[geos-commits] [SCM] GEOS branch master updated.	bdc41b10bb5f883c3379c4ce09093f5c382aef93
    git at osgeo.org
    git at osgeo.org
    Fri Sep 27 03:59:45 PDT 2019
the project "GEOS".
       via  bdc41b10bb5f883c3379c4ce09093f5c382aef93 (commit)
      from  177584e6af186769666bf022557c044548c757ff (commit)
revisions in full, below.
commit bdc41b10bb5f883c3379c4ce09093f5c382aef93
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 13 22:07:10 2019 -0400
    Add DefaultCoordinateSequenceFactory
    The previous default, CoordinateArraySequenceFactory, always creates a
    heap-allocating CoordinateArraySequence, even for small sizes. This
    commit defines DefaultCoordinateSequenceFactory that delegates to
    FixedSizeCoordinateSequence for length <= 5. This is big enough to cover
    some common cases like conversion of line segments, triangles, and
    boxes into geometries.
diff --git a/include/geos/geom/DefaultCoordinateSequenceFactory.h b/include/geos/geom/DefaultCoordinateSequenceFactory.h
new file mode 100644
index 0000000..cf96123
--- /dev/null
+++ b/include/geos/geom/DefaultCoordinateSequenceFactory.h
@@ -0,0 +1,66 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2019 Daniel Baston
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_GEOM_DEFAULTCOORDINATESEQUENCEFACTORY_H
+#define GEOS_GEOM_DEFAULTCOORDINATESEQUENCEFACTORY_H
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/FixedSizeCoordinateSequence.h>
+namespace geos {
+namespace geom {
+class GEOS_DLL DefaultCoordinateSequenceFactory : public CoordinateSequenceFactory {
+public:
+    std::unique_ptr<CoordinateSequence> create() const final {
+        return detail::make_unique<CoordinateArraySequence>();
+    std::unique_ptr<CoordinateSequence> create(std::vector<Coordinate> *coords, std::size_t dims = 0) const final {
+        return detail::make_unique<CoordinateArraySequence>(coords, dims);
+    std::unique_ptr <CoordinateSequence> create(std::vector <Coordinate> &&coords, std::size_t dims = 0) const final {
+        return detail::make_unique<CoordinateArraySequence>(std::move(coords), dims);
+    std::unique_ptr <CoordinateSequence> create(std::size_t size, std::size_t dims = 0) const final {
+        switch(size) {
+            case 5: return detail::make_unique<FixedSizeCoordinateSequence<5>>(dims);
+            case 4: return detail::make_unique<FixedSizeCoordinateSequence<4>>(dims);
+            case 3: return detail::make_unique<FixedSizeCoordinateSequence<3>>(dims);
+            case 2: return detail::make_unique<FixedSizeCoordinateSequence<2>>(dims);
+            case 1: return detail::make_unique<FixedSizeCoordinateSequence<1>>(dims);
+            default:
+                return detail::make_unique<CoordinateArraySequence>(size, dims);
+    std::unique_ptr <CoordinateSequence> create(const CoordinateSequence &coordSeq) const final {
+        auto cs = create(coordSeq.size(), coordSeq.getDimension());
+        for (size_t i = 0; i < cs->size(); i++) {
+            cs->setAt(coordSeq[i], i);
+        return cs;
+    static const CoordinateSequenceFactory *instance();
+#endif //GEOS_DEFAULTCOORDINATESEQUENCEFACTORY_H
diff --git a/include/geos/geom/Makefile.am b/include/geos/geom/Makefile.am
index d5e4665..b633085 100644
--- a/include/geos/geom/Makefile.am
+++ b/include/geos/geom/Makefile.am
@@ -21,6 +21,7 @@ geos_HEADERS = \
     CoordinateSequenceFactory.h \
     CoordinateSequenceFilter.h \
     CoordinateSequence.h \
+    DefaultCoordinateSequenceFactory.h \
     Dimension.h \
     Envelope.h \
     Envelope.inl \
diff --git a/src/geom/DefaultCoordinateSequenceFactory.cpp b/src/geom/DefaultCoordinateSequenceFactory.cpp
index 0000000..8d958d5
--- /dev/null
+++ b/src/geom/DefaultCoordinateSequenceFactory.cpp
@@ -0,0 +1,30 @@
+#include <geos/geom/DefaultCoordinateSequenceFactory.h>
+namespace geos {
+namespace geom { // geos::geom
+static DefaultCoordinateSequenceFactory defaultCoordinateSequenceFactory;
+const CoordinateSequenceFactory*
+DefaultCoordinateSequenceFactory::instance()
+    return &defaultCoordinateSequenceFactory;
+} // namespace geos::geom
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 8925e2f..fc692f6 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -19,8 +19,8 @@
 #include <geos/geom/Coordinate.h>
-#include <geos/geom/CoordinateArraySequenceFactory.h>
 #include <geos/geom/CoordinateSequence.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Point.h>
 #include <geos/geom/LineString.h>
@@ -83,7 +83,7 @@ public:
 GeometryFactory::GeometryFactory()
     SRID(0),
-    coordinateListFactory(CoordinateArraySequenceFactory::instance())
+    coordinateListFactory(DefaultCoordinateSequenceFactory::instance())
     , _refCount(0), _autoDestroy(false)
 #if GEOS_DEBUG
@@ -115,7 +115,7 @@ GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID,
     if(! nCoordinateSequenceFactory) {
-        coordinateListFactory = CoordinateArraySequenceFactory::instance();
+        coordinateListFactory = DefaultCoordinateSequenceFactory::instance();
     else {
         coordinateListFactory = nCoordinateSequenceFactory;
@@ -144,7 +144,7 @@ GeometryFactory::GeometryFactory(
               nCoordinateSequenceFactory << "])" << std::endl;
 #endif
     else {
@@ -165,7 +165,7 @@ GeometryFactory::create(
 GeometryFactory::GeometryFactory(const PrecisionModel* pm)
     SRID(0),
 #if GEOS_DEBUG
@@ -189,7 +189,7 @@ GeometryFactory::create(const PrecisionModel* pm)
 GeometryFactory::GeometryFactory(const PrecisionModel* pm, int newSRID)
     SRID(newSRID),
 #if GEOS_DEBUG
@@ -262,8 +262,8 @@ GeometryFactory::toGeometry(const Envelope* envelope) const
         coord.y = envelope->getMinY();
         return std::unique_ptr<Geometry>(createPoint(coord));
-    auto cl = CoordinateArraySequenceFactory::instance()->
-                             create((size_t) 5, 2);
+    auto cl = coordinateListFactory->create(5, 2);
     coord.x = envelope->getMinX();
diff --git a/src/geom/LineSegment.cpp b/src/geom/LineSegment.cpp
index 699316f..8ba6d7d 100644
--- a/src/geom/LineSegment.cpp
+++ b/src/geom/LineSegment.cpp
@@ -23,8 +23,8 @@
 #include <geos/geom/LineString.h> // for toGeometry
-#include <geos/geom/CoordinateArraySequence.h> // should we really be using this?
 #include <geos/algorithm/Orientation.h>
 #include <geos/algorithm/LineIntersector.h>
 #include <geos/algorithm/Intersection.h>
@@ -298,12 +298,11 @@ LineSegment::pointAlongOffset(double segmentLengthFraction,
 std::unique_ptr<LineString>
 LineSegment::toGeometry(const GeometryFactory& gf) const
-    CoordinateSequence* cl = new CoordinateArraySequence(2);
+    auto cl = gf.getCoordinateSequenceFactory()->create(2, 0);
     cl->setAt(p0, 0);
     cl->setAt(p1, 1);
-    return std::unique_ptr<LineString>(
-               gf.createLineString(cl) // ownership transferred
+    return gf.createLineString(std::move(cl));
diff --git a/src/geom/Makefile.am b/src/geom/Makefile.am
index b9b7da3..12b3d23 100644
--- a/src/geom/Makefile.am
+++ b/src/geom/Makefile.am
@@ -15,6 +15,7 @@ libgeom_la_SOURCES = \
     CoordinateSequence.cpp \
     CoordinateArraySequence.cpp \
     CoordinateArraySequenceFactory.cpp \
+    DefaultCoordinateSequenceFactory.cpp \
     Dimension.cpp \
     Envelope.cpp \
     Geometry.cpp \
Summary of changes:
 .../geos/geom/DefaultCoordinateSequenceFactory.h   | 66 ++++++++++++++++++++++
 include/geos/geom/Makefile.am                      |  1 +
 ...ry.cpp => DefaultCoordinateSequenceFactory.cpp} | 14 ++---
 src/geom/GeometryFactory.cpp                       | 16 +++---
 src/geom/LineSegment.cpp                           |  9 ++-
 src/geom/Makefile.am                               |  1 +
 6 files changed, 84 insertions(+), 23 deletions(-)
 create mode 100644 include/geos/geom/DefaultCoordinateSequenceFactory.h
 copy src/geom/{CoordinateArraySequenceFactory.cpp => DefaultCoordinateSequenceFactory.cpp} (60%)
hooks/post-receive
More information about the geos-commits
