[geos-commits] [SCM] GEOS branch master updated. 388953bccc5fe1cb9196b0fd393a14988b8a3d84
git at osgeo.org
git at osgeo.org
Fri Nov 8 08:17:12 PST 2019
the project "GEOS".
via 388953bccc5fe1cb9196b0fd393a14988b8a3d84 (commit)
via cada197cb59846ae6803f1a90c9cbd573aa79239 (commit)
via a8e417b17cd1731cf875e1bfa1a4a8b08369eb60 (commit)
from c96422005f1bd2bff98e74f201e4a3a4328c85f2 (commit)
revisions in full, below.
commit 388953bccc5fe1cb9196b0fd393a14988b8a3d84
Merge: c964220 cada197
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Nov 8 11:16:37 2019 -0500
Merge branch 'trac-1001-alternate'
commit cada197cb59846ae6803f1a90c9cbd573aa79239
Date: Fri Oct 25 15:13:44 2019 -0400
Distinguish between 2D and 3D empty Points
diff --git a/include/geos/geom/FixedSizeCoordinateSequence.h b/include/geos/geom/FixedSizeCoordinateSequence.h
index 2bdcbb2..20e661d 100644
--- a/include/geos/geom/FixedSizeCoordinateSequence.h
+++ b/include/geos/geom/FixedSizeCoordinateSequence.h
@@ -35,9 +35,9 @@ namespace geom {
explicit FixedSizeCoordinateSequence(size_t dimension_in = 0) : dimension(dimension_in) {}
std::unique_ptr<CoordinateSequence> clone() const final override {
- auto seq = detail::make_unique<FixedSizeCoordinateSequence<N>>();
+ auto seq = detail::make_unique<FixedSizeCoordinateSequence<N>>(dimension);
seq->m_data = m_data;
- return std::unique_ptr<CoordinateSequence>(seq.release());
+ return std::move(seq); // move needed for gcc 4.8
const Coordinate& getAt(size_t i) const final override {
diff --git a/include/geos/geom/Point.h b/include/geos/geom/Point.h
index a631e70..bc84980 100644
--- a/include/geos/geom/Point.h
+++ b/include/geos/geom/Point.h
@@ -178,7 +178,9 @@ private:
* The <code>Coordinate</code> wrapped by this <code>Point</code>.
FixedSizeCoordinateSequence<1> coordinates;
- bool empty;
+ bool empty2d;
+ bool empty3d;
} // namespace geos::geom
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 3724503..864e883 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -41,18 +41,20 @@ using namespace std;
namespace geos {
namespace geom { // geos::geom
-const static FixedSizeCoordinateSequence<0> emptyCoords;
+const static FixedSizeCoordinateSequence<0> emptyCoords2d(2);
+const static FixedSizeCoordinateSequence<0> emptyCoords3d(3);
/*protected*/
Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
Geometry(factory),
- empty(false)
+ empty2d(false),
+ empty3d(false)
std::unique_ptr<CoordinateSequence> coords(newCoords);
if(coords == nullptr) {
- empty = true;
+ empty3d = true;
return;
@@ -60,14 +62,17 @@ Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
coordinates.setAt(coords->getAt(0), 0);
} else if (coords->getSize() > 1) {
throw util::IllegalArgumentException("Point coordinate list must contain a single element");
+ } else if (coords->getDimension() == 3) {
+ empty3d = true;
} else {
- empty = true;
+ empty2d = true;
Point::Point(const Coordinate & c, const GeometryFactory* factory) :
Geometry(factory),
- empty(false)
+ empty2d(false),
+ empty3d(false)
coordinates.setAt(c, 0);
@@ -77,7 +82,8 @@ Point::Point(const Point& p)
Geometry(p),
coordinates(p.coordinates),
- empty(p.empty)
+ empty2d(p.empty3d),
+ empty3d(p.empty3d)
@@ -90,13 +96,13 @@ Point::getCoordinates() const
size_t
Point::getNumPoints() const
- return empty ? 0 : 1;
+ return isEmpty() ? 0 : 1;
bool
Point::isEmpty() const
- return empty;
+ return empty2d || empty3d;
bool
@@ -153,7 +159,7 @@ Point::getZ() const
const Coordinate*
Point::getCoordinate() const
- return empty ? nullptr : &coordinates[0];
+ return isEmpty() ? nullptr : &coordinates[0];
string
@@ -288,8 +294,10 @@ Point::getGeometryTypeId() const
const CoordinateSequence*
Point::getCoordinatesRO() const
- if (isEmpty()) {
- return &emptyCoords;
+ if (empty2d) {
+ return &emptyCoords2d;
+ } else if (empty3d) {
+ return &emptyCoords3d;
return &coordinates;
diff --git a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
index 968c733..9987750 100644
--- a/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
+++ b/tests/unit/geom/FixedSizeCoordinateSequenceTest.cpp
@@ -124,4 +124,20 @@ void object::test<5>() {
ensure_equals(seq1_3d.getDimension(), 3ul);
+// test clone
+template<>
+template<>
+void object::test<6>
+ FixedSizeCoordinateSequence<1> a(2);
+ a.setAt({ 1, 2, 3 }, 0);
+ ensure_equals(a.getDimension(), 2);
+ auto b = a.clone();
+ ensure_equals(b->getDimension(), 2);
+ ensure(a.getAt(0).equals3D(b->getAt(0)));
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 883ad7b..67f085c 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -559,5 +559,26 @@ void object::test<44>
ensure_equals(empty_point_->getCoordinatesRO()->getSize(), 0u);
+// check dimensionality of empty points
+template<>
+template<>
+void object::test<45>
+ auto empty3d = factory_->createPoint();
+ ensure_equals(empty3d->getCoordinateDimension(), 3);
+ geos::geom::FixedSizeCoordinateSequence<0> seq2(2);
+ ensure_equals(seq2.getDimension(), 2u);
+ ensure_equals(factory_->createPoint(seq2)->getCoordinateDimension(), 2);
+ geos::geom::FixedSizeCoordinateSequence<0> seq3(3);
+ ensure_equals(seq3.getDimension(), 3u);
+ ensure_equals(factory_->createPoint(seq3)->getCoordinateDimension(), 3);
} // namespace tut
commit a8e417b17cd1731cf875e1bfa1a4a8b08369eb60
Date: Wed Oct 23 21:25:39 2019 -0400
Avoid returning size-1 CoordinateSequence from empty point
Fixes #1001
index 0db6b30..3724503 100644
@@ -41,6 +41,7 @@ using namespace std;
namespace geos {
+const static FixedSizeCoordinateSequence<0> emptyCoords;
/*protected*/
@@ -83,7 +84,7 @@ Point::Point(const Point& p)
- return coordinates.clone();
+ return getCoordinatesRO()->clone();
size_t
@@ -113,7 +114,7 @@ Point::getDimension() const
int
Point::getCoordinateDimension() const
- return (int) coordinates.getDimension();
+ return (int) getCoordinatesRO()->getDimension();
int
@@ -191,6 +192,9 @@ Point::apply_ro(CoordinateFilter* filter) const
void
Point::apply_rw(const CoordinateFilter* filter)
+ if (isEmpty()) {
+ return;
coordinates.apply_rw(filter);
@@ -284,6 +288,9 @@ Point::getGeometryTypeId() const
+ if (isEmpty()) {
+ return &emptyCoords;
index 4a91875..883ad7b 100644
@@ -549,5 +549,15 @@ void object::test<43>
ensure(!point_->isDimensionStrict(geos::geom::Dimension::A));
+// empty point has size-0 coordinate sequence
+template<>
+template<>
+void object::test<44>
+ ensure_equals(empty_point_->getCoordinates()->getSize(), 0u);
+ ensure_equals(empty_point_->getCoordinatesRO()->getSize(), 0u);
} // namespace tut
Summary of changes:
include/geos/geom/FixedSizeCoordinateSequence.h | 4 +--
include/geos/geom/Point.h | 4 ++-
src/geom/Point.cpp | 35 +++++++++++++++-------
.../unit/geom/FixedSizeCoordinateSequenceTest.cpp | 16 ++++++++++
tests/unit/geom/PointTest.cpp | 31 +++++++++++++++++++
5 files changed, 77 insertions(+), 13 deletions(-)
hooks/post-receive
More information about the geos-commits
