[geos-commits] [SCM] GEOS branch master updated. 8eaa475d27ab262489c3b88ced922f30d4dc136f
git at osgeo.org
git at osgeo.org
Wed Sep 4 18:41:39 PDT 2019
the project "GEOS".
via 8eaa475d27ab262489c3b88ced922f30d4dc136f (commit)
from 53f842fb79cdb3f44291bfdbe05388dbbb99a6f5 (commit)
revisions in full, below.
commit 8eaa475d27ab262489c3b88ced922f30d4dc136f
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Sep 4 21:35:10 2019 -0400
Use unique_ptr in geomgraph::Edge
Also reorder members to reduce class size by 8 bytes
diff --git a/benchmarks/ClassSizes.cpp b/benchmarks/ClassSizes.cpp
index 1e45a7f..a8b5e63 100644
--- a/benchmarks/ClassSizes.cpp
+++ b/benchmarks/ClassSizes.cpp
@@ -28,7 +28,9 @@
#include <geos/geom/MultiPoint.h>
#include <geos/geom/MultiLineString.h>
#include <geos/geom/MultiPolygon.h>
+#include <geos/geomgraph/Depth.h>
#include <geos/geomgraph/DirectedEdge.h>
+#include <geos/geomgraph/Edge.h>
#include <geos/geomgraph/EdgeEnd.h>
#include <geos/geomgraph/PlanarGraph.h>
#include <geos/noding/NodedSegmentString.h>
@@ -45,9 +47,11 @@ using namespace geos;
int
main()
- check(geomgraph::PlanarGraph);
- check(geomgraph::EdgeEnd);
+ check(geomgraph::Depth);
check(geomgraph::DirectedEdge);
+ check(geomgraph::Edge);
+ check(geomgraph::EdgeEnd);
+ check(geomgraph::PlanarGraph);
check(noding::NodedSegmentString);
check(geom::Geometry);
check(geom::Point);
diff --git a/include/geos/geomgraph/Edge.h b/include/geos/geomgraph/Edge.h
index e91a9ba..b6d6be9 100644
--- a/include/geos/geomgraph/Edge.h
+++ b/include/geos/geomgraph/Edge.h
@@ -71,17 +71,17 @@ private:
std::string name;
/// Lazily-created, owned by Edge.
- index::MonotoneChainEdge* mce;
+ std::unique_ptr<index::MonotoneChainEdge> mce;
- geom::Envelope* env;
- bool isIsolatedVar;
+ std::unique_ptr<geom::Envelope> env;
Depth depth;
int depthDelta; // the change in area depth from the R to L side of this edge
+ bool isIsolatedVar;
public:
void
@@ -97,7 +97,7 @@ public:
static void updateIM(const Label& lbl, geom::IntersectionMatrix& im);
/// Externally-set, owned by Edge. FIXME: refuse ownership
- geom::CoordinateSequence* pts;
+ std::unique_ptr<geom::CoordinateSequence> pts;
EdgeIntersectionList eiList;
@@ -127,7 +127,7 @@ public:
getCoordinates() const
testInvariant();
- return pts;
+ return pts.get();
virtual const geom::Coordinate&
diff --git a/src/geomgraph/Edge.cpp b/src/geomgraph/Edge.cpp
index 5787260..1aa22e2 100644
--- a/src/geomgraph/Edge.cpp
+++ b/src/geomgraph/Edge.cpp
@@ -35,6 +35,7 @@
#include <geos/geom/CoordinateSequence.h>
#include <geos/geom/CoordinateArraySequence.h> // FIXME: shouldn't use
#include <geos/geom/Coordinate.h>
+#include <geos/util.h>
//#define GEOS_DEBUG_INTERSECT 0
#ifndef GEOS_DEBUG
@@ -77,13 +78,7 @@ Edge::updateIM(const Label& lbl, IntersectionMatrix& im)
/*public*/
-Edge::~Edge()
- //cerr<<"["<<this<<"] ~Edge()"<<endl;
- delete mce;
- delete pts;
- delete env;
+Edge::~Edge() = default;
/*public*/
Edge::Edge(CoordinateSequence* newPts, const Label& newLabel)
@@ -91,9 +86,9 @@ Edge::Edge(CoordinateSequence* newPts, const Label& newLabel)
GraphComponent(newLabel),
mce(nullptr),
env(nullptr),
- isIsolatedVar(true),
depth(),
depthDelta(0),
+ isIsolatedVar(true),
pts(newPts),
eiList(this)
@@ -106,9 +101,9 @@ Edge::Edge(CoordinateSequence* newPts)
GraphComponent(),
mce(nullptr),
env(nullptr),
depth(),
depthDelta(0),
pts(newPts),
eiList(this)
@@ -121,9 +116,9 @@ Edge::getMonotoneChainEdge()
testInvariant();
if(mce == nullptr) {
- mce = new MonotoneChainEdge(this);
+ mce = detail::make_unique<MonotoneChainEdge>(this);
- return mce;
+ return mce.get();
@@ -309,14 +304,14 @@ Edge::getEnvelope()
// compute envelope lazily
if(env == nullptr) {
- env = new Envelope();
+ env = detail::make_unique<Envelope>();
auto npts = getNumPoints();
for(size_t i = 0; i < npts; ++i) {
env->expandToInclude(pts->getAt(i));
testInvariant();
- return env;
+ return env.get();
std::ostream&
Summary of changes:
benchmarks/ClassSizes.cpp | 8 ++++++--
include/geos/geomgraph/Edge.h | 12 ++++++------
src/geomgraph/Edge.cpp | 21 ++++++++-------------
3 files changed, 20 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits
