[geos-commits] [SCM] GEOS branch master updated. 54c1b88be087e30cf3af17893803acb3c74095b6
Fri Sep 27 04:02:50 PDT 2019
the project "GEOS".
       via  54c1b88be087e30cf3af17893803acb3c74095b6 (commit)
       via  e6ecb28f73709eb4b81456e93c7b09723fe8084e (commit)
      from  bdc41b10bb5f883c3379c4ce09093f5c382aef93 (commit)
revisions in full, below.
commit 54c1b88be087e30cf3af17893803acb3c74095b6
Merge: bdc41b1 e6ecb28
Author: dbaston <dbaston at gmail.com>
Date:   Fri Sep 27 04:02:50 2019 -0700
    Merge branch 'doxygen-predefined-macro' of nila/geos into master
commit e6ecb28f73709eb4b81456e93c7b09723fe8084e
Author: nila <n_larsson at yahoo.com>
Date:   Mon Sep 23 16:44:04 2019 +0200
    Enable macro expansion.
    Enables macro expansion with GEOS_DLL predefined. Addresses issue with doxygen generation of geom::Location
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index fd61667..c841508 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -2017,7 +2017,7 @@ ENABLE_PREPROCESSING   = YES
 # The default value is: NO.
 # This tag requires that the tag ENABLE_PREPROCESSING is set to YES.
-MACRO_EXPANSION        = NO
+MACRO_EXPANSION        = YES
 # If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES then
 # the macro expansion is limited to the macros specified with the PREDEFINED and
@@ -2057,7 +2057,7 @@ INCLUDE_FILE_PATTERNS  =
 # recursively expanded use the := operator instead of the = operator.
-PREDEFINED             =
+PREDEFINED             = GEOS_DLL
 # If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then this
 # tag can be used to specify a list of macro names that should be expanded. The
Summary of changes:
 doc/Doxyfile.in | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
