[geos-commits] [SCM] GEOS branch master updated. 876eb551d6c32fb60f71e0e72bbb4d92e53cda92
git at osgeo.org
git at osgeo.org
Mon May 27 08:10:02 PDT 2019
the project "GEOS".
via 876eb551d6c32fb60f71e0e72bbb4d92e53cda92 (commit)
from a5bf88a6bd882209a3e2bb78c54b4886988d51bb (commit)
revisions in full, below.
commit 876eb551d6c32fb60f71e0e72bbb4d92e53cda92
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon May 27 08:09:54 2019 -0700
Minor edits
diff --git a/README.md b/README.md
index 98bc55e..9488768 100644
--- a/README.md
+++ b/README.md
@@ -126,9 +126,10 @@ linker flags for building against the C library:
All functionality of the C API is available through the `geos_c.h` header file.
-Documentation for the C API is provided via comments in the `geos_c.h` header file.
-C API usage examples can be found in the GEOS unit tests and in the source
-code of software that uses GEOS, such as PostGIS and the sf package for R.
+Documentation for the C API is provided via comments in the `geos_c.h` header
+file. C API usage examples can be found in the GEOS unit tests and in the
+source code of software that uses GEOS, such as PostGIS and the sf package
+for R.
### Using the C++ interface
@@ -147,39 +148,41 @@ linker flags for building against the C++ library:
CFLAGS += `geos-config --cflags`
LDFLAGS += `geos-config --ldflags` -lgeos
-A compiler warning may be issued when building against the C++ library. To remove
-the compiler warning, define `USE_UNSTABLE_GEOS_CPP_API` somewhere in the program.
+A compiler warning may be issued when building against the C++ library. To
+remove the compiler warning, define `USE_UNSTABLE_GEOS_CPP_API` somewhere
+in the program.
-Commonly-used functionality of GEOS is available in the `geos.h` header file.
-Less-common functionality can be accessed by including headers for individual
+Commonly-used functionality of GEOS is available in the `geos.h` header file.
+Less-common functionality can be accessed by including headers for individual
classes, e.g. `#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>`.
#include <geos.h>
-Documentation for the C++ API is available at https://geos.osgeo.org/doxygen/, and
-basic C++ usage examples can be found in `doc/example.cpp`.
+Documentation for the C++ API is available at https://geos.osgeo.org/doxygen/,
+and basic C++ usage examples can be found in `doc/example.cpp`.
### Scripting language bindings
#### Ruby
-Ruby bindings are fully supported. To build, use the `--enable-ruby` option
+Ruby bindings are part of GEOS. To build, use the `--enable-ruby` option
when configuring:
./configure .. --enable-ruby
#### PHP
-PHP bindings for GEOS are available from the
-[php-geos](https://git.osgeo.org/gitea/geos/php-geos) project:
+PHP bindings for GEOS are available separately from
+[php-geos](https://git.osgeo.org/gitea/geos/php-geos).
#### Python
-Since version 3.0, the Python bindings are unsupported. Recommended options:
- 1. Become or recruit a new maintainer.
- 2. Use [Shapely](http://pypi.python.org/pypi/Shapely) with Python
- versions 2.4 or greater.
- 3. Call functions from `libgeos_c` via Python ctypes.
+Python bindings are available via:
+ 1. [Shapely](http://pypi.python.org/pypi/Shapely) package.
+ 2. Calling functions from `libgeos_c` via Python ctypes.
## Documentation
Summary of changes:
README.md | 37 ++++++++++++++++++++-----------------
1 file changed, 20 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
