[geos-commits] [SCM] GEOS branch master updated. 1df959cc8a39807e63a09bff6953ef43d434ccbf
git at osgeo.org
git at osgeo.org
Fri Sep 20 09:42:27 PDT 2019
the project "GEOS".
via 1df959cc8a39807e63a09bff6953ef43d434ccbf (commit)
from 28e20ccf1bdcb6edb339c08a2a7225e23ae05451 (commit)
revisions in full, below.
commit 1df959cc8a39807e63a09bff6953ef43d434ccbf
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Sep 20 09:41:40 2019 -0700
Fix MSVC 2017 compilation, from @hobu.
References #975
diff --git a/CMakeLists.txt b/CMakeLists.txt
index e3752d2..625f51d 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -54,6 +54,12 @@ cmake_dependent_option(GEOS_BUILD_DEVELOPER
"GEOS_BUILD_FROM_GIT" OFF)
mark_as_advanced(GEOS_BUILD_DEVELOPER)
+if (POLICY CMP0092)
+ # dont set /W3 warning flags by default, we already
+ # set /W4 anyway
+ cmake_policy(SET CMP0092 NEW)
+endif()
# Setup build directories
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index 0e729b0..3673890 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -948,14 +948,14 @@ struct GEOS_DLL GeometryGreaterThen {
/// Return current GEOS version
-std::string geosversion();
+GEOS_DLL std::string geosversion();
* \brief
* Return the version of JTS this GEOS
* release has been ported from.
-std::string jtsport();
+GEOS_DLL std::string jtsport();
// We use this instead of std::pair<unique_ptr<Geometry>> because C++11
// forbids that construct:
diff --git a/include/geos/geom/Location.h b/include/geos/geom/Location.h
index 050b9d4..e56eae4 100644
--- a/include/geos/geom/Location.h
+++ b/include/geos/geom/Location.h
@@ -30,7 +30,8 @@ namespace geom { // geos::geom
* For a description of the DE-9IM, see the
* [OpenGIS Simple Features Specification for SQL](http://www.opengis.org/techno/specs.htm").
-GEOS_DLL enum class Location : char {
+enum class GEOS_DLL Location : char {
* Used for uninitialized location values.
@@ -58,7 +59,7 @@ GEOS_DLL enum class Location : char {
EXTERIOR = 2
-std::ostream& operator<<(std::ostream& os, const Location& loc);
+GEOS_DLL std::ostream& operator<<(std::ostream& os, const Location& loc);
} // namespace geos::geom
} // namespace geos
diff --git a/include/geos/geomgraph/index/MonotoneChain.h b/include/geos/geomgraph/index/MonotoneChain.h
index 4611a00..e5d8b63 100644
--- a/include/geos/geomgraph/index/MonotoneChain.h
+++ b/include/geos/geomgraph/index/MonotoneChain.h
@@ -47,6 +47,9 @@ private:
MonotoneChainEdge* mce;
size_t chainIndex;
+ MonotoneChain(const MonotoneChain& other) = delete;
+ MonotoneChain& operator=(const MonotoneChain& rhs) = delete;
public:
MonotoneChain(MonotoneChainEdge* newMce, size_t newChainIndex):
diff --git a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
index b92be69..55ef114 100644
--- a/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
+++ b/include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
@@ -90,6 +90,9 @@ private:
void processOverlaps(size_t start, size_t end,
SweepLineEvent* ev0,
SegmentIntersector* si);
+ // Declare type as noncopyable
+ SimpleMCSweepLineIntersector(const SimpleMCSweepLineIntersector& other) = delete;
+ SimpleMCSweepLineIntersector& operator=(const SimpleMCSweepLineIntersector& rhs) = delete;
} // namespace geos.geomgraph.index
diff --git a/include/geos/operation/distance/ConnectedElementLocationFilter.h b/include/geos/operation/distance/ConnectedElementLocationFilter.h
index 36bff6e..9273653 100644
--- a/include/geos/operation/distance/ConnectedElementLocationFilter.h
+++ b/include/geos/operation/distance/ConnectedElementLocationFilter.h
@@ -51,7 +51,8 @@ private:
std::vector<std::unique_ptr<GeometryLocation>> locations;
ConnectedElementLocationFilter() = default;
+ ConnectedElementLocationFilter(const ConnectedElementLocationFilter&) = delete;
+ ConnectedElementLocationFilter& operator=(const ConnectedElementLocationFilter&) = delete;
public:
/** \brief
* Returns a list containing a point from each Polygon, LineString, and
diff --git a/include/geos/profiler.h b/include/geos/profiler.h
index c98e3b4..83be471 100644
--- a/include/geos/profiler.h
+++ b/include/geos/profiler.h
@@ -106,6 +106,7 @@ public:
std::string name;
private:
/* \brief current start and stop times */
std::chrono::high_resolution_clock::time_point starttime, stoptime;
@@ -139,6 +140,9 @@ public:
Profiler() = default;
~Profiler() = default;
+ Profiler(const Profiler&) = delete;
+ Profiler& operator=(const Profiler&) = delete;
* \brief
* Return the singleton instance of the
diff --git a/src/operation/overlay/PolygonBuilder.cpp b/src/operation/overlay/PolygonBuilder.cpp
index 979ad82..90d12ca 100644
--- a/src/operation/overlay/PolygonBuilder.cpp
+++ b/src/operation/overlay/PolygonBuilder.cpp
@@ -28,11 +28,13 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/LinearRing.h>
#include <geos/geom/Polygon.h>
+#include <geos/geom/CoordinateArraySequence.h>
#include <geos/algorithm/PointLocation.h>
#include <geos/util/TopologyException.h>
#include <geos/util/GEOSException.h>
#include <geos/util.h>
#include <vector>
#include <cassert>
diff --git a/src/operation/polygonize/HoleAssigner.cpp b/src/operation/polygonize/HoleAssigner.cpp
index 9a06123..85997c9 100644
--- a/src/operation/polygonize/HoleAssigner.cpp
+++ b/src/operation/polygonize/HoleAssigner.cpp
@@ -16,6 +16,7 @@
#include <geos/operation/polygonize/HoleAssigner.h>
#include <geos/util/Interrupt.h>
diff --git a/src/operation/polygonize/Polygonizer.cpp b/src/operation/polygonize/Polygonizer.cpp
index beb1c05..38bd0b1 100644
--- a/src/operation/polygonize/Polygonizer.cpp
+++ b/src/operation/polygonize/Polygonizer.cpp
@@ -25,6 +25,7 @@
#include <geos/geom/LineString.h>
#include <geos/geom/Geometry.h>
#include <geos/index/strtree/STRtree.h>
// std
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index b55bde9..3dedc16 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -101,8 +101,7 @@ OverlapUnion::extractByEnvelope(const Envelope& env, const Geometry* geom, std::
disjointGeoms.push_back(elem->clone());
- std::unique_ptr<Geometry> intersectingGeom(geomFactory->buildGeometry(intersectingGeoms));
- return std::move(intersectingGeom);
+ return std::unique_ptr<Geometry>(geomFactory->buildGeometry(intersectingGeoms));
/* private */
Summary of changes:
CMakeLists.txt | 6 ++++++
include/geos/geom/Geometry.h | 4 ++--
include/geos/geom/Location.h | 5 +++--
include/geos/geomgraph/index/MonotoneChain.h | 3 +++
include/geos/geomgraph/index/SimpleMCSweepLineIntersector.h | 3 +++
include/geos/operation/distance/ConnectedElementLocationFilter.h | 3 ++-
include/geos/profiler.h | 4 ++++
src/operation/overlay/PolygonBuilder.cpp | 2 ++
src/operation/polygonize/HoleAssigner.cpp | 1 +
src/operation/polygonize/Polygonizer.cpp | 1 +
src/operation/union/OverlapUnion.cpp | 3 +--
11 files changed, 28 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits
