[geos-commits] [SCM] GEOS branch master updated. 60583394172397a47e444443175d06d7dbb17f1c
git at osgeo.org
git at osgeo.org
Thu Sep 26 10:01:32 PDT 2019
the project "GEOS".
via 60583394172397a47e444443175d06d7dbb17f1c (commit)
from 8c837b6e821cf5bebd4f6561c5947aed3c7f1d51 (commit)
revisions in full, below.
commit 60583394172397a47e444443175d06d7dbb17f1c
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Sep 26 10:01:13 2019 -0700
Expose MinimumBoundingCircle to CAPI
Closes #735
diff --git a/NEWS b/NEWS
index a4dcd2b..40c9961 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ Changes in 3.8.0
- CAPI: GEOSCoverageUnion (Dan Baston)
- CAPI: GEOSCoordSeq_setXY, GEOSCoordSeq_setXYZ,
GEOSCoordSeq_getXY, GEOSCoordSeq_getXYZ (Dan Baston)
+ - CAPI: GEOSMinimumBoundingCircle (#735)
- Improvements:
- Improve performance and robustness of GEOSPointOnSurface (Martin Davis)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 2974eca..ad8584f 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -706,6 +706,12 @@ extern "C" {
Geometry*
+ GEOSMinimumBoundingCircle(const Geometry* g, double* radius, Geometry** center)
+ return GEOSMinimumBoundingCircle_r(handle, g, radius, center);
+ Geometry*
GEOSGeom_createCollection(int type, Geometry** geoms, unsigned int ngeoms)
return GEOSGeom_createCollection_r(handle, type, geoms, ngeoms);
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 73207e3..31da35e 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -602,6 +602,9 @@ extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface_r(GEOSContextHandle_t handle,
const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSGetCentroid_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g, double* radius,
+ GEOSGeometry** center);
extern GEOSGeometry GEOS_DLL *GEOSNode_r(GEOSContextHandle_t handle,
/* Fast, non-robust intersection between an arbitrary geometry and
@@ -1642,8 +1645,10 @@ extern GEOSGeometry GEOS_DLL *GEOSCoverageUnion(const GEOSGeometry *g);
/* @deprecated in 3.3.0: use GEOSUnaryUnion instead */
extern GEOSGeometry GEOS_DLL *GEOSUnionCascaded(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSMinimumBoundingCircle(const GEOSGeometry* g, double* radius, GEOSGeometry** center);
extern GEOSGeometry GEOS_DLL *GEOSNode(const GEOSGeometry* g);
extern GEOSGeometry GEOS_DLL *GEOSClipByRect(const GEOSGeometry* g, double xmin, double ymin, double xmax, double ymax);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index c2a1b80..828f01e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -44,7 +44,7 @@
#include <geos/io/WKTWriter.h>
#include <geos/io/WKBWriter.h>
#include <geos/algorithm/BoundaryNodeRule.h>
-#include <geos/algorithm/Orientation.h>
+#include <geos/algorithm/MinimumBoundingCircle.h>
#include <geos/algorithm/MinimumDiameter.h>
#include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
@@ -3000,6 +3000,44 @@ extern "C" {
Geometry*
+ GEOSMinimumBoundingCircle_r(GEOSContextHandle_t extHandle, const Geometry* g,
+ double* radius, Geometry** center)
+ if(0 == extHandle) {
+ return NULL;
+ GEOSContextHandleInternal_t* handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if(0 == handle->initialized) {
+ return NULL;
+ try {
+ geos::algorithm::MinimumBoundingCircle mc(g);
+ std::unique_ptr<Geometry> ret = mc.getCircle();
+ const GeometryFactory* gf = handle->geomFactory;
+ if(!ret) {
+ if (center) *center = NULL;
+ if (radius) *radius = 0.0;
+ return gf->createPolygon().release();
+ if (center) *center = static_cast<Geometry*>(gf->createPoint(mc.getCentre()));
+ if (radius) *radius = mc.getRadius();
+ ret->setSRID(g->getSRID());
+ return ret.release();
+ catch(const std::exception& e) {
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch(...) {
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return NULL;
+ Geometry*
GEOSGeom_createEmptyCollection_r(GEOSContextHandle_t extHandle, int type)
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 40973c5..88c4816 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -87,6 +87,7 @@ geos_unit_SOURCES = \
capi/GEOSisValidDetailTest.cpp \
capi/GEOSLineString_PointTest.cpp \
capi/GEOSMakeValidTest.cpp \
+ capi/GEOSMinimumBoundingCircleTest.cpp \
capi/GEOSMinimumClearanceTest.cpp \
capi/GEOSMinimumRectangleTest.cpp \
capi/GEOSMinimumWidthTest.cpp \
diff --git a/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
new file mode 100644
index 0000000..87165c3
--- /dev/null
+++ b/tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
@@ -0,0 +1,160 @@
+// $Id$
+// Test Suite for C-API GEOSGetCentroid
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capiminimumboundingcircle_data {
+ GEOSGeometry* geom1_;
+ GEOSGeometry* geom2_;
+ GEOSGeometry* geom3_;
+ GEOSWKTWriter* wktw_;
+ char* wkt_;
+ double area_;
+ static void
+ notice(const char* fmt, ...)
