[geos-commits] [SCM] GEOS branch 3.8 updated. 03c1615171eae48fa0ef42d6dd6435152d469988
Mon Apr 20 11:18:41 PDT 2020
the project "GEOS".
The branch, 3.8 has been updated
       via  03c1615171eae48fa0ef42d6dd6435152d469988 (commit)
      from  925397281833cbea15050c221299a1cf841afa97 (commit)
revisions in full, below.
commit 03c1615171eae48fa0ef42d6dd6435152d469988
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 20 10:17:42 2020 -0700
    Fix crash on WKT write of MULTIPOINT(EMPTY, 1 1)
    References #1027
diff --git a/NEWS b/NEWS
index eab62a4..5d3a981 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ Changes in 3.8.2
   - DistanceOp against geometry with empty components
     crashes (#1026, Paul Ramsey)
   - Remove undefined behaviour in CAPI (#1021, Greg Troxel)
+  - WKT writing of MULTIPOINT with EMPTY component crash (#1027, Paul Ramsey)
 Changes in 3.8.1
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 7c842a1..1573e6f 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -426,13 +426,17 @@ WKTWriter::appendMultiPointText(const MultiPoint* multiPoint,
         writer->write("(");
         for(size_t i = 0, n = multiPoint->getNumGeometries();
                 i < n; ++i) {
             if(i > 0) {
                 writer->write(", ");
-            appendCoordinate(
-                dynamic_cast<const Point*>(multiPoint->getGeometryN(i))->getCoordinate(),
-                writer);
+            const Coordinate* coord = multiPoint->getGeometryN(i)->getCoordinate();
+            if(coord == nullptr) {
+                writer->write("EMPTY");
+            else {
+                appendCoordinate(coord, writer);
         writer->write(")");
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 9b88cf4..fc26b25 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -9,6 +9,8 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Geometry.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Point.h>
 // std
 #include <sstream>
 #include <string>
@@ -23,6 +25,8 @@ namespace tut {
 struct test_wktwriter_data {
     typedef geos::geom::PrecisionModel PrecisionModel;
     typedef geos::geom::GeometryFactory GeometryFactory;
+    typedef geos::geom::Geometry Geometry;
+    typedef geos::geom::GeometryCollection GeometryCollection;
     typedef geos::io::WKTReader WKTReader;
     typedef geos::io::WKTWriter WKTWriter;
     typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
@@ -149,5 +153,32 @@ void object::test<5>
     ensure_equals(result, std::string("POINT (123000 654000)"));
+// 6 - Test writing out a multipoint with an empty member
+template<>
+template<>
+void object::test<6>
+    PrecisionModel pm_e(1000);
+    GeometryFactory::Ptr gf_e(GeometryFactory::create(&pm_e, 0));
+    std::unique_ptr<geos::geom::Point> empty_pt(gf_e->createPoint());
+    ensure(empty_pt != nullptr);
+    geos::geom::Coordinate coord(1, 2);
+    std::unique_ptr<Geometry> point(gf_e->createPoint(coord));
+    ensure(point != nullptr);
+    std::vector<const geos::geom::Geometry*> geoms{empty_pt.get(), point.get()};
+    std::unique_ptr<geos::geom::Geometry> col(gf_e->createMultiPoint(geoms));
+    wktwriter.setRoundingPrecision(2);
+    wktwriter.setTrim(true);
+    std::string result = wktwriter.write(col.get());
+    ensure_equals(result, std::string("MULTIPOINT (EMPTY, 1 2)"));
 } // namespace tut
Summary of changes:
 NEWS                            |  1 +
 src/io/WKTWriter.cpp            | 12 ++++++++----
 tests/unit/io/WKTWriterTest.cpp | 31 +++++++++++++++++++++++++++++++
 3 files changed, 40 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
