[geos-commits] [SCM] GEOS branch master updated. 32af81367a06cc47725cbf7d0c3b6773862d04d0
git at osgeo.org
git at osgeo.org
Fri Sep 6 13:32:38 PDT 2019
the project "GEOS".
via 32af81367a06cc47725cbf7d0c3b6773862d04d0 (commit)
from 7a143371ed80b0f4a613894ab5717ca4cd878a21 (commit)
revisions in full, below.
commit 32af81367a06cc47725cbf7d0c3b6773862d04d0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Sep 6 13:31:50 2019 -0700
Port JTS PR 468
https://github.com/locationtech/jts/pull/468
Refactor line intersection code into Intersection class.
Use new class for all line intersection computation
Unroll input conditioning for performance
Add tests to verify accuracy of conditioned double-precision intersection algorithm
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index ad97e95..05e2678 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -6579,11 +6579,9 @@ extern "C" {
try {
geos::geom::LineSegment a(ax0, ay0, ax1, ay1);
geos::geom::LineSegment b(bx0, by0, bx1, by1);
- geos::geom::Coordinate isect;
+ geos::geom::Coordinate isect = a.intersection(b);
- bool intersects = a.intersection(b, isect);
- if(!intersects) {
+ if(isect.isNull()) {
return -1;
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index 258361b..f596466 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -111,9 +111,17 @@ public:
return CGAlgorithmsDD::STRAIGHT;
- static void intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& q1, const geom::Coordinate& q2,
- geom::Coordinate& rv);
+ * If the lines are parallel (either identical
+ * or separate) a null value is returned.
+ * @param p1 an endpoint of line segment 1
+ * @param p2 an endpoint of line segment 1
+ * @param q1 an endpoint of line segment 2
+ * @param q2 an endpoint of line segment 2
+ * @return an intersection point if one exists, or null if the lines are parallel
+ static geom::Coordinate intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q1, const geom::Coordinate& q2);
static int signOfDet2x2(double dx1, double dy1, double dx2, double dy2);
diff --git a/include/geos/algorithm/Intersection.h b/include/geos/algorithm/Intersection.h
new file mode 100644
index 0000000..16991a3
--- /dev/null
+++ b/include/geos/algorithm/Intersection.h
@@ -0,0 +1,61 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2019 Paul Ramsey <pramsey at cleverlephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_ALGORITHM_INTERSECTION_H
+#define GEOS_ALGORITHM_INTERSECTION_H
+#include <geos/export.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequence.h>
+namespace geos {
+namespace algorithm { // geos::algorithm
+* Computes the intersection point of two lines.
+* If the lines are parallel or collinear this case is detected
+* and <code>null</code> is returned.
+* <p>
+* In general it is not possible to accurately compute
+* the intersection point of two lines, due to
+* numerical roundoff.
+* This is particularly true when the input lines are nearly parallel.
+* This routine uses numerical conditioning on the input values
+* to ensure that the computed value should be very close to the correct value.
+* @param p1 an endpoint of line 1
+* @param p2 an endpoint of line 1
+* @param q1 an endpoint of line 2
+* @param q2 an endpoint of line 2
+* @return the intersection point between the lines, if there is one,
+* or null if the lines are parallel or collinear
+* @see CGAlgorithmsDD#intersection(Coordinate, Coordinate, Coordinate, Coordinate)
+class GEOS_DLL Intersection {
+public:
+static geom::Coordinate intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
+} // namespace geos::algorithm
+#endif // GEOS_ALGORITHM_INTERSECTION_H
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index fad89ad..94b041a 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -260,12 +260,6 @@ public:
private:
- void intersectionWithNormalization(const geom::Coordinate& p1,
- const geom::Coordinate& p2,
- const geom::Coordinate& q2,
- geom::Coordinate& ret) const;
* If makePrecise is true, computed intersection coordinates
* will be made precise using Coordinate#makePrecise
@@ -298,8 +292,8 @@ private:
return result == COLLINEAR_INTERSECTION;
- int computeIntersect(const geom::Coordinate& p1, const geom::Coordinate& p2, const geom::Coordinate& q1,
- const geom::Coordinate& q2);
+ int computeIntersect(const geom::Coordinate& p1, const geom::Coordinate& p2,
bool
isEndPoint() const
@@ -311,9 +305,8 @@ private:
void computeIntLineIndex(int segmentIndex);
- int computeCollinearIntersection(const geom::Coordinate& p1,
- const geom::Coordinate& p2, const geom::Coordinate& q1,
+ int computeCollinearIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
/** \brief
* This method computes the actual value of the intersection point.
