[geos-commits] [SCM] GEOS branch master updated. c0f70dbc73906ae4c0b90954dfb3e030b7694d9d
git at osgeo.org
git at osgeo.org
Tue May 28 07:12:14 PDT 2019
the project "GEOS".
via c0f70dbc73906ae4c0b90954dfb3e030b7694d9d (commit)
via 872d902579fa11f22e7b2b6b23c415354f8ae9bb (commit)
from 876eb551d6c32fb60f71e0e72bbb4d92e53cda92 (commit)
revisions in full, below.
commit c0f70dbc73906ae4c0b90954dfb3e030b7694d9d
Merge: 876eb55 872d902
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue May 28 10:12:02 2019 -0400
Merge remote-tracking branch 'mloskot/ml/azure-pipelines'
commit 872d902579fa11f22e7b2b6b23c415354f8ae9bb
Author: Mateusz Ĺoskot <mateusz at loskot.net>
Date: Tue May 21 16:07:43 2019 +0200
Add CI builds on Azure Pipelines using CMake
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
new file mode 100644
index 0000000..d5b2eb6
--- /dev/null
+++ b/.azure-pipelines.yml
@@ -0,0 +1,292 @@
+# Azure Pipelines for GEOS
+# All builds are based on the CMake configuration.
+# Author: Mateusz Loskot <mateusz at loskot dot net>
+# trigger:
+# branches:
+# include:
+# - master
+# - bugfix/*
+# - feature/*
+# - fix/*
+# - pr/*
+pr:
+ branches:
+ include:
+ - master
+variables:
+ - name: BUILD_TYPE
+ value: Release
+stages:
+- stage: Test
+ jobs:
+ - job: 'Linux'
+ pool:
+ vmImage: 'ubuntu-16.04'
+ strategy:
+ matrix:
+ GCC 8:
+ CXXSTD: 11, 14, 17, 20
+ CXX: g++-8
+ PACKAGES: g++-8
+ GCC 7:
+ CXX: g++-7
+ PACKAGES: g++-7
+ GCC 6:
+ CXXSTD: 11, 14
+ CXX: g++-6
+ PACKAGES: g++-6
+ GCC 5:
+ CXXSTD: 11
+ CXX: g++-5
+ PACKAGES: g++-5
+ GCC 4.9:
+ CXXSTD: 11
+ CXX: g++-4.9
+ PACKAGES: g++-4.9
+ GCC 4.8:
+ CXXSTD: 11
+ CXX: g++-4.8
+ PACKAGES: g++-4.8
+ Clang 8:
+ CXX: clang++-8
+ PACKAGES: clang-8
+ LLVM_REPO: llvm-toolchain-xenial-8
+ Clang 7:
+ CXXSTD: 14, 17, 20
+ CXX: clang++-7
+ PACKAGES: clang-7
+ LLVM_REPO: llvm-toolchain-xenial-7
+ Clang 6:
+ CXX: clang++-6.0
+ PACKAGES: clang-6.0
+ LLVM_REPO: llvm-toolchain-xenial-6.0
+ Clang 5:
+ PACKAGES: clang-5.0
+ CXX: clang++-5.0
+ LLVM_REPO: llvm-toolchain-xenial-5.0
+ Clang 4:
+ CXXSTD: 11, 14
+ CXX: clang++-4.0
+ PACKAGES: clang-4.0
+ LLVM_REPO: llvm-toolchain-xenial-4.0
+ Clang 3.9:
+ CXXSTD: 11, 14
+ CXX: clang++-3.9
+ PACKAGES: clang-3.9
+ Clang 3.8:
+ CXX: clang++-3.8
+ CXXSTD: 11, 14
+ PACKAGES: clang-3.8
+ Clang 3.7:
+ CXXSTD: 11
+ CXX: clang++-3.7
+ PACKAGES: clang-3.7
+ Clang 3.6:
+ CXXSTD: 11
+ CXX: clang++-3.6
+ PACKAGES: clang-3.6
+ Clang 3.5:
+ CXXSTD: 11
+ CXX: clang++-3.5
+ PACKAGES: clang-3.5
+ steps:
+ - script: |
+ set -e
+ uname -a
+ sudo -E apt-add-repository -y "ppa:ubuntu-toolchain-r/test"
+ if test -n "${LLVM_REPO}" ; then
+ wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
+ sudo -E apt-add-repository "deb http://apt.llvm.org/xenial/ ${LLVM_REPO} main"
+ fi
+ sudo -E apt-get update
+ sudo -E apt-get -yq --no-install-suggests --no-install-recommends install cmake ${PACKAGES}
+ displayName: 'Install'
+ - script: |
+ set -e
+ mkdir build.cxx11
+ cd build.cxx11
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=11 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ cmake --build . --config $BUILD_TYPE
+ ctest -V --output-on-failure -C $BUILD_TYPE
+ displayName: 'Build C++11'
+ condition: contains(variables['CXXSTD'], '11')
+ - script: |
+ set -e
+ mkdir build.cxx14
+ cd build.cxx14
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=14 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ displayName: 'Build C++14'
+ condition: contains(variables['CXXSTD'], '14')
+ - script: |
+ set -e
+ mkdir build.cxx17
+ cd build.cxx17
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=17 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ displayName: 'Build C++17'
+ condition: contains(variables['CXXSTD'], '17')
+ - script: |
+ set -e
+ mkdir build.cxx20
+ cd build.cxx20
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=20 -DCMAKE_BUILD_TYPE=$BUILD_TYPE ..
