[geos-commits] [SCM] GEOS branch master updated. f1c5dcecc2daf47b76941919a60e3c06ace8f5a3
Wed Sep 18 15:15:54 PDT 2019
the project "GEOS".
       via  f1c5dcecc2daf47b76941919a60e3c06ace8f5a3 (commit)
       via  823467f36cb86c94a140351cfc2d7735fa1a713e (commit)
       via  a16006c14c56b7f68997f9c8c947cd9b64583dca (commit)
       via  3c5d8252a5a48e64685a76e0766fce68d7394275 (commit)
       via  628542854071fc8e8c314827b4b7697c877ce994 (commit)
      from  abaa838bb869419d178c96653c7d066422664bf5 (commit)
revisions in full, below.
commit f1c5dcecc2daf47b76941919a60e3c06ace8f5a3
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Sep 18 14:27:03 2019 -0400
    Use simpler GeometryFactory methods in GeometryTransformer
diff --git a/src/geom/util/GeometryTransformer.cpp b/src/geom/util/GeometryTransformer.cpp
index 49f3f08..67b9106 100644
--- a/src/geom/util/GeometryTransformer.cpp
+++ b/src/geom/util/GeometryTransformer.cpp
@@ -44,8 +44,6 @@
 #include <iostream>
 #endif
-using namespace std;
 namespace geos {
 namespace geom { // geos.geom
 namespace util { // geos.geom.util
@@ -74,7 +72,7 @@ GeometryTransformer::setSkipTransformedInvalidInteriorRings(bool b)
 /*public*/
-unique_ptr<Geometry>
+std::unique_ptr<Geometry>
 GeometryTransformer::transform(const Geometry* nInputGeom)
     using geos::util::IllegalArgumentException;
@@ -168,7 +166,7 @@ GeometryTransformer::transformMultiPoint(
               std::endl;
 #endif
-    vector<Geometry*>* transGeomList = new vector<Geometry*>();
+    std::vector<std::unique_ptr<Geometry>> transGeomList;
     for(size_t i = 0, n = geom->getNumGeometries(); i < n; i++) {
         const Point* p = dynamic_cast<const Point*>(geom->getGeometryN(i));
@@ -182,11 +180,10 @@ GeometryTransformer::transformMultiPoint(
             continue;
-        // If an exception is thrown we'll leak
-        transGeomList->push_back(transformGeom.release());
+        transGeomList.push_back(std::move(transformGeom));
-    return Geometry::Ptr(factory->buildGeometry(transGeomList));
+    return factory->buildGeometry(std::move(transGeomList));
@@ -245,7 +242,7 @@ GeometryTransformer::transformMultiLineString(
               << std::endl;
 #endif
         const LineString* l = dynamic_cast<const LineString*>(
@@ -260,11 +257,10 @@ GeometryTransformer::transformMultiLineString(
             continue;
@@ -292,7 +288,7 @@ GeometryTransformer::transformPolygon(
         isAllValidLinearRings = false;
-    vector<LinearRing*>* holes = new vector<LinearRing*>();
+    std::vector<std::unique_ptr<LinearRing>> holes;
     for(size_t i = 0, n = geom->getNumInteriorRing(); i < n; i++) {
         const LinearRing* p_lr = geom->getInteriorRingN(i);
         assert(p_lr);
@@ -303,35 +299,32 @@ GeometryTransformer::transformPolygon(
             continue;
-        if(! dynamic_cast<LinearRing*>(hole.get())) {
+        if(dynamic_cast<LinearRing*>(hole.get())) {
+            holes.emplace_back(dynamic_cast<LinearRing*>(hole.release()));
+        } else {
             if(skipTransformedInvalidInteriorRings) {
                 continue;
-        holes->push_back(dynamic_cast<LinearRing*>(hole.release()));
     if(isAllValidLinearRings) {
-        Geometry* sh = shell.release();
-        LinearRing* p_lr = dynamic_cast<LinearRing*>(sh);
-        assert(p_lr);
-        return Geometry::Ptr(factory->createPolygon(p_lr, holes));
+        std::unique_ptr<LinearRing> shell_lr(dynamic_cast<LinearRing*>(shell.release()));
