[geos-commits] [SCM] GEOS branch master updated. a4465831d3fefdc1840ab000868e121ecb9769f3
git at osgeo.org
git at osgeo.org
Fri Oct 18 06:06:08 PDT 2019
the project "GEOS".
via a4465831d3fefdc1840ab000868e121ecb9769f3 (commit)
from 6d7d21530f466ab36d62912ac5f2a2cdb5070700 (commit)
revisions in full, below.
commit a4465831d3fefdc1840ab000868e121ecb9769f3
Author: nila <n_larsson at yahoo.com>
Date: Wed Sep 25 15:15:18 2019 +0200
[docs] Add exposure of brief descriptions to doxygen
diff --git a/include/geos/algorithm/ConvexHull.h b/include/geos/algorithm/ConvexHull.h
index c611a45..427ffa4 100644
--- a/include/geos/algorithm/ConvexHull.h
+++ b/include/geos/algorithm/ConvexHull.h
@@ -45,7 +45,7 @@ class GeometryFactory;
namespace geos {
namespace algorithm { // geos::algorithm
+/** \brief
* Computes the convex hull of a Geometry.
* The convex hull is the smallest convex Geometry that contains all the
diff --git a/include/geos/algorithm/Distance.h b/include/geos/algorithm/Distance.h
index 68009a4..8f0523d 100644
--- a/include/geos/algorithm/Distance.h
+++ b/include/geos/algorithm/Distance.h
@@ -26,7 +26,7 @@
namespace geos {
+/** \brief
* Functions to compute distance between basic geometric structures.
* @author Martin Davis
diff --git a/include/geos/algorithm/Intersection.h b/include/geos/algorithm/Intersection.h
index 16991a3..2cfd4ff 100644
--- a/include/geos/algorithm/Intersection.h
+++ b/include/geos/algorithm/Intersection.h
@@ -22,7 +22,7 @@
namespace geos {
+/** \brief
* Computes the intersection point of two lines.
* If the lines are parallel or collinear this case is detected
* and <code>null</code> is returned.
diff --git a/include/geos/algorithm/Length.h b/include/geos/algorithm/Length.h
index 250b355..0ec6f8f 100644
--- a/include/geos/algorithm/Length.h
+++ b/include/geos/algorithm/Length.h
@@ -26,7 +26,7 @@
namespace geos {
+/** \brief
* Functions for computing length.
diff --git a/include/geos/geomgraph/Depth.h b/include/geos/geomgraph/Depth.h
index 829e1c5..2e12545 100644
--- a/include/geos/geomgraph/Depth.h
+++ b/include/geos/geomgraph/Depth.h
@@ -37,6 +37,8 @@ class Label;
namespace geos {
namespace geomgraph { // geos.geomgraph
+/// \brief A Depth object records the topological depth of the sides of an Edge
+/// for up to two Geometries.
class GEOS_DLL Depth {
public:
static int depthAtLocation(geom::Location location);
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index 050e8a8..5684b97 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -34,7 +34,7 @@
namespace geos {
+/** \brief
* Represents a point on an edge which intersects with another edge.
* The intersection may either be a single point, or a line segment
diff --git a/include/geos/geomgraph/EdgeIntersectionList.h b/include/geos/geomgraph/EdgeIntersectionList.h
index eed7641..abbc21c 100644
--- a/include/geos/geomgraph/EdgeIntersectionList.h
+++ b/include/geos/geomgraph/EdgeIntersectionList.h
@@ -51,8 +51,9 @@ namespace geos {
+/** \brief
* A list of edge intersections along an Edge.
* Implements splitting an edge with intersections
* into multiple resultant edges.
diff --git a/include/geos/geomgraph/EdgeList.h b/include/geos/geomgraph/EdgeList.h
index 77ad48e..bf6597a 100644
--- a/include/geos/geomgraph/EdgeList.h
+++ b/include/geos/geomgraph/EdgeList.h
@@ -49,7 +49,7 @@ class Edge;
namespace geos {
+/** \brief
* A EdgeList is a list of Edges.
* It supports locating edges
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index d0e1a00..56a766e 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
@@ -35,6 +35,7 @@ namespace geomgraph { // geos.geomgraph
/** \brief
* A <code>Label</code> indicates the topological relationship of a component
* of a topology graph to a given <code>Geometry</code>.
