[geos-commits] [SCM] GEOS branch master updated. 1f341e58649a4b35973b9272706cecea276c21ab
Fri Sep 20 10:15:31 PDT 2019
the project "GEOS".
       via  1f341e58649a4b35973b9272706cecea276c21ab (commit)
      from  1df959cc8a39807e63a09bff6953ef43d434ccbf (commit)
revisions in full, below.
commit 1f341e58649a4b35973b9272706cecea276c21ab
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 20 10:14:54 2019 -0700
    Fix test case expected value to match up to results generated now.
    No longer an exception, and result passes visual inspection.
    Finally,
    Closes #488
diff --git a/tests/xmltester/tests/failure/issue-geos-488.xml b/tests/xmltester/tests/issue/issue-geos-488.xml
similarity index 73%
rename from tests/xmltester/tests/failure/issue-geos-488.xml
rename to tests/xmltester/tests/issue/issue-geos-488.xml
index 33da73f..0ee7111 100644
--- a/tests/xmltester/tests/failure/issue-geos-488.xml
+++ b/tests/xmltester/tests/issue/issue-geos-488.xml
@@ -7,8 +7,8 @@
   <case>
     <desc>
-      TopologyException unioning two valid polygons.
-      Cause is very high precision causing almost-coincident line segments.
+      This used to be a TopologyException unioning two valid polygons.
+      Cause was very high precision causing almost-coincident line segments.
       This causes robustness failures in noding in JTS 1.12.
       Reduced version.
     </desc>
@@ -27,7 +27,7 @@
   <case>
     <desc>
       Full version, using UnaryUnion.
@@ -37,7 +37,7 @@
     </a>
     <test>
       <op name='union' arg1='A' >
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
 610340ED7A03AFB96F484068C81149076103404DB670F5AA6F48405BC22326A25F0340CEF481F9AA6F484025CD6488A25F0340A1BB14B3B96F48405B59B2EB13530340E0CCA41CAB6F48405AC5D14614530340D2A637D6B96F4840E13957FF495003403886AADDB96F48400F5AE1584A50034036093D97C86F48406484CF0F804D034067788E9EC86F4840507F9BC7814D0340D9C5653E127048406022AF17814D03403BEB43CBF46F4840CB89B9BF804D03405375B211E66F4840665E3A27EC4703406A06F11FE66F48407285047CEC4703400D8482D9F46F4840485227E839470340C4E33FDBF46F4840655E3A27EC4703406906F11FE66F4840CA89B9BF804D03405375B211E66F4840380346EB1A4C034069A42AA2C86F4840C0D831A25049034034E549A9C86F4840F7F89D4C504903406558B7EFB96F4840C039DB99564203405A14F300BA6F484004000000B888AA59BD43034025CD6A9D037048403F9518A987460340F4658E9603704840429518A987460340F4658E9603704840B888AA59BD43034025CD6A9D03704840040000002898DAC9B64A0340E1F173D2F46F4840EF4C7DB4694B03403D243B8A0370484019DA3A20B74A0340A210058C037048402898DAC9B64A0340E1F173D2F46F48400400000025BB365A824D0340CBF1F0C82A7048402BB8160E354E0340DF9EADA
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
       </op>
     </test>
   </case>
Summary of changes:
 tests/xmltester/tests/{failure => issue}/issue-geos-488.xml | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
 rename tests/xmltester/tests/{failure => issue}/issue-geos-488.xml (73%)
hooks/post-receive
More information about the geos-commits mailing list
