[geos-commits] [SCM] GEOS branch 3.7 updated. 6f5aa31f7401dec617cb6b51bf821fe11ca2f3e3
Mon Apr 20 11:18:25 PDT 2020
the project "GEOS".
The branch, 3.7 has been updated
       via  6f5aa31f7401dec617cb6b51bf821fe11ca2f3e3 (commit)
      from  45b28eb41288e31c7d489ee765ae633034efee94 (commit)
revisions in full, below.
commit 6f5aa31f7401dec617cb6b51bf821fe11ca2f3e3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 20 10:17:42 2020 -0700
    WKT output of MULTIPOINT with empty member crashes #1027
diff --git a/NEWS b/NEWS
index de74976..f91d32d 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ Changes in 3.7.3dev
   - Overlay performance improvement (#986, Paul Ramsey)
   - Avoid changing MultiLineString component order in GEOSReverse
     (#1013, Dan Baston)
+  - WKT writing of MULTIPOINT with EMPTY component crash
+    (#1027, Paul Ramsey)
 Changes in 3.7.2
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index fae7135..f30199f 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -76,7 +76,7 @@ string
 WKTWriter::toLineString(const CoordinateSequence& seq)
 	stringstream buf(ios_base::in|ios_base::out);
-    buf << "LINESTRING ";
+	buf << "LINESTRING ";
 	unsigned int npts = static_cast<unsigned int>(seq.getSize());
 	if ( npts == 0 )
@@ -112,7 +112,7 @@ WKTWriter::toLineString(const Coordinate& p0, const Coordinate& p1)
 #if PRINT_Z
 	ret << " " << p1.z;
 #endif
-    ret << ")";
+	ret << ")";
 	return ret.str();
@@ -122,7 +122,7 @@ string
 WKTWriter::toPoint(const Coordinate& p0)
 	stringstream ret(ios_base::in|ios_base::out);
-    ret << "POINT (";
+	ret << "POINT (";
 #if PRINT_Z
 	ret << p0.x << " " << p0.y  << " " << p0.z << " )";
 #else
@@ -169,9 +169,9 @@ void WKTWriter::writeFormatted(const Geometry *geometry, Writer *writer) {
 void
 WKTWriter::writeFormatted(const Geometry *geometry, bool isFormatted,
-                          Writer *writer)
+						  Writer *writer)
-        CLocalizer clocale;
+		CLocalizer clocale;
 	this->isFormatted=isFormatted;
   decimalPlaces = roundingPrecision == -1 ? geometry->getPrecisionModel()->getMaximumSignificantDigits() : roundingPrecision;
 	appendGeometryTaggedText(geometry, 0, writer);
@@ -182,51 +182,51 @@ WKTWriter::appendGeometryTaggedText(const Geometry *geometry, int level,
 		Writer *writer)
   outputDimension = std::min( defaultOutputDimension,
-                         geometry->getCoordinateDimension() );
+						 geometry->getCoordinateDimension() );
   indent(level, writer);
   if ( const Point* point = dynamic_cast<const Point*>(geometry) )
-    appendPointTaggedText(point->getCoordinate(),level,writer);
+	appendPointTaggedText(point->getCoordinate(),level,writer);
   else if ( const LinearRing* lr =
-    dynamic_cast<const LinearRing*>(geometry) )
+	dynamic_cast<const LinearRing*>(geometry) )
-    appendLinearRingTaggedText(lr, level, writer);
+	appendLinearRingTaggedText(lr, level, writer);
   else if ( const LineString* ls =
-    dynamic_cast<const LineString*>(geometry) )
+	dynamic_cast<const LineString*>(geometry) )
-    appendLineStringTaggedText(ls, level, writer);
+	appendLineStringTaggedText(ls, level, writer);
   else if ( const Polygon* x =
-    dynamic_cast<const Polygon*>(geometry) )
+	dynamic_cast<const Polygon*>(geometry) )
-    appendPolygonTaggedText(x, level, writer);
+	appendPolygonTaggedText(x, level, writer);
   else if ( const MultiPoint* x =
-    dynamic_cast<const MultiPoint*>(geometry) )
+	dynamic_cast<const MultiPoint*>(geometry) )
-    appendMultiPointTaggedText(x, level, writer);
+	appendMultiPointTaggedText(x, level, writer);
   else if ( const MultiLineString* x =
-    dynamic_cast<const MultiLineString*>(geometry) )
+	dynamic_cast<const MultiLineString*>(geometry) )
-    appendMultiLineStringTaggedText(x, level, writer);
+	appendMultiLineStringTaggedText(x, level, writer);
   else if ( const MultiPolygon* x =
-    dynamic_cast<const MultiPolygon*>(geometry) )
+	dynamic_cast<const MultiPolygon*>(geometry) )
-    appendMultiPolygonTaggedText(x, level, writer);
+	appendMultiPolygonTaggedText(x, level, writer);
   else if ( const GeometryCollection* x =
-    dynamic_cast<const GeometryCollection*>(geometry) )
+	dynamic_cast<const GeometryCollection*>(geometry) )
-    appendGeometryCollectionTaggedText(x, level, writer);
+	appendGeometryCollectionTaggedText(x, level, writer);
   else
-    assert(0); // Unsupported Geometry implementation
+	assert(0); // Unsupported Geometry implementation
@@ -401,9 +401,13 @@ WKTWriter::appendMultiPointText(const MultiPoint *multiPoint,
 				writer->write(", ");
-			appendCoordinate(
-				dynamic_cast<const Point*>(multiPoint->getGeometryN(i))->getCoordinate(),
-				writer);
+			const Coordinate* coord = multiPoint->getGeometryN(i)->getCoordinate();
+			if(coord == nullptr) {
+				writer->write("EMPTY");
+			else {
