[geos-commits] [SCM] GEOS branch master updated. 6820ce966014f59880f71fa01dda6ddf64e4beb1
git at osgeo.org
git at osgeo.org
Wed May 22 06:10:24 PDT 2019
the project "GEOS".
via 6820ce966014f59880f71fa01dda6ddf64e4beb1 (commit)
via 5b889fad7344928da223ed08169d64de1fda6f18 (commit)
via 34e54992be3147a9e7aa8758fcd32308bc97ab9f (commit)
from f552ee8bdd85b5d2b422879d5a81093591d7bb0e (commit)
revisions in full, below.
commit 6820ce966014f59880f71fa01dda6ddf64e4beb1
Merge: f552ee8 5b889fa
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed May 22 09:10:07 2019 -0400
Merge branch 'readme-updates'
commit 5b889fad7344928da223ed08169d64de1fda6f18
Date: Tue May 21 15:23:41 2019 -0400
Update Visual Studio instructions in README.md [ci skip]
NMake Makefiles are no longer supported.
diff --git a/README.md b/README.md
index 5f843ab..e9a0364 100644
--- a/README.md
+++ b/README.md
@@ -62,24 +62,8 @@ check`.
### Microsoft Windows
-If you use Microsoft Visual C++ (7.1 or later) compiler, you can build
-GEOS using NMAKE program and provided `makefile.vc` files.
-If you are building from SVN or GIT checkout, first run: `autogen.bat`
-Then:
- nmake /f makefile.vc MSVC_VER=1400
-where 1400 is version number of Visual C++ compiler, here Visual C++ 8.0
-from Visual Studio 2005 (supported versions are 1300, 1310, 1400, 1500,
-1600, 1700, 1800 and 1900).
-The bootstrap.bat step is required to generate a couple of header files.
-In order to build debug configuration of GEOS, additional flag `DEBUG=1`
-is required:
- nmake /f makefile.vc MSVC_VER=1400 DEBUG=1
+GEOS can be built with Microsoft Visual C++ by opening the `CMakeLists.txt` in
+the project root using `File > Open > CMake`.
## Client applications
commit 34e54992be3147a9e7aa8758fcd32308bc97ab9f
Date: Tue May 21 09:58:58 2019 -0400
Some updates to README [ci skip]
index 8f6d012..5f843ab 100644
--- a/README.md
+++ b/README.md
@@ -1,7 +1,14 @@
GEOS -- Geometry Engine, Open Source
-Project homepage: http://geos.osgeo.org/
+GEOS is a C++11 library for performing operations on two-dimensional vector
+geometries. It is primarily a port of the [JTS Topology
+Suite](https://github.com/locationtech/jts) Java library. It provides many of
+the algorithms used by [PostGIS](http://www.postgis.net/), the
+[Shapely](https://pypi.org/project/Shapely/) package for Python, the
+[sf](https://github.com/r-spatial/sf) package for R, and others.
+More information is available the [project homepage](https://trac.osgeo.org/geos).
## Build status
@@ -11,35 +18,47 @@ Project homepage: http://geos.osgeo.org/
| 3.7 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [](https://drone.osgeo.org/geos/geos?branch=3.7) | [](https://travis-ci.com/libgeos/geos?branch=3.7) | [](https://gitlab.com/geos/libgeos/commits/3.7) | [](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) ||
| 3.6 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.6/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.6/) | [](https://drone.osgeo.org/geos/geos?branch=svn-3.6) | [](https://travis-ci.com/libgeos/geos?branch=svn-3.6) | [](https://gitlab.com/geos/libgeos/commits/svn-3.6) | [](https://ci.appveyor.com/project/dbaston/geos/branch/svn-3.6) |
-More on: https://trac.osgeo.org/geos#BuildandInstall
-## Building, testing, installing
+## Building GEOS From Source
### Prerequisites
-Building GEOS requires a C++11 compiler
+GEOS has no external library dependencies and can be built with any C++11
+compiler.
### Unix
-#### Gen Buildchain
+GEOS can be built on Unix systems using either the autotools or CMake build
+systems.
