[geos-commits] [SCM] GEOS branch master updated. c17501f0a9c5132e455eb5995be5ebcf536f7bb6
git at osgeo.org
git at osgeo.org
Wed Sep 18 16:28:18 PDT 2019
the project "GEOS".
via c17501f0a9c5132e455eb5995be5ebcf536f7bb6 (commit)
via 6493e5760af104f17789e7c02f0436bf0a4e9204 (commit)
from a1710cdc950658e3dcc9cb4d52c352052587ef72 (commit)
revisions in full, below.
commit c17501f0a9c5132e455eb5995be5ebcf536f7bb6
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed Sep 18 19:18:26 2019 -0400
Return unique_ptr from MinimumBoundingCircle
diff --git a/include/geos/algorithm/MinimumBoundingCircle.h b/include/geos/algorithm/MinimumBoundingCircle.h
index 1e62c56..76b64fe 100644
--- a/include/geos/algorithm/MinimumBoundingCircle.h
+++ b/include/geos/algorithm/MinimumBoundingCircle.h
@@ -93,7 +93,7 @@ public:
* @return a empty LineString if the input is empty
* @return a Point if the input is a point
- geom::Geometry* getFarthestPoints();
+ std::unique_ptr<geom::Geometry> getFarthestPoints();
* Gets a geometry representing the diameter of the computed Minimum Bounding
@@ -103,7 +103,7 @@ public:
- geom::Geometry* getDiameter();
+ std::unique_ptr<geom::Geometry> getDiameter();
* Gets the extremal points which define the computed Minimum Bounding Circle.
diff --git a/src/algorithm/MinimumBoundingCircle.cpp b/src/algorithm/MinimumBoundingCircle.cpp
index 2533278..2a6a508 100644
--- a/src/algorithm/MinimumBoundingCircle.cpp
+++ b/src/algorithm/MinimumBoundingCircle.cpp
@@ -60,15 +60,15 @@ MinimumBoundingCircle::getCircle()
/*public*/
-Geometry*
+std::unique_ptr<Geometry>
MinimumBoundingCircle::getFarthestPoints()
compute();
switch(extremalPts.size()) {
case 0:
- return input->getFactory()->createLineString().release();
+ return input->getFactory()->createLineString();
case 1:
- return input->getFactory()->createPoint(centre);
+ return std::unique_ptr<Geometry>(input->getFactory()->createPoint(centre));
size_t dims = input->getCoordinateDimension();
@@ -76,19 +76,19 @@ MinimumBoundingCircle::getFarthestPoints()
auto cs = input->getFactory()->getCoordinateSequenceFactory()->create(len, dims);
cs->setAt(extremalPts[0], 0);
cs->setAt(extremalPts[extremalPts.size() - 1], 1);
- return input->getFactory()->createLineString(cs.release());
+ return input->getFactory()->createLineString(std::move(cs));
/*public*/
-Geometry*
MinimumBoundingCircle::getDiameter()
compute();
case 0:
case 1:
size_t len = 2;
@@ -97,7 +97,7 @@ MinimumBoundingCircle::getDiameter()
// them through the centre point with len = 2*radius
cs->setAt(extremalPts[1], 1);
/*public*/
commit 6493e5760af104f17789e7c02f0436bf0a4e9204
Date: Wed Sep 18 19:18:50 2019 -0400
Minor simplification in ConvexHull
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 2fd08b3..734459d 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -227,7 +227,7 @@ ConvexHull::getConvexHull()
size_t nInputPts = inputPts.size();
if(nInputPts == 0) { // Return an empty geometry
- return std::unique_ptr<Geometry>(geomFactory->createEmptyGeometry());
+ return geomFactory->createEmptyGeometry();
if(nInputPts == 1) { // Return a Point
@@ -238,7 +238,7 @@ ConvexHull::getConvexHull()
if(nInputPts == 2) { // Return a LineString
// Copy all Coordinates from the ConstVect
auto cs = toCoordinateSequence(inputPts);
- return std::unique_ptr<Geometry>(geomFactory->createLineString(cs.release()));
+ return geomFactory->createLineString(std::move(cs));
// use heuristic to reduce points, if large
Summary of changes:
include/geos/algorithm/MinimumBoundingCircle.h | 4 ++--
src/algorithm/ConvexHull.cpp | 4 ++--
src/algorithm/MinimumBoundingCircle.cpp | 16 ++++++++--------
3 files changed, 12 insertions(+), 12 deletions(-)
hooks/post-receive
More information about the geos-commits