+        return factory->createPolygon(std::move(shell_lr), std::move(holes));
     else {
-        // would like to use a manager constructor here
-        vector<Geometry*>* components = new vector<Geometry*>();
+        std::vector<std::unique_ptr<Geometry>> components;
         if(shell.get() != nullptr) {
-            components->push_back(shell.release());
+            components.push_back(std::move(shell));
-        components->insert(components->end(),
-                           holes->begin(), holes->end());
-        delete holes; // :(
+        for (auto& g : holes) {
+            components.push_back(std::move(g));
-        return Geometry::Ptr(factory->buildGeometry(components));
+        return factory->buildGeometry(std::move(components));
@@ -348,7 +341,7 @@ GeometryTransformer::transformMultiPolygon(
               std::endl;
 #endif
-    unique_ptr< vector<Geometry*> > transGeomList(new vector<Geometry*>());
     for(std::size_t i = 0, n = geom->getNumGeometries(); i < n; i++) {
         const Polygon* p = dynamic_cast<const Polygon*>(
@@ -363,11 +356,10 @@ GeometryTransformer::transformMultiPolygon(
             continue;
-    return Geometry::Ptr(factory->buildGeometry(transGeomList.release()));
@@ -383,7 +375,7 @@ GeometryTransformer::transformGeometryCollection(
               << ");" << std::endl;
 #endif
         Geometry::Ptr transformGeom = transform(
@@ -395,16 +387,14 @@ GeometryTransformer::transformGeometryCollection(
             continue;
     if(preserveGeometryCollectionType) {
-        return Geometry::Ptr(factory->createGeometryCollection(
-                                 transGeomList));
+        return factory->createGeometryCollection(std::move(transGeomList));
     else {
commit 823467f36cb86c94a140351cfc2d7735fa1a713e
Date:   Wed Sep 18 12:07:14 2019 -0400
    Add GeometryFactory::buildGeometry signature and simplify implementations
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 0c00b71..6393c67 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -328,6 +328,8 @@ public:
     Geometry* buildGeometry(std::vector<Geometry*>* geoms) const;
+    std::unique_ptr<Geometry> buildGeometry(std::vector<std::unique_ptr<Geometry>> && geoms) const;
     /// See buildGeometry(std::vector<Geometry *>&) for semantics
     /// Will clone the geometries accessible trough the iterator.
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 7ba51e9..8925e2f 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -647,6 +647,32 @@ const
     return g;
+template<typename T>
+GeometryTypeId commonType(const T& geoms) {
+    if (geoms.empty()) {
+        return GEOS_GEOMETRYCOLLECTION;
+    if (geoms.size() == 1) {
+        return geoms[0]->getGeometryTypeId();
+    GeometryTypeId type = geoms[0]->getGeometryTypeId();
+    for (size_t i = 1; i < geoms.size(); i++) {
+        if (geoms[i]->getGeometryTypeId() != type) {
+    switch(geoms[0]->getGeometryTypeId()) {
+        case GEOS_POINT: return GEOS_MULTIPOINT;
+        case GEOS_LINEARRING:
+        case GEOS_LINESTRING: return GEOS_MULTILINESTRING;
+        case GEOS_POLYGON: return GEOS_MULTIPOLYGON;
+        default: return GEOS_GEOMETRYCOLLECTION;
 /*public*/
 Geometry*
 GeometryFactory::buildGeometry(vector<Geometry*>* newGeoms) const
@@ -657,91 +683,63 @@ GeometryFactory::buildGeometry(vector<Geometry*>* newGeoms) const
         return createGeometryCollection().release();
-    bool isHeterogeneous = false;
-    bool hasGeometryCollection = false;
-    GeometryTypeId type = (*newGeoms)[0]->getGeometryTypeId();
