[geos-commits] [SCM] GEOS branch master updated. 7ebc493dd6955e98c70506fa89be5449e8ca8dbd
Thu Aug 20 10:24:29 PDT 2020
the project "GEOS".
       via  7ebc493dd6955e98c70506fa89be5449e8ca8dbd (commit)
      from  2b85f6e862bc289b648b2bd362db136e93bba2e0 (commit)
revisions in full, below.
commit 7ebc493dd6955e98c70506fa89be5449e8ca8dbd
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Aug 20 19:23:55 2020 +0200
    Debug print of OverlayNG failure exceptions
diff --git a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
index bc1f6b6..257457d 100644
--- a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
+++ b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
@@ -118,11 +118,10 @@ OverlayNGSnapIfNeeded::Overlay(const Geometry* geom0, const Geometry* geom1, int
         * so it can be rethrown if the remaining strategies all fail.
         exOriginal = ex;
 #if GEOS_DEBUG
-    std::cout << std::endl << "Floating point overlay FAILURE." << std::endl;
+        std::cout << std::endl << "Floating point overlay FAILURE: " << ex.what() << std::endl;
 #endif
      * On failure retry using snapping noding with a "safe" tolerance.
@@ -170,9 +169,16 @@ OverlayNGSnapIfNeeded::overlaySnapping(const Geometry* geom0, const Geometry* ge
     try {
         return overlaySnapTol(geom0, geom1, opCode, snapTol);
-    catch (const geos::util::TopologyException &) {
+    catch (const geos::util::TopologyException &
+#if GEOS_DEBUG
+            ex
+#endif
         //---- ignore this exception, just return a nullptr result
-        // TODO: print a debug message here, beware of leaks
+#if GEOS_DEBUG
+        std::cout << std::endl << "overlaySnapping(tol " << snapTol << ") FAILURE: " << ex.what() << std::endl;
+#endif
     return nullptr;
@@ -186,9 +192,16 @@ OverlayNGSnapIfNeeded::overlaySnapBoth(const Geometry* geom0, const Geometry* ge
         std::unique_ptr<Geometry> snap1 = overlaySnapTol(geom1, nullptr, OverlayNG::UNION, snapTol);
         return overlaySnapTol(snap0.get(), snap1.get(), opCode, snapTol);
+#if GEOS_DEBUG
+      ex
+#endif
+#if GEOS_DEBUG
+        std::cout << std::endl << "overlaySnapBoth(tol " << snapTol << ") FAILURE: " << ex.what() << std::endl;
+#endif
     return nullptr;
@@ -249,10 +262,17 @@ OverlayNGSnapIfNeeded::overlaySR(const Geometry* geom0, const Geometry* geom1, i
         result = OverlayNG::overlay(geom0, geom1, opCode, &PM_FLOAT);
         return result;
+#if GEOS_DEBUG
+            ex
+#endif
         // ignore this exception, since the operation will be rerun
         //System.out.println("Overlay failed");
-        // TODO: print debug line, beware of leaks
+#if GEOS_DEBUG
+        std::cout << std::endl << "overlaySR(tol " << snapTol << ") FAILURE: " << ex.what() << std::endl;
+#endif
     // on failure retry with a "safe" fixed PM
     // this should not throw an exception, but if it does just let it go
Summary of changes:
 src/operation/overlayng/OverlayNGSnapIfNeeded.cpp | 38 +++++++++++++++++------
 1 file changed, 29 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