* This class supports labels for relationships to two <code>Geometry</code>s,
* which is sufficient for algorithms for binary operations.
diff --git a/include/geos/geomgraph/Node.h b/include/geos/geomgraph/Node.h
index c28fbad..5297711 100644
--- a/include/geos/geomgraph/Node.h
+++ b/include/geos/geomgraph/Node.h
@@ -58,7 +58,7 @@ class NodeFactory;
namespace geos {
-/** The node component of a geometry graph */
+/** \brief The node component of a geometry graph. */
class GEOS_DLL Node: public GraphComponent {
using GraphComponent::setLabel;
diff --git a/include/geos/geomgraph/Quadrant.h b/include/geos/geomgraph/Quadrant.h
index 0bc9bf3..e9adf53 100644
--- a/include/geos/geomgraph/Quadrant.h
+++ b/include/geos/geomgraph/Quadrant.h
@@ -36,8 +36,10 @@ class Coordinate;
namespace geos {
- * Utility functions for working with quadrants, which are numbered as follows:
+/** \brief
+ * Utility functions for working with quadrants.
+ * The quadrants are numbered as follows:
* <pre>
* 1 | 0
diff --git a/include/geos/geomgraph/index/EdgeSetIntersector.h b/include/geos/geomgraph/index/EdgeSetIntersector.h
index 8fe90b5..29e68b5 100644
--- a/include/geos/geomgraph/index/EdgeSetIntersector.h
+++ b/include/geos/geomgraph/index/EdgeSetIntersector.h
@@ -33,12 +33,14 @@ namespace geos {
namespace geomgraph { // geos::geomgraph
namespace index { // geos::geomgraph::index
- * This is derived from a Java interface.
+/** \brief
+ * An EdgeSetIntersector computes all the intersections between the edges in the set.
+ * \note This is derived from a Java interface.
class GEOS_DLL EdgeSetIntersector {
public:
+ /** \brief
* Computes all self-intersections between edges in a set of edges,
* allowing client to choose whether self-intersections are computed.
@@ -49,7 +51,7 @@ public:
virtual void computeIntersections(std::vector<Edge*>* edges,
SegmentIntersector* si, bool testAllSegments) = 0;
+ /** \brief
* Computes all mutual intersections between two sets of edges
virtual void computeIntersections(std::vector<Edge*>* edges0,
diff --git a/include/geos/geomgraph/index/MonotoneChainEdge.h b/include/geos/geomgraph/index/MonotoneChainEdge.h
index 238338c..131b9e1 100644
--- a/include/geos/geomgraph/index/MonotoneChainEdge.h
+++ b/include/geos/geomgraph/index/MonotoneChainEdge.h
@@ -41,6 +41,8 @@ namespace geos {
+/// \brief MonotoneChains are a way of partitioning the segments of an edge to
+/// allow for fast searching of intersections.
class GEOS_DLL MonotoneChainEdge {
public:
//MonotoneChainEdge();
diff --git a/include/geos/geomgraph/index/MonotoneChainIndexer.h b/include/geos/geomgraph/index/MonotoneChainIndexer.h
index 616217e..42bb692 100644
--- a/include/geos/geomgraph/index/MonotoneChainIndexer.h
+++ b/include/geos/geomgraph/index/MonotoneChainIndexer.h
@@ -30,7 +30,28 @@ namespace geos {
+/// Specifically, a sequence of contiguous line segments is a monotone chain
+/// iff all the vectors defined by the oriented segments lies in the same
+/// quadrant.
+/// Monotone Chains have the following useful properties:
+/// - the segments within a monotone chain will never intersect each other
+/// - the envelope of any contiguous subset of the segments in a monotone chain
+/// is simply the envelope of the endpoints of the subset.
+/// Property 1 means that there is no need to test pairs of segments from
+/// within the same monotone chain for intersection. Property 2 allows binary
+/// search to be used to find the intersection points of two monotone chains.
+/// For many types of real-world data, these properties eliminate a large
+/// number of segment comparisons, producing substantial speed gains.
