[geos-commits] [SCM] GEOS branch master updated. 27f86283ab954a905f65495067981276bd1f5fe1
Wed Sep 18 17:26:23 PDT 2019
the project "GEOS".
       via  27f86283ab954a905f65495067981276bd1f5fe1 (commit)
      from  c17501f0a9c5132e455eb5995be5ebcf536f7bb6 (commit)
revisions in full, below.
commit 27f86283ab954a905f65495067981276bd1f5fe1
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Sep 18 20:26:06 2019 -0400
    Simplify access to NodeMap
    Using "auto" removes boilerplate and makes it easier to try different
    backing containers for NodeMap. I tried unordered_map but did not see a
    performance benefit.
diff --git a/include/geos/operation/relate/RelateNodeGraph.h b/include/geos/operation/relate/RelateNodeGraph.h
index 88ee2f4..7f642ee 100644
--- a/include/geos/operation/relate/RelateNodeGraph.h
+++ b/include/geos/operation/relate/RelateNodeGraph.h
@@ -20,6 +20,7 @@
 #define GEOS_OP_RELATE_RELATENODEGRAPH_H
 #include <geos/export.h>
+#include <geos/geomgraph/NodeMap.h>
 #include <map>
 #include <vector>
@@ -35,7 +36,6 @@ namespace geomgraph {
 class Node;
 class GeometryGraph;
 class EdgeEnd;
-class NodeMap;
@@ -73,8 +73,7 @@ public:
     virtual ~RelateNodeGraph();
-    std::map<geom::Coordinate*, geomgraph::Node*,
-        geom::CoordinateLessThen>& getNodeMap();
+    geomgraph::NodeMap::container& getNodeMap();
     void build(geomgraph::GeometryGraph* geomGraph);
diff --git a/src/operation/overlay/LineBuilder.cpp b/src/operation/overlay/LineBuilder.cpp
index 372c382..d89f3a7 100644
--- a/src/operation/overlay/LineBuilder.cpp
+++ b/src/operation/overlay/LineBuilder.cpp
@@ -84,12 +84,10 @@ LineBuilder::build(OverlayOp::OpCode opCode)
 void
 LineBuilder::findCoveredLineEdges()
-// first set covered for all L edges at nodes which have A edges too
-    map<Coordinate*, Node*, CoordinateLessThen>& nodeMap = op->getGraph().getNodeMap()->nodeMap;
-    map<Coordinate*, Node*, CoordinateLessThen>::iterator it = nodeMap.begin();
-    map<Coordinate*, Node*, CoordinateLessThen>::iterator endIt = nodeMap.end();
-    for(; it != endIt; ++it) {
-        Node* node = it->second;
+    // first set covered for all L edges at nodes which have A edges too
+    auto& nodeMap = op->getGraph().getNodeMap()->nodeMap;
+    for(auto& entry : nodeMap) {
+        Node* node = entry.second;
         //node.print(System.out);
         assert(dynamic_cast<DirectedEdgeStar*>(node->getEdges()));
         DirectedEdgeStar* des = static_cast<DirectedEdgeStar*>(node->getEdges());
diff --git a/src/operation/overlay/PointBuilder.cpp b/src/operation/overlay/PointBuilder.cpp
index 6ff6aac..851f9c2 100644
--- a/src/operation/overlay/PointBuilder.cpp
+++ b/src/operation/overlay/PointBuilder.cpp
@@ -61,11 +61,9 @@ PointBuilder::build(OverlayOp::OpCode opCode)
 void
 PointBuilder::extractNonCoveredResultNodes(OverlayOp::OpCode opCode)
-        op->getGraph().getNodeMap()->nodeMap;
-    for(; it != nodeMap.end(); ++it) {
-        Node* n = it->second;
+        Node* n = entry.second;
         // filter out nodes which are known to be in the result
         if(n->isInResult()) {
diff --git a/src/operation/relate/RelateComputer.cpp b/src/operation/relate/RelateComputer.cpp
index 0bc338d..27b6313 100644
--- a/src/operation/relate/RelateComputer.cpp
+++ b/src/operation/relate/RelateComputer.cpp
@@ -413,11 +413,10 @@ RelateComputer::computeDisjointIM(IntersectionMatrix* imX)
 void
 RelateComputer::labelNodeEdges()
-    std::map<Coordinate*, Node*, CoordinateLessThen>& nMap = nodes.nodeMap;
-    std::map<Coordinate*, Node*, CoordinateLessThen>::iterator nodeIt;
-    for(nodeIt = nMap.begin(); nodeIt != nMap.end(); nodeIt++) {
-        assert(dynamic_cast<RelateNode*>(nodeIt->second));
