[geos-commits] [SCM] GEOS branch master updated. d3c68bbc91896f1732adc871a06f51f5b953d089
git at osgeo.org
git at osgeo.org
Fri Aug 21 08:23:48 PDT 2020
the project "GEOS".
via d3c68bbc91896f1732adc871a06f51f5b953d089 (commit)
from 7ebc493dd6955e98c70506fa89be5449e8ca8dbd (commit)
revisions in full, below.
commit d3c68bbc91896f1732adc871a06f51f5b953d089
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Aug 21 17:23:29 2020 +0200
Add more debugging and fix existing one
diff --git a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
index 257457d..a95efb6 100644
--- a/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
+++ b/src/operation/overlayng/OverlayNGSnapIfNeeded.cpp
@@ -145,6 +145,10 @@ OverlayNGSnapIfNeeded::overlaySnapTries(const Geometry* geom0, const Geometry* g
for (std::size_t i = 0; i < NUM_SNAP_TRIES; i++) {
+#if GEOS_DEBUG
+ std::cout << std::endl << "Trying overlaySnapping(tol " << snapTol << ")." << std::endl;
+#endif
result = overlaySnapping(geom0, geom1, opCode, snapTol);
if (result != nullptr) return result;
@@ -271,7 +275,7 @@ OverlayNGSnapIfNeeded::overlaySR(const Geometry* geom0, const Geometry* geom1, i
// ignore this exception, since the operation will be rerun
//System.out.println("Overlay failed");
#if GEOS_DEBUG
- std::cout << std::endl << "overlaySR(tol " << snapTol << ") FAILURE: " << ex.what() << std::endl;
+ std::cout << std::endl << "overlaySR FAILURE: " << ex.what() << std::endl;
#endif
// on failure retry with a "safe" fixed PM
Summary of changes:
src/operation/overlayng/OverlayNGSnapIfNeeded.cpp | 6 +++++-
1 file changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
