[geos-commits] [SCM] GEOS branch master updated. 0d4d08f0d11eff4e331aead0d25df8fe72f451f9
git at osgeo.org
git at osgeo.org
Wed May 22 08:07:06 PDT 2019
the project "GEOS".
via 0d4d08f0d11eff4e331aead0d25df8fe72f451f9 (commit)
via 5364af8387fdf480bff50e8caa1956e950721e38 (commit)
via 3732058a44e0ab554b91a628750e5d97bcab9ccc (commit)
via 364ce2403a5b550b7cee38fcedf751a662644b4b (commit)
via 8188abd3b7ea5e522d2700b53e0fde1e14cdce20 (commit)
via efd3fd12652f6c53680be815e36e22571fe5b1e5 (commit)
from 6820ce966014f59880f71fa01dda6ddf64e4beb1 (commit)
revisions in full, below.
commit 0d4d08f0d11eff4e331aead0d25df8fe72f451f9
Merge: 6820ce9 5364af8
Author: Dan Baston <dbaston at isciences.com>
Date: Wed May 22 11:05:41 2019 -0400
Merge remote-tracking branch 'pramsey/modern-cmake'
commit 5364af8387fdf480bff50e8caa1956e950721e38
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu May 16 17:02:44 2019 -0500
Change bigtest to add_executable() syntax
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index a809e5c..8526a6a 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -12,9 +12,7 @@ add_executable(test_bug234 bug234.cpp)
target_link_libraries(test_bug234 PRIVATE geos)
add_test(NAME test_bug234 COMMAND test_bug234)
-add_executable(test_sweep_line_speed)
-target_sources(test_sweep_line_speed
- PRIVATE
+add_executable(test_sweep_line_speed
TestSweepLineSpeed.cpp
GeometryTestFactory.cpp)
target_link_libraries(test_sweep_line_speed PRIVATE geos)
commit 3732058a44e0ab554b91a628750e5d97bcab9ccc
Date: Thu May 16 16:51:35 2019 -0500
Go to old Cmake syntax for add_executable()
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 1908edb..2f49cf1 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -12,9 +12,7 @@
add_executable(test_simplewkttester SimpleWKTTester.cpp)
target_link_libraries(test_simplewkttester PRIVATE geos)
-add_executable(test_xmltester "")
-target_sources(test_xmltester
- PRIVATE
+add_executable(test_xmltester
XMLTester.cpp
BufferResultMatcher.cpp
SingleSidedBufferResultMatcher.cpp
commit 364ce2403a5b550b7cee38fcedf751a662644b4b
Date: Thu May 16 16:44:39 2019 -0500
Use slightly older CMake syntax in add_executable()
index 9fea5aa..1908edb 100644
@@ -12,7 +12,7 @@
-add_executable(test_xmltester)
+add_executable(test_xmltester "")
PRIVATE
XMLTester.cpp
commit 8188abd3b7ea5e522d2700b53e0fde1e14cdce20
Date: Thu May 16 16:31:28 2019 -0500
Add geos_revision.h back to dist files
diff --git a/Makefile.am b/Makefile.am
index ee5c238..9f8991e 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -30,6 +30,7 @@ EXTRA_DIST = acsite.m4 .editorconfig \
cmake/GetGitRevision.cmake \
cmake/cmake_uninstall.cmake.in \
cmake/geos-config.cmake \
+ geos_revision.h \
README.md
ACLOCAL_AMFLAGS = -I macros
commit efd3fd12652f6c53680be815e36e22571fe5b1e5
Date: Thu May 16 16:26:50 2019 -0500
Emit cmake version in CI
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index 22e1eed..069d392 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -11,6 +11,8 @@
source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
+cmake --version
cmake ${TRAVIS_BUILD_DIR}
run_make
ctest --output-on-failure .
Summary of changes:
tests/bigtest/CMakeLists.txt | 4 +---
tests/xmltester/CMakeLists.txt | 4 +---
tools/ci/script_cmake.sh | 2 ++
3 files changed, 4 insertions(+), 6 deletions(-)
hooks/post-receive
More information about the geos-commits