+/// \note Due to the efficient intersection test, there is no need to limit the
+/// size of chains to obtain fast performance.
class GEOS_DLL MonotoneChainIndexer {
public:
diff --git a/include/geos/geomgraph/index/SegmentIntersector.h b/include/geos/geomgraph/index/SegmentIntersector.h
index 2584cd4..9139e33 100644
--- a/include/geos/geomgraph/index/SegmentIntersector.h
+++ b/include/geos/geomgraph/index/SegmentIntersector.h
@@ -42,7 +42,8 @@ namespace geos {
+/// \brief Computes the intersection of line segments, and adds the
+/// intersection to the edges containing the segments.
class GEOS_DLL SegmentIntersector {
private:
diff --git a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
index 1cd1e32..473f7b8 100644
--- a/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
+++ b/include/geos/geomgraph/index/SimpleEdgeSetIntersector.h
@@ -35,6 +35,11 @@ namespace geos {
+/// \brief Finds all intersections in one or two sets of edges, using the
+/// straightforward method of comparing all segments.
+/// \note This algorithm is too slow for production use, but is useful for
+/// testing purposes.
class GEOS_DLL SimpleEdgeSetIntersector: public EdgeSetIntersector {
public:
diff --git a/include/geos/geomgraphindex.h b/include/geos/geomgraphindex.h
index 0077679..786e391 100644
--- a/include/geos/geomgraphindex.h
+++ b/include/geos/geomgraphindex.h
@@ -18,6 +18,9 @@
namespace geos {
+/// \brief Contains classes that implement indexes for performing noding on
+/// geometry graph edges.
namespace index {
diff --git a/include/geos/geosAlgorithm.h b/include/geos/geosAlgorithm.h
index 1b1224b..f49c35d 100644
--- a/include/geos/geosAlgorithm.h
+++ b/include/geos/geosAlgorithm.h
@@ -87,6 +87,10 @@ namespace algorithm { // geos::algorithm
namespace locate {
} // namespace geos::algorithm::locate
+/// \brief Classes to compute distance metrics between geometries.
+namespace distance { // namespace geos::algorithm::distance
+} // namespace geos::algorithm::distance
} // namespace geos
diff --git a/include/geos/io/ByteOrderDataInStream.h b/include/geos/io/ByteOrderDataInStream.h
index eb79926..6f516c2 100644
--- a/include/geos/io/ByteOrderDataInStream.h
+++ b/include/geos/io/ByteOrderDataInStream.h
@@ -31,10 +31,10 @@
namespace geos {
namespace io {
* \class ByteOrderDataInStream io.h geos.h
- * Allows reading an stream of primitive datatypes from an underlying
+ * \brief Allows reading an stream of primitive datatypes from an underlying
* istream, with the representation being in either common byte ordering.
diff --git a/include/geos/io/ByteOrderValues.h b/include/geos/io/ByteOrderValues.h
index 779cb9b..d41794b 100644
--- a/include/geos/io/ByteOrderValues.h
+++ b/include/geos/io/ByteOrderValues.h
@@ -26,11 +26,11 @@
namespace geos {
namespace io {
* \class ByteOrderValues io.h geos.h
- * Methods to read and write primitive datatypes from/to byte
- * sequences, allowing the byte order to be specified
+ * \brief Methods to read and write primitive datatypes from/to byte
+ * sequences, allowing the byte order to be specified.
* Similar to the standard Java <code>ByteBuffer</code> class.
diff --git a/include/geos/linearref/LengthLocationMap.h b/include/geos/linearref/LengthLocationMap.h
index 1b2a92d..1a229c9 100644
--- a/include/geos/linearref/LengthLocationMap.h
+++ b/include/geos/linearref/LengthLocationMap.h
@@ -28,9 +28,10 @@
namespace geos {
namespace linearref { // geos::linearref
- * Computes the LinearLocation for a given length
- * along a linear [Geometry](@ref geom::Geometry).
+/** \brief
+ * Computes the LinearLocation for a given length along a linear
+ * [Geometry](@ref geom::Geometry).
* Negative lengths are measured in reverse from end of the linear geometry.
* Out-of-range values are clamped.
diff --git a/include/geos/noding/NodingValidator.h b/include/geos/noding/NodingValidator.h
index b62bafe..7f17a7b 100644
--- a/include/geos/noding/NodingValidator.h
+++ b/include/geos/noding/NodingValidator.h
@@ -38,7 +38,7 @@ class SegmentString;
namespace geos {
namespace noding { // geos.noding
+/** \brief
* Validates that a collection of {@link SegmentString}s is correctly noded.