+    if (newGeoms->size() == 1) {
+        Geometry* ret = (*newGeoms)[0];
+        delete newGeoms;
+        return ret;
-    for(Geometry* gp : *newGeoms) {
-        GeometryTypeId geometryType = gp->getGeometryTypeId();
-        if(type != geometryType) {
-            isHeterogeneous = true;
-        if(geometryType == GEOS_GEOMETRYCOLLECTION) {
-            hasGeometryCollection = true;
+    auto resultType = commonType(*newGeoms);
+    switch(resultType) {
+        case GEOS_MULTIPOINT: return createMultiPoint(newGeoms);
+        case GEOS_MULTILINESTRING: return createMultiLineString(newGeoms);
+        case GEOS_MULTIPOLYGON: return createMultiPolygon(newGeoms);
+        default: return createGeometryCollection(newGeoms);
-    if(isHeterogeneous || hasGeometryCollection) {
-        return createGeometryCollection(newGeoms);
+GeometryFactory::buildGeometry(std::vector<std::unique_ptr<Geometry>> && geoms) const
+        return createGeometryCollection();
-    // At this point we know the collection is not hetereogenous.
-    bool isCollection = newGeoms->size() > 1;
-    if(isCollection) {
-        if(type == GEOS_POLYGON) {
-            return createMultiPolygon(newGeoms);
-        else if(type == GEOS_LINESTRING) {
-            return createMultiLineString(newGeoms);
-        else if(type == GEOS_LINEARRING) {
-        else if(type == GEOS_POINT) {
-            return createMultiPoint(newGeoms);
-        else {
+        return std::move(geoms[0]);
-    // since this is not a collection we can delete vector
-    Geometry* geom0 = (*newGeoms)[0];
-    delete newGeoms;
-    return geom0;
+    auto resultType = commonType(geoms);
+        case GEOS_MULTIPOINT: return createMultiPoint(std::move(geoms));
+        case GEOS_MULTILINESTRING: return createMultiLineString(std::move(geoms));
+        case GEOS_MULTIPOLYGON: return createMultiPolygon(std::move(geoms));
+        default: return createGeometryCollection(std::move(geoms));
 /*public*/
 Geometry*
 GeometryFactory::buildGeometry(const vector<const Geometry*>& fromGeoms) const
-    size_t geomsSize = fromGeoms.size();
-    if(geomsSize == 0) {
+    if(fromGeoms.empty()) {
-    if(geomsSize == 1) {
+    if(fromGeoms.size() == 1) {
         return fromGeoms[0]->clone().release();
-    GeometryTypeId type = fromGeoms[0]->getGeometryTypeId();
+    auto resultType = commonType(fromGeoms);
-    for(const Geometry* gp : fromGeoms) {
+        case GEOS_MULTIPOINT: return createMultiPoint(fromGeoms);
+        case GEOS_MULTILINESTRING: return createMultiLineString(fromGeoms);
+        case GEOS_MULTIPOLYGON: return createMultiPolygon(fromGeoms);
+        default: return createGeometryCollection(fromGeoms);
-    if(isHeterogeneous) {
-        return createGeometryCollection(fromGeoms);
-        return createMultiPolygon(fromGeoms);
-        return createMultiLineString(fromGeoms);
-        return createMultiPoint(fromGeoms);
-    throw geos::util::GEOSException("GeometryFactory::buildGeometry encountered an unknown geometry type!");
 /*public*/
commit a16006c14c56b7f68997f9c8c947cd9b64583dca
Date:   Wed Sep 18 11:13:33 2019 -0400
    Use simpler GeometryFactory methods in CoordinateOperation
diff --git a/src/geom/util/CoordinateOperation.cpp b/src/geom/util/CoordinateOperation.cpp
index 7676fb7..b3d383c 100644
--- a/src/geom/util/CoordinateOperation.cpp
+++ b/src/geom/util/CoordinateOperation.cpp
@@ -34,12 +34,12 @@ CoordinateOperation::edit(const Geometry* geometry,
