[geos-commits] [SCM] GEOS branch master updated. 76e23a266acf72314ae1c659f8c472ffd95262b4
git at osgeo.org
git at osgeo.org
Thu Sep 26 11:04:41 PDT 2019
the project "GEOS".
via 76e23a266acf72314ae1c659f8c472ffd95262b4 (commit)
from 60583394172397a47e444443175d06d7dbb17f1c (commit)
revisions in full, below.
commit 76e23a266acf72314ae1c659f8c472ffd95262b4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Sep 26 11:04:10 2019 -0700
Preserve SRID in constructive geometry functions called via CAPI
Closes #896
diff --git a/NEWS b/NEWS
index 40c9961..c1cff26 100644
--- a/NEWS
+++ b/NEWS
@@ -26,6 +26,10 @@ Changes in 3.8.0
test running (Paul Ramsey)
- CMake modernization (Mateusz Loskot)
+- Changes:
+ - Constructive geometry functions in CAPI now preserve SRID
+ of input arguments in output (#896)
Changes in 3.7.2
2019-05-02
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 828f01e..edaea13 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1679,6 +1679,7 @@ extern "C" {
try {
Geometry* g3 = g1->getEnvelope().release();
+ g3->setSRID(g1->getSRID());
return g3;
catch(const std::exception& e) {
@@ -1705,7 +1706,9 @@ extern "C" {
try {
- return g1->intersection(g2).release();
+ Geometry* g3 = g1->intersection(g2).release();
+ return g3;
handle->ERROR_MESSAGE("%s", e.what());
@@ -1732,6 +1735,7 @@ extern "C" {
try {
Geometry* g3 = g1->buffer(width, quadrantsegments).release();
return g3;
@@ -1782,6 +1786,7 @@ extern "C" {
bp.setMitreLimit(mitreLimit);
BufferOp op(g1, bp);
Geometry* g3 = op.getResultGeometry(width);
return g3;
@@ -1828,7 +1833,7 @@ extern "C" {
BufferBuilder bufBuilder(bp);
Geometry* g3 = bufBuilder.bufferLineSingleSided(g1, width, isLeftSide);
return g3;
@@ -1872,7 +1877,7 @@ extern "C" {
bool isLeftSide = leftSide == 0 ? false : true;
return g3;
@@ -1900,6 +1905,7 @@ extern "C" {
try {
Geometry* g3 = g1->convexHull().release();
return g3;
@@ -1928,8 +1934,9 @@ extern "C" {
try {
geos::algorithm::MinimumDiameter m(g);
- return m.getMinimumRectangle().release();
+ Geometry* g3 = m.getMinimumRectangle().release();
+ g3->setSRID(g->getSRID());
+ return g3;
@@ -1956,8 +1963,9 @@ extern "C" {
try {
- return m.getDiameter().release();
+ Geometry* g3 = m.getDiameter().release();
+ return g3;
@@ -1984,7 +1992,9 @@ extern "C" {
try {
geos::precision::MinimumClearance mc(g);
- return mc.getLine().release();
+ Geometry *g3 = mc.getLine().release();
+ return g3;
@@ -2040,7 +2050,9 @@ extern "C" {
try {
- return g1->difference(g2).release();
+ Geometry *g3 = g1->difference(g2).release();
+ return g3;
@@ -2067,6 +2079,7 @@ extern "C" {
try {
Geometry* g3 = g1->getBoundary().release();
return g3;
@@ -2093,7 +2106,9 @@ extern "C" {
try {
- return g1->symDifference(g2).release();
+ Geometry *g3 = g1->symDifference(g2).release();
+ return g3;
@@ -2120,7 +2135,9 @@ extern "C" {
try {
- return g1->Union(g2).release();
+ Geometry *g3 = g1->Union(g2).release();
+ return g3;
#if VERBOSE_EXCEPTIONS
@@ -2153,7 +2170,9 @@ extern "C" {
try {
- return geos::operation::geounion::CoverageUnion::Union(g).release();
+ Geometry *g3 = geos::operation::geounion::CoverageUnion::Union(g).release();
+ return g3;
@@ -2180,6 +2199,7 @@ extern "C" {
try {
GeomPtr g3(g->Union());
return g3.release();
@@ -2214,6 +2234,7 @@ extern "C" {
try {
std::unique_ptr<Geometry> g3 = geos::noding::GeometryNoder::node(*g);
@@ -2254,7 +2275,9 @@ extern "C" {
using geos::operation::geounion::CascadedPolygonUnion;
- return CascadedPolygonUnion::Union(p);
+ Geometry *g3 = CascadedPolygonUnion::Union(p);
+ return g3;
@@ -2286,6 +2309,7 @@ extern "C" {
// return an empty point
return gf->createPoint().release();
+ ret->setSRID(g1->getSRID());
return ret.release();
@@ -2316,6 +2340,7 @@ extern "C" {
using geos::operation::intersection::RectangleIntersection;
Rectangle rect(xmin, ymin, xmax, ymax);
std::unique_ptr<Geometry> g3 = RectangleIntersection::clip(*g, rect);
@@ -2987,6 +3012,7 @@ extern "C" {
const GeometryFactory* gf = handle->geomFactory;
+ ret->setSRID(g->getSRID());
return ret;