+ displayName: 'Build C++20'
+ condition: contains(variables['CXXSTD'], '20')
+ - job: 'Windows'
+ strategy:
+ matrix:
+ VS 2019 C++20 Strict:
+ TOOLSET: msvc-14.2
+ CXXSTD: 20
+ CXXFLAGS: -permissive-
+ VM_IMAGE: 'windows-2019'
+ VS 2017 C++20 Strict:
+ TOOLSET: msvc-14.1
+ CXXSTD: 20
+ VM_IMAGE: 'vs2017-win2016'
+ VS 2017 C++17:
+ CXXSTD: 17
+ VS 2017 C++14:
+ CXXSTD: 14 # default
+ VS 2015 C++14:
+ TOOLSET: msvc-14.0
+ VM_IMAGE: 'vs2015-win2012r2'
+ pool:
+ vmImage: $(VM_IMAGE)
+ steps:
+ - powershell: |
+ Write-Host "Installing CMake 3.14.4"
+ Invoke-WebRequest https://cmake.org/files/v3.14/cmake-3.14.4-win64-x64.zip -OutFile C:\cmake-3.14.4-win64-x64.zip
+ Expand-Archive C:\cmake-3.14.4-win64-x64.zip -DestinationPath C:\
+ Rename-Item -Path C:\cmake-3.14.4-win64-x64 -NewName C:\cmake
+ Write-Host "##vso[task.prependpath]C:\cmake\bin"
+ - script: |
+ mkdir build.cxx%CXXSTD%
+ cd build.cxx%CXXSTD%
+ cmake --version
+ cmake -DCMAKE_CXX_STANDARD=%CXXSTD% -DBUILD_SHARED_LIBS=OFF ..
+ displayName: 'CMake'
+ - script: |
+ cmake --build . --config %BUILD_TYPE%
+ displayName: 'Build'
+ - script: |
+ ctest -V --output-on-failure -C %BUILD_TYPE%
+ displayName: 'Test'
+ - job: 'macOS'
+ pool:
+ vmImage: 'macOS-10.13'
+ strategy:
+ matrix:
+ Xcode 10.1:
+ TOOLSET: clang
+ XCODE_APP: /Applications/Xcode_10.1.app
+ Xcode 10.0:
+ XCODE_APP: /Applications/Xcode_10.app
+ Xcode 9.4.1:
+ XCODE_APP: /Applications/Xcode_9.4.1.app
+ Xcode 9.4:
+ XCODE_APP: /Applications/Xcode_9.4.app
+ Xcode 9.3.1:
+ XCODE_APP: /Applications/Xcode_9.3.1.app
+ Xcode 9.3:
+ CXXSTD: 11, 14
+ XCODE_APP: /Applications/Xcode_9.3.app
+ Xcode 9.2:
+ CXXSTD: 11, 14
+ XCODE_APP: /Applications/Xcode_9.2.app
+ Xcode 9.1:
+ CXXSTD: 11
+ XCODE_APP: /Applications/Xcode_9.1.app
+ Xcode 9.0.1:
+ CXXSTD: 11
+ XCODE_APP: /Applications/Xcode_9.0.1.app
+ Xcode 9.0:
+ CXXSTD: 11
+ XCODE_APP: /Applications/Xcode_9.app
+ Xcode 8.3.3:
+ CXXSTD: 11
+ XCODE_APP: /Applications/Xcode_8.3.3.app
+ steps:
+ - script: |
+ set -e
+ uname -a
+ sudo xcode-select -switch ${XCODE_APP}
+ which clang++
+ clang++ --version
+ displayName: Install
+ - script: |
+ set -e
+ mkdir build.cxx11
+ cd build.cxx11
+ cmake --version
+ - script: |
+ set -e
+ mkdir build.cxx14
+ cd build.cxx14
+ cmake --version
+ - script: |
+ set -e
+ mkdir build.cxx17
+ cd build.cxx17
+ cmake --version
+ - script: |
+ set -e
+ mkdir build.cxx20
+ cd build.cxx20
+ cmake --version
Summary of changes:
.azure-pipelines.yml | 292 +++++++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 292 insertions(+)
create mode 100644 .azure-pipelines.yml
hooks/post-receive
More information about the geos-commits