* Throws a TopologyException if a noding error is found.
diff --git a/include/geos/noding/SegmentPointComparator.h b/include/geos/noding/SegmentPointComparator.h
index 48d5e11..23e0ac4 100644
--- a/include/geos/noding/SegmentPointComparator.h
+++ b/include/geos/noding/SegmentPointComparator.h
@@ -26,9 +26,10 @@
namespace geos {
+/** \brief
* Implements a robust method of comparing the relative position of two
* points along the same segment.
* The coordinates are assumed to lie "near" the segment.
* This means that this algorithm will only return correct results
* if the input coordinates
@@ -40,7 +41,7 @@ class GEOS_DLL SegmentPointComparator {
public:
+ /** \brief
* Compares two Coordinates for their relative position along a
* segment lying in the specified Octant.
diff --git a/include/geos/opPolygonize.h b/include/geos/opPolygonize.h
index 7242e1d..43ea58e 100644
--- a/include/geos/opPolygonize.h
+++ b/include/geos/opPolygonize.h
@@ -18,6 +18,8 @@
namespace geos {
namespace operation { // geos.operation
+/// An API for polygonizing sets of lines.
namespace polygonize { // geos.operation.polygonize
} // namespace geos.operation.polygonize
diff --git a/include/geos/opPredicate.h b/include/geos/opPredicate.h
index edaebfd..06a5358 100644
--- a/include/geos/opPredicate.h
+++ b/include/geos/opPredicate.h
@@ -17,6 +17,8 @@
namespace geos {
+/// Classes which implement topological predicates optimized for particular kinds of geometries.
namespace predicate {
} // namespace predicate
diff --git a/include/geos/operation/polygonize/HoleAssigner.h b/include/geos/operation/polygonize/HoleAssigner.h
index 82dbe1f..53776fe 100644
--- a/include/geos/operation/polygonize/HoleAssigner.h
+++ b/include/geos/operation/polygonize/HoleAssigner.h
@@ -28,8 +28,9 @@ namespace geos {
+/** \brief
* Assigns hole rings to shell rings during polygonization.
* Uses spatial indexing to improve performance of shell lookup.
* @author mdavis
diff --git a/include/geos/operation/polygonize/PolygonizeEdge.h b/include/geos/operation/polygonize/PolygonizeEdge.h
index 2da144f..fb43195 100644
--- a/include/geos/operation/polygonize/PolygonizeEdge.h
+++ b/include/geos/operation/polygonize/PolygonizeEdge.h
@@ -36,7 +36,7 @@ namespace geos {
namespace operation { // geos::operation
namespace polygonize { // geos::operation::polygonize
-/* \brief
+/** \brief
* An edge of a polygonization graph.
* @version 1.4
diff --git a/include/geos/operation/sharedpaths/SharedPathsOp.h b/include/geos/operation/sharedpaths/SharedPathsOp.h
index accd293..7275b48 100644
--- a/include/geos/operation/sharedpaths/SharedPathsOp.h
+++ b/include/geos/operation/sharedpaths/SharedPathsOp.h
@@ -42,6 +42,8 @@ class GeometryFactory;
namespace geos {
+/// Find shared paths among two linear Geometry objects.
namespace sharedpaths { // geos.operation.sharedpaths
/** \brief
@@ -53,7 +55,7 @@ namespace sharedpaths { // geos.operation.sharedpaths
* Paths reported as shared are given in the direction they
* appear in the first geometry.
- * Developed by Sandro Santilli (strk at kbt.io)
+ * \remark Developed by Sandro Santilli (strk at kbt.io)
* for Faunalia (http://www.faunalia.it)
* with funding from Regione Toscana - Settore SISTEMA INFORMATIVO
* TERRITORIALE ED AMBIENTALE - for the project: "Sviluppo strumenti
diff --git a/include/geos/operation/union/OverlapUnion.h b/include/geos/operation/union/OverlapUnion.h
index 1c72bcd..c7f32b2 100644
--- a/include/geos/operation/union/OverlapUnion.h
+++ b/include/geos/operation/union/OverlapUnion.h
@@ -39,13 +39,14 @@ namespace geos {
namespace geounion { // geos::operation::geounion
- * Unions MultiPolygons efficiently by
- * using full topological union only for polygons which may overlap
- * by virtue of intersecting the common area of the inputs.
- * Other polygons are simply combined with the union result,
- * which is much more performant.
- * <p>
+/** \brief
+ * Unions MultiPolygons efficiently by using full topological union only
+ * for polygons which may overlap by virtue of intersecting the common
+ * area of the inputs.
+ * Other polygons are simply combined with the union result, which is much
+ * more performant.
