[geos-commits] [SCM] GEOS branch master updated. a73568cc5c06fad4711b049a132c5f115182b357
Mon Apr 20 11:18:59 PDT 2020
the project "GEOS".
       via  a73568cc5c06fad4711b049a132c5f115182b357 (commit)
      from  a5e8b64efc516c2592016235443dac166034fe7f (commit)
revisions in full, below.
commit a73568cc5c06fad4711b049a132c5f115182b357
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Apr 20 10:17:42 2020 -0700
    Fix crash on WKT write of MULTIPOINT(EMPTY, 1 1)
diff --git a/src/io/WKTWriter.cpp b/src/io/WKTWriter.cpp
index 977618c..5ce1c93 100644
--- a/src/io/WKTWriter.cpp
+++ b/src/io/WKTWriter.cpp
@@ -426,11 +426,17 @@ WKTWriter::appendMultiPointText(const MultiPoint* multiPoint,
         writer->write("(");
         for(size_t i = 0, n = multiPoint->getNumGeometries();
                 i < n; ++i) {
             if(i > 0) {
                 writer->write(", ");
-            appendCoordinate(multiPoint->getGeometryN(i)->getCoordinate(), writer);
+            const Coordinate* coord = multiPoint->getGeometryN(i)->getCoordinate();
+            if(coord == nullptr) {
+                writer->write("EMPTY");
+            else {
+                appendCoordinate(coord, writer);
         writer->write(")");
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 9b88cf4..db9d97d 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -9,6 +9,7 @@
 #include <geos/geom/PrecisionModel.h>
 #include <geos/geom/GeometryFactory.h>
 #include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryCollection.h>
 // std
 #include <sstream>
 #include <string>
@@ -23,6 +24,8 @@ namespace tut {
 struct test_wktwriter_data {
     typedef geos::geom::PrecisionModel PrecisionModel;
     typedef geos::geom::GeometryFactory GeometryFactory;
+    typedef geos::geom::Geometry Geometry;
+    typedef geos::geom::GeometryCollection GeometryCollection;
     typedef geos::io::WKTReader WKTReader;
     typedef geos::io::WKTWriter WKTWriter;
     typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
@@ -149,5 +152,35 @@ void object::test<5>
     ensure_equals(result, std::string("POINT (123000 654000)"));
+// 6 - Test writing out a multipoint with an empty member
+template<>
+template<>
+void object::test<6>
+    PrecisionModel pm3(PrecisionModel::FLOATING);
+    GeometryFactory::Ptr gf3(GeometryFactory::create(&pm3));
+    std::unique_ptr<Geometry> empty_point(gf3->createPoint());
+    ensure(empty_point != nullptr);
+    geos::geom::Coordinate coord(1, 2);
+    std::unique_ptr<Geometry> point(gf3->createPoint(coord));
+    ensure(point != nullptr);
+    std::vector<const Geometry*> geoms{empty_point.get(), point.get()};
+    std::unique_ptr<Geometry> col(gf3->createMultiPoint(geoms));
+    ensure(col != nullptr);
+    ensure(col->getCoordinate() != nullptr);
+    ensure_equals(col->getCoordinate()->x, 1);
+    ensure_equals(col->getCoordinate()->y, 2);
+    wktwriter.setRoundingPrecision(2);
+    wktwriter.setTrim(true);
+    std::string result = wktwriter.write(col.get());
+    ensure_equals(result, std::string("MULTIPOINT (EMPTY, 1 2)"));
 } // namespace tut
Summary of changes:
 src/io/WKTWriter.cpp            | 10 ++++++++--
 tests/unit/io/WKTWriterTest.cpp | 33 +++++++++++++++++++++++++++++++++
 2 files changed, 41 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