+				appendCoordinate(coord, writer);
 		writer->write(")");
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 94be2b0..ff50a8c 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -9,6 +9,8 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Geometry.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Point.h>
 // std
 #include <sstream>
 #include <string>
@@ -35,11 +37,11 @@ namespace tut
 		WKTWriter wktwriter;
 		test_wktwriter_data()
-                pm(1000.0),
-                gf(GeometryFactory::create(&pm)),
-                wktreader(gf.get())
+				pm(1000.0),
+				gf(GeometryFactory::create(&pm)),
+				wktreader(gf.get())
@@ -58,93 +60,120 @@ namespace tut
 	template<>
 	void object::test<1>()
-        GeomPtr geom ( wktreader.read("POINT(-117 33)") );
-        std::string  result;
+		GeomPtr geom ( wktreader.read("POINT(-117 33)") );
+		std::string  result;
-        wktwriter.setTrim(false);
-        result = wktwriter.write( geom.get() );
+		wktwriter.setTrim(false);
+		result = wktwriter.write( geom.get() );
-        ensure_equals( result , "POINT (-117.000 33.000)" );
+		ensure_equals( result , "POINT (-117.000 33.000)" );
-        wktwriter.setTrim(true);
+		wktwriter.setTrim(true);
-        ensure_equals( result , "POINT (-117 33)" );
+		ensure_equals( result , "POINT (-117 33)" );
 	// 2 - Test the output precision capability
 	template<>
 	template<>
 	void object::test<2>()
-        GeomPtr geom ( wktreader.read("POINT(-117.1234567 33.1234567)") );
+		GeomPtr geom ( wktreader.read("POINT(-117.1234567 33.1234567)") );
-        ensure_equals( result , "POINT (-117.123 33.123)" );
+		ensure_equals( result , "POINT (-117.123 33.123)" );
-        wktwriter.setRoundingPrecision(2);
+		wktwriter.setRoundingPrecision(2);
-        ensure_equals( result , "POINT (-117.12 33.12)" );
+		ensure_equals( result , "POINT (-117.12 33.12)" );
 	// 3 - Test 3D generation from a 3D geometry.
 	template<>
 	template<>
 	void object::test<3>()
-        GeomPtr geom ( wktreader.read("POINT Z (-117 33 120)") );
+		GeomPtr geom ( wktreader.read("POINT Z (-117 33 120)") );
-        wktwriter.setOutputDimension(3);
-        wktwriter.setTrim( true );
-        wktwriter.setOld3D( false );
+		wktwriter.setOutputDimension(3);
+		wktwriter.setTrim( true );
+		wktwriter.setOld3D( false );
-        ensure_equals( result, std::string("POINT Z (-117 33 120)") );
+		ensure_equals( result, std::string("POINT Z (-117 33 120)") );
-        wktwriter.setOld3D( true );
+		wktwriter.setOld3D( true );
-        ensure_equals( result, std::string("POINT (-117 33 120)") );
+		ensure_equals( result, std::string("POINT (-117 33 120)") );
 	// 4 - Test 2D generation from a 3D geometry.
 	template<>
 	template<>
 	void object::test<4>()
-        GeomPtr geom ( wktreader.read("POINT(-117 33 120)") );
+		GeomPtr geom ( wktreader.read("POINT(-117 33 120)") );
-        wktwriter.setOutputDimension(2);
+		wktwriter.setOutputDimension(2);
-        ensure_equals( result, std::string("POINT (-117 33)") );
+		ensure_equals( result, std::string("POINT (-117 33)") );
   // 5 - Test negative number of digits in precision model
   template<>
   template<>
   void object::test<5>()
-    PrecisionModel pm3(0.001);
-    GeometryFactory::Ptr gf3(GeometryFactory::create(&pm3));
-    WKTReader wktreader3(gf3.get());
-    GeomPtr geom ( wktreader3.read("POINT(123456 654321)") );
+	PrecisionModel pm3(0.001);
+	GeometryFactory::Ptr gf3(GeometryFactory::create(&pm3));
+	WKTReader wktreader3(gf3.get());
+	GeomPtr geom ( wktreader3.read("POINT(123456 654321)") );
-    std::string  result = wktwriter.write( geom.get() );
-    ensure_equals( result, std::string("POINT (123000 654000)") );
+	std::string  result = wktwriter.write( geom.get() );
+	ensure_equals( result, std::string("POINT (123000 654000)") );
+// 6 - Test writing out a multipoint with an empty member
+template<>
+template<>
+void object::test<6>
+	PrecisionModel pm_e(1000);
+	geos::geom::GeometryFactory::Ptr gf_e(GeometryFactory::create(&pm_e, 0));
+	std::unique_ptr<geos::geom::Point> empty_pt(gf_e->createPoint());
+	ensure(empty_pt != nullptr);
+	geos::geom::Coordinate coord(1, 2);
+	std::unique_ptr<geos::geom::Geometry> point(gf_e->createPoint(coord));
+	ensure(point != nullptr);
+	const std::vector<geos::geom::Geometry*> geoms{empty_pt.release(), point.release()};
+	std::unique_ptr<geos::geom::Geometry> col(gf_e->createMultiPoint(geoms));
+	std::string result = wktwriter.write(col.get());
+	ensure_equals(result, std::string("MULTIPOINT (EMPTY, 1 2)"));
 } // namespace tut
Summary of changes:
 NEWS                            |   2 +
 src/io/WKTWriter.cpp            |  54 +++++++++--------
 tests/unit/io/WKTWriterTest.cpp | 125 +++++++++++++++++++++++++---------------
 3 files changed, 108 insertions(+), 73 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
