[geos-commits] [SCM] GEOS branch master updated. a096c8324e78558b5fd029e8c80acc743df4acab
git at osgeo.org
git at osgeo.org
Mon Jan 13 14:34:28 PST 2020
the project "GEOS".
via a096c8324e78558b5fd029e8c80acc743df4acab (commit)
via c48aea6eacffd7693f3eaf6735994fb6882f4dc6 (commit)
from e84fd01ca1796eaef9f6f814f717e4d405c84293 (commit)
revisions in full, below.
commit a096c8324e78558b5fd029e8c80acc743df4acab
Merge: e84fd01 c48aea6
Author: Dan Baston <dbaston at gmail.com>
Date: Mon Jan 13 17:34:06 2020 -0500
Merge branch 'noding-error-message'
commit c48aea6eacffd7693f3eaf6735994fb6882f4dc6
Date: Thu Jan 9 14:17:09 2020 -0500
Provide location for GEOSNode failure
Also resolve memory leak in error case.
diff --git a/include/geos/noding/IntersectionAdder.h b/include/geos/noding/IntersectionAdder.h
index 89a2549..0ef8663 100644
--- a/include/geos/noding/IntersectionAdder.h
+++ b/include/geos/noding/IntersectionAdder.h
@@ -32,9 +32,6 @@
// Forward declarations
namespace geos {
-namespace geom {
-class Coordinate;
namespace noding {
class SegmentString;
@@ -71,7 +68,7 @@ private:
bool hasInterior;
// the proper intersection point found
- const geom::Coordinate* properIntersectionPoint;
+ geom::Coordinate properIntersectionPoint;
algorithm::LineIntersector& li;
// bool isSelfIntersection;
@@ -105,7 +102,7 @@ public:
hasProper(false),
hasProperInterior(false),
hasInterior(false),
- properIntersectionPoint(nullptr),
+ properIntersectionPoint(),
li(newLi),
numIntersections(0),
numInteriorIntersections(0),
@@ -120,10 +117,10 @@ public:
- * @return the proper intersection point, or `NULL`
+ * @return the proper intersection point, or `Coordinate::getNull()`
* if none was found
+ const geom::Coordinate&
getProperIntersectionPoint()
return properIntersectionPoint;
diff --git a/include/geos/noding/IteratedNoder.h b/include/geos/noding/IteratedNoder.h
index 54d0c37..ac34172 100644
--- a/include/geos/noding/IteratedNoder.h
+++ b/include/geos/noding/IteratedNoder.h
@@ -68,7 +68,8 @@ private:
* and create the split edges between the nodes
void node(std::vector<SegmentString*>* segStrings,
- int* numInteriorIntersections);
+ int& numInteriorIntersections,
+ geom::Coordinate& intersectionPoint);
public:
diff --git a/src/noding/IntersectionAdder.cpp b/src/noding/IntersectionAdder.cpp
index 4c4f89a..8bf3988 100644
--- a/src/noding/IntersectionAdder.cpp
+++ b/src/noding/IntersectionAdder.cpp
@@ -88,7 +88,6 @@ IntersectionAdder::processIntersections(
numIntersections++;
if(li.isInteriorIntersection()) {
numInteriorIntersections++;
hasInterior = true;
@@ -110,7 +109,7 @@ IntersectionAdder::processIntersections(
numProperIntersections++;
//Debug.println(li.toString());
//Debug.println(li.getIntersection(0));
-//properIntersectionPoint = (Coordinate) li.getIntersection(0).clone();
+ properIntersectionPoint = li.getIntersection(0);
hasProper = true;
hasProperInterior = true;
diff --git a/src/noding/IteratedNoder.cpp b/src/noding/IteratedNoder.cpp
index fbb9139..4f56b72 100644
--- a/src/noding/IteratedNoder.cpp
+++ b/src/noding/IteratedNoder.cpp
@@ -31,7 +31,6 @@
#define GEOS_DEBUG 0
#endif
-using namespace std;
using namespace geos::geom;
namespace geos {
