[geos-commits] [SCM] GEOS branch master updated. da0cb7bf9f7d3ce50edace9fa370b22c48e0e685
git at osgeo.org
git at osgeo.org
Wed Feb 5 10:40:05 PST 2020
the project "GEOS".
via da0cb7bf9f7d3ce50edace9fa370b22c48e0e685 (commit)
from 545f6452bd758fdbdc2e09bf2062da25c58b6462 (commit)
revisions in full, below.
commit da0cb7bf9f7d3ce50edace9fa370b22c48e0e685
Author: Dan Baston <dbaston at gmail.com>
Date: Thu Jan 30 10:32:25 2020 -0500
Retain component order in MultiLineString::reverse
Updated for consistency with the behavior of other geometry types (as
changed in https://github.com/locationtech/jts/pull/513)
diff --git a/src/geom/MultiLineString.cpp b/src/geom/MultiLineString.cpp
index 29b158d..901ceef 100644
--- a/src/geom/MultiLineString.cpp
+++ b/src/geom/MultiLineString.cpp
@@ -125,14 +125,16 @@ MultiLineString::reverse() const
return clone();
- size_t nLines = geometries.size();
- std::vector<std::unique_ptr<Geometry>> revLines(nLines);
+ std::vector<std::unique_ptr<Geometry>> reversed(geometries.size());
- for(size_t i = 0; i < nLines; ++i) {
- const LineString* iLS = static_cast<LineString*>(geometries[i].get());
- revLines[nLines - 1 - i] = iLS->reverse();
- return getFactory()->createMultiLineString(std::move(revLines));
+ std::transform(geometries.begin(),
+ geometries.end(),
+ reversed.begin(),
+ [](const std::unique_ptr<Geometry> & g) {
+ return g->reverse();
+ return getFactory()->createMultiLineString(std::move(reversed));
const LineString*
diff --git a/tests/unit/capi/GEOSReverseTest.cpp b/tests/unit/capi/GEOSReverseTest.cpp
index 76c60d4..42d218f 100644
--- a/tests/unit/capi/GEOSReverseTest.cpp
+++ b/tests/unit/capi/GEOSReverseTest.cpp
@@ -95,7 +95,7 @@ void object::test<4>
testReverse("MULTILINESTRING ((1 1, 2 2), (3 3, 4 4))",
- "MULTILINESTRING ((4 4, 3 3), (2 2, 1 1))");
+ "MULTILINESTRING ((2 2, 1 1), (4 4, 3 3))");
template<>
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 2fd9034..f85dcec 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -331,7 +331,7 @@ void object::test<16>
checkExtractLine("MULTILINESTRING ((0 0, 10 0), (20 0, 25 0, 30 0))",
- 19, 1, "MULTILINESTRING ((29 0, 25 0, 20 0), (10 0, 1 0))");
+ 19, 1, "MULTILINESTRING ((10 0, 1 0), (29 0, 25 0, 20 0))");
// testExtractLineNegative()
Summary of changes:
src/geom/MultiLineString.cpp | 16 +++++++++-------
tests/unit/capi/GEOSReverseTest.cpp | 2 +-
tests/unit/linearref/LengthIndexedLineTest.cpp | 2 +-
3 files changed, 11 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
