[geos-commits] [SCM] GEOS branch master updated. 2b85f6e862bc289b648b2bd362db136e93bba2e0
git at osgeo.org
git at osgeo.org
Tue Aug 18 14:55:27 PDT 2020
the project "GEOS".
via 2b85f6e862bc289b648b2bd362db136e93bba2e0 (commit)
from e6ffc18a8de531f487088e7275a0af9d1d6736bc (commit)
revisions in full, below.
commit 2b85f6e862bc289b648b2bd362db136e93bba2e0
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Aug 18 23:54:51 2020 +0200
Add debugging lines
diff --git a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
index c127850..bc1f6b6 100644
--- a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
+++ b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
@@ -26,6 +26,10 @@
#include <stdexcept>
+#ifndef GEOS_DEBUG
+# define GEOS_DEBUG 0
+#endif
namespace geos { // geos
namespace operation { // geos.operation
namespace overlayng { // geos.operation.overlayng
@@ -83,7 +87,9 @@ OverlayNGSnapIfNeeded::Overlay(const Geometry* geom0, const Geometry* geom1, int
* in snap-rounding mode with that precision.
if (!geom0->getPrecisionModel()->isFloating()) {
- // std::cout << std::endl << "Using fixed precision overlay." << std::endl;
+#if GEOS_DEBUG
+ std::cout << std::endl << "Using fixed precision overlay." << std::endl;
+#endif
return OverlayNG::overlay(geom0, geom1, opCode, geom0->getPrecisionModel());
@@ -114,7 +120,9 @@ OverlayNGSnapIfNeeded::Overlay(const Geometry* geom0, const Geometry* geom1, int
exOriginal = ex;
- // std::cout << std::endl << "Floating point overlay FAILURE." << std::endl;
+#if GEOS_DEBUG
+ std::cout << std::endl << "Floating point overlay FAILURE." << std::endl;
+#endif
* On failure retry using snapping noding with a "safe" tolerance.
Summary of changes:
src/operation/overlayng/OverlayNGSnapIfNeeded.cpp | 12 ++++++++++--
1 file changed, 10 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