-        RelateNode* node = static_cast<RelateNode*>(nodeIt->second);
+    auto& nMap = nodes.nodeMap;
+    for(auto& entry : nMap) {
+        assert(dynamic_cast<RelateNode*>(entry.second));
+        RelateNode* node = static_cast<RelateNode*>(entry.second);
 #if GEOS_DEBUG
         std::cerr << "RelateComputer::labelNodeEdges: "
                   << "node edges: " << *(node->getEdges())
@@ -433,22 +432,16 @@ RelateComputer::labelNodeEdges()
 void
 RelateComputer::updateIM(IntersectionMatrix& imX)
-    //Debug.println(im);
     std::vector<Edge*>::iterator ei = isolatedEdges.begin();
     for(; ei < isolatedEdges.end(); ++ei) {
         Edge* e = *ei;
         e->GraphComponent::updateIM(imX);
-        RelateNode* node = (RelateNode*) nodeIt->second;
+        RelateNode* node = (RelateNode*) entry.second;
         node->updateIM(imX);
         node->updateIMFromEdges(imX);
-        //node.print(System.out);
diff --git a/src/operation/relate/RelateNodeGraph.cpp b/src/operation/relate/RelateNodeGraph.cpp
index 90b8eb6..e4e8e0a 100644
--- a/src/operation/relate/RelateNodeGraph.cpp
+++ b/src/operation/relate/RelateNodeGraph.cpp
@@ -49,7 +49,7 @@ RelateNodeGraph::~RelateNodeGraph()
     delete nodes;
-map<Coordinate*, Node*, CoordinateLessThen>&
+NodeMap::container&
 RelateNodeGraph::getNodeMap()
     return nodes->nodeMap;
@@ -124,13 +124,11 @@ RelateNodeGraph::computeIntersectionNodes(GeometryGraph* geomGraph,
 void
 RelateNodeGraph::copyNodesAndLabels(GeometryGraph* geomGraph, int argIndex)
-    map<Coordinate*, Node*, CoordinateLessThen>& nMap = geomGraph->getNodeMap()->nodeMap;
-    map<Coordinate*, Node*, CoordinateLessThen>::iterator nodeIt;
-        Node* graphNode = nodeIt->second;
+    auto& nMap = geomGraph->getNodeMap()->nodeMap;
+        Node* graphNode = entry.second;
         Node* newNode = nodes->addNode(graphNode->getCoordinate());
         newNode->setLabel(argIndex, graphNode->getLabel().getLocation(argIndex));
diff --git a/src/operation/valid/ConsistentAreaTester.cpp b/src/operation/valid/ConsistentAreaTester.cpp
index 852df55..c3f3cda 100644
--- a/src/operation/valid/ConsistentAreaTester.cpp
+++ b/src/operation/valid/ConsistentAreaTester.cpp
@@ -87,10 +87,9 @@ ConsistentAreaTester::isNodeEdgeAreaLabelsConsistent()
     assert(geomGraph);
-    map<Coordinate*, Node*, CoordinateLessThen>& nMap = nodeGraph.getNodeMap();
-        relate::RelateNode* node = static_cast<relate::RelateNode*>(nodeIt->second);
+    auto& nMap = nodeGraph.getNodeMap();
+        relate::RelateNode* node = static_cast<relate::RelateNode*>(entry.second);
         if(!node->getEdges()->isAreaLabelsConsistent(*geomGraph)) {
             invalidPoint = node->getCoordinate();
             return false;
@@ -103,11 +102,10 @@ ConsistentAreaTester::isNodeEdgeAreaLabelsConsistent()
 bool
 ConsistentAreaTester::hasDuplicateRings()
-    for(nodeIt = nMap.begin(); nodeIt != nMap.end(); ++nodeIt) {
-        assert(dynamic_cast<relate::RelateNode*>(nodeIt->second));
+        assert(dynamic_cast<relate::RelateNode*>(entry.second));
         EdgeEndStar* ees = node->getEdges();
         EdgeEndStar::iterator endIt = ees->end();
         for(EdgeEndStar::iterator it = ees->begin(); it != endIt; ++it) {
Summary of changes:
 include/geos/operation/relate/RelateNodeGraph.h |  5 ++---
 src/operation/overlay/LineBuilder.cpp           | 10 ++++------
 src/operation/overlay/PointBuilder.cpp          |  8 +++-----
 src/operation/relate/RelateComputer.cpp         | 21 +++++++--------------
 src/operation/relate/RelateNodeGraph.cpp        | 10 ++++------
 src/operation/valid/ConsistentAreaTester.cpp    | 16 +++++++---------
 6 files changed, 27 insertions(+), 43 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