@@ -324,14 +317,10 @@ private:
* removing common significant digits from the calculation to
* maintain more bits of precision.
- void intersection(const geom::Coordinate& p1,
- double smallestInAbsValue(double x1, double x2,
- double x3, double x4) const;
+ geom::Coordinate intersection(const geom::Coordinate& p1,
+ const geom::Coordinate& p2,
+ const geom::Coordinate& q2) const;
* Test whether a point lies in the envelopes of both input segments.
@@ -345,23 +334,9 @@ private:
bool isInSegmentEnvelopes(const geom::Coordinate& intPt) const;
- /** \brief
- * Normalize the supplied coordinates to
- * so that the midpoint of their intersection envelope
- * lies at the origin.
- * @param n00
- * @param n01
- * @param n10
- * @param n11
- * @param normPt
- void normalizeToEnvCentre(geom::Coordinate& n00, geom::Coordinate& n01,
- geom::Coordinate& n10, geom::Coordinate& n11,
- geom::Coordinate& normPt) const;
- * Computes a segment intersection using homogeneous coordinates.
+ * Computes a segment intersection.
* Round-off error can cause the raw computation to fail,
* (usually due to the segments being approximately parallel).
* If this happens, a reasonable approximation is computed instead.
@@ -370,13 +345,10 @@ private:
* @param p2 a segment endpoint
* @param q1 a segment endpoint
* @param q2 a segment endpoint
- * @param intPt the computed intersection point is stored there
+ * @return the computed intersection point is stored there
- void safeHCoordinateIntersection(const geom::Coordinate& p1,
- geom::Coordinate& intPt) const;
+ geom::Coordinate intersectionSafe(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q1, const geom::Coordinate& q2) const;
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index e4c22f1..717e63d 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -24,6 +24,7 @@ geos_HEADERS = \
InteriorPointArea.h \
InteriorPointLine.h \
InteriorPointPoint.h \
+ Intersection.h \
Length.h \
LineIntersector.h \
MinimumBoundingCircle.h \
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 2430c12..38191d9 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -335,10 +335,9 @@ public:
* intersection, the LineIntersector class should be used.
* @param line
- * @param coord the Coordinate to write the result into
- * @return true if an intersection was found, false otherwise
+ * @return intersection if found, setNull() otherwise
- bool intersection(const LineSegment& line, Coordinate& coord) const;
+ Coordinate intersection(const LineSegment& line) const;
/** \brief
* Computes the intersection point of the lines defined
@@ -353,11 +352,10 @@ public:
* be used.
* @param line a line segment defining a straight line
- * @param ret will be set to the intersection point (if any)
- bool lineIntersection(const LineSegment& line, Coordinate& ret) const;
+ Coordinate lineIntersection(const LineSegment& line) const;
* Creates a LineString with the same coordinates as this segment
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 7d884a9..c25c1f2 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -21,6 +21,7 @@
#include <geos/util/IllegalArgumentException.h>
#include <sstream>
+#include <cmath>
using namespace geos::geom;
using namespace geos::algorithm;
@@ -146,10 +147,9 @@ CGAlgorithmsDD::orientationIndexFilter(const Coordinate& pa,
return CGAlgorithmsDD::FAILURE;
-void
+Coordinate
CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
- const Coordinate& q1, const Coordinate& q2,
- Coordinate& rv)
+ const Coordinate& q1, const Coordinate& q2)
DD q1x(q1.x);
DD q1y(q1.y);
@@ -161,35 +161,32 @@ CGAlgorithmsDD::intersection(const Coordinate& p1, const Coordinate& p2,
DD p2x(p2.x);
DD p2y(p2.y);
- DD qdy = q2y - q1y;
- DD qdx = q2x - q1x;
+ DD px = p1y - p2y;
+ DD py = p2x - p1x;
+ DD pw = (p1x * p2y) - (p2x * p1y);
- DD pdy = p2y - p1y;
- DD pdx = p2x - p1x;
+ DD qx = q1y - q2y;
+ DD qy = q2x - q1x;
+ DD qw = (q1x * q2y) - (q2x * q1y);
- DD denom = (qdy * pdx) - (qdx * pdy);
+ DD x = (py * qw) - (qy * pw);
+ DD y = (qx * pw) - (px * qw);
+ DD w = (px * qy) - (qx * py);
- * Cases:
- * - denom is 0 if lines are parallel
- * - intersection point lies within line segment p if fracP is between 0 and 1
- * - intersection point lies within line segment q if fracQ is between 0 and 1
- DD numx1 = (q2x - q1x) * (p1y - q1y);
- DD numx2 = (q2y - q1y) * (p1x - q1x);
- DD numx = numx1 - numx2;
- DD fracP = numx / denom;
+ double xInt = (x / w).ToDouble();
+ double yInt = (y / w).ToDouble();
- DD x = p1x + (p2x - p1x) * fracP;
+ Coordinate rv;
- DD numy1 = (p2x - p1x) * (p1y - q1y);
- DD numy2 = (p2y - p1y) * (p1x - q1x);
- DD numy = numy1 - numy2;
- DD fracQ = numy / denom;
- DD y = q1y + (q2y - q1y) * fracQ;
+ if (std::isnan(xInt) || std::isnan(yInt) ||
+ std::isinf(xInt) || std::isinf(yInt)) {
+ rv.setNull();
+ return rv;
- rv.x = x.ToDouble();
- rv.y = y.ToDouble();
+ rv.x = xInt;
+ rv.y = yInt;
+ return rv;
/* public static */
diff --git a/src/algorithm/Intersection.cpp b/src/algorithm/Intersection.cpp
index 0000000..834b7c0
--- /dev/null
+++ b/src/algorithm/Intersection.cpp
@@ -0,0 +1,88 @@
+#include <cmath>
+#include <vector>
+#include <geos/algorithm/Intersection.h>
+namespace geos {
+namespace algorithm { // geos.algorithm
+/* public static */
+geom::Coordinate
+Intersection::intersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ double minX0 = p1.x < p2.x ? p1.x : p2.x;
+ double minY0 = p1.y < p2.y ? p1.y : p2.y;
+ double maxX0 = p1.x > p2.x ? p1.x : p2.x;
+ double maxY0 = p1.y > p2.y ? p1.y : p2.y;
+ double minX1 = q1.x < q2.x ? q1.x : q2.x;
+ double minY1 = q1.y < q2.y ? q1.y : q2.y;
+ double maxX1 = q1.x > q2.x ? q1.x : q2.x;
+ double maxY1 = q1.y > q2.y ? q1.y : q2.y;
+ double intMinX = minX0 > minX1 ? minX0 : minX1;
+ double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
+ double intMinY = minY0 > minY1 ? minY0 : minY1;
+ double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
+ double midx = (intMinX + intMaxX) / 2.0;
+ double midy = (intMinY + intMaxY) / 2.0;
+ // condition ordinate values by subtracting midpoint
+ double p1x = p1.x - midx;
+ double p1y = p1.y - midy;
+ double p2x = p2.x - midx;
+ double p2y = p2.y - midy;
+ double q1x = q1.x - midx;
+ double q1y = q1.y - midy;
+ double q2x = q2.x - midx;
+ double q2y = q2.y - midy;
+ // unrolled computation using homogeneous coordinates eqn
+ double px = p1y - p2y;
+ double py = p2x - p1x;
+ double pw = p1x * p2y - p2x * p1y;
+ double qx = q1y - q2y;
+ double qy = q2x - q1x;
+ double qw = q1x * q2y - q2x * q1y;
+ double x = py * qw - qy * pw;
+ double y = qx * pw - px * qw;
+ double w = px * qy - qx * py;
+ double xInt = x/w;
+ double yInt = y/w;
+ geom::Coordinate rv;
+ // check for parallel lines
+ rv.setNull();
+ return rv;
+ // de-condition intersection point
+ rv.x = xInt + midx;
+ rv.y = yInt + midy;
+ return rv;
+} // namespace geos.algorithm
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index e928e5b..33f379d 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -21,7 +21,7 @@
#include <geos/algorithm/LineIntersector.h>
#include <geos/algorithm/Distance.h>
#include <geos/algorithm/Orientation.h>
-#include <geos/algorithm/HCoordinate.h>
#include <geos/algorithm/NotRepresentableException.h>
#include <geos/geom/PrecisionModel.h>
@@ -385,8 +385,8 @@ LineIntersector::hasIntersection(const Coordinate& p, const Coordinate& p1, cons
/*private*/
int
-LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2, const Coordinate& q1,
- const Coordinate& q2)
+LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
#if GEOS_DEBUG
cerr << "LineIntersector::computeIntersect called" << endl;
@@ -543,7 +543,7 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2, co
else {
isProperVar = true;
- intersection(p1, p2, q1, q2, intPt[0]);
+ intPt[0] = intersection(p1, p2, q1, q2);
#if GEOS_DEBUG
cerr << " POINT_INTERSECTION; intPt[0]:" << intPt[0].toString() << endl;
@@ -553,8 +553,8 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2, co
/*private*/
int
-LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordinate& p2, const Coordinate& q1,
+LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordinate& p2,
#if COMPUTE_Z
double ztot;
@@ -840,13 +840,12 @@ LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordi
/*private*/
-void
-LineIntersector::intersection(const Coordinate& p1,
- const Coordinate& p2, const Coordinate& q1, const Coordinate& q2,
- Coordinate& intPtOut) const
+Coordinate
+LineIntersector::intersection(const Coordinate& p1, const Coordinate& p2,
+ const Coordinate& q1, const Coordinate& q2) const
- intersectionWithNormalization(p1, p2, q1, q2, intPtOut);
+ Coordinate intPtOut = intersectionSafe(p1, p2, q1, q2);
* Due to rounding it can happen that the computed intersection is
@@ -894,47 +893,7 @@ LineIntersector::intersection(const Coordinate& p1,
intPtOut.z = ztot / zvals;
#endif // COMPUTE_Z
-/*private*/
-void
-LineIntersector::intersectionWithNormalization(const Coordinate& p1,
- Coordinate n1 = p1;
- Coordinate n2 = p2;
- Coordinate n3 = q1;
- Coordinate n4 = q2;
- Coordinate normPt;
- normalizeToEnvCentre(n1, n2, n3, n4, normPt);
- safeHCoordinateIntersection(n1, n2, n3, n4, intPtOut);
- intPtOut.x += normPt.x;
- intPtOut.y += normPt.y;
-/*private*/
-double
-LineIntersector::smallestInAbsValue(double x1, double x2, double x3, double x4) const
- double x = x1;
- double xabs = fabs(x);
- if(fabs(x2) < xabs) {
- x = x2;
- xabs = fabs(x2);
- if(fabs(x3) < xabs) {
- x = x3;
- xabs = fabs(x3);
- if(fabs(x4) < xabs) {
- x = x4;
- return x;
+ return intPtOut;
/*private*/
@@ -947,82 +906,17 @@ LineIntersector::isInSegmentEnvelopes(const Coordinate& pt) const
/*private*/
-void
-LineIntersector::normalizeToEnvCentre(Coordinate& n00, Coordinate& n01,
- Coordinate& n10, Coordinate& n11, Coordinate& normPt) const
+Coordinate
+LineIntersector::intersectionSafe(const Coordinate& p1, const Coordinate& p2,
- double minX0 = n00.x < n01.x ? n00.x : n01.x;
- double minY0 = n00.y < n01.y ? n00.y : n01.y;
- double maxX0 = n00.x > n01.x ? n00.x : n01.x;
- double maxY0 = n00.y > n01.y ? n00.y : n01.y;
- double minX1 = n10.x < n11.x ? n10.x : n11.x;
- double minY1 = n10.y < n11.y ? n10.y : n11.y;
- double maxX1 = n10.x > n11.x ? n10.x : n11.x;
- double maxY1 = n10.y > n11.y ? n10.y : n11.y;
- double intMinX = minX0 > minX1 ? minX0 : minX1;
- double intMaxX = maxX0 < maxX1 ? maxX0 : maxX1;
- double intMinY = minY0 > minY1 ? minY0 : minY1;
- double intMaxY = maxY0 < maxY1 ? maxY0 : maxY1;
- double intMidX = (intMinX + intMaxX) / 2.0;
- double intMidY = (intMinY + intMaxY) / 2.0;
- normPt.x = intMidX;
- normPt.y = intMidY;
- n00.x -= normPt.x;
- n00.y -= normPt.y;
- n01.x -= normPt.x;
- n01.y -= normPt.y;
- n10.x -= normPt.x;
- n10.y -= normPt.y;
- n11.x -= normPt.x;
- n11.y -= normPt.y;
-#if COMPUTE_Z
- // Only do this if input does have Z
- // See https://trac.osgeo.org/geos/ticket/811
- if(std::isnan(n00.z)) {
- return;
+ Coordinate intPt = Intersection::intersection(p1, p2, q1, q2);
+ if (intPt.isNull()) {
+ intPt = nearestEndpoint(p1, p2, q1, q2);
- double minZ0 = n00.z < n01.z ? n00.z : n01.z;
- double minZ1 = n10.z < n11.z ? n10.z : n11.z;
- double maxZ0 = n00.z > n01.z ? n00.z : n01.z;
- double maxZ1 = n10.z > n11.z ? n10.z : n11.z;
- double intMinZ = minZ0 > minZ1 ? minZ0 : minZ1;
- double intMaxZ = maxZ0 < maxZ1 ? maxZ0 : maxZ1;
- double intMidZ = (intMinZ + intMaxZ) / 2.0;
- normPt.z = intMidZ;
- n00.z -= normPt.z;
- n01.z -= normPt.z;
- n10.z -= normPt.z;
- n11.z -= normPt.z;
-#endif
+ return intPt;
-/*private*/
-void
-LineIntersector::safeHCoordinateIntersection(const Coordinate& p1,
- const Coordinate& q2, Coordinate& intPtOut) const
- try {
- HCoordinate::intersection(p1, p2, q1, q2, intPtOut);
-#if GEOS_DEBUG
- cerr << " HCoordinate found intersection h:" << intPt.toString() << endl;
-#endif
- catch(const NotRepresentableException& /* e */) {
- // compute an approximate result
- //intPt = CentralEndpointIntersector::getIntersection(p1, p2, q1, q2);
- intPtOut = nearestEndpoint(p1, p2, q1, q2);
} // namespace geos
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 2579281..75dfb6c 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -21,6 +21,7 @@ libalgorithm_la_SOURCES = \
InteriorPointArea.cpp \
InteriorPointLine.cpp \
InteriorPointPoint.cpp \
+ Intersection.cpp \
LineIntersector.cpp \
Length.cpp \
MinimumBoundingCircle.cpp \
@@ -33,7 +34,6 @@ libalgorithm_la_SOURCES = \
RayCrossingCounterDD.cpp \
RobustDeterminant.cpp
libalgorithm_la_LIBADD = \
locate/liblocation.la \
distance/libdistance.la
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 762d3a9..31ceb24 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -343,11 +343,10 @@ MinimumDiameter::getMinimumRectangle()
LineSegment minParaLine = computeSegmentForLine(-dy, dx, minPara);
// compute vertices of rectangle (where the para/perp max & min lines intersect)
- Coordinate p0, p1, p2, p3;
- maxParaLine.lineIntersection(maxPerpLine, p0);
- minParaLine.lineIntersection(maxPerpLine, p1);
- minParaLine.lineIntersection(minPerpLine, p2);
- maxParaLine.lineIntersection(minPerpLine, p3);
+ Coordinate p0 = maxParaLine.lineIntersection(maxPerpLine);
+ Coordinate p1 = minParaLine.lineIntersection(maxPerpLine);
+ Coordinate p2 = minParaLine.lineIntersection(minPerpLine);
+ Coordinate p3 = maxParaLine.lineIntersection(minPerpLine);
const CoordinateSequenceFactory* csf =
inputGeom->getFactory()->getCoordinateSequenceFactory();
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 1b6bb5d..699316f 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -27,8 +27,7 @@
#include <geos/geom/CoordinateArraySequence.h> // should we really be using this?
-#include <geos/algorithm/NotRepresentableException.h>
#include <geos/util/IllegalStateException.h>
#include <geos/profiler.h>
#include <geos/inline.h>
@@ -41,11 +40,6 @@
# include <geos/geom/LineSegment.inl>
#endif
-using namespace std;
-//using namespace geos::algorithm;
-using geos::algorithm::HCoordinate;
-using geos::algorithm::NotRepresentableException;
-using geos::algorithm::LineIntersector;
namespace geos {
namespace geom { // geos::geom
@@ -194,8 +188,8 @@ std::array<Coordinate, 2>
LineSegment::closestPoints(const LineSegment& line)
// test for intersection
- Coordinate intPt;
- if(intersection(line, intPt)) {
+ Coordinate intPt = intersection(line);
+ if(!intPt.isNull()) {
return { intPt, intPt };
@@ -245,29 +239,23 @@ LineSegment::closestPoints(const LineSegment& line)
return closestPt;
-bool
-LineSegment::intersection(const LineSegment& line, Coordinate& ret) const
+Coordinate
+LineSegment::intersection(const LineSegment& line) const
algorithm::LineIntersector li;
li.computeIntersection(p0, p1, line.p0, line.p1);
if(li.hasIntersection()) {
- ret = li.getIntersection(0);
- return true;
+ return li.getIntersection(0);
- return false;
+ Coordinate rv;
+ rv.setNull();
+ return rv;
-bool
-LineSegment::lineIntersection(const LineSegment& line, Coordinate& ret) const
+Coordinate
+LineSegment::lineIntersection(const LineSegment& line) const
- try {
- HCoordinate::intersection(p0, p1, line.p0, line.p1, ret);
- return true;
- catch(const NotRepresentableException& /*ex*/) {
- // eat this exception, and return null;
- return false;
+ return algorithm::Intersection::intersection(p0, p1, line.p0, line.p1);
diff --git a/src/operation/buffer/OffsetSegmentGenerator.cpp b/src/operation/buffer/OffsetSegmentGenerator.cpp
index 6c392ae..9605ec1 100644
--- a/src/operation/buffer/OffsetSegmentGenerator.cpp
+++ b/src/operation/buffer/OffsetSegmentGenerator.cpp
@@ -33,7 +33,7 @@
#include <geos/util.h>
#ifndef GEOS_DEBUG
@@ -481,43 +481,22 @@ OffsetSegmentGenerator::addMitreJoin(const geom::Coordinate& p,
const geom::LineSegment& p_offset1,
double p_distance)
- bool isMitreWithinLimit = true;
- Coordinate intPt;
- * This computation is unstable if the offset segments
- * are nearly collinear.
- * Howver, this situation should have been eliminated earlier
- * by the check for whether the offset segment endpoints are
- * almost coincident
+ * This computation is unstable if the offset segments are nearly collinear.
