[geos-commits] [SCM] GEOS branch 3.8 updated. c01c8c1c30091d655ba888790c2daeec1f33bae3
git at osgeo.org
git at osgeo.org
Wed Feb 5 10:43:35 PST 2020
the project "GEOS".
The branch, 3.8 has been updated
via c01c8c1c30091d655ba888790c2daeec1f33bae3 (commit)
from c2a683d19b72d092f11f59e6063dfdf1cb739d9a (commit)
revisions in full, below.
commit c01c8c1c30091d655ba888790c2daeec1f33bae3
Author: Dan Baston <dbaston at gmail.com>
Date: Thu Jan 30 10:32:25 2020 -0500
Retain component order in MultiLineString::reverse
Updated for consistency with the behavior of other geometry types (as
changed in https://github.com/locationtech/jts/pull/513)
Fixes #1013
diff --git a/NEWS b/NEWS
index 440d266..b634f11 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,8 @@ Changes in 3.8.1
- Avoid assertion failure with MSVC 2017 / 2019 (#1002, Dan Baston)
- Remove whitespace from end of GEOSversion() output (azhi)
- Improve performance of GEOSisValid (#1008, Dan Baston)
+ - Avoid changing MultiLineString component order in GEOSReverse
+ (#1013, Dan Baston)
Changes in 3.8.0
2019-10-10
diff --git a/src/geom/MultiLineString.cpp b/src/geom/MultiLineString.cpp
index 592f38a..3b6991c 100644
--- a/src/geom/MultiLineString.cpp
+++ b/src/geom/MultiLineString.cpp
@@ -126,14 +126,16 @@ MultiLineString::reverse() const
return clone();
- size_t nLines = geometries.size();
- std::vector<std::unique_ptr<Geometry>> revLines(nLines);
+ std::vector<std::unique_ptr<Geometry>> reversed(geometries.size());
- for(size_t i = 0; i < nLines; ++i) {
- const LineString* iLS = static_cast<LineString*>(geometries[i].get());
- revLines[nLines - 1 - i] = iLS->reverse();
- return getFactory()->createMultiLineString(std::move(revLines));
+ std::transform(geometries.begin(),
+ geometries.end(),
+ reversed.begin(),
+ [](const std::unique_ptr<Geometry> & g) {
+ return g->reverse();
+ return getFactory()->createMultiLineString(std::move(reversed));
} // namespace geos::geom
diff --git a/tests/unit/capi/GEOSReverseTest.cpp b/tests/unit/capi/GEOSReverseTest.cpp
index 76c60d4..42d218f 100644
--- a/tests/unit/capi/GEOSReverseTest.cpp
+++ b/tests/unit/capi/GEOSReverseTest.cpp
@@ -95,7 +95,7 @@ void object::test<4>
testReverse("MULTILINESTRING ((1 1, 2 2), (3 3, 4 4))",
- "MULTILINESTRING ((4 4, 3 3), (2 2, 1 1))");
+ "MULTILINESTRING ((2 2, 1 1), (4 4, 3 3))");
template<>
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 2fd9034..f85dcec 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -331,7 +331,7 @@ void object::test<16>
checkExtractLine("MULTILINESTRING ((0 0, 10 0), (20 0, 25 0, 30 0))",
- 19, 1, "MULTILINESTRING ((29 0, 25 0, 20 0), (10 0, 1 0))");
+ 19, 1, "MULTILINESTRING ((10 0, 1 0), (29 0, 25 0, 20 0))");
// testExtractLineNegative()
Summary of changes:
NEWS | 2 ++
src/geom/MultiLineString.cpp | 16 +++++++++-------
tests/unit/capi/GEOSReverseTest.cpp | 2 +-
tests/unit/linearref/LengthIndexedLineTest.cpp | 2 +-
4 files changed, 13 insertions(+), 9 deletions(-)
hooks/post-receive
More information about the geos-commits
