[geos-commits] [SCM] GEOS branch master updated. 03a76a371bfe81adb0d6e18cde41b6aa7c494786
Fri Sep 20 16:07:58 PDT 2019
the project "GEOS".
       via  03a76a371bfe81adb0d6e18cde41b6aa7c494786 (commit)
       via  842593ebd97c5c6380421e0f10e08966269cea5e (commit)
      from  e4125d66bf4951a41d9d71a196769707b3d0431d (commit)
revisions in full, below.
commit 03a76a371bfe81adb0d6e18cde41b6aa7c494786
Merge: 842593e e4125d6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 20 16:07:54 2019 -0700
    Merge branch 'master' of https://git.osgeo.org/gogs/geos/geos
commit 842593ebd97c5c6380421e0f10e08966269cea5e
Date:   Fri Sep 20 16:07:31 2019 -0700
    Add robust determinant test files
    References #591
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 74c9477..a0e3db8 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -34,7 +34,9 @@ SAFE_XMLTESTS= \
 	$(srcdir)/tests/general/TestFunctionPLPrec.xml \
 	$(srcdir)/tests/general/TestFunctionPP.xml \
 	$(srcdir)/tests/general/TestInteriorPoint.xml \
+	$(srcdir)/tests/general/TestIntersectsPL.xml \
 	$(srcdir)/tests/general/TestMinimumClearance.xml \
+	$(srcdir)/tests/general/TestPreparedIntersectsPL.xml \
 	$(srcdir)/tests/general/TestPreparedPointPredicate.xml \
 	$(srcdir)/tests/general/TestPreparedPolygonPredicate.xml \
 	$(srcdir)/tests/general/TestPreparedPredicatesWithGeometryCollection.xml \
diff --git a/tests/xmltester/tests/general/TestIntersectsPL.xml b/tests/xmltester/tests/general/TestIntersectsPL.xml
new file mode 100644
index 0000000..3d2634a
--- /dev/null
+++ b/tests/xmltester/tests/general/TestIntersectsPL.xml
@@ -0,0 +1,37 @@
+<run>
+  <desc>Test P/L intersects cases that require robust determinant. See discussion http://trac.osgeo.org/geos/ticket/591</desc>
+  <!-- first occurrence is used -->
+  <precisionModel type="FLOATING"/> <!-- passes -->
+  <precisionModel scale="1.0" offsetx="0.0" offsety="0.0"/> <!-- passes -->
+<case>
+  <desc>Point on segment between 3rd and 4th vertex of line</desc>
+  <a>
+    POINT(-23.1094689600055 50.5195368635957)
+  </a>
+  <b>
+    LINESTRING(-23.122057005539 50.5201976774794,-23.1153476966995 50.5133404815199,-23.1094689600055 50.5223376452201,-23.1094689600055 50.5169177629559,-23.0961967920942 50.5330464848094,-23.0887991006034 50.5258515213185,-23.0852302622362 50.5264582238409)
+  </b>
+<test>
+  <op name="intersects" arg1="A" arg2="B">
+    true
+  </op>
+</test>
+</case>
+<case>
+  <desc>Point on the 3rd vertex of line</desc>
+  <a>
+    POINT(-23.1094689600055 50.5223376452201)
+  </a>
+  <b>
+  </b>
+<test>
+    true
+  </op>
+</test>
+</case>
+</run>
diff --git a/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml b/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
index 0000000..55c69a5
--- /dev/null
+++ b/tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
@@ -0,0 +1,37 @@
+<run>
+  <geometryOperation>com.vividsolutions.jtstest.geomop.PreparedGeometryOperation</geometryOperation>
+<case>
+  <a>
+  </a>
+  <b>
+  </b>
+<test>
+    true
+  </op>
+</test>
+</case>
+<case>
+  <a>
+  </a>
+  <b>
+  </b>
+<test>
+    true
+  </op>
+</test>
+</case>
+</run>
Summary of changes:
 tests/xmltester/Makefile.am                        |  2 ++
 tests/xmltester/tests/general/TestIntersectsPL.xml | 37 ++++++++++++++++++++++
 .../tests/general/TestPreparedIntersectsPL.xml     | 37 ++++++++++++++++++++++
 3 files changed, 76 insertions(+)
 create mode 100644 tests/xmltester/tests/general/TestIntersectsPL.xml
 create mode 100644 tests/xmltester/tests/general/TestPreparedIntersectsPL.xml
hooks/post-receive
More information about the geos-commits mailing list