+ * However, this situation should have been eliminated earlier by the check
+ * for whether the offset segment endpoints are almost coincident
- try {
- HCoordinate::intersection(p_offset0.p0, p_offset0.p1,
- p_offset1.p0, p_offset1.p1,
- intPt);
- double mitreRatio = p_distance <= 0.0 ? 1.0
- : intPt.distance(p) / fabs(p_distance);
- if(mitreRatio > bufParams.getMitreLimit()) {
- isMitreWithinLimit = false;
+ Coordinate intPt = algorithm::Intersection::intersection(offset0.p0, offset0.p1, offset1.p0, offset1.p1);
+ if (!intPt.isNull()) {
+ double mitreRatio = p_distance <= 0.0 ? 1.0 : intPt.distance(p) / fabs(p_distance);
+ if (mitreRatio <= bufParams.getMitreLimit()) {
+ segList.addPt(intPt);
+ return;
- catch(const NotRepresentableException& e) {
- ::geos::ignore_unused_variable_warning(e);
- intPt = Coordinate(0, 0);
- if(isMitreWithinLimit) {
- segList.addPt(intPt);
- else {
- addLimitedMitreJoin(p_offset0, p_offset1, p_distance,
- bufParams.getMitreLimit());
- //addBevelJoin(offset0, offset1);
+ // at this point either intersection failed or mitre limit was exceeded
+ addLimitedMitreJoin(p_offset0, p_offset1, p_distance,
+ bufParams.getMitreLimit());
/* private */
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 71e1210..a7184de 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -49,6 +49,7 @@ geos_unit_SOURCES = \
algorithm/distance/DiscreteFrechetDistanceTest.cpp \
algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
algorithm/InteriorPointAreaTest.cpp \
+ algorithm/IntersectionTest.cpp \
algorithm/LengthTest.cpp \
algorithm/LocatePointInRingTest.cpp \
algorithm/MinimumBoundingCircleTest.cpp \
diff --git a/tests/unit/algorithm/IntersectionTest.cpp b/tests/unit/algorithm/IntersectionTest.cpp
index 0000000..9cae8e4
--- /dev/null
+++ b/tests/unit/algorithm/IntersectionTest.cpp
@@ -0,0 +1,117 @@
+ * Copyright (C) 2019 Martin Davis <mtnclimb at gmail.com>
+ * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
+// Test Suite for geos::algorithm::InteriorPointArea
+#include <tut/tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/geom/Geometry.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+namespace tut {
+// Test Group
+// dummy data, not used
+struct test_intersection_data {
+ typedef geos::geom::Geometry Geometry;
+ typedef geos::geom::Coordinate Coordinate;
+ typedef geos::algorithm::Intersection Intersection;
+ geos::io::WKTReader reader;
+ std::unique_ptr<Geometry> geom;
+ double MAX_ABS_ERROR = 1e-5;
+ void checkIntersectionNull(double p1x, double p1y, double p2x, double p2y,
+ double q1x, double q1y, double q2x, double q2y) {
+ Coordinate p1(p1x, p1y);
+ Coordinate p2(p2x, p2y);
+ Coordinate q1(q1x, q1y);
+ Coordinate q2(q2x, q2y);
+ Coordinate actual = Intersection::intersection(p1, p2, q1, q2);
+ ensure("checkIntersectionNull", actual.isNull());
+ void checkIntersection(double p1x, double p1y, double p2x, double p2y,
+ double q1x, double q1y, double q2x, double q2y,
+ double expectedx, double expectedy) {
+ Coordinate expected(expectedx, expectedy);
+ double dist = actual.distance(expected);
+ // std::cout << "Expected: " << expected << " Actual: " << actual << " Dist = " << dist << std::endl;
