[geos-commits] [SCM] GEOS branch master updated. 55307b6e233fb7ff25acb200450cbbf8c40d4498
Thu Apr 23 08:55:08 PDT 2020
the project "GEOS".
       via  55307b6e233fb7ff25acb200450cbbf8c40d4498 (commit)
      from  658b865930b15b733bf108ebd1009eea64d5e9fa (commit)
revisions in full, below.
commit 55307b6e233fb7ff25acb200450cbbf8c40d4498
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 23 08:55:00 2020 -0700
    quiet compiler warnings (clang)
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index 4162e0c..abe99d3 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -115,7 +115,7 @@ private:
     void addPolygon(const geom::Polygon* p);
-    void addRingBothSides(const geom::CoordinateSequence* coord, double distance);
+    void addRingBothSides(const geom::CoordinateSequence* coord, double p_distance);
      * Add an offset curve for a polygon ring.
diff --git a/src/operation/buffer/OffsetCurveBuilder.cpp b/src/operation/buffer/OffsetCurveBuilder.cpp
index 1629c26..42283d5 100644
--- a/src/operation/buffer/OffsetCurveBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveBuilder.cpp
@@ -166,13 +166,13 @@ OffsetCurveBuilder::getSingleSidedLineCurve(const CoordinateSequence* inputPts,
 /*public*/
 bool
-OffsetCurveBuilder::isLineOffsetEmpty(double distance)
+OffsetCurveBuilder::isLineOffsetEmpty(double p_distance)
     // a zero width buffer of a line or point is empty
-    if (distance == 0.0) return true;
+    if (p_distance == 0.0) return true;
     // a negative width buffer of a line or point is empty,
     // except for single-sided buffers, where the sign indicates the side
-    if (distance < 0.0 && ! bufParams.isSingleSided()) return true;
+    if (p_distance < 0.0 && ! bufParams.isSingleSided()) return true;
     return false;
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 0f548a9..e982065 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -290,14 +290,14 @@ OffsetCurveSetBuilder::addPolygon(const Polygon* p)
 /* private */
 void
-OffsetCurveSetBuilder::addRingBothSides(const CoordinateSequence* coord, double distance)
+OffsetCurveSetBuilder::addRingBothSides(const CoordinateSequence* coord, double p_distance)
-    addRingSide(coord, distance,
+    addRingSide(coord, p_distance,
                 Position::LEFT,
     /* Add the opposite side of the ring
                 Position::RIGHT,
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index fd41083..daf2675 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -251,8 +251,8 @@ void object::test<7>
     GEOSSTRtree* tree = GEOSSTRtree_create(16);
     GEOSGeometry* q = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 1, 0 0))");
     GEOSSTRtree_query(tree, q, [](void* item, void* userdata) {
-        assert(item); // make unused parameter warning go away
-        assert(userdata);
+        (void)(item); // make unused parameter warning go away
+        (void)(userdata); // make unused parameter warning go away
     }, nullptr);
     GEOSGeom_destroy(q);
diff --git a/tests/unit/math/DDTest.cpp b/tests/unit/math/DDTest.cpp
index 00a29b8..177ec48 100644
--- a/tests/unit/math/DDTest.cpp
+++ b/tests/unit/math/DDTest.cpp
@@ -204,13 +204,13 @@ struct test_dd_data {
      *    Pi / 4  =  4 arctan(1/5) - arctan(1/239)
-    DD computePiByMachin()
+    DD computePiByMachine()
         DD t1 = DD(1.0) / DD(5.0);
         DD t2 = DD(1.0) / DD(239.0);
-        DD pi4 = (DD(4.0) * arctan(t1)) - arctan(t2);
-        DD pi = DD(4.0) * pi4;
-        return pi;
+        DD pie4 = (DD(4.0) * arctan(t1)) - arctan(t2);
+        DD pie = DD(4.0) * pie4;
+        return pie;
     test_dd_data():
@@ -236,7 +236,7 @@ template<>
 void object::test<1>
-    DD testPi = computePiByMachin();
+    DD testPi = computePiByMachine();
     double err = std::abs((testPi - pi).doubleValue());
     // std::cout << "Difference from PI = " << err << std::endl;
     ensure("Test PI calculation", err < 8*eps);
diff --git a/tests/xmltester/tinyxml2/tinyxml2.cpp b/tests/xmltester/tinyxml2/tinyxml2.cpp
index 182f406..414ca6a 100755
--- a/tests/xmltester/tinyxml2/tinyxml2.cpp
+++ b/tests/xmltester/tinyxml2/tinyxml2.cpp
@@ -432,17 +432,17 @@ void XMLUtil::ConvertUTF32ToUTF8( unsigned long input, char* output, int* length
             --output;
             *output = (char)((input | BYTE_MARK) & BYTE_MASK);
             input >>= 6;
-            //fall through
+            // fall through
         case 3:
             --output;
             input >>= 6;
-            //fall through
+            // fall through
         case 2:
             --output;
             input >>= 6;
-            //fall through
+            // fall through
         case 1:
             --output;
             *output = (char)(input | FIRST_BYTE_MARK[*length]);
Summary of changes:
 include/geos/operation/buffer/OffsetCurveSetBuilder.h |  2 +-
 src/operation/buffer/OffsetCurveBuilder.cpp           |  6 +++---
 src/operation/buffer/OffsetCurveSetBuilder.cpp        |  6 +++---
 tests/unit/capi/GEOSSTRtreeTest.cpp                   |  4 ++--
 tests/unit/math/DDTest.cpp                            | 10 +++++-----
 tests/xmltester/tinyxml2/tinyxml2.cpp                 |  6 +++---
 6 files changed, 17 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
