[geos-commits] [SCM] GEOS branch master updated. c96422005f1bd2bff98e74f201e4a3a4328c85f2
git at osgeo.org
git at osgeo.org
Fri Nov 8 06:16:07 PST 2019
the project "GEOS".
via c96422005f1bd2bff98e74f201e4a3a4328c85f2 (commit)
via 698c97f490a1786994b1606f37a606818757582f (commit)
via 7be06d1dac9113b06d48edfad6752446d00546eb (commit)
via 962089ed871d3032e164fea4b42adc2d49e84143 (commit)
from 18be6c2dae08059ed901252d48ceefa1283b0c59 (commit)
revisions in full, below.
commit c96422005f1bd2bff98e74f201e4a3a4328c85f2
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Nov 5 21:51:10 2019 -0500
Speed up sort in SortedPackedIntervalRTree construction
diff --git a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
index 1025eca..bb5604e 100644
--- a/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
+++ b/src/index/intervalrtree/SortedPackedIntervalRTree.cpp
@@ -51,6 +51,15 @@ SortedPackedIntervalRTree::buildTree()
branches.reserve(leaves.size() - 1);
+ // sort the leaf nodes
+ std::sort(leaves.begin(), leaves.end(),
+ [](const IntervalRTreeLeafNode & n1, const IntervalRTreeLeafNode & n2) {
+ double mid1 = n1.getMin() + n1.getMax();
+ double mid2 = n2.getMin() + n2.getMax();
+ return mid1 > mid2;
// now group nodes into blocks of two and build tree up recursively
std::vector<const IntervalRTreeNode*> src{leaves.size()};
std::vector<const IntervalRTreeNode*> dest;
@@ -58,9 +67,6 @@ SortedPackedIntervalRTree::buildTree()
return &n;
- // sort the leaf nodes
- std::sort(src.begin(), src.end(), IntervalRTreeNode::compare);
while(true) {
buildLevel(src, dest);
commit 698c97f490a1786994b1606f37a606818757582f
Date: Tue Nov 5 21:28:50 2019 -0500
Presize segment vector in IntervalIndexedGeometry
diff --git a/src/algorithm/locate/IndexedPointInAreaLocator.cpp b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
index 96899a4..bbe6890 100644
--- a/src/algorithm/locate/IndexedPointInAreaLocator.cpp
+++ b/src/algorithm/locate/IndexedPointInAreaLocator.cpp
@@ -52,6 +52,13 @@ IndexedPointInAreaLocator::IntervalIndexedGeometry::init(const geom::Geometry& g
geom::LineString::ConstVect lines;
geom::util::LinearComponentExtracter::getLines(g, lines);
+ // pre-compute size of segment vector
+ size_t nsegs = 0;
+ for(const geom::LineString* line : lines) {
+ nsegs += line->getCoordinatesRO()->size() - 1;
+ segments.reserve(nsegs);
addLine(line->getCoordinatesRO());
commit 7be06d1dac9113b06d48edfad6752446d00546eb
Date: Tue Nov 5 21:19:15 2019 -0500
Inline SortedPackedIntervalRTree::insert
diff --git a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
index e12442a..0bab17e 100644
--- a/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
+++ b/include/geos/index/intervalrtree/SortedPackedIntervalRTree.h
@@ -19,6 +19,7 @@
#include <geos/index/intervalrtree/IntervalRTreeNode.h>
#include <geos/index/intervalrtree/IntervalRTreeBranchNode.h>
#include <geos/index/intervalrtree/IntervalRTreeLeafNode.h>
+#include <geos/util/UnsupportedOperationException.h>
// forward declarations
namespace geos {
@@ -84,7 +85,13 @@ public:
* @throw IllegalStateException if the index has already been queried
- void insert(double min, double max, void* item);
+ void insert(double min, double max, void* item) {
+ if(root != nullptr) {
+ throw util::UnsupportedOperationException("Index cannot be added to once it has been queried");
+ leaves.emplace_back(min, max, item);
* Search for intervals in the index which intersect the given closed interval
index 83b4829..1025eca 100644
@@ -17,7 +17,6 @@
#include <geos/index/ItemVisitor.h>
-#include <geos/util/UnsupportedOperationException.h>
#include <algorithm>
@@ -103,15 +102,6 @@ SortedPackedIntervalRTree::buildLevel(IntervalRTreeNode::ConstVect& src, Interva
// public:
-void
-SortedPackedIntervalRTree::insert(double min, double max, void* item)
- if(root != nullptr) {
- throw util::UnsupportedOperationException("Index cannot be added to once it has been queried");
- leaves.emplace_back(min, max, item);
void
SortedPackedIntervalRTree::query(double min, double max, index::ItemVisitor* visitor)
commit 962089ed871d3032e164fea4b42adc2d49e84143
Date: Tue Nov 5 21:18:05 2019 -0500
Initialize interval tree with known number of segments
index 181ecf5..96899a4 100644
@@ -56,6 +56,8 @@ IndexedPointInAreaLocator::IntervalIndexedGeometry::init(const geom::Geometry& g
+ index = index::intervalrtree::SortedPackedIntervalRTree(segments.size());
for(geom::LineSegment& seg : segments) {
index.insert(
std::min(seg.p0.y, seg.p1.y),
Summary of changes:
.../intervalrtree/SortedPackedIntervalRTree.h | 9 ++++++++-
src/algorithm/locate/IndexedPointInAreaLocator.cpp | 9 +++++++++
.../intervalrtree/SortedPackedIntervalRTree.cpp | 22 +++++++++-------------
3 files changed, 26 insertions(+), 14 deletions(-)
hooks/post-receive
More information about the geos-commits