+ ensure("checkIntersection", dist <= MAX_ABS_ERROR);
+ test_intersection_data()
+typedef test_group<test_intersection_data> group;
+typedef group::object object;
+group test_intersection_data("geos::algorithm::Intersection");
+template<>
+template<>
+void object::test<1>
+ // testSimple
+ checkIntersection(
+ 0,0, 10,10,
+ 0,10, 10,0,
+ 5,5);
+ // testCollinear
+ checkIntersectionNull(
+ 0,0, 10,10,
+ 20,20, 30, 30 );
+ // testParallel
+ 0,0, 10,10,
+ 10,0, 20,10 );
+ // testAlmostCollinear
+ 35613471.6165017, 4257145.306132293, 35613477.7705378, 4257160.528222711,
+ 35613477.77505724, 4257160.539653536, 35613479.85607389, 4257165.92369170,
+ 35613477.772841461, 4257160.5339209242 );
+ // testAlmostCollinearCond
+ 1.6165017, 45.306132293, 7.7705378, 60.528222711,
+ 7.77505724, 60.539653536, 9.85607389, 65.92369170,
+ 7.772841461, 60.5339209242 );
+} // namespace tut
diff --git a/tests/unit/geom/LineSegmentTest.cpp b/tests/unit/geom/LineSegmentTest.cpp
index 701d2e2..eb95aae 100644
--- a/tests/unit/geom/LineSegmentTest.cpp
+++ b/tests/unit/geom/LineSegmentTest.cpp
@@ -14,12 +14,30 @@ namespace tut {
struct test_lineseg_data {
+ typedef geos::geom::LineSegment LineSegment;
geos::geom::Coordinate ph1;
geos::geom::Coordinate ph2;
geos::geom::Coordinate pv1;
geos::geom::Coordinate pv2;
geos::geom::LineSegment h1;
geos::geom::LineSegment v1;
+ double MAX_ABS_ERROR_INTERSECTION = 1e-5;
+ void checkLineIntersection(double p1x, double p1y, double p2x, double p2y,
+ LineSegment seg1(p1x, p1y, p2x, p2y);
+ LineSegment seg2(q1x, q1y, q2x, q2y);
+ Coordinate actual = seg1.lineIntersection(seg2);
+ ensure("checkLineIntersection", dist <= MAX_ABS_ERROR_INTERSECTION);
test_lineseg_data()
: ph1(0, 2), ph2(10, 2), pv1(0, 0), pv2(0, 10), h1(ph1, ph2), v1(pv1, pv2)
@@ -117,5 +135,23 @@ void object::test<6>
ensure_equals(v1.distance(p), 1);
+template<>
+template<>
+void object::test<7>
+ // simple case
+ checkLineIntersection(
+ 0,0, 10,10,
+ 0,10, 10,0,
+ 5,5);
+ //Almost collinear - See JTS GitHub issue #464
} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 6 +-
include/geos/algorithm/CGAlgorithmsDD.h | 14 ++-
include/geos/algorithm/Intersection.h | 61 ++++++++++
include/geos/algorithm/LineIntersector.h | 52 ++-------
include/geos/algorithm/Makefile.am | 1 +
include/geos/geom/LineSegment.h | 10 +-
src/algorithm/CGAlgorithmsDD.cpp | 49 ++++----
src/algorithm/Intersection.cpp | 88 +++++++++++++++
src/algorithm/LineIntersector.cpp | 142 +++---------------------
src/algorithm/Makefile.am | 2 +-
src/algorithm/MinimumDiameter.cpp | 9 +-
src/geom/LineSegment.cpp | 36 ++----
src/operation/buffer/OffsetSegmentGenerator.cpp | 47 +++-----
tests/unit/Makefile.am | 1 +
tests/unit/algorithm/IntersectionTest.cpp | 117 +++++++++++++++++++
tests/unit/geom/LineSegmentTest.cpp | 36 ++++++
16 files changed, 404 insertions(+), 267 deletions(-)
create mode 100644 include/geos/algorithm/Intersection.h
create mode 100644 src/algorithm/Intersection.cpp
create mode 100644 tests/unit/algorithm/IntersectionTest.cpp
hooks/post-receive
More information about the geos-commits
