[geos-commits] [SCM] GEOS branch master updated. 86c21dc435d5f58d70a8dbd1a90cfd8845615e4e
git at osgeo.org
git at osgeo.org
Thu Apr 23 14:37:59 PDT 2020
the project "GEOS".
via 86c21dc435d5f58d70a8dbd1a90cfd8845615e4e (commit)
from 55307b6e233fb7ff25acb200450cbbf8c40d4498 (commit)
revisions in full, below.
commit 86c21dc435d5f58d70a8dbd1a90cfd8845615e4e
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Apr 23 14:37:50 2020 -0700
Add a test to IFD and make it actually a test
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index b239c52..3dcabb5 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -49,10 +49,10 @@ struct test_facetdistanceop_data {
std::vector<geos::geom::Coordinate> pts;
pts = IndexedFacetDistance::nearestPoints(g1.get(), g2.get());
ensure(fabs(pts[0].distance(pts[1])-distance) < 1e08);
- ensure(fabs(pts[0].x - p1.x) < 1e08);
- ensure(fabs(pts[0].y - p1.y) < 1e08);
- ensure(fabs(pts[1].x - p2.x) < 1e08);
- ensure(fabs(pts[1].y - p2.y) < 1e08);
+ ensure(fabs(pts[0].x - p1.x) < 1e-08);
+ ensure(fabs(pts[0].y - p1.y) < 1e-08);
+ ensure(fabs(pts[1].x - p2.x) < 1e-08);
+ ensure(fabs(pts[1].y - p2.y) < 1e-08);
return;
@@ -74,7 +74,6 @@ void object::test<1>
using geos::operation::distance::IndexedFacetDistance;
- using geos::geom::Coordinate;
std::string wkt0("POINT(0 0)");
std::string wkt1("POINT(10 0)");
@@ -89,7 +88,6 @@ template<>
void object::test<2>
- using geos::operation::distance::DistanceOp;
std::string wkt0("POLYGON ((200 180, 60 140, 60 260, 200 180))");
@@ -106,7 +104,6 @@ template<>
void object::test<3>
@@ -123,7 +120,6 @@ template<>
void object::test<4>
std::string wkt0("LINESTRING (100 100, 200 100, 200 200, 100 200, 100 100)");
@@ -140,7 +136,6 @@ template<>
void object::test<5>
std::string wkt0("POLYGON ((76 185, 125 283, 331 276, 324 122, 177 70, 184 155, 69 123, 76 185), (267 237, 148 248, 135 185, 223 189, 251 151, 286 183, 267 237))");
@@ -152,23 +147,41 @@ void object::test<5>
checkDistanceNearestPoints(wkt0, wkt1, dist, p1, p2);
template<>
template<>
void object::test<6>
+ using geos::operation::distance::IndexedFacetDistance;
- std::string wkt0("POLYGON ((76 185, 125 283, 331 276, 324 122, 177 70, 184 155, 69 123, 76 185), (267 237, 148 248, 135 185, 223 189, 251 151, 286 183, 267 237))");
- std::string wkt1("LINESTRING (120 215, 185 224, 209 207, 238 222, 254 186)");
- double dist = 0.0;
- Coordinate p1(120, 215);
- Coordinate p2(120, 215);
+ std::string wkt0("POLYGON((100 200, 200 200, 200 100, 100 100, 100 200))");
+ std::string wkt1("POINT(150 150)");
+ GeomPtr g0(wktreader.read(wkt0));
+ GeomPtr g1(wktreader.read(wkt1));
+ double d = IndexedFacetDistance::distance(g0.get(), g1.get());
+ ensure_equals(d, 50);
- checkDistanceNearestPoints(wkt0, wkt1, dist, p1, p2);
+template<>
+template<>
+void object::test<7>
// TODO: finish the tests by adding:
// LINESTRING - *all*
// MULTILINESTRING - *all*
Summary of changes:
.../distance/IndexedFacetDistanceTest.cpp | 47 ++++++++++++++--------
1 file changed, 30 insertions(+), 17 deletions(-)
hooks/post-receive
More information about the geos-commits
