[geos-commits] [SCM] GEOS branch master updated. 311b64a08768c3d4f2329ec4647070928058bcd2
git at osgeo.org
git at osgeo.org
Wed Sep 18 08:38:36 PDT 2019
the project "GEOS".
via 311b64a08768c3d4f2329ec4647070928058bcd2 (commit)
from d47ea8c428da1ed4957916c49268740b362db9fb (commit)
revisions in full, below.
commit 311b64a08768c3d4f2329ec4647070928058bcd2
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 18 08:37:46 2019 -0700
Improve the bit-shifting logic with good types and so on
Even Roualt, Kurt Schwehr
References #869
diff --git a/src/precision/CommonBits.cpp b/src/precision/CommonBits.cpp
index a960803..b2ba370 100644
--- a/src/precision/CommonBits.cpp
+++ b/src/precision/CommonBits.cpp
@@ -44,11 +44,12 @@ CommonBits::numCommonMostSigMantissaBits(int64 num1, int64 num2)
int64
CommonBits::zeroLowerBits(int64 bits, int nBits)
- if (nBits >= 64) return 0;
- int64 invMask = (1 << nBits) - 1;
- int64 mask = ~ invMask;
- int64 zeroed = bits & mask;
- return zeroed;
+ if (nBits >= 64 || nBits < 1) return 0;
+ const uint64_t bits_ = static_cast<uint64_t>(bits);
+ const uint64_t invMask = (1ull << nBits) - 1;
+ const uint64_t mask = ~ invMask;
+ const uint64_t zeroed = bits_ & mask;
+ return static_cast<int64>(zeroed);
/*static public*/
diff --git a/tests/unit/precision/CommonBitsTest.cpp b/tests/unit/precision/CommonBitsTest.cpp
index 02e36df..3ddea74 100644
--- a/tests/unit/precision/CommonBitsTest.cpp
+++ b/tests/unit/precision/CommonBitsTest.cpp
@@ -53,4 +53,28 @@ void object::test<3>
ensure_equals(CommonBits::getBit(val, 63), 1);
+// zeroLowerBits.
+template<>
+template<>
+void object::test<4>()
+ constexpr int64 val = static_cast<int64>(0xffffffffffffffffull);
+ ensure_equals(sizeof(val), 8);
+ ensure_equals(CommonBits::zeroLowerBits(val, -1), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 0), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 1), -2);
+ ensure_equals(CommonBits::zeroLowerBits(val, 2), -4);
+ ensure_equals(CommonBits::zeroLowerBits(val, 16), -65536);
+ ensure_equals(CommonBits::zeroLowerBits(val, 31), -2147483648ll);
+ ensure_equals(CommonBits::zeroLowerBits(val, 32), -4294967296ll);
+ ensure_equals(CommonBits::zeroLowerBits(val, 62), -4611686018427387904ll);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 62)), 0xc000000000000000ull);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 63)), 9223372036854775808ull);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 63)), 0x8000000000000000ull);
+ ensure_equals(CommonBits::zeroLowerBits(val, 64), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 10000), 0);
} // namespace tut
Summary of changes:
src/precision/CommonBits.cpp | 11 ++++++-----
tests/unit/precision/CommonBitsTest.cpp | 24 ++++++++++++++++++++++++
2 files changed, 30 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
