[geos-commits] [SCM] GEOS branch master updated. e6ffc18a8de531f487088e7275a0af9d1d6736bc
git at osgeo.org
git at osgeo.org
Mon Aug 17 13:10:59 PDT 2020
the project "GEOS".
via e6ffc18a8de531f487088e7275a0af9d1d6736bc (commit)
via 16512c007ecc29780e53c58271bb9143f5bf37d0 (commit)
from 264168eeb0f921f0edfc9acab6f12ee5357a15ae (commit)
revisions in full, below.
commit e6ffc18a8de531f487088e7275a0af9d1d6736bc
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Aug 17 22:05:30 2020 +0200
[OverlayNG] Fix handling of LinearRing
Closes #1043
diff --git a/src/operation/overlayng/EdgeNodingBuilder.cpp b/src/operation/overlayng/EdgeNodingBuilder.cpp
index c925dc7..725cc32 100644
--- a/src/operation/overlayng/EdgeNodingBuilder.cpp
+++ b/src/operation/overlayng/EdgeNodingBuilder.cpp
@@ -156,13 +156,13 @@ EdgeNodingBuilder::add(const Geometry* g, int geomIndex)
case GEOS_POLYGON:
return addPolygon(static_cast<const Polygon*>(g), geomIndex);
case GEOS_LINESTRING:
+ case GEOS_LINEARRING:
return addLine(static_cast<const LineString*>(g), geomIndex);
case GEOS_MULTILINESTRING:
case GEOS_MULTIPOLYGON:
case GEOS_GEOMETRYCOLLECTION:
return addCollection(static_cast<const GeometryCollection*>(g), geomIndex);
case GEOS_POINT:
- case GEOS_LINEARRING:
case GEOS_MULTIPOINT:
return; // do nothing
default:
commit 16512c007ecc29780e53c58271bb9143f5bf37d0
Date: Mon Aug 17 22:04:38 2020 +0200
Add debugging lines (default to off)
diff --git a/src/operation/overlayng/OverlayGraph.cpp b/src/operation/overlayng/OverlayGraph.cpp
index d381bcf..2033c19 100644
--- a/src/operation/overlayng/OverlayGraph.cpp
+++ b/src/operation/overlayng/OverlayGraph.cpp
@@ -18,6 +18,10 @@
#include <geos/geom/Coordinate.h>
#include <geos/geom/CoordinateSequence.h>
+#ifndef GEOS_DEBUG
+#define GEOS_DEBUG 0
+#endif
namespace geos { // geos
namespace operation { // geos.operation
namespace overlayng { // geos.operation.overlayng
@@ -80,6 +84,9 @@ OverlayGraph::addEdge(Edge* edge)
// CoordinateSequence* pts = = edge->getCoordinates().release();
CoordinateSequence* pts = edge->releaseCoordinates();
OverlayEdge* e = createEdgePair(pts, createOverlayLabel(edge));
+#if GEOS_DEBUG
+ std::cerr << "added edge: " << *e << std::endl;
+#endif
insert(e);
insert(e->symOE());
return e;
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index 961be62..dbcae1b 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -32,6 +32,11 @@
#include <algorithm>
+#ifndef GEOS_DEBUG
+#endif
@@ -220,6 +225,11 @@ OverlayNG::labelGraph(OverlayGraph* graph)
std::unique_ptr<Geometry>
OverlayNG::extractResult(int p_opCode, OverlayGraph* graph)
+#if GEOS_DEBUG
+ std::cerr << "OverlayNG::extractResult: graph: " << *graph << std::endl;
+#endif
//--- Build polygons
std::vector<OverlayEdge*> resultAreaEdges = graph->getResultAreaEdges();
PolygonBuilder polyBuilder(resultAreaEdges, geomFact);
Summary of changes:
src/operation/overlayng/EdgeNodingBuilder.cpp | 2 +-
src/operation/overlayng/OverlayGraph.cpp | 7 +++++++
src/operation/overlayng/OverlayNG.cpp | 10 ++++++++++
3 files changed, 18 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