* This situation is likely to occur during cascaded polygon union,
* since the partitioning of polygons is done heuristically
* and thus may group disjoint polygons which can lie far apart.
diff --git a/include/geos/operation/valid/RepeatedPointRemover.h b/include/geos/operation/valid/RepeatedPointRemover.h
index 03e3c36..b22dd1f 100644
--- a/include/geos/operation/valid/RepeatedPointRemover.h
+++ b/include/geos/operation/valid/RepeatedPointRemover.h
@@ -20,6 +20,8 @@
namespace geos {
namespace valid {
+ /// Removes repeated, consecutive equal, coordinates from a CoordinateSequence.
class GEOS_DLL RepeatedPointRemover {
/// \brief
diff --git a/include/geos/precision/MinimumClearance.h b/include/geos/precision/MinimumClearance.h
index 9fcd226..d1a80c6 100644
--- a/include/geos/precision/MinimumClearance.h
+++ b/include/geos/precision/MinimumClearance.h
@@ -25,6 +25,8 @@
namespace geos {
namespace precision {
+/// Computes the Minimum Clearance of a Geometry.
class GEOS_DLL MinimumClearance {
private:
const geom::Geometry* inputGeom;
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index ce53f6c..50b139e 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -43,7 +43,7 @@ namespace geos {
namespace triangulate { //geos.triangulate
+/** \brief
* A utility class which creates Delaunay Triangulations
* from collections of points and extract the resulting
* triangulation edges or triangles as geometries.
diff --git a/include/geos/triangulate/IncrementalDelaunayTriangulator.h b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
index 231de04..dcdadc1 100644
--- a/include/geos/triangulate/IncrementalDelaunayTriangulator.h
+++ b/include/geos/triangulate/IncrementalDelaunayTriangulator.h
@@ -32,7 +32,7 @@ class QuadEdge;
class QuadEdgeSubdivision;
+/** \brief
* Computes a Delauanay Triangulation of a set of {@link quadedge::Vertex}es,
* using an incrementatal insertion algorithm.
diff --git a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
index a2e7fe7..bea7270 100644
--- a/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/LastFoundQuadEdgeLocator.h
@@ -29,7 +29,7 @@ namespace quadedge { //geos.triangulate.quadedge
//fwd declarations
+/** \brief
* Locates {@link QuadEdge}s in a {@link QuadEdgeSubdivision},
* optimizing the search by starting in the
* locality of the last edge found.
diff --git a/include/geos/triangulate/quadedge/QuadEdgeLocator.h b/include/geos/triangulate/quadedge/QuadEdgeLocator.h
index cbdff34..827ff1a 100644
--- a/include/geos/triangulate/quadedge/QuadEdgeLocator.h
+++ b/include/geos/triangulate/quadedge/QuadEdgeLocator.h
@@ -26,10 +26,11 @@ namespace quadedge { //geos.triangulate.quadedge
class Vertex;
class QuadEdge;
+/** \brief
* An interface for classes which locate an edge in a {@link QuadEdgeSubdivision}
- * which either contains a given {@link Vertex} V
- * or is an edge of a triangle which contains V.
+ * which either contains a given {@link Vertex} V or is an edge of a triangle
+ * which contains V.
* Implementors may utilized different strategies for
* optimizing locating containing edges/triangles.
diff --git a/include/geos/triangulate/quadedge/TrianglePredicate.h b/include/geos/triangulate/quadedge/TrianglePredicate.h
index f045be0..8742fc1 100644
--- a/include/geos/triangulate/quadedge/TrianglePredicate.h
+++ b/include/geos/triangulate/quadedge/TrianglePredicate.h
@@ -24,9 +24,10 @@ namespace geom { // geos.geom
class Coordinate;
+/** \brief
* Algorithms for computing values and predicates
* associated with triangles.
* For some algorithms extended-precision
* implementations are provided, which are more robust
* (i.e. they produce correct answers in more cases).
diff --git a/include/geos/triangulate/quadedge/TriangleVisitor.h b/include/geos/triangulate/quadedge/TriangleVisitor.h
index 48f4efb..443b665 100644
--- a/include/geos/triangulate/quadedge/TriangleVisitor.h
+++ b/include/geos/triangulate/quadedge/TriangleVisitor.h
@@ -25,7 +25,7 @@ namespace geos {
+/** \brief
* An interface for algorithms which process the triangles in a {@link QuadEdgeSubdivision}.
