[geos-commits] [SCM] GEOS branch master updated. a1710cdc950658e3dcc9cb4d52c352052587ef72
git at osgeo.org
git at osgeo.org
Wed Sep 18 15:23:16 PDT 2019
the project "GEOS".
via a1710cdc950658e3dcc9cb4d52c352052587ef72 (commit)
from f1c5dcecc2daf47b76941919a60e3c06ace8f5a3 (commit)
revisions in full, below.
commit a1710cdc950658e3dcc9cb4d52c352052587ef72
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Sep 18 18:23:03 2019 -0400
Simplify FuzzyPointLocator
diff --git a/src/operation/overlay/validate/FuzzyPointLocator.cpp b/src/operation/overlay/validate/FuzzyPointLocator.cpp
index e9cc604..ac2ffdd 100644
--- a/src/operation/overlay/validate/FuzzyPointLocator.cpp
+++ b/src/operation/overlay/validate/FuzzyPointLocator.cpp
@@ -37,7 +37,6 @@
#define USE_ELEVATION_MATRIX 1
#define USE_INPUT_AVGZ 0
-using namespace std;
using namespace geos::geom;
using namespace geos::algorithm;
@@ -62,30 +61,17 @@ FuzzyPointLocator::extractLineWork(const geom::Geometry& geom)
::geos::ignore_unused_variable_warning(geom);
- vector<Geometry*>* lineGeoms = new vector<Geometry*>();
- try { // geoms array will leak if an exception is thrown
+ std::vector<std::unique_ptr<Geometry>> lineGeoms;
- for(size_t i = 0, n = g.getNumGeometries(); i < n; ++i) {
- const Geometry* gComp = g.getGeometryN(i);
- Geometry* lineGeom = nullptr;
+ for(size_t i = 0, n = g.getNumGeometries(); i < n; ++i) {
+ const Geometry* gComp = g.getGeometryN(i);
- // only get linework for polygonal components
- if(gComp->getDimension() == 2) {
- lineGeom = gComp->getBoundary().release();
- lineGeoms->push_back(lineGeom);
+ // only get linework for polygonal components
+ if(gComp->getDimension() == Dimension::A) {
+ lineGeoms.push_back(gComp->getBoundary());
- return std::unique_ptr<Geometry>(g.getFactory()->buildGeometry(lineGeoms));
- catch(...) { // avoid leaks
- for(size_t i = 0, n = lineGeoms->size(); i < n; ++i) {
- delete(*lineGeoms)[i];
- delete lineGeoms;
- throw;
+ return g.getFactory()->buildGeometry(std::move(lineGeoms));
/*private*/
@@ -94,39 +80,25 @@ FuzzyPointLocator::getLineWork(const geom::Geometry& geom)
- Geometry* lineGeom;
- else {
- lineGeom = gComp->clone().release();
+ if(gComp->getDimension() == 2) {
+ } else {
+ lineGeoms.push_back(gComp->clone());
- delete lineGeoms;
- throw;
/* public */
Location
FuzzyPointLocator::getLocation(const Coordinate& pt)
- unique_ptr<Geometry> point(g.getFactory()->createPoint(pt));
+ std::unique_ptr<Geometry> point(g.getFactory()->createPoint(pt));
double dist = linework->distance(point.get());
Summary of changes:
.../overlay/validate/FuzzyPointLocator.cpp | 60 ++++++----------------
1 file changed, 16 insertions(+), 44 deletions(-)
hooks/post-receive
More information about the geos-commits
