[geos-commits] [SCM] GEOS branch master updated. 28e20ccf1bdcb6edb339c08a2a7225e23ae05451
git at osgeo.org
git at osgeo.org
Thu Sep 19 08:58:20 PDT 2019
the project "GEOS".
via 28e20ccf1bdcb6edb339c08a2a7225e23ae05451 (commit)
from 9066456df82036cdd5f88b3b0136a667fb6d0279 (commit)
revisions in full, below.
commit 28e20ccf1bdcb6edb339c08a2a7225e23ae05451
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Sep 19 17:58:03 2019 +0200
Move build section from README.md to INSTALL
diff --git a/INSTALL b/INSTALL
index 7e51a13..e9ea10a 100644
--- a/INSTALL
+++ b/INSTALL
@@ -1,114 +1,92 @@
-Compatibility notes
+## Building GEOS From Source
-OS/X 10.6, compile with gcc-4.0 rather than the default gcc that
-comes with XCode.
+### Prerequisites
- CC=gcc-4.0 CXX=g++-4.0 ./configure
+GEOS has no external library dependencies and can be built with any C++11
+compiler.
-Quickstart
+### Unix
-As root:
+GEOS can be built on Unix systems using either the autotools or CMake build
+systems.
- ./configure
- make
- make install
+#### Using Autotools:
-The default install location for GEOS is /usr/local.
+When building GEOS using autotools, a `configure` script must first be generated
+using the `autogen.sh` file included in the root of the repository:
-Linux: Make sure that /usr/local/lib is added to /etc/ld.so.conf
- Make sure that you run /sbin/ldconfig afterwards
+ ./autogen.sh
-Solaris: Make sure that /usr/local/lib is added to LD_LIBRARY_PATH
+An out-of-tree build can then be initiated by creating a subdirectory and
+running the generated `configure` script from that subdirectory:
+ mkdir obj && cd obj && ../configure
-Basic Installation
+Once the `configure` script has run, GEOS can be built by running `make` and
+installed by running `make install`. The test suite can be run using `make
+check`.
-The simplest way to compile this package is:
+#### Using CMake:
+To build `GEOS` using CMake, create a build directory and run the `cmake` command
+from that location:
- 1. `cd' to the directory containing the package's source code and type
- `./configure' to configure the package for your system. If you're
- using `csh' on an old version of System V, you might need to type
- `sh ./configure' instead to prevent `csh' from trying to execute
- `configure' itself.
+ mkdir build && cd build && cmake -DCMAKE_BUILD_TYPE=Release ..
- Running `configure' takes awhile. While running, it prints some
- messages telling which features it is checking for.
+Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
+optimizations.
- 2. Type `make' to compile the package.
+Once the `cmake` tool has run, GEOS can be built by running `make` and
- 3. Optionally, type `make check' to run any self-tests that come with
- the package.
+The entire test suite can be run using `make check`.
+Alternatively, the `ctest` command can be used, which provides more control over test execution.
+For example, `ctest -R unit-capi -j2` uses a regular expression to run all tests
+associated with the C API, using two processes in parallel.
+A list of available tests can be obtained using `ctest -N`.
- 4. Type `make install' to install the programs and any data files and
- documentation.
+### Microsoft Windows
- 5. You can remove the program binaries and object files from the
- source code directory by typing `make clean'. To also remove the
- files that `configure' created (so you can compile the package for
- a different kind of computer), type `make distclean'. There is
- also a `make maintainer-clean' target, but that is intended mainly
- for the package's developers. If you use it, you may have to get
- all sorts of other programs in order to regenerate files that came
- with the distribution.
+GEOS can be built with Microsoft Visual C++ by opening the `CMakeLists.txt` in
+the project root using `File > Open > CMake`.
+If you prefer the command-line
-Compilers and Options
+#### Build with CMake generator for Ninja (fast)
- Some systems require unusual options for compilation or linking that
-the `configure' script does not know about. You can give `configure'
-initial values for variables by setting them in the environment. Using
-a Bourne-compatible shell, you can do that on the command line like
-this:
- CC=c89 CFLAGS=-O2 LIBS=-lposix ./configure
+In the Visual Studio 2019 command prompt, `x64 Native Tools Command Prompt for VS 2019` or `x64_x86 Cross Tools Command Prompt for VS 2019`:
-Or on systems that have the `env' program, you can do it like this:
- env CPPFLAGS=-I/usr/local/include LDFLAGS=-s ./configure
+cmake -S . -B _build_vs2019_ninja -G Ninja -DCMAKE_BUILD_TYPE=Release
+cmake --build _build_vs2019_ninja -j 16 --verbose
+#### Build with CMake generator for MSBuild (default)
-Installation Names
+In the non-specific Command Prompt:
- By default, `make install' will install the package's files in
-`/usr/local/bin', `/usr/local/man', etc. You can specify an
-installation prefix other than `/usr/local' by giving `configure' the
-option `--prefix=PATH'.
+##### 64-bit
+cmake -S . -B _build_vs2019x64 -G "Visual Studio 16 2019" -A x64 -DCMAKE_GENERATOR_TOOLSET=host=x64
+cmake --build _build_vs2019x64 --config Release -j 16 --verbose
-Operation Controls
+##### 32-bit
-`configure' recognizes the following options to control how it
-operates.
