[geos-commits] [SCM] GEOS branch master updated. 177584e6af186769666bf022557c044548c757ff
git at osgeo.org
git at osgeo.org
Fri Sep 27 02:31:57 PDT 2019
the project "GEOS".
via 177584e6af186769666bf022557c044548c757ff (commit)
via 01488a3b6d28d5fd302c8f59777bdc191b62d10c (commit)
from 76e23a266acf72314ae1c659f8c472ffd95262b4 (commit)
revisions in full, below.
commit 177584e6af186769666bf022557c044548c757ff
Merge: 01488a3 76e23a2
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Sep 27 05:28:39 2019 -0400
Merge branch 'master' into add-cmake-doxygen-error-check
commit 01488a3b6d28d5fd302c8f59777bdc191b62d10c
Author: nila <n_larsson at yahoo.com>
Date: Thu Sep 12 17:29:18 2019 +0200
Add doxygen error test with CMake
diff --git a/doc/CMakeLists.txt b/doc/CMakeLists.txt
index 0712355..9365381 100644
--- a/doc/CMakeLists.txt
+++ b/doc/CMakeLists.txt
@@ -28,14 +28,28 @@ if(BUILD_DOCUMENTATION)
set(srcdir ${CMAKE_CURRENT_SOURCE_DIR})
set(VERSION ${GEOS_VERSION_FULL})
- set(DOXYGEN_LOGFILE ${CMAKE_CURRENT_BINARY_DIR}/doxygen_log)
- configure_file(${CMAKE_CURRENT_SOURCE_DIR}/Doxyfile.in
- ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile
- @ONLY)
+ set(DOXYGEN_LOGFILE ${CMAKE_CURRENT_BINARY_DIR}/doxygen.log)
+ set(CHECK_ERROR_SCRIPT "check_doxygen_errors.cmake")
+ configure_file(
+ "${CMAKE_CURRENT_SOURCE_DIR}/${CHECK_ERROR_SCRIPT}"
+ "${CMAKE_CURRENT_BINARY_DIR}/${CHECK_ERROR_SCRIPT}"
+ COPYONLY)
+ configure_file(
+ ${CMAKE_CURRENT_SOURCE_DIR}/Doxyfile.in
+ ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile
+ @ONLY)
unset(srcdir)
unset(VERSION)
- unset(DOXYGEN_LOGFILE)
add_custom_target(docs
- COMMAND ${DOXYGEN_EXECUTABLE} ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile)
+ COMMAND ${DOXYGEN_EXECUTABLE} ${CMAKE_CURRENT_BINARY_DIR}/Doxyfile
+ BYPRODUCTS ${DOXYGEN_LOGFILE} ${CMAKE_CURRENT_BINARY_DIR}/doxygen_docs)
+ add_test(NAME test_docs
+ COMMAND ${CMAKE_COMMAND}
+ -D DOXYGEN_LOGFILE="${DOXYGEN_LOGFILE}"
+ -P "${CMAKE_CURRENT_BINARY_DIR}/${CHECK_ERROR_SCRIPT}")
+ unset(DOXYGEN_LOGFILE)
+ unset(CHECK_ERROR_SCRIPT)
endif()
diff --git a/doc/check_doxygen_errors.cmake b/doc/check_doxygen_errors.cmake
new file mode 100644
index 0000000..78a0c74
--- /dev/null
+++ b/doc/check_doxygen_errors.cmake
@@ -0,0 +1,50 @@
+# Part of CMake configuration for GEOS
+# Script checking the doxygen logfile for errors and warnings, which are not
+# accepted. Throws FATAL_ERROR if found.
+# Copyright (C) 2019 Nicklas Larsson <n_larsson at yahoo.com>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+file(TO_NATIVE_PATH ${DOXYGEN_LOGFILE} DOXYGEN_LOGFILE)
+if(EXISTS "${DOXYGEN_LOGFILE}")
+ set(ERRORS "")
+ file(READ "${DOXYGEN_LOGFILE}" LOGFILE)
+ # convert file content to list
+ string(REGEX REPLACE "\n$" "" LOGFILE "${LOGFILE}")
+ string(REGEX REPLACE ";" "\\\\;" LOGFILE "${LOGFILE}")
+ string(REGEX REPLACE "\n" ";" LOGFILE "${LOGFILE}")
+ # let's not forget non-fatal warnings
+ list(LENGTH LOGFILE NUM_WARNINGS)
+ if(NUM_WARNINGS GREATER 0)
+ message(STATUS
+ "Doxygen issued ${NUM_WARNINGS} warning(s), see ${DOXYGEN_LOGFILE}")
+ endif()
+ foreach(LINE ${LOGFILE})
+ string(REGEX MATCH
+ ".*(not documented|ignoring unsupported tag).*" IGNORE ${LINE})
+ if("${IGNORE}" STREQUAL "")
+ list(APPEND ERRORS ${LINE})
+ endif()
+ endforeach()
+ if(NOT "${ERRORS}" STREQUAL "")
+ # convert list to string
+ string(REGEX REPLACE ";" "\n" ERROR_MSG "${ERRORS}")
+ message(FATAL_ERROR "${ERROR_MSG}")
+ endif()
+ unset(ERRORS)
+endif()
+message(STATUS "Doxygen documentation is OK")
Summary of changes:
doc/CMakeLists.txt | 26 +++++++++++++++++-----
doc/check_doxygen_errors.cmake | 50 ++++++++++++++++++++++++++++++++++++++++++
2 files changed, 70 insertions(+), 6 deletions(-)
create mode 100644 doc/check_doxygen_errors.cmake
hooks/post-receive
More information about the geos-commits