+#### Using Autotools:
+When building GEOS using autotools, a `configure` script must first be generated
+using the `autogen.sh` file included in the root of the repository:
+ ./autogen.sh
-##### Using Autotools:
+An out-of-tree build can then be initiated by creating a subdirectory and
+running the generated `configure` script from that subdirectory:
- ./autogen.sh # in ${srcdir}, if obtained from SVN or GIT
- (mkdir obj && cd obj && ../configure)
+ mkdir obj && cd obj && ../configure
-##### Using CMake:
+Once the `configure` script has run, GEOS can be built by running `make` and
+installed by running `make install`. The test suite can be run using `make
+check`.
- (mkdir build && cd build && cmake ..)
+#### Using CMake:
-#### Build (both Autotools and CMake)
+To build `GEOS` using CMake, create a build directory and run the `cmake` command
+from that location:
- make
- make check
- make install # (as root, assuming PREFIX is not writable by the build user)
+ mkdir build && cd build && cmake -DCMAKE_BUILD_TYPE=Release ..
- On a GNU/Linux system, if installed in a system prefix:
- ldconfig # as root
+Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
+optimizations.
+Once the `cmake` tool has run, GEOS can be built by running `make` and
+check`.
@@ -64,41 +83,56 @@ is required:
-### Using the C interface (recommended)
-GEOS promises long term stability of C API
+### Using the C interface
-The C library uses the C++ interface, but the C library follows
-normal ABI-change-sensitive versioning, so programs that link only
-against the C library should work without relinking when GEOS is upgraded.
+GEOS promises long-term stability of the C API. In general, successive releases
+of the C API may add new functions but will not remove or change existing types
+or function signatures. The C library uses the C++ interface, but the C library
+follows normal ABI-change-sensitive versioning, so programs that link only
+against the C library should work without relinking when GEOS is upgraded. For
+this reason, it is recommended to use the C API for software that is intended
+to be dynamically linked to a system install of GEOS.
-To compile programs against the C lib (recommended):
+The `geos-config` program can be used to determine appropriate compiler and
+linker flags for building against the C library:
CFLAGS += `geos-config --cflags`
LDFLAGS += `geos-config --ldflags` -lgeos_c
- #include <geos_c.h>
-Example usage:
+All functionality of the C API is available through the `geos_c.h` header file.
- capi/geostest.c contains basic usage examples.
+Documentation for the C API is provided via comments in the `geos_c.h` header file.
+C API usage examples can be found in the GEOS unit tests and in the source
+code of software that uses GEOS, such as PostGIS and the sf package for R.
-### Using the C++ interface (no stability promise)
+### Using the C++ interface
-Developers who decide to use the C++ interface should be aware GEOS
-does not promise API or ABI stability of C++ API between releases.
-Moreover C++ API/ABI breaking changes may not even be announced
-or include in the NEWS file
+The C++ interface to GEOS provides a more natural API for C++ programs, as well
+as additional functionality that has not been exposed in the C API. However,
+developers who decide to use the C++ interface should be aware that GEOS does
+not promise API or ABI stability of the C++ API between releases. Breaking
+changes in the C++ API/ABI are not typically announced or included in the NEWS
+file.
-The C++ library name will change on every minor release because
-it is too hard to know if there have been ABI changes.
+The C++ library name will change on every minor release.
-To compile programs against the C++ lib:
+linker flags for building against the C++ library:
+A compiler warning may be issued when building against the C++ library. To remove
+the compiler warning, define `USE_UNSTABLE_GEOS_CPP_API` somewhere in the program.
+Commonly-used functionality of GEOS is available in the `geos.h` header file.
+Less-common functionality can be accessed by including headers for individual
+classes, e.g. `#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>`.
#include <geos.h>
-Basic usage examples can be found in `doc/example.cpp`.
+Documentation for the C++ API is available at https://geos.osgeo.org/doxygen/, and
+basic C++ usage examples can be found in `doc/example.cpp`.
### Scripting language bindings
@@ -110,10 +144,9 @@ when configuring:
./configure .. --enable-ruby
#### PHP
-Since version 3.6.0 PHP bindings are not included in the core
-library anymore but available as a separate project:
-* https://git.osgeo.org/gitea/geos/php-geos
+PHP bindings for GEOS are available from the
+[php-geos](https://git.osgeo.org/gitea/geos/php-geos) project:
#### Python
Since version 3.0, the Python bindings are unsupported. Recommended options:
Summary of changes:
README.md | 125 +++++++++++++++++++++++++++++++++++---------------------------
1 file changed, 71 insertions(+), 54 deletions(-)
hooks/post-receive
More information about the geos-commits
