[geos-commits] [SCM] GEOS branch master updated. 26ccaf42ee19df2ff2f4164a1a7d7a5237e93140
Mon Sep 9 06:21:11 PDT 2019
the project "GEOS".
       via  26ccaf42ee19df2ff2f4164a1a7d7a5237e93140 (commit)
       via  140c81a50ad133f005a0e5e511049ea2328f127c (commit)
      from  32af81367a06cc47725cbf7d0c3b6773862d04d0 (commit)
revisions in full, below.
commit 26ccaf42ee19df2ff2f4164a1a7d7a5237e93140
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 6 20:47:02 2019 -0400
    Add doxygen to Travis
diff --git a/.travis.yml b/.travis.yml
index c4d7633..0af9a79 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -27,7 +27,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-7','cmake','ccache']
+          packages: ['g++-7','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
@@ -39,7 +39,7 @@ matrix:
       addons:
         apt:
           sources: *sources
       env:
         - E="TOOL=cmake && BUILD_TYPE=Coverage && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
@@ -51,7 +51,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-7','ccache','git2cl']
+          packages: ['g++-7','ccache','git2cl','doxygen']
       env:
         - E="TOOL=autotools && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
@@ -63,7 +63,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-4.8','cmake','ccache']
+          packages: ['g++-4.8','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
@@ -75,7 +75,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache','git2cl']
+          packages: ['g++-4.8-multilib','gcc-4.8-multilib','g++-multilib','gcc-multilib','ccache','git2cl','doxygen']
       env:
         - E="TOOL=autotools && CXX=g++-4.8 && ARCH=-m32 && CC=gcc-4.8"
@@ -87,7 +87,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['clang-3.9','cmake','ccache']
+          packages: ['clang-3.9','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
@@ -99,7 +99,7 @@ matrix:
       addons:
         apt:
           sources: *sources
-          packages: ['clang','cmake','ccache']
+          packages: ['clang','cmake','ccache','doxygen']
       env:
         - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && ARCH=-m64 && CC=clang"
commit 140c81a50ad133f005a0e5e511049ea2328f127c
Date:   Thu Sep 5 20:43:29 2019 -0400
    Add Doxygen "docs" target to CMake build
    Must be explicitly enabled using -DBUILD_DOCUMENTATION=YES
    Direct all warnings to a log file that can be grepped for specific
    errors as part of a CI build.
    Fixes #902
diff --git a/configure.ac b/configure.ac
index 5067088..8677887 100644
--- a/configure.ac
+++ b/configure.ac
@@ -53,6 +53,8 @@ dnl -- JTS_PORT: the version of JTS this release is bound to
 dnl JTS_PORT=1.13.0
 JTS_PORT=`cat $VERTXT | awk -F= '/^JTS_PORT/ {print $2}'`
+DOXYGEN_LOGFILE=
+AC_SUBST(DOXYGEN_LOGFILE)
 dnl Hush warnings
 AC_DEFINE(USE_UNSTABLE_GEOS_CPP_API, [1], [We know])
diff --git a/doc/CMakeLists.txt b/doc/CMakeLists.txt
index f2295fe..f855379 100644
--- a/doc/CMakeLists.txt
+++ b/doc/CMakeLists.txt
@@ -2,6 +2,7 @@
 # Part of CMake configuration for GEOS
 # Copyright (C) 2018 Mateusz Loskot <mateusz at loskot.net>
+# Copyright (C) 2019 Daniel Baston <dbaston at gmail.com>
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
@@ -15,3 +16,24 @@ target_link_libraries(example PRIVATE geos)
 target_include_directories(test_geos_unit
         PRIVATE
         $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
+option(BUILD_DOCUMENTATION "Build Doxygen documentation" OFF)
+if(BUILD_DOCUMENTATION)
+    find_package(Doxygen)
+    if(NOT DOXYGEN_FOUND)
+        message(FATAL_ERROR "Doxygen was not found.")
+    endif()
+    set(srcdir ${CMAKE_CURRENT_SOURCE_DIR})
+    set(DOXYGEN_LOGFILE ${CMAKE_CURRENT_BINARY_DIR}/doxygen_log)
+    configure_file(${CMAKE_CURRENT_SOURCE_DIR}/Doxyfile.in
+                   ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile
+                   @ONLY)
+    unset(srcdir)
+    unset(DOXYGEN_LOGFILE)
+    add_custom_target(docs
+            COMMAND ${DOXYGEN_EXECUTABLE} ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile)
+endif()
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index ef93b77..fd61667 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -779,7 +779,7 @@ WARN_FORMAT            = "$file:$line: $text"
 # messages should be written. If left blank the output is written to standard
 # error (stderr).
-WARN_LOGFILE           =
+WARN_LOGFILE           = @DOXYGEN_LOGFILE@
 # Configuration options related to the input files
@@ -853,6 +853,7 @@ EXCLUDE_PATTERNS       = */examples/* \
                          */test/* \
                          */bigtest/* \
                          */io/markup/* \
+                         */ttmath/* \
                          config.h \
                          acconfig.h \
                          CoordinateList.cpp \
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index 583ff6b..287abda 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -13,8 +13,9 @@ source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
 cmake --version
-cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} ${TRAVIS_BUILD_DIR}
+cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -DBUILD_DOCUMENTATION=YES ${TRAVIS_BUILD_DIR}
 run_make
+cmake --build . --target docs
 ctest --output-on-failure .
 if [ "${BUILD_TYPE}" = "Coverage" ]; then
Summary of changes:
 .travis.yml              | 14 +++++++-------
 configure.ac             |  2 ++
 doc/CMakeLists.txt       | 22 ++++++++++++++++++++++
 doc/Doxyfile.in          |  3 ++-
 tools/ci/script_cmake.sh |  3 ++-
 5 files changed, 35 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
