[geos-commits] [SCM] GEOS branch 3.7 updated. 06e23006f944e691a4018ac0dd77dad413ebf4bd
Wed Sep 4 15:53:10 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
       via  06e23006f944e691a4018ac0dd77dad413ebf4bd (commit)
      from  f249089b763ceb859e6b9b83ee28742262753b54 (commit)
revisions in full, below.
commit 06e23006f944e691a4018ac0dd77dad413ebf4bd
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Sep 4 15:52:34 2019 -0700
    Match 3.7 behaviour to trunk.
    There are still performance issues with cascaded union in 3.7 that
    are a regression vs 3.6. No fix has been found in JTS either
    thus far.
diff --git a/src/operation/union/CascadedPolygonUnion.cpp b/src/operation/union/CascadedPolygonUnion.cpp
index 23a1aaf..976baa4 100644
--- a/src/operation/union/CascadedPolygonUnion.cpp
+++ b/src/operation/union/CascadedPolygonUnion.cpp
@@ -263,7 +263,7 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
     std::unique_ptr<geom::Geometry> unionCommon(unionActual(g0Int.get(), g1Int.get()));
 #if GEOS_DEBUG_CASCADED_UNION
-    if ( ! check_valid(*u, "unionUsingEnvelopeIntersection unionActual return") )
+    if ( ! check_valid(*unionCommon, "unionUsingEnvelopeIntersection unionActual return") )
 #if GEOS_DEBUG_CASCADED_UNION_PRINT_INVALID
       std::cerr << " union between the following is invalid"
@@ -288,36 +288,24 @@ CascadedPolygonUnion::unionUsingEnvelopeIntersection(geom::Geometry* g0,
 #endif
-    geom::Envelope const* unionCommonEnv = unionCommon->getEnvelopeInternal(); // TODO: check for EMPTY ?
     std::vector<geom::Geometry*> polysOn;
     std::vector<geom::Geometry*> polysOff;
+    geom::Envelope const* unionCommonEnv = unionCommon->getEnvelopeInternal(); // TODO: check for EMPTY ?
     extractByEnvelope(*unionCommonEnv, disjointPolys, polysOn, polysOff);
     std::cerr << "unionUsingEnvelopeIntersection: " << polysOn.size() << "/" << disjointPolys.size() << " polys intersect union of final thing" << std::endl;
 #endif
-    // If the union of the interacting geometries
-    // is contained in the envelope of the inputs
-    // (and this is highly likely unless overlay robustness failure occurs)
-    // it is safe to combine with the disjoint polygons
-    geom::Envelope beforeUnionEnv( *(g0Int->getEnvelopeInternal()) );
-    beforeUnionEnv.expandToInclude( g1Int->getEnvelopeInternal() );
-    bool isUnionSafe = beforeUnionEnv.contains(unionCommonEnv);
-    //if (! isUnionSafe) std::cerr << "Found unsafe union" << std::endl;
     std::unique_ptr<geom::Geometry> ret;
-    if(polysOn.empty() || isUnionSafe) {
+    if(polysOn.empty()) {
       disjointPolys.push_back(unionCommon.get());
-      ret.reset( geom::util::GeometryCombiner::combine(disjointPolys));
+      ret.reset(geom::util::GeometryCombiner::combine(disjointPolys));
     } else {
-      // The union envelope changed (e.g. due to snapping heuristics)
-      // so to be safe must union everything (which is slow, but infrequent)
       // TODO: could be further tweaked to only union with polysOn
       //       and combine with polysOff, but then it'll need again to
       //       recurse in the check for disjoint/intersecting
-      std::unique_ptr<geom::Geometry> disjointCombined( geom::util::GeometryCombiner::combine(disjointPolys) );
-      ret.reset( unionActual( disjointCombined.get(), unionCommon.get() ) );
+      ret.reset(unionActual(ret.get(), unionCommon.get()));
Summary of changes:
 src/operation/union/CascadedPolygonUnion.cpp | 24 ++++++------------------
 1 file changed, 6 insertions(+), 18 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