+cmake -S . -B _build_vs2019x32 -G "Visual Studio 16 2019" -A x32 -DCMAKE_GENERATOR_TOOLSET=host=x64
+cmake --build _build_vs2019x32 --config Release -j 16 --verbose
---cache-file=FILE
- Use and save the results of the tests in FILE instead of
- `./config.cache'. Set FILE to `/dev/null' to disable caching, for
- debugging `configure'.
+#### Test using CMake
---help
- Print a summary of the options to `configure', and exit.
+cd <build directory>
+ctest --show-only
+ctest
+ctest --output-on-failure
+ctest -V
+ctest -VV
---quiet
---silent
--q
- Do not print messages saying which checks are being made. To
- suppress all normal output, redirect it to `/dev/null' (any error
- messages will still be shown).
---srcdir=DIR
- Look for the package's source code in directory DIR. Usually
- `configure' can determine that directory automatically.
---version
- Print the version of Autoconf used to generate the `configure'
- script, and exit.
---prefix
- Change the default installation location
-`configure' also accepts some other, not widely useful, options.
diff --git a/README.md b/README.md
index b37f684..48cb71d 100644
--- a/README.md
+++ b/README.md
@@ -18,98 +18,9 @@ More information is available the [project homepage](https://trac.osgeo.org/geos
| 3.7 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.7/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.7/) | [](https://dronie.osgeo.org/geos/geos?branch=3.7) | [](https://travis-ci.com/libgeos/geos?branch=3.7) | [](https://gitlab.com/geos/libgeos/commits/3.7) | [](https://ci.appveyor.com/project/dbaston/geos/branch/3.7) ||
| 3.6 | [](https://debbie.postgis.net/view/GEOS/job/GEOS_Branch_3.6/) | [](https://winnie.postgis.net:444/view/GEOS/job/GEOS_Branch_3.6/) | [](https://dronie.osgeo.org/geos/geos?branch=svn-3.6) | [](https://travis-ci.com/libgeos/geos?branch=svn-3.6) | [](https://gitlab.com/geos/libgeos/commits/svn-3.6) | [](https://ci.appveyor.com/project/dbaston/geos/branch/svn-3.6) |
-## Building GEOS From Source
-### Prerequisites
-GEOS has no external library dependencies and can be built with any C++11
-compiler.
-### Unix
-GEOS can be built on Unix systems using either the autotools or CMake build
-systems.
-#### Using Autotools:
-When building GEOS using autotools, a `configure` script must first be generated
-using the `autogen.sh` file included in the root of the repository:
- ./autogen.sh
-An out-of-tree build can then be initiated by creating a subdirectory and
-running the generated `configure` script from that subdirectory:
- mkdir obj && cd obj && ../configure
-Once the `configure` script has run, GEOS can be built by running `make` and
-installed by running `make install`. The test suite can be run using `make
-check`.
-#### Using CMake:
-To build `GEOS` using CMake, create a build directory and run the `cmake` command
-from that location:
- mkdir build && cd build && cmake -DCMAKE_BUILD_TYPE=Release ..
-Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
-optimizations.
-Once the `cmake` tool has run, GEOS can be built by running `make` and
-The entire test suite can be run using `make check`.
-Alternatively, the `ctest` command can be used, which provides more control over test execution.
-For example, `ctest -R unit-capi -j2` uses a regular expression to run all tests
-associated with the C API, using two processes in parallel.
-A list of available tests can be obtained using `ctest -N`.
-### Microsoft Windows
-GEOS can be built with Microsoft Visual C++ by opening the `CMakeLists.txt` in
-the project root using `File > Open > CMake`.
-If you prefer the command-line
-#### Build with CMake generator for Ninja (fast)
-In the Visual Studio 2019 command prompt, `x64 Native Tools Command Prompt for VS 2019` or `x64_x86 Cross Tools Command Prompt for VS 2019`:
-cmake -S . -B _build_vs2019_ninja -G Ninja -DCMAKE_BUILD_TYPE=Release
-cmake --build _build_vs2019_ninja -j 16 --verbose
-#### Build with CMake generator for MSBuild (default)
-In the non-specific Command Prompt:
-##### 64-bit
-cmake -S . -B _build_vs2019x64 -G "Visual Studio 16 2019" -A x64 -DCMAKE_GENERATOR_TOOLSET=host=x64
-cmake --build _build_vs2019x64 --config Release -j 16 --verbose
-##### 32-bit
-cmake -S . -B _build_vs2019x32 -G "Visual Studio 16 2019" -A x32 -DCMAKE_GENERATOR_TOOLSET=host=x64
-cmake --build _build_vs2019x32 --config Release -j 16 --verbose
-#### Test using CMake
-cd <build directory>
-ctest --show-only
-ctest
-ctest --output-on-failure
-ctest -V
-ctest -VV
+## Build/install
+See INSTALL file
## Client applications
Summary of changes:
INSTALL | 144 ++++++++++++++++++++++++++------------------------------------
README.md | 93 +---------------------------------------
2 files changed, 63 insertions(+), 174 deletions(-)
hooks/post-receive
More information about the geos-commits
