[geos-commits] [SCM] GEOS branch master updated. e4125d66bf4951a41d9d71a196769707b3d0431d
Fri Sep 20 13:16:18 PDT 2019
the project "GEOS".
       via  e4125d66bf4951a41d9d71a196769707b3d0431d (commit)
      from  6a8fecd2ff9177adceff8e245d8d3dc7be9599f2 (commit)
revisions in full, below.
commit e4125d66bf4951a41d9d71a196769707b3d0431d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 20 16:16:07 2019 -0400
    Remove unused files
diff --git a/.drone.yml b/.drone.yml
deleted file mode 100644
index 1addc51..0000000
--- a/.drone.yml
+++ /dev/null
@@ -1,20 +0,0 @@
-# See http://readme.drone.io/0.5/usage/overview
-# See https://git.osgeo.org/gogs/geos/geos-docker
-test-image: &test-image docker.kbt.io/geos/build-test:alpine
-pipeline:
-  clone:
-    image: plugins/git
-    depth: 50
-    recursive: false
-  build:
-    image: *test-image
-    commands:
-      - ./autogen.sh
-      - CXXFLAGS="-O0" ./configure
-      - make
-  check:
-    commands:
-      - CXXFLAGS="-O0" make check
diff --git a/.vimrc b/.vimrc
index d487fcb..0000000
--- a/.vimrc
+++ /dev/null
@@ -1,6 +0,0 @@
-" This file is for reference for when
-" there _is_ a standard style (none yet)
-set tabstop=2
-set shiftwidth=2
-set expandtab
diff --git a/TODO b/TODO
index 01abb45..0000000
--- a/TODO
+++ /dev/null
@@ -1,26 +0,0 @@
-GEOS TODO:
-- Feed PrecisionModel to OverlayResultValidator to set _TOLERANCE
-- Test unit tests for snapround package
-- DoubleBits misregards BYTE_ENDIAN, must check it.
-- BUILD CORRECTNESS:
-	- include <geos/config.h> from all .cpp files
-- WKB tester in doc/examples.cpp should do point-by-point comparison.
-- Implement Safe's idea of a compile-time enabled 2d-only
-  inlineable CoordinateSequence
-- WKB extension with LINEARRING ?
-- Check how to disable GEOS_VERSION define on command line
-  (or make GEOS_VERSION define in version.h optional)
-  not a major problems, just makes the compiler issue some warninigs.
-- Check GeometryEditor behaviour (modify passed geom or create a new one ?)
-  [not documented]
-- Add distinct binary predicates test support in XMLTester
Summary of changes:
 .drone.yml | 20 --------------------
 .vimrc     |  6 ------
 TODO       | 26 --------------------------
 3 files changed, 52 deletions(-)
 delete mode 100644 .drone.yml
 delete mode 100644 .vimrc
 delete mode 100644 TODO
hooks/post-receive
More information about the geos-commits mailing list
