[geos-commits] [SCM] GEOS branch master updated. 6d7d21530f466ab36d62912ac5f2a2cdb5070700
git at osgeo.org
git at osgeo.org
Thu Oct 10 12:46:52 PDT 2019
the project "GEOS".
via 6d7d21530f466ab36d62912ac5f2a2cdb5070700 (commit)
via 398b0bd019e305ec76cd2730a6a1f11be8d54269 (commit)
via 695340f0ebccae7175622af107c8be7e638f8819 (commit)
via b624ffb5b4a5327effe83470fd245a9bb14a9dfe (commit)
via ecfeb6fa494f8fa5da9ad53d2e1a1da8551fd3de (commit)
from 8bc0ff9dc0a1036989238d1e01d1fa4c9f5df3c4 (commit)
revisions in full, below.
commit 6d7d21530f466ab36d62912ac5f2a2cdb5070700
Merge: 8bc0ff9 398b0bd
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu Oct 10 15:46:41 2019 -0400
Merge remote-tracking branch 'nilason/doublebits-tostring-implement'
commit 398b0bd019e305ec76cd2730a6a1f11be8d54269
Author: nila <n_larsson at yahoo.com>
Date: Fri Oct 4 12:08:44 2019 +0200
Update JTS port info
diff --git a/include/geos/index/quadtree/DoubleBits.h b/include/geos/index/quadtree/DoubleBits.h
index 4fa3351..9a00d90 100644
--- a/include/geos/index/quadtree/DoubleBits.h
+++ b/include/geos/index/quadtree/DoubleBits.h
@@ -12,7 +12,7 @@
- * Last port: index/quadtree/DoubleBits.java rev. 1.7 (JTS-1.10)
+ * Last port: index/quadtree/DoubleBits.java rev. 1.7 (JTS-1.16)
diff --git a/src/index/quadtree/DoubleBits.cpp b/src/index/quadtree/DoubleBits.cpp
index c64b24e..336d411 100644
--- a/src/index/quadtree/DoubleBits.cpp
+++ b/src/index/quadtree/DoubleBits.cpp
@@ -13,7 +13,7 @@
commit 695340f0ebccae7175622af107c8be7e638f8819
Date: Fri Oct 4 11:59:13 2019 +0200
Remove commented-out variable
following https://github.com/locationtech/jts/commit/f503345e5be88ab457076ecc96307a6dd18ad86c
index 2ab1abc..c64b24e 100644
@@ -157,7 +157,6 @@ int
DoubleBits::numCommonMantissaBits(const DoubleBits& db) const
for(int i = 0; i < 52; i++) {
- //int bitIndex=i+12;
if(getBit(i) != db.getBit(i)) {
return i;
commit b624ffb5b4a5327effe83470fd245a9bb14a9dfe
Date: Fri Oct 4 11:42:44 2019 +0200
Add toString test
diff --git a/tests/unit/index/quadtree/DoubleBitsTest.cpp b/tests/unit/index/quadtree/DoubleBitsTest.cpp
index 338c69e..f33a128 100644
--- a/tests/unit/index/quadtree/DoubleBitsTest.cpp
+++ b/tests/unit/index/quadtree/DoubleBitsTest.cpp
@@ -31,6 +31,19 @@ void object::test<1>
ensure_equals(DoubleBits::exponent(128.0), 7);
+// 2 - Test toString()
+template<>
+template<>
+void object::test<2>
+ ensure_equals(DoubleBits(-1).toString(),
+ "1 01111111111(0) 0000000000000000000000000000000000000000000000000000 [ -1.000000 ]");
+ ensure_equals(DoubleBits(8.0).toString(),
+ "0 10000000010(3) 0000000000000000000000000000000000000000000000000000 [ 8.000000 ]");
+ ensure_equals(DoubleBits(128.0).toString(),
+ "0 10000000110(7) 0000000000000000000000000000000000000000000000000000 [ 128.000000 ]");
} // namespace tut
commit ecfeb6fa494f8fa5da9ad53d2e1a1da8551fd3de
Date: Fri Oct 4 11:42:17 2019 +0200
Add implementation
index ec036de..2ab1abc 100644
@@ -22,6 +22,7 @@
#include <string>
#include <cstring>
+#include <bitset>
#if __STDC_IEC_559__
#define ASSUME_IEEE_DOUBLE 1
@@ -168,20 +169,16 @@ DoubleBits::numCommonMantissaBits(const DoubleBits& db) const
string
DoubleBits::toString() const
- // TODO: Fix it!
- return "FIXME: unimplemented DoubleBits::toString()";
- //String numStr = Long.toBinaryString(xBits);
- //// 64 zeroes!
- //String zero64 = "0000000000000000000000000000000000000000000000000000000000000000";
- //String padStr = zero64 + numStr;
- //String bitStr = padStr.substring(padStr.length() - 64);
- //String str = bitStr.substring(0, 1) + " "
- //+ bitStr.substring(1, 12) + "(" + getExponent() + ") "
- //+ bitStr.substring(12)
- //+ " [ " + x + " ]";
- //return str;
+ int64 bit;
+ memcpy(&bit, &x, sizeof(x));
+ string bitStr = bitset<64>(bit).to_string();
+ string str = bitStr.substr(0, 1) + " "
+ + bitStr.substr(1, 11) + "(" + std::to_string(getExponent()) + ") "
+ + bitStr.substr(12)
+ + " [ " + std::to_string(x) + " ]";
+ return str;
} // namespace geos.index.quadtree
Summary of changes:
include/geos/index/quadtree/DoubleBits.h | 2 +-
src/index/quadtree/DoubleBits.cpp | 28 ++++++++++++----------------
tests/unit/index/quadtree/DoubleBitsTest.cpp | 13 +++++++++++++
3 files changed, 26 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
