[geos-commits] [SCM] GEOS branch 3.7 updated. 3e8be5b6f78961093ab7dbb5f404b20746618845
git at osgeo.org
git at osgeo.org
Wed Sep 18 08:45:59 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
via 3e8be5b6f78961093ab7dbb5f404b20746618845 (commit)
from 6c5b169568dc1e9556748e56bb83f3875018bccc (commit)
revisions in full, below.
commit 3e8be5b6f78961093ab7dbb5f404b20746618845
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Sep 18 08:45:43 2019 -0700
Improve the bit-shifting logic with good types and so on
Even Roualt, Kurt Schwehr
References #869
diff --git a/src/precision/CommonBits.cpp b/src/precision/CommonBits.cpp
index 547ed5b..f54482d 100644
--- a/src/precision/CommonBits.cpp
+++ b/src/precision/CommonBits.cpp
@@ -43,11 +43,12 @@ CommonBits::numCommonMostSigMantissaBits(int64 num1, int64 num2)
int64
CommonBits::zeroLowerBits(int64 bits, int nBits)
- if (nBits >= 64) return 0;
- int64 invMask = (1<< nBits)-1;
- int64 mask = ~ invMask;
- int64 zeroed = bits & mask;
- return zeroed;
+ if (nBits >= 64 || nBits < 1) return 0;
+ const uint64_t bits_ = static_cast<uint64_t>(bits);
+ const uint64_t invMask = (1ull << nBits) - 1;
+ const uint64_t mask = ~ invMask;
+ const uint64_t zeroed = bits_ & mask;
+ return static_cast<int64>(zeroed);
/*static public*/
diff --git a/tests/unit/precision/CommonBitsTest.cpp b/tests/unit/precision/CommonBitsTest.cpp
index e3c0bf4..1114074 100644
--- a/tests/unit/precision/CommonBitsTest.cpp
+++ b/tests/unit/precision/CommonBitsTest.cpp
@@ -11,46 +11,69 @@ using geos::precision::CommonBits;
namespace tut
- // Common data used by tests
- struct test_commonbits_data {};
- typedef test_group<test_commonbits_data> group;
- typedef group::object object;
- group test_commonbits_group("geos::precision::CommonBits");
- // getBit from zero.
- template<>
- template<>
- void object::test<1>()
- constexpr int64 val = 0ull;
- for (int i=0; i < 64; i++)
- ensure_equals(CommonBits::getBit(val, i), 0);
- // getBit from all ones.
- template<>
- template<>
- void object::test<2>()
- constexpr int64 val = 0xffffffffffffffffull;
- ensure_equals(CommonBits::getBit(val, i), 1);
- // getBit check high versus low bits.
- template<>
- template<>
- void object::test<3>()
- constexpr int64 val = 0xffffffff00000000ull;
- ensure_equals(CommonBits::getBit(val, 0), 0);
- ensure_equals(CommonBits::getBit(val, 63), 1);
+ // Common data used by tests
+ struct test_commonbits_data {};
+ typedef test_group<test_commonbits_data> group;
+ typedef group::object object;
+ group test_commonbits_group("geos::precision::CommonBits");
+ // getBit from zero.
+ template<>
+ template<>
+ void object::test<1>()
+ constexpr int64 val = 0ull;
+ for (int i=0; i < 64; i++)
+ ensure_equals(CommonBits::getBit(val, i), 0);
+ // getBit from all ones.
+ template<>
+ template<>
+ void object::test<2>()
+ constexpr int64 val = 0xffffffffffffffffull;
+ ensure_equals(CommonBits::getBit(val, i), 1);
+ // getBit check high versus low bits.
+ template<>
+ template<>
+ void object::test<3>()
+ constexpr int64 val = 0xffffffff00000000ull;
+ ensure_equals(CommonBits::getBit(val, 0), 0);
+ ensure_equals(CommonBits::getBit(val, 63), 1);
+ // zeroLowerBits.
+ template<>
+ template<>
+ void object::test<4>()
+ constexpr int64 val = static_cast<int64>(0xffffffffffffffffull);
+ ensure_equals(sizeof(val), 8);
+ ensure_equals(CommonBits::zeroLowerBits(val, -1), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 0), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 1), -2);
+ ensure_equals(CommonBits::zeroLowerBits(val, 2), -4);
+ ensure_equals(CommonBits::zeroLowerBits(val, 16), -65536);
+ ensure_equals(CommonBits::zeroLowerBits(val, 31), -2147483648ll);
+ ensure_equals(CommonBits::zeroLowerBits(val, 32), -4294967296ll);
+ ensure_equals(CommonBits::zeroLowerBits(val, 62), -4611686018427387904ll);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 62)), 0xc000000000000000ull);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 63)), 9223372036854775808ull);
+ ensure_equals(static_cast<uint64_t>(CommonBits::zeroLowerBits(val, 63)), 0x8000000000000000ull);
+ ensure_equals(CommonBits::zeroLowerBits(val, 64), 0);
+ ensure_equals(CommonBits::zeroLowerBits(val, 10000), 0);
} // namespace tut
Summary of changes:
src/precision/CommonBits.cpp | 11 ++--
tests/unit/precision/CommonBitsTest.cpp | 105 +++++++++++++++++++-------------
2 files changed, 70 insertions(+), 46 deletions(-)
hooks/post-receive
More information about the geos-commits
