[geos-commits] [SCM] GEOS branch master updated. 3bd25055aaa0f50cf4a773d95172ef150be3bca9
git at osgeo.org
git at osgeo.org
Wed May 22 08:42:45 PDT 2019
the project "GEOS".
via 3bd25055aaa0f50cf4a773d95172ef150be3bca9 (commit)
from 0d4d08f0d11eff4e331aead0d25df8fe72f451f9 (commit)
revisions in full, below.
commit 3bd25055aaa0f50cf4a773d95172ef150be3bca9
Author: Sandro Santilli <strk at kbt.io>
Date: Wed May 22 17:42:21 2019 +0200
Convert test for bug234 into an XMLTeste
Tweaks both autotools and CMake accordingly
diff --git a/tests/bigtest/CMakeLists.txt b/tests/bigtest/CMakeLists.txt
index 8526a6a..c8759ae 100644
--- a/tests/bigtest/CMakeLists.txt
+++ b/tests/bigtest/CMakeLists.txt
@@ -8,9 +8,6 @@
# by the Free Software Foundation.
# See the COPYING file for more information.
-add_executable(test_bug234 bug234.cpp)
-target_link_libraries(test_bug234 PRIVATE geos)
-add_test(NAME test_bug234 COMMAND test_bug234)
add_executable(test_sweep_line_speed
TestSweepLineSpeed.cpp
diff --git a/tests/bigtest/Makefile.am b/tests/bigtest/Makefile.am
index b06e4e0..bc9eae2 100644
--- a/tests/bigtest/Makefile.am
+++ b/tests/bigtest/Makefile.am
@@ -5,8 +5,7 @@ prefix=@prefix@
top_srcdir=@top_srcdir@
top_builddir=@top_builddir@
-check_PROGRAMS = bug234
-check_PROGRAMS += TestSweepLineSpeed
+check_PROGRAMS = TestSweepLineSpeed
LIBS = $(top_builddir)/src/libgeos.la
# -lmpatrol -lbfd -lintl -liberty -limagehlp
@@ -14,9 +13,6 @@ LIBS = $(top_builddir)/src/libgeos.la
TestSweepLineSpeed_SOURCES = TestSweepLineSpeed.cpp GeometryTestFactory.cpp bigtest.h
TestSweepLineSpeed_LDADD = $(LIBS)
-bug234_SOURCES = bug234.cpp
-bug234_LDADD = $(LIBS)
AM_CPPFLAGS = -I$(top_srcdir)/include
EXTRA_DIST = CMakeLists.txt
diff --git a/tests/bigtest/bug234.cpp b/tests/bigtest/bug234.cpp
deleted file mode 100644
index 79b75e8..0000000
--- a/tests/bigtest/bug234.cpp
+++ /dev/null
@@ -1,51 +0,0 @@
-#include <vector>
-#include "geos/geom/GeometryFactory.h"
-#include "geos/geom/Geometry.h"
-#include "geos/geom/Coordinate.h"
-#include "geos/geom/CoordinateArraySequence.h"
-#include "geos/geom/LinearRing.h"
-#include "geos/geom/Polygon.h"
-#include "geos/geom/MultiPolygon.h"
-using namespace geos::geom;
-using namespace std;
-int
-main()
- GeometryFactory::Ptr factory = GeometryFactory::create();
- vector< Geometry* >* polys1 = new vector<Geometry*>();
- vector< Geometry* >* polys2 = new vector<Geometry*>();
- vector< Geometry* >* holes1 = new vector<Geometry*>();
- CoordinateArraySequence coords1;
- coords1.add(Coordinate(1, 1));
- coords1.add(Coordinate(1, 5));
- coords1.add(Coordinate(5, 5));
- coords1.add(Coordinate(5, 1));
- holes1->push_back(factory->createLinearRing());
- polys1->push_back(factory->createPolygon(factory->createLinearRing(coords1), holes1));
- CoordinateArraySequence coords2;
- coords2.add(Coordinate(3, 3));
- coords2.add(Coordinate(3, 4));
- coords2.add(Coordinate(4, 4));
- coords2.add(Coordinate(4, 3));
- polys2->push_back(factory->createPolygon(factory->createLinearRing(coords2), new vector<Geometry*>));
- MultiPolygon* mpoly1 = factory->createMultiPolygon(polys1);
- MultiPolygon* mpoly2 = factory->createMultiPolygon(polys2);
- cout << " Mpoly1: " << mpoly1->toString() << endl;
- cout << " Mpoly2: " << mpoly2->toString() << endl;
- Geometry* intersection = mpoly1->intersection(mpoly2);
- cout << "Intersection: " << intersection->toString() << endl;
- delete mpoly1;
- delete mpoly2;
- delete intersection;
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index ff96f47..81e727f 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -82,6 +82,7 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/robust/TestRobustRelate.xml \
$(srcdir)/tests/issue/issue-geos-176.xml \
$(srcdir)/tests/issue/issue-geos-188.xml \
+ $(srcdir)/tests/issue/issue-geos-234.xml \
$(srcdir)/tests/issue/issue-geos-244.xml \
$(srcdir)/tests/issue/issue-geos-275.xml \
$(srcdir)/tests/issue/issue-geos-350.xml \
diff --git a/tests/xmltester/tests/issue/issue-geos-234.xml b/tests/xmltester/tests/issue/issue-geos-234.xml
new file mode 100644
index 0000000..ad25099
--- /dev/null
+++ b/tests/xmltester/tests/issue/issue-geos-234.xml
@@ -0,0 +1,26 @@
+<run>
+ <desc>
+http://trac.osgeo.org/geos/ticket/234
+ </desc>
+ <precisionModel type="FLOATING" />
+<case>
+ <desc>
+Assertion failed on intersecting collection with empty component
+ </desc>
+ <a>
+MULTIPOLYGON (((1 1, 1 5, 5 5, 5 1, 1 1), EMPTY))
+ </a>
+ <b>
+MULTIPOLYGON (((3 3, 3 4, 4 4, 4 3, 3 3)))
+ </b>
+<test>
+ <op name="intersection" arg1="A" arg2="B">
+POLYGON ((3 3, 3 4, 4 4, 4 3, 3 3))
+ </op>
+</test>
+</case>
+</run>
Summary of changes:
tests/bigtest/CMakeLists.txt | 3 --
tests/bigtest/Makefile.am | 6 +--
tests/bigtest/bug234.cpp | 51 --------------------------
tests/xmltester/Makefile.am | 1 +
tests/xmltester/tests/issue/issue-geos-234.xml | 26 +++++++++++++
5 files changed, 28 insertions(+), 59 deletions(-)
delete mode 100644 tests/bigtest/bug234.cpp
create mode 100644 tests/xmltester/tests/issue/issue-geos-234.xml
hooks/post-receive
More information about the geos-commits
