_buffer PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/perf/operation/predicate/CMakeLists.txt b/tests/perf/operation/predicate/CMakeLists.txt
index 2ce3624..72f7a8a 100644
--- a/tests/perf/operation/predicate/CMakeLists.txt
+++ b/tests/perf/operation/predicate/CMakeLists.txt
@@ -11,3 +11,4 @@
add_executable(test_perf_rectangle_intersects RectangleIntersectsPerfTest.cpp)
target_link_libraries(test_perf_rectangle_intersects PRIVATE geos)
add_test(NAME test_perf_rectangle_intersects COMMAND test_perf_rectangle_intersects)
+target_compile_definitions(test_perf_rectangle_intersects PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 307b561..5926cef 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -17,4 +17,6 @@ target_include_directories(test_geos_unit
PRIVATE
$<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
+target_compile_definitions(test_geos_unit PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_test(NAME test_geos_unit COMMAND test_geos_unit)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 9fea5aa..3d41ce2 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -11,6 +11,7 @@
add_executable(test_simplewkttester SimpleWKTTester.cpp)
target_link_libraries(test_simplewkttester PRIVATE geos)
+target_compile_definitions(test_simplewkttester PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
add_executable(test_xmltester)
target_sources(test_xmltester
@@ -24,6 +25,7 @@ target_link_libraries(test_xmltester PRIVATE geos)
target_include_directories(test_xmltester
PRIVATE
$<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
+target_compile_definitions(test_xmltester PRIVATE "USE_UNSTABLE_GEOS_CPP_API")
file(GLOB_RECURSE _tests ${CMAKE_CURRENT_LIST_DIR}/tests/*.xml CONFIGURE_DEPEND)
list(FILTER _tests EXCLUDE REGEX failure)
Summary of changes:
tests/bigtest/CMakeLists.txt | 2 ++
tests/perf/CMakeLists.txt | 1 +
tests/perf/capi/CMakeLists.txt | 1 +
tests/perf/operation/buffer/CMakeLists.txt | 1 +
tests/perf/operation/predicate/CMakeLists.txt | 1 +
tests/unit/CMakeLists.txt | 2 ++
tests/xmltester/CMakeLists.txt | 2 ++
7 files changed, 10 insertions(+)
hooks/post-receive
More information about the geos-commits