@@ -39,16 +38,20 @@ namespace noding { // geos.noding
/* private */
void
-IteratedNoder::node(vector<SegmentString*>* segStrings,
+IteratedNoder::node(std::vector<SegmentString*>* segStrings,
+ Coordinate& intersectionPoint)
IntersectionAdder si(li);
MCIndexNoder noder;
noder.setSegmentIntersector(&si);
noder.computeNodes(segStrings);
nodedSegStrings = noder.getNodedSubstrings();
- *numInteriorIntersections = si.numInteriorIntersections;
-//System.out.println("# intersection tests: " + si.numTests);
+ numInteriorIntersections = si.numInteriorIntersections;
+ if (si.hasProperInteriorIntersection()) {
+ intersectionPoint = si.getProperIntersectionPoint();
/* public */
@@ -60,11 +63,12 @@ IteratedNoder::computeNodes(SegmentString::NonConstVect* segStrings)
nodedSegStrings = segStrings;
int nodingIterationCount = 0;
int lastNodesCreated = -1;
- vector<SegmentString*>* lastStrings = nullptr;
- do {
+ std::vector<SegmentString*>* lastStrings = nullptr;
+ Coordinate intersectionPoint = Coordinate::getNull();
+ do {
// NOTE: will change this.nodedSegStrings
- node(nodedSegStrings, &numInteriorIntersections);
+ node(nodedSegStrings, numInteriorIntersections, intersectionPoint);
// Delete noded strings from previous iteration
if(lastStrings) {
@@ -86,9 +90,19 @@ IteratedNoder::computeNodes(SegmentString::NonConstVect* segStrings)
if(lastNodesCreated > 0
&& nodesCreated >= lastNodesCreated
&& nodingIterationCount > maxIter) {
- stringstream s;
+ // Delete noded strings from previous iteration
+ if(lastStrings) {
+ for(auto& s : *lastStrings) {
+ delete s;
+ delete lastStrings;
+ std::stringstream s;
s << "Iterated noding failed to converge after " <<
- nodingIterationCount << " iterations";
+ nodingIterationCount << " iterations (near " <<
+ intersectionPoint << ")";
throw util::TopologyException(s.str());
lastNodesCreated = nodesCreated;
diff --git a/tests/unit/capi/GEOSNodeTest.cpp b/tests/unit/capi/GEOSNodeTest.cpp
index 5d08407..8e9bafb 100644
--- a/tests/unit/capi/GEOSNodeTest.cpp
+++ b/tests/unit/capi/GEOSNodeTest.cpp
@@ -123,6 +123,24 @@ void object::test<3>
+// https://gis.stackexchange.com/questions/345341/get-location-of-postgis-geos-topology-exception/345482#345482
+template<>
+template<>
+void object::test<4>
+ std::string wkb = "010500000002000000010200000003000000dc874d65fcc25ec176032c6b350c5341b336429ffec25ec1f962bbd"
+ "9480c5341fc849518ffc25ec15be20f5f500c5341010200000006000000fa9bbfd3fcc25ec1b978232f390c5341"
+ "b336429ffec25ec1f962bbd9480c5341a77e6be5fec25ec1357c21334d0c5341c3eba27bfec25ec11be5a4c34a0"
+ "c5341b61d8cacfcc25ec1bcf273143c0c5341fa9bbfd3fcc25ec1b978232f390c5341";
+ geom1_ = GEOSGeomFromHEX_buf((const unsigned char*) wkb.c_str(), wkb.size());
+ geom2_ = GEOSNode(geom1_);
+ // Noding currently fails for this case.
+ // ensure(geom2_);
} // namespace tut
Summary of changes:
include/geos/noding/IntersectionAdder.h | 11 ++++-------
include/geos/noding/IteratedNoder.h | 3 ++-
src/noding/IntersectionAdder.cpp | 3 +--
src/noding/IteratedNoder.cpp | 34 +++++++++++++++++++++++----------
tests/unit/capi/GEOSNodeTest.cpp | 18 +++++++++++++++++
5 files changed, 49 insertions(+), 20 deletions(-)
hooks/post-receive
More information about the geos-commits