+ std::fprintf(stdout, "NOTICE: ");
+ va_list ap;
+ va_start(ap, fmt);
+ std::vfprintf(stdout, fmt, ap);
+ va_end(ap);
+ std::fprintf(stdout, "\n");
+ test_capiminimumboundingcircle_data()
+ : geom1_(nullptr), geom2_(nullptr), geom3_(nullptr), wkt_(nullptr)
+ initGEOS(notice, notice);
+ wktw_ = GEOSWKTWriter_create();
+ GEOSWKTWriter_setTrim(wktw_, 1);
+ GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
+ ~test_capiminimumboundingcircle_data()
+ GEOSGeom_destroy(geom1_);
+ GEOSGeom_destroy(geom2_);
+ GEOSGeom_destroy(geom3_);
+ GEOSWKTWriter_destroy(wktw_);
+ GEOSFree(wkt_);
+ geom1_ = nullptr;
+ geom2_ = nullptr;
+ geom3_ = nullptr;
+ wkt_ = nullptr;
+ finishGEOS();
+typedef test_group<test_capiminimumboundingcircle_data> group;
+typedef group::object object;
+group test_capiminimumboundingcircle_group("capi::GEOSMinimumBoundingCircle");
+// Test Cases
+// Single point
+template<>
+template<>
+void object::test<1>
+ geom1_ = GEOSGeomFromWKT("POINT(10 10)");
+ ensure(nullptr != geom1_);
+ geom2_ = GEOSMinimumBoundingCircle(geom1_, NULL, NULL);
+ ensure(nullptr != geom2_);
+ wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ ensure_equals(std::string(wkt_), std::string("POINT (10 10)"));
+template<>
+template<>
+void object::test<2>
+ geom1_ = GEOSGeomFromWKT("LINESTRING(0 10, 0 20)");
+ geom3_ = GEOSGeomFromWKT("POLYGON ((5 15, 4.9039264 14.024548, 4.6193977 13.086583, 4.1573481 12.222149, 3.5355339 11.464466, 2.7778512 10.842652, 1.9134172 10.380602, 0.97545161 10.096074, 8.0777229e-15 10, -0.97545161 10.096074, -1.9134172 10.380602, -2.7778512 10.842652, -3.5355339 11.464466, -4.1573481 12.222149, -4.6193977 13.086583, -4.9039264 14.024548, -5 15, -4.9039264 15.975452, -4.6193977 16.913417, -4.1573481 17.777851, -3.5355339 18.535534, -2.7778512 19.157348, -1.9134172 19.619398, -0.97545161 19.903926, -1.8682053e-14 20, 0.97545161 19.903926, 1.9134172 19.619398, 2.7778512 19.157348, 3.5355339 18.535534, 4.1573481 17.777851, 4.6193977 16.913417, 4.9039264 15.975452, 5 15))");
+ ensure(nullptr != geom3_);
+ // wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+ bool eq = GEOSEqualsExact(geom2_, geom3_, 0.0001);
+ ensure(eq);
+template<>
+template<>
+void object::test<3>
+ geom1_ = GEOSGeomFromWKT("LINESTRING EMPTY");
+ geom3_ = GEOSGeomFromWKT("POLYGON EMPTY");
+ // std::cout << wkt_ << std::endl;
+ ensure(eq);
+template<>
+template<>
+void object::test<4>
+ GEOSGeometry* center;
+ GEOSGeometry* center_expected;
+ double radius;
+ geom2_ = GEOSMinimumBoundingCircle(geom1_, &radius, ¢er);
+ center_expected = GEOSGeomFromWKT("POINT(0 15)");
+ bool eq;
+ eq = GEOSEqualsExact(geom2_, geom3_, 0.0001);
+ ensure(eq);
+ eq = GEOSEqualsExact(center, center_expected, 0.0001);
+ ensure(eq);
+ GEOSGeom_destroy(center);
+ GEOSGeom_destroy(center_expected);
+ ensure(fabs(radius) - 5.0 < 0.001);
+} // namespace tut
Summary of changes:
NEWS | 1 +
capi/geos_c.cpp | 6 +
capi/geos_c.h.in | 5 +
capi/geos_ts_c.cpp | 40 +++++-
tests/unit/Makefile.am | 1 +
tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp | 160 ++++++++++++++++++++++
6 files changed, 212 insertions(+), 1 deletion(-)
create mode 100644 tests/unit/capi/GEOSMinimumBoundingCircleTest.cpp
hooks/post-receive
More information about the geos-commits