* @author JTS: Martin Davis
diff --git a/include/geos/util.h b/include/geos/util.h
index c87fbe3..c841255 100644
--- a/include/geos/util.h
+++ b/include/geos/util.h
@@ -82,6 +82,10 @@ make_unique(Args &&...) = delete;
#endif
+/// Utility classes for GEOS.
+namespace util { // geos.util
+} // geos.util
#endif // GEOS_UTIL_H
diff --git a/include/geos/util/GeometricShapeFactory.h b/include/geos/util/GeometricShapeFactory.h
index bb83d27..776aa13 100644
--- a/include/geos/util/GeometricShapeFactory.h
+++ b/include/geos/util/GeometricShapeFactory.h
@@ -48,7 +48,7 @@ namespace geos {
namespace util { // geos::util
+/** \brief
* Computes various kinds of common geometric shapes.
* Allows various ways of specifying the location and extent of the shapes,
diff --git a/include/geos/util/Interrupt.h b/include/geos/util/Interrupt.h
index a3e564b..5d908e1 100644
--- a/include/geos/util/Interrupt.h
+++ b/include/geos/util/Interrupt.h
@@ -22,7 +22,7 @@ namespace util { // geos::util
#define GEOS_CHECK_FOR_INTERRUPTS() geos::util::Interrupt::process()
-/** Used to manage interruption requests and callbacks */
+/** \brief Used to manage interruption requests and callbacks. */
class GEOS_DLL Interrupt {
public:
Summary of changes:
include/geos/algorithm/ConvexHull.h | 2 +-
include/geos/algorithm/Distance.h | 2 +-
include/geos/algorithm/Intersection.h | 2 +-
include/geos/algorithm/Length.h | 2 +-
include/geos/geomgraph/Depth.h | 2 ++
include/geos/geomgraph/EdgeIntersection.h | 2 +-
include/geos/geomgraph/EdgeIntersectionList.h | 3 ++-
include/geos/geomgraph/EdgeList.h | 2 +-
include/geos/geomgraph/Label.h | 1 +
include/geos/geomgraph/Node.h | 2 +-
include/geos/geomgraph/Quadrant.h | 6 ++++--
include/geos/geomgraph/index/EdgeSetIntersector.h | 10 ++++++----
include/geos/geomgraph/index/MonotoneChainEdge.h | 2 ++
.../geos/geomgraph/index/MonotoneChainIndexer.h | 23 +++++++++++++++++++++-
include/geos/geomgraph/index/SegmentIntersector.h | 3 ++-
.../geomgraph/index/SimpleEdgeSetIntersector.h | 5 +++++
include/geos/geomgraphindex.h | 3 +++
include/geos/geosAlgorithm.h | 4 ++++
include/geos/io/ByteOrderDataInStream.h | 4 ++--
include/geos/io/ByteOrderValues.h | 6 +++---
include/geos/linearref/LengthLocationMap.h | 7 ++++---
include/geos/noding/NodingValidator.h | 2 +-
include/geos/noding/SegmentPointComparator.h | 5 +++--
include/geos/opPolygonize.h | 2 ++
include/geos/opPredicate.h | 2 ++
include/geos/operation/polygonize/HoleAssigner.h | 3 ++-
include/geos/operation/polygonize/PolygonizeEdge.h | 2 +-
include/geos/operation/sharedpaths/SharedPathsOp.h | 4 +++-
include/geos/operation/union/OverlapUnion.h | 15 +++++++-------
.../geos/operation/valid/RepeatedPointRemover.h | 2 ++
include/geos/precision/MinimumClearance.h | 2 ++
.../triangulate/DelaunayTriangulationBuilder.h | 2 +-
.../triangulate/IncrementalDelaunayTriangulator.h | 2 +-
.../quadedge/LastFoundQuadEdgeLocator.h | 2 +-
.../geos/triangulate/quadedge/QuadEdgeLocator.h | 7 ++++---
.../geos/triangulate/quadedge/TrianglePredicate.h | 3 ++-
.../geos/triangulate/quadedge/TriangleVisitor.h | 2 +-
include/geos/util.h | 4 ++++
include/geos/util/GeometricShapeFactory.h | 2 +-
include/geos/util/Interrupt.h | 2 +-
40 files changed, 111 insertions(+), 47 deletions(-)
hooks/post-receive
More information about the geos-commits