         const CoordinateSequence* coords = ring->getCoordinatesRO();
         auto newCoords = edit(coords, geometry);
         // LinearRing instance takes over ownership of newCoords instance
-        return std::unique_ptr<Geometry>(factory->createLinearRing(newCoords.release()));
+        return factory->createLinearRing(std::move(newCoords));
     if(const LineString* line = dynamic_cast<const LineString*>(geometry)) {
         const CoordinateSequence* coords = line->getCoordinatesRO();
-        return std::unique_ptr<Geometry>(factory->createLineString(newCoords.release()));
+        return factory->createLineString(std::move(newCoords));
     if(const Point* point = dynamic_cast<const Point*>(geometry)) {
         auto coords = point->getCoordinatesRO();
commit 3c5d8252a5a48e64685a76e0766fce68d7394275
Date:   Wed Sep 18 11:11:09 2019 -0400
    Use simpler GeometryFactory methods in WKBReader
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index ff1e260..f264f38 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -291,7 +291,7 @@ WKBReader::readLineString()
     cout << "WKB npoints: " << size << endl;
 #endif
     auto pts = readCoordinateSequence(size);
-    return std::unique_ptr<LineString>(factory.createLineString(pts.release()));
+    return factory.createLineString(std::move(pts));
@@ -302,7 +302,7 @@ WKBReader::readLinearRing()
 #endif
-    return std::unique_ptr<LinearRing>(factory.createLinearRing(pts.release()));
+    return factory.createLinearRing(std::move(pts));
 std::unique_ptr<Polygon>
commit 628542854071fc8e8c314827b4b7697c877ce994
Date:   Wed Sep 18 11:05:40 2019 -0400
    Avoid vector heap alloc in BuildArea
diff --git a/src/operation/polygonize/BuildArea.cpp b/src/operation/polygonize/BuildArea.cpp
index f120332..6b4b923 100644
--- a/src/operation/polygonize/BuildArea.cpp
+++ b/src/operation/polygonize/BuildArea.cpp
@@ -117,15 +117,15 @@ static void findFaceHoles(std::vector<std::unique_ptr<Face>>& faces) {
 static std::unique_ptr<geom::MultiPolygon> collectFacesWithEvenAncestors(
-    std::vector<geom::Geometry*>* geoms = new std::vector<geom::Geometry*>();
+    std::vector<std::unique_ptr<geom::Geometry>> geoms;
     for( auto& face: faces ) {
         if( face->countParents() % 2 ) {
             continue; /* we skip odd parents geoms */
-        geoms->push_back(face->poly->clone().release());
+        geoms.push_back(face->poly->clone());
-    return std::unique_ptr<geom::MultiPolygon>(
-        GeometryFactory::create()->createMultiPolygon(geoms));
+    // TODO don't create new GeometryFactory here
+    return GeometryFactory::create()->createMultiPolygon(std::move(geoms));
 #ifdef DUMP_GEOM
@@ -145,6 +145,7 @@ unique_ptr<geom::Geometry> BuildArea::build(const geom::Geometry* geom) {
     // No geometries in collection, early out
     if( polys->empty() ) {
         auto emptyGeomCollection = unique_ptr<geom::Geometry>(
             GeometryFactory::create()->createGeometryCollection());
         emptyGeomCollection->setSRID(geom->getSRID());
Summary of changes:
 include/geos/geom/GeometryFactory.h    |   2 +
 src/geom/GeometryFactory.cpp           | 126 ++++++++++++++++-----------------
 src/geom/util/CoordinateOperation.cpp  |   4 +-
 src/geom/util/GeometryTransformer.cpp  |  62 +++++++---------
 src/io/WKBReader.cpp                   |   4 +-
 src/operation/polygonize/BuildArea.cpp |   9 +--
 6 files changed, 99 insertions(+), 108 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