@@ -3217,24 +3243,26 @@ extern "C" {
Geometry*
GEOSPolygonize_valid_r(GEOSContextHandle_t extHandle, const Geometry* const* g, unsigned int ngeoms)
- if(0 == extHandle) {
- return 0;
+ if(nullptr == extHandle) {
+ return nullptr;
- GEOSContextHandleInternal_t* handle = 0;
+ GEOSContextHandleInternal_t* handle = nullptr;
handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if(0 == handle->initialized) {
- return 0;
+ return nullptr;
- Geometry* out = 0;
+ Geometry* out = nullptr;
try {
// Polygonize
using geos::operation::polygonize::Polygonizer;
Polygonizer plgnzr(true);
+ int srid = 0;
for(std::size_t i = 0; i < ngeoms; ++i) {
plgnzr.add(g[i]);
+ srid = g[i]->getSRID();
auto polys = plgnzr.getPolygons();
@@ -3250,6 +3278,7 @@ extern "C" {
out = handle->geomFactory->createMultiPolygon(geoms);
+ out->setSRID(srid);
@@ -3281,6 +3310,7 @@ extern "C" {
using geos::operation::polygonize::BuildArea;
BuildArea builder;
out = builder.build(g).release();
+ out->setSRID(g->getSRID());
@@ -3312,6 +3342,7 @@ extern "C" {
using geos::operation::valid::MakeValid;
MakeValid makeValid;
out = makeValid.build(g).release();
@@ -3342,8 +3373,10 @@ extern "C" {
// Polygonize
Polygonizer plgnzr;
+ int srid = 0;
plgnzr.add(g[i]);
#if GEOS_DEBUG
@@ -3372,6 +3405,7 @@ extern "C" {
// The below takes ownership of the passed vector,
// so we must *not* delete it
out = gf->createGeometryCollection(linevec);
@@ -3455,7 +3489,9 @@ extern "C" {
(*polyvec)[i] = (*polys)[i].release();
- return gf->createGeometryCollection(polyvec);
+ Geometry* out = gf->createGeometryCollection(polyvec);
+ return out;
@@ -3504,6 +3540,7 @@ extern "C" {
out = gf->buildGeometry(geoms);
// XXX: old version
//out = gf->createGeometryCollection(geoms);
@@ -3534,7 +3571,9 @@ extern "C" {
try {
- return g->reverse().release();
+ Geometry* g3 = g->reverse().release();
+ return g3;
@@ -4706,8 +4745,9 @@ extern "C" {
try {
using namespace geos::simplify;
- Geometry::Ptr g(DouglasPeuckerSimplifier::simplify(g1, tolerance));
- return g.release();
+ Geometry::Ptr g3(DouglasPeuckerSimplifier::simplify(g1, tolerance));
+ return g3.release();
@@ -4734,8 +4774,9 @@ extern "C" {
try {
- Geometry::Ptr g(TopologyPreservingSimplifier::simplify(g1, tolerance));
+ Geometry::Ptr g3(TopologyPreservingSimplifier::simplify(g1, tolerance));
@@ -6206,6 +6247,7 @@ extern "C" {
geos::geom::Coordinate coord = lil.extractPoint(d);
Geometry* point = gf->createPoint(coord);
+ point->setSRID(g->getSRID());
return point;
@@ -6274,7 +6316,9 @@ extern "C" {
/* 3: create a multipoint */
- return factory->createMultiPoint(points);
+ Geometry* out = factory->createMultiPoint(points);
+ return out;
@@ -6392,6 +6436,7 @@ extern "C" {
factory->createGeometryCollection(out.release())
+ outg->setSRID(g1->getSRID());
return outg.release();
@@ -6414,6 +6459,7 @@ extern "C" {
try {
GeometrySnapper snapper(*g1);
std::unique_ptr<Geometry> ret = snapper.snapTo(*g2, tolerance);
@@ -6624,6 +6670,7 @@ extern "C" {
try {
BufferOp op(g1, *bp);
return g3;
@@ -6657,10 +6704,14 @@ extern "C" {
builder.setSites(*g1);
if(onlyEdges) {
- return builder.getEdges(*g1->getFactory()).release();
+ Geometry* out = builder.getEdges(*g1->getFactory()).release();
+ out->setSRID(g1->getSRID());
+ return out;
else {
- return builder.getTriangles(*g1->getFactory()).release();
+ Geometry* out = builder.getTriangles(*g1->getFactory()).release();
+ return out;
@@ -6697,10 +6748,14 @@ extern "C" {
builder.setClipEnvelope(env->getEnvelopeInternal());
if(onlyEdges) {
- return builder.getDiagramEdges(*g1->getFactory()).release();
+ Geometry* out = builder.getDiagramEdges(*g1->getFactory()).release();
+ return out;
else {
- return builder.getDiagram(*g1->getFactory()).release();
+ Geometry* out = builder.getDiagram(*g1->getFactory()).release();
+ return out;
Summary of changes:
NEWS | 4 ++
capi/geos_ts_c.cpp | 113 +++++++++++++++++++++++++++++++++++++++--------------
2 files changed, 88 insertions(+), 29 deletions(-)
hooks/post-receive
More information about the geos-commits
